FreeBSD boot message on Firefly
22
Posted at 1/6/2015 21:58:23      View11553 | Replies7        Print      Only Author   [Copy Link] 1#
  1. DDR Version 1.00 20141007
  2. In
  3. Channel a: DDR3 200MHz
  4. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  5. Channel b: DDR3 200MHz
  6. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  7. Memory OK
  8. Memory OK
  9. OUT
  10. U-Boot 2014.10-RK3288-01-gadc60cd-dirty (Jan 05 2015 - 21:53:02)
  11. CPU: rk3288
  12. CPU's clock information:
  13. arm pll = 600000000HZ
  14. periph pll = 297000000HZ
  15. ddr pll = 200000000HZ
  16. codec pll = 384000000HZ
  17. Board:        Rockchip platform Board
  18. DRAM:  Found dram banks:1
  19. Adding bank:0000000000000000(0000000080000000)
  20. 128 MiB
  21. storage init OK!
  22. Using default environment
  23. GetParam
  24. check parameter success
  25. Unknow param: MACHINE_MODEL:rk30sdk!
  26. Unknow param: MACHINE_ID:007!
  27. Unknow param: MANUFACTURER:RK30SDK!
  28. Unknow param: PWR_HLD: 0,0,A,0,1!
  29. failed to prepare fdt from boot!
  30. power key: bank-0 pin-5
  31. can't find dts node for ricoh619
  32. pmic:act8846
  33. Can't find dts node for fuel guage cw201x
  34. SecureBootEn = 0, SecureBootLock = 0
  35. #Boot ver: 2015-01-05#2.19
  36. sn:1006120001000186
  37. checkKey
  38. vbus = 1
  39. rockusb key pressed.
  40. DDR Version 1.00 20141007
  41. In
  42. SRX
  43. Channel a: DDR3 200MHz
  44. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  45. Channel b: DDR3 200MHz
  46. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  47. OUT
  48. U-Boot 2014.10-RK3288-01-gadc60cd-dirty (Jan 05 2015 - 21:53:02)
  49. CPU: rk3288
  50. CPU's clock information:
  51. arm pll = 600000000HZ
  52. periph pll = 297000000HZ
  53. ddr pll = 200000000HZ
  54. codec pll = 384000000HZ
  55. Board:        Rockchip platform Board
  56. DRAM:  Found dram banks:1
  57. Adding bank:0000000000000000(0000000080000000)
  58. 128 MiB
  59. storage init OK!
  60. Using default environment
  61. GetParam
  62. check parameter success
  63. Unknow param: MACHINE_MODEL:rk30sdk!
  64. Unknow param: MACHINE_ID:007!
  65. Unknow param: MANUFACTURER:RK30SDK!
  66. Unknow param: PWR_HLD: 0,0,A,0,1!
  67. failed to prepare fdt from boot!
  68. power key: bank-0 pin-5
  69. can't find dts node for ricoh619
  70. pmic:act8846
  71. Can't find dts node for fuel guage cw201x
  72. SecureBootEn = 0, SecureBootLock = 0
  73. #Boot ver: 2015-01-05#2.19
  74. sn:1006120001000186
  75. unknown reboot type 1
  76. no fuel gauge found
  77. no fuel gauge found
  78. read logo_on switch from dts [0]
  79. no fuel gauge found
  80. SecureBootEn = 0, SecureBootLock = 0
  81. failed to find part:04bf0000
  82. kernel   @ 0x62000000 (0x004e47a4)
  83. ramdisk  @ 0x04bf0000 (0x00000000)
  84. Secure Boot state: 0
  85. bootrk: do_bootm_linux...
