Salesforce Certified Platform Integration Architect Dumps | Plat-Arch-204 Exam P
315
Posted at yesterday 11:29      View:6 | Replies:0        Print      Only Author   [Copy Link] 1#
Preparing for the Plat-Arch-204 Salesforce Certified Platform Integration Architect Exam requires not only theoretical knowledge but also a strong understanding of real-world integration scenarios. To simplify your preparation, the latest Salesforce Certified Platform Integration Architect Dumps from Passcert are designed to cover all key exam objectives, featuring real, updated exam questions and accurate answers aligned with the current exam version. These Passcert materials help candidates quickly identify weak areas, understand complex integration concepts, and pass the exam with confidence and efficiency.
About the Salesforce Certified Platform Integration Architect ExamThe Salesforce Platform Integration Architect Exam is a core credential for professionals responsible for designing and implementing secure, scalable, and maintainable integrations on the Salesforce Lightning Platform. This certification validates a candidate’s ability to analyze system landscapes, define integration requirements, and select appropriate integration patterns that meet both technical and business needs.
Unlike entry-level Salesforce exams, Plat-Arch-204 focuses heavily on architectural decision-making. Candidates are expected not only to understand Salesforce-native and external integration technologies, but also to clearly communicate design trade-offs, risks, and solutions to both technical teams and business stakeholders.
Role and Responsibilities of a Salesforce Platform Integration ArchitectA Salesforce Certified Platform Integration Architect is responsible for assessing integration requirements and translating them into effective architectural designs. This role requires deep experience with multiple integration patterns, Salesforce APIs, middleware solutions, and enterprise systems.
An Integration Architect must also be capable of:
  • Designing integrations that scale with business growth
  • Balancing real-time and asynchronous data flows
  • Managing security, authentication, and data governance
  • Explaining design trade-offs to both technical and non-technical stakeholders
The role sits at the intersection of business strategy and technical execution, making it one of the most valuable Salesforce architecture certifications.
Recommended Experience and Professional BackgroundCandidates pursuing the Plat-Arch-204 certification typically have the following experience:
  • 1–2 years of hands-on experience in Salesforce Platform Integration Architecture
  • 2–3 years of Salesforce administration and/or development experience
  • At least 1 year working with enterprise, data-centric integration solutions
A strong foundation in APIs, data synchronization, messaging systems, and security models is essential for success.
Salesforce Plat-Arch-204 Exam Structure and Key DetailsHere are the official details for the Plat-Arch-204 exam:
  • Exam Format: 60 multiple-choice and multiple-select questions (plus up to 5 unscored questions)
  • Duration: 105 minutes
  • Passing Score: 67%
  • Exam Version: Aligned with Salesforce Summer ’23 Release
  • Registration Fee: US$400 (plus applicable local taxes)
  • Retake Fee: US$200 (plus applicable local taxes)
  • Delivery Options: Onsite proctored exam at a testing center, Online proctored exam
  • References Allowed: None (closed book)
  • Prerequisites: None required
Detailed Breakdown of Salesforce Platform Integration Architect Exam ObjectivesThe Salesforce Certified Platform Integration Architect Exam evaluates both conceptual understanding and practical application across the following domains:
1. Evaluate the Current System Landscape (8%)
  • Given a set of business requirements, identify the current system landscape and determine what standards, limitations, boundaries, and protocols exist.
  • Given an existing system landscape, analyze for constraints and/or pain-points to satisfy a business requirement(s).
  • Given a set of requirements, evaluate the authentication and authorization needs based on the system landscape.
2. Evaluate Business Needs (11%)
  • Given a use case, identify functional and non-functional requirements needed for integration.
  • Based on a given integration requirement, identify and classify data into Confidential/Secure/Public.
  • Given a use case, identify key factors for CRM success that should be included as integration requirements.
  • Given a use case, identify the business growth and regulatory factors that can impact choice of integration solutions.
3. Translate Needs to Integration Requirements (22%)
  • Given an existing system landscape diagram, create an inventory of the systems and integration patterns.
  • Given a use case and business process, evaluate system and process constraints.
  • Given a use case, identify integration security/authentication/authorization requirements.
  • Given a use case, identify performance needs (volumes, response times, latency) and propose appropriate integration solutions that will meet business requirements.
4. Design Integration Solutions (28%)
  • Given a use case, identify the integration pattern that meets business requirements.
  • Given a use case, define the components which create a solution that meets business requirements.
  • Given a use case, identify the trade-offs, limitations, and constraints that meet the proposed solution.
  • Given a use case that includes technical requirements, constraints, or drivers, specify the appropriate Salesforce application programming interface(s) (API) for the proposed solution.
  • Given a use case that includes technical requirements, constraints, or drivers, determine the standards, components, techniques, and security mechanism that should be used.
5. Build Solution (23%)
  • Given a use case that includes technical requirements, constraints, or drivers, identify the considerations when designing and implementing an API(s), both Salesforce as an API provider and Salesforce as an API consumer.
  • Given a use case, identify the considerations when choosing the right option in making an outbound call to an external system.
  • Given a use case, describe what should be considered when building a scalable solution.
  • Given a use case, determine error handling for different integration options.
  • Given a use case, create a security solution for inbound or outbound integrations.
  • Given a use case, identify the factors needed to build resilience in an integration solution for system updates.
6. Maintain Integration (8%)
  • Given an integration maintenance use case, identify performance monitoring needs for integration requirements.
  • Given a use case, identify the appropriate error handling, escalation, and recovery procedures for a failed integration.
  • Given a use case, identify reporting needs for integration monitoring.
Why Passcert Is a Smart Choice for Plat-Arch-204 Exam PreparationThe Passcert Salesforce Certified Platform Integration Architect Dumps are specifically designed for professionals who want efficient, targeted preparation:
  • ✔ Real exam-style questions aligned with current objectives
  • ✔ Full coverage of all integration architecture domains
  • ✔ Accurate answers reflecting real-world scenarios
  • ✔ Updated content based on the latest Salesforce release
  • ✔ Ideal for both first-time and retake candidates
These materials help you reduce study time while increasing your chances of success.
Final Thoughts: Advance Your Salesforce Architecture Career with ConfidenceThe Plat-Arch-204 Salesforce Certified Platform Integration Architect Exam is a prestigious and demanding certification that demonstrates advanced integration expertise on the Salesforce Platform. Success requires a strong architectural mindset, real-world experience, and focused exam preparation.
Using the latest Passcert Salesforce Certified Platform Integration Architect Dumps allows you to study smarter, reinforce critical concepts, and approach the exam with confidence. If your goal is to validate your integration architecture skills and advance your Salesforce career, this certification—and the right preparation strategy—will get you there faster.
