Horizontally flipping the IPC-M10R800-A3399C screen
55
Posted at 1/31/2019 16:34:17      View4791 | Replies6        Print      Only Author   [Copy Link] 1#
Hello to everyone
I bought it from 1 IPC-M10R800-A3399C. Linux sdk and I use it with lubuntu. The main board is AIO-3399C and the display uses HSX101H40C. Turns on vertically when the device is switched on. On the Linux side, I can turn the device horizontally with the following commands.
xrandr --output LVDS1 --rotate right
xinput set-prop 'gslX680' 'Coordinate Transformation Matrix' 0 1 0 -1 0 1 0 0 1
But I want to open this way directly without the need to run the script when the device is turned on. How can I do that?
Is there a change in the file arch / arm64 / boot / dts / rockchip / rk3399-firefly-aioc-lvds.dts? Or is it necessary to change the rootfs?
Posted at 3/4/2019 14:42:42        Only Author  2#
Hello
is there anyone else on the world who wants to use this device horizontally?
Posted at 6/18/2019 15:07:23        Only Author  3#
Yes I want to ,
I think you can do it in any of the startup scripts
Posted at 1/14/2026 08:10:06        Only Author  4#
Wir sind der Schnellste, der daa CompTIA N10-009 Zertifikat erhält; wir sind noch der höchste, der Ihre Interessen schtzt. Wir sind Zertpruefung. Zertpruefung kann Ihnen versprechen, dass die Testaufgaben von CompTIA N10-009 Zertifizierungsprfung 100% richtig und ganz umfassend sind. Nachdem Sie die Testfragen zur CompTIA N10-009 Zertifizierung gekauft haben, werden Sie kostenlos die einjährige Aktualisierung genießen.
Posted at 1/20/2026 18:58:51        Only Author  5#
Thank you for your powerful article, it left a lasting impression. Valid test C_BW4H_2505 bootcamp exam papers are shared for free. Wishing you success in your exam!
Posted at 2/5/2026 12:17:59        Only Author  6#
This article is exceptional, I truly appreciate you sharing it! Weve made Reliable Plat-Arch-205 test camp materials freely available, packed with content to help you succeed.
Posted at 2/14/2026 17:20:07        Only Author  7#
Im deeply moved by your article, thank you for sharing this insight! Wishing myself all the best for the Latest study guide Introduction-to-Cryptography ebook exam!