  86. Starting kernel ...
  87. efgin initarm 1.1
  88. Cin initarm 2, 0xffe90000
  89. in initarm 3, 0xffe90000
  90. in initarm 4
  91. in initarm 5
  92. in initarm 6
  93. in initarm 7
  94. in initarm 8
  95. in initarm 9
  96. in initarm 10
  97. in initarm 101
  98. in initarm 11
  99. in initarm 12
  100. KDB: debugger backends: ddb
  101. KDB: current backend: ddb
  102. in initarm 17
  103. Copyright (c) 1992-2015 The FreeBSD Project.
  104. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
  105. The Regents of the University of California. All rights reserved.
  106. FreeBSD is a registered trademark of The FreeBSD Foundation.
  107. FreeBSD 11.0-CURRENT #112 r276691M: Tue Jan  6 19:10:18 ULAT 2015
  108. tsgan@beastie.micom.mng.net:/usr/obj/arm.armv6/usr/src/sys/FIREFLY arm
  109. FreeBSD clang version 3.5.0 (tags/RELEASE_350/final 216957) 20141124
  110. WARNING: WITNESS option enabled, expect reduced performance.
  111. WARNING: DIAGNOSTIC option enabled, expect reduced performance.
  112. CPU: Cortex A17 rev 1 (Cortex-A core)
  113. Supported features: ARM_ISA THUMB2 JAZELLE THUMBEE ARMv4 Security_Ext
  114. WB disabled EABT branch prediction enabled
  115. LoUU:2 LoC:3 LoUIS:2
  116. Cache level 1:
  117. 32KB/64B 4-way data cache WB Read-Alloc Write-Alloc
  118. 32KB/64B 4-way instruction cache Read-Alloc
  119. Cache level 2:
  120. 1024KB/64B 16-way unified cache WB Read-Alloc Write-Alloc
  121. real memory  = 2147479552 (2047 MB)
  122. avail memory = 2091311104 (1994 MB)
  123. random device not loaded/active; using insecure pseudo-random number generator
  124. random: entropy device infrastructure driver
  125. random: selecting highest priority adaptor
  126. random: SOFT: yarrow init()
  127. random: selecting highest priority adaptor
  128. ofwbus0:
  129. simplebus0:on ofwbus0
  130. gic0:mem 0xffc01000-0xffc01fff,0xffc02000-0xffc02fff on simplebus0
  131. gic0: pn 0x20, arch 0x2, rev 0x1, implementer 0x43b irqs 192
  132. generic_timer0:irq 29,30,27,26 on simplebus0
  133. Timecounter "ARM MPCore Timecounter" frequency 24000000 Hz quality 1000
  134. Event timer "ARM MPCore Eventtimer" frequency 24000000 Hz quality 1000
  135. rk30_pmu0:mem 0xff730000-0xff7300ff on simplebus0
  136. rk30_grf0:mem 0xff770000-0xff771fff on simplebus0
  137. gpio0:mem 0xff750000-0xff7500ff irq 113 on simplebus0
  138. gpioc0:on gpio0
  139. gpiobus0:on gpio0
  140. gpio1:mem 0xff780000-0xff7800ff irq 114 on simplebus0
  141. gpioc1:on gpio1
  142. gpiobus1:on gpio1
  143. gpio2:mem 0xff790000-0xff7900ff irq 115 on simplebus0
  144. gpioc2:on gpio2
  145. gpiobus2:on gpio2
  146. gpio3:mem 0xff7a0000-0xff7a00ff irq 116 on simplebus0
  147. gpioc3:on gpio3
  148. gpiobus3:on gpio3
  149. gpio4:mem 0xff7b0000-0xff7b00ff irq 117 on simplebus0
  150. gpioc4:on gpio4
  151. gpiobus4:on gpio4
  152. gpio5:mem 0xff7c0000-0xff7c00ff irq 118 on simplebus0
  153. gpioc5:on gpio5
  154. gpiobus5:on gpio5
  155. gpio6:mem 0xff7d0000-0xff7d00ff irq 119 on simplebus0
  156. gpioc6:on gpio6
  157. gpiobus6:on gpio6
  158. gpio7:mem 0xff7e0000-0xff7e00ff irq 120 on simplebus0
  159. gpioc7:on gpio7
  160. gpiobus7:on gpio7
  161. gpio8:mem 0xff7f0000-0xff7f00ff irq 121 on simplebus0
  162. gpioc8:on gpio8
  163. gpiobus8:on gpio8
  164. dwcotg0: mem 0xff580000-0xff5bffff irq 55 on simplebus0
  165. usbus0 on dwcotg0
  166. dwcotg1: mem 0xff540000-0xff57ffff irq 57 on simplebus0
  167. usbus1 on dwcotg1
  168. Timecounters tick every 10.000 msec
  169. usbus0: 480Mbps High Speed USB v2.0
  170. usbus1: 480Mbps High Speed USB v2.0
  171. random: unblocking device.
