NSE7_SOC_AR-7.6 & NSE7_SOC_AR-7.6ߥ`}
Posted at 1/8/2026 17:44:23
View354
Replies3
ҡSTȫ24rgʤΤϤ碌ƤޤʤҡNSE7_SOC_AR-7.6}Ɇ֤äƤʤ顢ʤϤĤǤɤǤ⥪饤ҡSTϤ碌ꡢ`ҡΥ`륢ɥ쥹ͤäꤹ뤳ȤǤޤҡϥ`ˤʤNSE7_SOC_AR-7.6}ˤĤƤ|؏ͤƤޤʤŤZӭƤޤʤ˥`ӥṩΤҡҤǤ
⤷FortinetNSE7_SOC_AR-7.6JԇY˺ϸΤͨơITINǤελߤơITܤʤ顢PassTest FortinetNSE7_SOC_AR-7.6ԇYȥ`˥YϤxۤǤLŬͨơPassTestFortinetNSE7_SOC_AR-7.6JԇYκϸʤѩ`ȤˤʤäƤޤPassTestx֤Τϳɹx֤Τ˵ȤǤ
NSE7_SOC_AR-7.6ߥ`}NSE7_SOC_AR-7.6ձZpdf}^ʵĤ˶ɤ״r_J뤿ˡNSE7_SOC_AR-7.6YϤһΌTҤˤäƾƤޤ äơ˽Υ`ɤؤޤ ۤʤΤFؤʕrgojˤ뤳Ȥʤӥ`{MΤޤ ˤϡԇYNSE7_SOC_AR-7.6ǥɤͨƥȤΤxNSE7_SOC_AR-7.6gHΥƥȤe֪Rޤ
Fortinet NSE 7 - Security Operations 7.6 Architect J NSE7_SOC_AR-7.6 ԇY} (Q46-Q51):| # 46
You configured a playbook namedFalse Positive Close, and want to run it to verify if it works. However, when you clickExecuteand search for the playbook, you do not see it listed. Which two reasons could be the cause of the problem? (Choose two answers)
- A. Another instance of the playbook is currently executing.
- B. The playbook must first be published using the Application Editor.
- C. The manual trigger is configured to require record input to run.
- D. The Alerts module is not among the list of modules the playbook can execute on.
⣺CD
h
Comprehensive and Detailed Explanation From FortiSOAR 7.6., FortiSIEM 7.3 Exact Extract study guide:
InFortiSOAR 7.6, manual playbooks appear in theExecutemenu of a record only if they meet specific configuration criteria defined in theManual Triggerstep:
* Module Scope (C):When creating a playbook with a manual trigger, the administrator must explicitly select which modules (e.g., Alerts, Incidents, Indicators) can execute the playbook. If theAlertsmodule is not selected in the "Applicable Modules" section of the trigger configuration, the playbook will remain hidden from the Execute menu when an analyst is viewing the Alerts module.
* Trigger Execution Requirements (D):Manual triggers can be configured to execute onno records, asingle record, ormultiple records. If a playbook is configured with the "Requires record input to run" setting but is specifically restricted to a different input type (or if there is a mismatch in the selection logic), it will not appear in the menu unless the correct number of records are selected. Furthermore, if a playbook is designed to run only whennorecord is selected (global utility), it will not show up in the context-sensitive menu of a specific record.
* Publishing (A):FortiSOAR playbooks do not require a separate "publishing" step via an Application Editor to become visible. Once they aresavedandactive(toggled on), they are immediately available for use based on their trigger settings.
* Concurrent Execution (B):FortiSOAR allows multiple instances of the same playbook to run simultaneously. An active execution of a playbook does not hide it from the menu for other analysts or subsequent runs.
| # 47
Refer to the exhibits.
You configured a spearphishing event handler and the associated rule. However. FortiAnalyzer did not generate an event.
When you check the FortiAnalyzer log viewer, you confirm that FortiSandbox forwarded the appropriate logs, as shown in the raw log exhibit.
What configuration must you change on FortiAnalyzer in order for FortiAnalyzer to generate an event?
- A. In the Log Filter by Text field, type the value: .5 ub t ype ma Iwa re..
- B. In the Log Type field, change the selection to AntiVirus Log(malware).
- C. Configure a FortiSandbox data selector and add it tothe event handler.
- D. Change trigger condition by selecting. Within a group, the log field Malware Kame (mname> has 2 or more unique values.
⣺C
h
* Understanding the Event Handler Configuration:
* The event handler is set up to detect specific security incidents, such as spearphishing, based on logs forwarded from other Fortinet products like FortiSandbox.
* An event handler includes rules that define the conditions under which an event should be triggered.
* Analyzing the Current Configuration:
* The current event handler is named "Spearphishing handler" with a rule titled "Spearphishing Rule 1".
