New Topic
[Hardware] Mass-production of EMMC images
27
Hardware Mass-production of EMMC images
Posted at 3/26/2019 16:16:00      View9331 | Replies12        Print      Only Author   [Copy Link] 1#
Hi
I have a project in which I need to flash several EMMC images (16GB) for the ROC-RK3328-CC. I am running Ubutun 16.04 and I want to make an .img file which all my custom tools installed, and afterwards flash several EMMC's with this image. And so far I have not found any way of doing this.
So far I have only had succes flashing the raw Ubuntu 16.04 linked inside the documentation. I have not been able to flash my custom version. Can anyone help me do this?
I have tried using both the AndroidTool for windows and rkdeveloptool to flash my custom image to a blank EMMC. The flash is succesfull both the board wont boot  afterwards.
I hope someone can help me as this is a major issue for my project.
vip
Rank: 6Rank: 6
Posted at 3/27/2019 16:07:02        Only Author  2#
Hi @bga,  how do you pack your custom image?
Did you follow the guide at:
http://wiki.t-firefly.com/ROC-RK ... mpile_firmware.html  ?
Posted at 3/29/2019 16:09:39        Only Author  3#
hi @penguin
Yes I am following excatly that guide. And using the rkdeveloptool to flash the EMMC. For the Linux root filesystem I am using an .img file I created from an SD card with linux 16.04 previously plugged into a RK3328-cc. My idea was to install the basic 16.04, power up the firefly and install all my custom applications. and then copy the content of this SD card into many EMMC cards. Is this idea wrong? Might this be my issue?
vip
Rank: 6Rank: 6
Posted at 4/1/2019 10:59:22        Only Author  4#
hi @bga
You need a serial-to-usb adapter hooked to the uart debug port to see all the u-boot and kernel boot messages.
Without the log, I cannot tell what happened.
Posted at 4/11/2019 15:40:34        Only Author  5#
Hi @penguin
I finally got the UART debugger, and I get the following message when booting the device:
DDR version 1.06 20170424
In
DDR4
786MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:14
OUT
Boot1 Release Time: 2017-05-18, version: 2.43
ChipType = 0x11, 178
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 21135
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa539c
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):f947c7e
NOTICE:  BL31: Built : 09:28:45, May 31 2017
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE init        ialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-gc58a816 (Mar 29 2019 - 08:35:09 +0100)
Model: Firefly ROC-RK3328-CC
DRAM:  2 GiB
MMC:   rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
Card did not respond to voltage select!
mmc_init: -95, time 10
*** Warning - No block device, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
misc_init_r
cpuid=55524b50303130313400000000031b14
serial=3cf0f5335646df8
roc-rk3328-cc late init ...
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
GPT: last_usable_lba incorrect: 1D687DE > 1d1f000
part_get_info_efi: *** ERROR: Invalid GPT ***
GUID Partition Table Header signature is wrong: 0xA6B619CC7822D86 != 0x545241502        0494645
vip
Rank: 6Rank: 6
Posted at 4/16/2019 16:42:39        Only Author  6#
hmm, from the last lines of your log:
GPT: last_usable_lbaing incorrect: 1D687DE > 1d1f000
It seems that the GPT partition table is wrong.
Could you post all the commands ( creating the firmware and flashing) , and the result?
Posted at 6/26/2025 17:01:50        Only Author  7#
When you create your custom image from an SD card, are you sure it's capturing the entire boot sequence correctly, including the bootloader (U-Boot, SPL, ATF) and the partition table (GPT or space waves)? The stock image likely has these configured precisely for the ROC-RK3328-CC eMMC. If your custom image is just a dd of the root filesystem from an SD card, it might be missing crucial boot components that the eMMC expects at specific offsets. The eMMC boot process can be very particular.
Posted at 12/1/2025 16:04:03        Only Author  8#
Emotional connection is a prominent feature of modern trans sex dolls. Many buyers place particular emphasis on the emotional companionship value of trans sex dolls; therefore, smart products are equipped with advanced interactive systems. These
Posted at 1/11/2026 21:32:15        Only Author  9#
I appreciate you sharing this article, its very inspiring! Ready to tackle the New 300-745 dumps book exam. Fingers crossed for success!
Posted at 1/30/2026 22:06:15        Only Author  10#
The article was brilliantly written and thought-provoking. Sharing Free AANP-FNP questions and answers materials for free with you allbest of luck!
Return to List
12