  172. WARNING: WITNESS option enabled, expect reduced performance.
  173. WARNING: DIAGNOSTIC option enabled, expect reduced performance.
  174. ugen0.1:at usbus0
  175. uhub0: on usbus0
  176. ugen1.1:at usbus1
  177. uhub1: on usbus1
  178. uhub1: 1 port with 1 removable, self powered
  179. uhub0: 1 port with 1 removable, self powered
  180. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  181. ugen0.2:at usbus0 (disconnected)
  182. uhub_reattach_port: could not allocate new device
  183. ugen1.2:at usbus1
  184. uhub2: on usbus1
  185. uhub2: MTT enabled
  186. Root mount waiting for: usbus1
  187. uhub2: 4 ports with 4 removable, self powered
  188. Root mount waiting for: usbus1
  189. Root mount waiting for: usbus1
  190. ugen1.3: at usbus1
  191. umass0: on usbus1
  192. umass0:  SCSI over Bulk-Only; quirks = 0x4100
  193. umass0:0:0: Attached to scbus0
  194. Trying to mount root from ufs:/dev/da0 []...
  195. mountroot: waiting for device /dev/da0 ...
  196. da0 at umass-sim0 bus 0 scbus0 target 0 lun 0
  197. da0: Removable Direct Access SCSI-2 device
  198. da0: Serial Number 15213301BF1BC700
  199. da0: 40.000MB/s transfers
  200. da0: 3998MB (8187904 512 byte sectors: 255H 63S/T 509C)
  201. da0: quirks=0x3
  202. WARNING: / was not properly dismounted
  203. warning: no time-of-day clock registered, system time will not be set accurately
  204. Expensive timeout(9) function: 0xc20642b0(0xc7228000) 0.002127708 s
  205. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  206. ugen0.2:at usbus0 (disconnected)
  207. uhub_reattach_port: could not allocate new device
  208. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  209. ugen0.2:at usbus0 (disconnected)
  210. uhub_reattach_port: could not allocate new device
  211. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  212. ugen0.2:at usbus0 (disconnected)
  213. uhub_reattach_port: could not allocate new device
  214. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  215. ugen0.2:at usbus0 (disconnected)
  216. uhub_reattach_port: could not allocate new device
  217. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  218. ugen0.2:at usbus0 (disconnected)
  219. uhub_reattach_port: could not allocate new device
  220. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  221. ugen0.2:at usbus0 (disconnected)
  222. uhub_reattach_port: could not allocate new device
  223. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  224. ugen0.2:at usbus0 (disconnected)
  225. uhub_reattach_port: could not allocate new device
  226. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  227. ugen0.2:at usbus0 (disconnected)
  228. uhub_reattach_port: could not allocate new device
  229. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  230. ugen0.2:at usbus0 (disconnected)
  231. uhub_reattach_port: could not allocate new device
Copy the code
Posted at 1/8/2015 14:33:43        Only Author  2#
Hi @ganbold , what can we do for you?
You can PM me.
Posted at 1/9/2015 18:49:12        Only Author  3#
I would like to have RK3288 TRM if possible, because uart driver is not working yet for FreeBSD and I wanted to make sure about physical memory start address and kernel load address. Looking at linux source or u-boot source is sometimes hard and sometimes there are too many sources and all seem to different.