* The log viewer shows that logs are being forwarded by FortiSandbox but no events are generated by FortiAnalyzer.
* Key Components of Event Handling:
* Log Type: Determines which type of logs will trigger the event handler.
* Data Selector: Specifies the criteria that logs must meet to trigger an event.
* Automation Stitch: Optional actions that can be triggered when an event occurs.
* Notifications: Defines how alerts are communicated when an event is detected.
* Issue Identification:
* Since FortiSandbox logs are correctly forwarded but no event is generated, the issue likely lies in the data selector configuration or log type matching.
* The data selector must be configured to include logs forwarded by FortiSandbox.
* Solution:
* B. Configure a FortiSandbox data selector and add it to the event handler:
* By configuring a data selector specifically for FortiSandbox logs and adding it to the event handler, FortiAnalyzer can accurately identify and trigger events based on the forwarded logs.
* Steps to Implement the Solution:
* Step 1: Go to the Event Handler settings in FortiAnalyzer.
* Step 2: Add a new data selector that includes criteria matching the logs forwarded by FortiSandbox (e.g., log subtype, malware detection details).
* Step 3: Link this data selector to the existing spearphishing event handler.
* Step 4: Save the configuration and test to ensure events are now being generated.
* Conclusion:
* The correct configuration of a FortiSandbox data selector within the event handler ensures that FortiAnalyzer can generate events based on relevant logs.
Fortinet Documentation on Event Handlers and Data Selectors FortiAnalyzer Event Handlers Fortinet Knowledge Base for Configuring Data Selectors FortiAnalyzer Data Selectors By configuring a FortiSandbox data selector and adding it to the event handler, FortiAnalyzer will be able to accurately generate events based on the appropriate logs.
| # 48
Match the FortiSIEM device type to its description. Select each FortiSIEM device type in the left column, hold and drag it to the blank space next to its corresponding description in the column on the right.
h
* Collector2.Worker3.Supervisor4.Agent
* The FortiSIEM 7.3 architecture is built upon a distributed multi-tenant model consisting of several distinct functional roles to ensure scalability and performance:
* Supervisor:This is the primary management node in a FortiSIEM cluster. It hosts the Graphical User Interface (GUI), the Configuration Management Database (CMDB), and manages the overall system configurations, reporting, and dashboarding.
* Worker:These nodes are responsible for the heavy lifting of data processing. They execute real- time event correlation against the rules engine, perform historical search queries, and handle the analytics workload to ensure the Supervisor node is not overwhelmed.
* Collector:Collectors are typically deployed at remote sites or different network segments to offload log collection from the central cluster. They receive logs via Syslog, SNMP, or WMI, compress the data, and securely forward it to the Workers or Supervisor. They also perform performance monitoring of local devices.
* Agent:These are lightweight software components installed directly on endpoints (Windows
/Linux). Their primary role is to collect local endpoint logs, monitor file integrity (system changes), and track user activity that cannot be captured via traditional network-based logging.
| # 49
You configured a custom event handler and an associated rule to generate events whenever FortiMail detects spam emails. However, you notice that the event handler is generating events for both spam emails and clean emails.
Which change must you make in the rule so that it detects only spam emails?
- A. Disable the rule to use the filter in the data selector to create the event.
- B. In the Log filter by Text field, type type==spam.
- C. In the Log Type field, select Anti-Spam Log (spam)
- D. In the Trigger an event when field, select Within a group, the log field Spam Name (snane) has 2 or more unique values.
⣺C
h
* Understanding the Custom Event Handler Configuration:
* The event handler is set up to generate events based on specific log data.
* The goal is to generate events specifically for spam emails detected by FortiMail.
* Analyzing the Issue:
* The event handler is currently generating events for both spam emails and clean emails.
* This indicates that the rule's filtering criteria are not correctly distinguishing between spam and non-spam emails.
* Evaluating the Options:
* Option A:Selecting the "Anti-Spam Log (spam)" in the Log Type field will ensure that only logs related to spam emails are considered. This is the most straightforward and accurate way to filter for spam emails.
* Option B:Typing type==spam in the Log filter by Text field might help filter the logs, but it is not as direct and reliable as selecting the correct log type.
* Option C isabling the rule to use the filter in the data selector to create the event does not address the issue of filtering for spam logs specifically.
* Option D:Selecting "Within a group, the log field Spam Name (snane) has 2 or more unique values" is not directly relevant to filtering spam logs and could lead to incorrect filtering criteria.
* Conclusion:
* The correct change to make in the rule is to select "Anti-Spam Log (spam)" in the Log Type field. This ensures that the event handler only generates events for spam emails.
Fortinet Documentation on Event Handlers and Log Types.
