Channel init fail!
211
Channel init fail!
Posted at 6/11/2019 16:46:36      View:4492 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi,
What can be issue? I try load Ubuntu 18 image to AIO-3399C and it was start some time but not more than twice. I get then only channel error. I use another AIO-3399C board and that works fine.
dwmmc@fe320000: 1, sdhci@fe330000: 0
Card did not respond to voltage select!
mmc_init: -95, time 9
switch to partitions #0, OK
mmc0(part 0) is current device
boot mode: None
DTB: rk-kernel.dtb
Using kernel dtb
PMIC:  RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
pwm-regulator(vdd-log): init 900000 uV
vdd_log 900000 uV
Warn: can't find connect driver
Failed to found available display route
In:    serial
Out:   serial
Err:   serial
Model: AIO-3399C Board LVDS HSX101H40C (Linux Opensource)
download key pressed, entering download mode...
RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d1f000
\DDR Version 1.17 20190115
In
soft reset
SRX
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1 training pass!
change freq to 400MHz 0,1
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
some channel init fail!
ERR
Thanks,
Pekka
Posted at 6/13/2019 20:19:48        Only Author  2#
I had an issue closed to the one you have (having "full training error" / "CAP error") and was able to recover my board by entering maskrom mode (http://wiki.t-firefly.com/en/AIO-3399C/maskrom_mode.html)
The problem was my firmware, built from Android 7.1.2 sources, but without upgrading with bundle. Maybe you should try another ubuntu image ?
Posted at 1/9/2026 23:50:18        Only Author  3#
It was a truly rewarding and enlightening piece of writing. Free access to the Valid braindumps FCSS_NST_SE-7.6 book test questions. Best of luck to everyone!
Posted at 1/11/2026 13:06:30        Only Author  4#
Your article is breathtaking, I really appreciate you sharing it! The content in New 1Z0-922 test notes is rich and free, available to aid you in your learning journey.
Posted at 2/15/2026 04:24:59        Only Author  5#
It was one of the most beneficial pieces I’ve read in a while. Thanks to the CLF-C02 new study guide ppt, I received a promotion and raise. It's now free to all. Hope your promotions come soon!
Posted at 2/18/2026 12:23:19        Only Author  6#
The content of this article has been very helpful to my personal growth. Here’s the C_THR82_2505 latest test camp free test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