Posted at 1/11/2015 14:09:16        Only Author  4#
Posted at 1/12/2015 13:28:18        Only Author  5#
Full boot msg in multi-user mode
https://github.com/tsgan/rockchip/blob/ ... i-user.txt
  2. In
  3. SRX
  4. Channel a: DDR3 200MHz
  5. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  6. Channel b: DDR3 200MHz
  7. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  8. OUT
  9. U-Boot 2014.10-RK3288-01-gadc60cd-dirty (Jan 10 2015 - 11:21:08)
  10. CPU: rk3288
  11. CPU's clock information:
  12.     arm pll = 600000000HZ
  13.     periph pll = 297000000HZ
  14.     ddr pll = 200000000HZ
  15.     codec pll = 384000000HZ
  16. Board:        Rockchip platform Board
  17. DRAM:  Found dram banks:1
  18. Adding bank:0000000000000000(0000000080000000)
  19. 128 MiB
  20. storage init OK!
  21. Using default environment
  22. GetParam
  23. check parameter success
  24. Unknow param: MACHINE_MODEL:rk30sdk!
  25. Unknow param: MACHINE_ID:007!
  26. Unknow param: MANUFACTURER:RK30SDK!
  27. Unknow param: PWR_HLD: 0,0,A,0,1!
  28. failed to prepare fdt from boot!
  29. power key: bank-0 pin-5
  30. can't find dts node for ricoh619
  31. pmic:act8846
  32. Can't find dts node for fuel guage cw201x
  33. SecureBootEn = 0, SecureBootLock = 0
  34. #Boot ver: 2015-01-10#2.19
  35. sn:1006120001000186
  36. unknown reboot type 1
  37. no fuel gauge found
  38. no fuel gauge found
  39. read logo_on switch from dts [0]
  40. no fuel gauge found
  41. SecureBootEn = 0, SecureBootLock = 0
  42. failed to find part:04bf0000
  43. kernel   @ 0x60400000 (0x004ea724)
  44. ramdisk  @ 0x04bf0000 (0x00000000)
  45. Secure Boot state: 0
  46. bootrk: do_bootm_linux...
  47. Starting kernel ...
  48. in initarm 6
  49. in initarm 7
  50. in initarm 8
  51. in initarm 9
  52. in initarm 10
  53. in initarm 101
  54. in initarm 11
  55. in initarm 12
  56. KDB: debugger backends: ddb
  57. KDB: current backend: ddb
  58. in initarm 17
  59. Copyright (c) 1992-2015 The FreeBSD Project.
  60. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
  61.         The Regents of the University of California. All rights reserved.
  62. FreeBSD is a registered trademark of The FreeBSD Foundation.
  63. FreeBSD 11.0-CURRENT #159 r276691M: Mon Jan 12 12:51:13 ULAT 2015
  64.     tsgan@beastie.micom.mng.net:/usr/obj/arm.armv6/usr/src/sys/FIREFLY arm
  65. FreeBSD clang version 3.5.0 (tags/RELEASE_350/final 216957) 20141124
  66. WARNING: WITNESS option enabled, expect reduced performance.
  67. WARNING: DIAGNOSTIC option enabled, expect reduced performance.
  68. CPU: Cortex A17 rev 1 (Cortex-A core)
  69. Supported features: ARM_ISA THUMB2 JAZELLE THUMBEE ARMv4 Security_Ext
  70. WB disabled EABT branch prediction enabled
  71. LoUU:2 LoC:3 LoUIS:2
  72. Cache level 1:
  73. 32KB/64B 4-way data cache WB Read-Alloc Write-Alloc
  74. 32KB/64B 4-way instruction cache Read-Alloc
  75. Cache level 2:
  76. 1024KB/64B 16-way unified cache WB Read-Alloc Write-Alloc
  77. real memory  = 2147479552 (2047 MB)
  78. avail memory = 2091266048 (1994 MB)
  79. random device not loaded/active; using insecure pseudo-random number generator
  80. random: entropy device infrastructure driver
  81. random: selecting highest priority adaptor <Dummy>
  82. random: SOFT: yarrow init()
  83. random: selecting highest priority adaptor <Yarrow>
  84. ofwbus0: <Open Firmware Device Tree>
  85. simplebus0: <Flattened device tree simple bus> on ofwbus0
  86. gic0: <ARM Generic Interrupt Controller> mem 0xffc01000-0xffc01fff,0xffc02000-0xffc02fff on simplebus0
  87. gic0: pn 0x20, arch 0x2, rev 0x1, implementer 0x43b irqs 192
  88. generic_timer0: <ARMv7 Generic Timer> irq 29,30,27,26 on simplebus0
  89. Timecounter "ARM MPCore Timecounter" frequency 24000000 Hz quality 1000
  90. Event timer "ARM MPCore Eventtimer" frequency 24000000 Hz quality 1000
  91. rk30_pmu0: <RK30XX PMU> mem 0xff730000-0xff7300ff on simplebus0
  92. rk30_grf0: <RK30XX General Register File> mem 0xff770000-0xff771fff on simplebus0
  93. gpio0: <Rockchip RK30XX GPIO controller> mem 0xff750000-0xff7500ff irq 113 on simplebus0
  94. gpioc0: <GPIO controller> on gpio0
  95. gpiobus0: <GPIO bus> on gpio0
  96. gpio1: <Rockchip RK30XX GPIO controller> mem 0xff780000-0xff7800ff irq 114 on simplebus0
  97. gpioc1: <GPIO controller> on gpio1
  98. gpiobus1: <GPIO bus> on gpio1
  99. gpio2: <Rockchip RK30XX GPIO controller> mem 0xff790000-0xff7900ff irq 115 on simplebus0
  100. gpioc2: <GPIO controller> on gpio2
  101. gpiobus2: <GPIO bus> on gpio2
  102. gpio3: <Rockchip RK30XX GPIO controller> mem 0xff7a0000-0xff7a00ff irq 116 on simplebus0
  103. gpioc3: <GPIO controller> on gpio3
  104. gpiobus3: <GPIO bus> on gpio3
  105. gpio4: <Rockchip RK30XX GPIO controller> mem 0xff7b0000-0xff7b00ff irq 117 on simplebus0
  106. gpioc4: <GPIO controller> on gpio4
  107. gpiobus4: <GPIO bus> on gpio4
  108. gpio5: <Rockchip RK30XX GPIO controller> mem 0xff7c0000-0xff7c00ff irq 118 on simplebus0
  109. gpioc5: <GPIO controller> on gpio5
  110. gpiobus5: <GPIO bus> on gpio5
  111. gpio6: <Rockchip RK30XX GPIO controller> mem 0xff7d0000-0xff7d00ff irq 119 on simplebus0
  112. gpioc6: <GPIO controller> on gpio6
  113. gpiobus6: <GPIO bus> on gpio6
  114. gpio7: <Rockchip RK30XX GPIO controller> mem 0xff7e0000-0xff7e00ff irq 120 on simplebus0
  115. gpioc7: <GPIO controller> on gpio7
  116. gpiobus7: <GPIO bus> on gpio7
  117. gpio8: <Rockchip RK30XX GPIO controller> mem 0xff7f0000-0xff7f00ff irq 121 on simplebus0
  118. gpioc8: <GPIO controller> on gpio8
  119. gpiobus8: <GPIO bus> on gpio8
  120. dwcotg0: <DWC OTG 2.0 integrated USB controller> mem 0xff580000-0xff5bffff irq 55 on simplebus0
  121. usbus0 on dwcotg0
  122. dwcotg1: <DWC OTG 2.0 integrated USB controller> mem 0xff540000-0xff57ffff irq 57 on simplebus0
  123. usbus1 on dwcotg1
  124. uart0: <16750 or compatible> mem 0xff690000-0xff6903ff irq 89 on simplebus0
  125. uart0: console (115200,n,8,1)
  126. Timecounters tick every 10.000 msec
  127. usbus0: 480Mbps High Speed USB v2.0
  128. usbus1: 480Mbps High Speed USB v2.0
  129. random: unblocking device.
  130. WARNING: WITNESS option enabled, expect reduced performance.
  131. WARNING: DIAGNOSTIC option enabled, expect reduced performance.
  132. ugen0.1: <DWCOTG> at usbus0
  133. uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
  134. ugen1.1: <DWCOTG> at usbus1
  135. uhub1: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
  136. uhub1: 1 port with 1 removable, self powered
  137. uhub0: 1 port with 1 removable, self powered
  138. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  139. ugen0.2: <Unknown> at usbus0 (disconnected)
  140. uhub_reattach_port: could not allocate new device
  141. ugen1.2: <vendor 0x1a40> at usbus1
  142. uhub2: <vendor 0x1a40 USB 2.0 Hub MTT, class 9/0, rev 2.00/1.00, addr 2> on usbus1
  143. uhub2: MTT enabled
  144. Root mount waiting for: usbus1
  145. uhub2: 4 ports with 4 removable, self powered
  146. Root mount waiting for: usbus1
  147. Root mount waiting for: usbus1
  148. ugen1.3: <USB 2.0> at usbus1
  149. umass0: <USB 2.0 Flash Disk, class 0/0, rev 2.00/1.00, addr 3> on usbus1
  150. umass0:  SCSI over Bulk-Only; quirks = 0x4100
  151. umass0:0:0: Attached to scbus0
  152. da0 at umass-sim0 bus 0 scbus0 target 0 lun 0
  153. da0: <USB 2.0 Flash Disk 5.00> Removable Direct Access SCSI-2 device
  154. da0: Serial Number 15213301BF1BC700
  155. da0: 40.000MB/s transfers
  156. da0: 3998MB (8187904 512 byte sectors: 255H 63S/T 509C)
  157. da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
  158. Trying to mount root from ufs:/dev/da0 []...
  159. warning: no time-of-day clock registered, system time will not be set accurately
  160. Setting hostuuid: 249385b8-be3d-11e3-a644-678d5837e307.
  161. Setting hostid: 0xd8d50f9f.
  162. No suitable dump device was found.
  163. Entropy harvesting:sysctl: unknown oid 'kern.random.sys.harvest.interrupt': No such file or directory
  164. interruptssysctl: unknown oid 'kern.random.sys.harvest.ethernet': No such file or directory
  165. ethernetsysctl: unknown oid 'kern.random.sys.harvest.point_to_point': No such file or directory
  166. point_to_pointsysctl: unknown oid 'kern.random.sys.harvest.swi': No such file or directory
  167. swi.
  168. Starting file system checks:
  169. /dev/da0: FILE SYSTEM CLEAN; SKIPPING CHECKS
  170. /dev/da0: clean, 572815 free (3335 frags, 71185 blocks, 0.3% fragmentation)
  171. Mounting local file systems:.
  172. Writing entropy file:usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  173. ugen0.2: <Unknown> at usbus0 (disconnected)
  174. uhub_reattach_port: could not allocate new device
  175. .
  176. Setting hostname: arm.
  177. Starting Network: lo0.
  178. lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
  179.         options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
  180.         inet6 ::1 prefixlen 128
  181.         inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
  182.         inet 127.0.0.1 netmask 0xff000000
  183.         nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
  184. Starting devd.
  185. Starting pflogd:
  186. add net fe80::: gateway ::1
  187. add net ff02::: gateway ::1
  188. add net ::ffff:0.0.0.0: gateway ::1
  189. add net ::0.0.0.0: gateway ::1
  190. Creating and/or trimming log files.
  191. Starting syslogd.
  192. ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
  193. Starting casperd.
  194. Clearing /tmp (X related).
  195. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  196. ugen0.2: <Unknown> at usbus0 (disconnected)
  197. uhub_reattach_port: could not allocate new device
  198. Updating motd:.
  199. Mounting late file systems:.
  200. Performing sanity check on sshd configuration.
  201. Starting sshd.
  202. Starting sendmail_submit.
  203. Starting sendmail_msp_queue.
  204. Starting cron.
  205. Jan 12 13:13:14 arm sm-mta[535]: s940mWXg007341: SYSERR(root): hash map "Alias0": missing map file /etc/mail/aliases.db: No such file or directory
  206. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  207. ugen0.2: <Unknown> at usbus0 (disconnected)
  208. uhub_reattach_port: could not allocate new device
  209. Starting background file system checks in 60 seconds.
  210. Mon Jan 12 13:13:21 ULAT 2015
  211. FreeBSD/arm (arm) (ttyu0)
  212. login: root
  213. Jan 12 13:13:25 arm login: ROOT LOGIN (root) ON ttyu0
  214. Last login: Wed Oct  1 18:39:36 on ttyu0
  215. FreeBSD 11.0-CURRENT (FIREFLY) #159 r276691M: Mon Jan 12 12:51:13 ULAT 2015
  216. Welcome to FreeBSD!
  217. Before seeking technical support, please use the following resources:
  218. o  Security advisories and updated errata information for all releases are
  219.    at http://www.FreeBSD.org/releases/ - always consult the ERRATA section
  220.    for your release first as it's updated frequently.
  221. o  The Handbook and FAQ documents are at http://www.FreeBSD.org/ and,
  222.    along with the mailing lists, can be searched by going to
  223.    http://www.FreeBSD.org/search/.  If the doc package has been installed
  224.    (or fetched via pkg install lang-freebsd-doc, where lang is the
  225.    2-letter language code, e.g. en), they are also available formatted
  226.    in /usr/local/share/doc/freebsd.
  227. If you still have a question or problem, please take the output of
  228. `uname -a', along with any relevant error messages, and email it
  229. as a question to the questions@FreeBSD.org mailing list.  If you are
  230. unfamiliar with FreeBSD's directory layout, please refer to the hier(7)
  231. manual page.  If you are not familiar with manual pages, type `man man'.
  232. Edit /etc/motd to change this login announcement.
  233. You have new mail.
  234. usb_alloc_device: setting up USB template failed maybe the USB template module has not been loaded
  235. ugen0.2: <Unknown> at usbus0 (disconnected)
  236. uhub_reattach_port: could not allocate new device
  237. root@arm:~ # uname -an
  238. FreeBSD arm 11.0-CURRENT FreeBSD 11.0-CURRENT #159 r276691M: Mon Jan 12 12:51:13 ULAT 2015     tsgan@beastie.micom.mng.net:/usr/obj/arm.armv6/usr/src/sys/FIREFLY  arm
  239. root@arm:~ # id
  240. uid=0(root) gid=0(wheel) groups=0(wheel),5(operator)
  241. root@arm:~ #
Copy the code
Posted at 1/25/2025 15:50:21        Only Author  6#
good
Posted at 1/25/2025 15:51:15        Only Author  7#
RE: FreeBSD boot message on Firefly
Navigating trademark rights can feel complex, but protecting intellectual property is vital for organizations like The Regents of the University of California or The FreeBSD Foundation. For businesses, securing your brand is easier with top-Rated Trademark Registration Services in Tennessee, ensuring your name is protected and recognized, especially in competitive markets.
Posted at 2/21/2026 21:56:07        Only Author  8#
I appreciate your article, it really made me see things differently. Best of luck in your exams! AP-207 latest dumps sheet questions are available for free!