Best Practices for Configuring FortiMail Anti-Spam Settings.
| # 50
You are trying to find traffic flows to destinations that are in Europe or Asia, for hosts in the local LAN segment. However, the query returns no results. Assume these logs exist on FortiSIEM.
Which three mistakes can you see in the query shown in the exhibit? (Choose three answers)
- A. The logical operator for the first row (Group: Europe) must be OR.
- B. The Source IP row operator must be BETWEEN 10.0.0.0, 10.200.200.254.
- C. The null value cannot be used with the IS NOT operator.
- D. There are missing parentheses between the first row (Group: Europe) and the second row (Group: Asia).
- E. The time range must be Absolute for queries that use configuration management database (CMDB) groups.
⣺ABD
h
Analyzing theQuery Configurationexhibit in the context of FortiSIEM 7.3 search logic reveals several syntax and logical errors that prevent the query from returning results:
* Logical Operator Error (E):The user intends to find traffic to EuropeORAsia. In the exhibit, the first row (Group: Europe) is followed by a defaultANDoperator. This forces the query to look for a single flow where the destination is simultaneously in Europe and Asia, which is logically impossible. It must be changed toOR.
* Missing Parentheses (C):When combiningORandANDlogic in FortiSIEM, parentheses are required to define the order of operations. Without them, the query might evaluate "Asia AND Destination Country IS NOT null AND Source IP IN..." first. To correctly find (Europe OR Asia) that also matches the LAN segment, parentheses must group the first two rows.
* Incorrect Operator for IP Range (D):The exhibit uses theINoperator for the value 10.0.0.0,
10.200.200.254. In FortiSIEM, theINoperator is used for a comma-separated list of specific values or CMDB groups. To specify a continuous range of IP addresses (the "LAN segment"), theBETWEENoperator must be used.
* IS NOT null (A):In FortiSIEM, "IS NOT null" is a valid operator/value combination used to ensure a specific attribute has been successfully parsed and populated in the event record.
* Time Range (B):There is no requirement for a time range to be "Absolute" when using CMDB groups;
"Relative" time ranges (like the "Last 30 Days" shown) are commonly used and fully supported for such queries.
SOC Concepts and Frameworks
| # 51
϶यYߤΐä륽եȰȥ饤ṩƤޤNSE7_SOC_AR-7.6}ΥեȰϥ饤ݤͬǡgԇY냇ݤФ뤳ȤǤޤեȰϏΥѥnjgФ뤳ȤǤơwindowsΤߤʹä뤳ȤǤޤNSE7_SOC_AR-7.6}Υ饤Windows/Mac/Android/iOSǤߤʤϥեȰȥ饤NSE7_SOC_AR-7.6}R귵Ʋ뤳ȤǤޤ
NSE7_SOC_AR-7.6ߥ`}: https://www.passtest.jp/Fortinet/NSE7_SOC_AR-7.6-shiken.html
NSE7_SOC_AR-7.6}ͨơԇY˺ϸΤϺgˤʤäơˤäYJȡޤFortinet NSE7_SOC_AR-7.6 Ygͨ^ȤǤdz˚ݤFortinetNSE7_SOC_AR-7.6JԇYxkǤޤFortinet NSE7_SOC_AR-7.6 ̨Υѥ˥ȩ`ǤޤPassTestFortinetNSE7_SOC_AR-7.6ԇYȥ`˥YϤmǤΤǡѩ`Ȥκϸʤ^ޤFortinet NSE7_SOC_AR-7.6 ǡ˾ϡƤ륨`Ȥx֤˺ΤҪȤޤ˽ѧ̲ĤǤʤΤ˹s줿rgNSE7_SOC_AR-7.6˽ˤȤäΥ`Ǥ
ɰˡؤǤ뤴ȤˤӰǤζäơNSE7_SOC_AR-7.6}ͨơԇY˺ϸΤϺgˤʤäơˤäYJȡޤYgͨ^ȤǤ
gHĤNSE7_SOC_AR-7.6ԇYĩ`α^ُΰȫ-NSE7_SOC_AR-7.6ߥ`}dz˚ݤFortinetNSE7_SOC_AR-7.6JԇYxkǤޤ̨Υѥ˥ȩ`ǤޤPassTestFortinetNSE7_SOC_AR-7.6ԇYȥ`˥YϤmǤΤǡѩ`Ȥκϸʤ^ޤ
- NSE7_SOC_AR-7.6rg 🎶 NSE7_SOC_AR-7.6^ȥ 👲 NSE7_SOC_AR-7.6ģԇ 🎤 [url]www.passtest.jp _⇛ NSE7_SOC_AR-7.6 ⇚ơoϤǥ`ɤƤNSE7_SOC_AR-7.6Y[/url]
- 2026JNSE7_SOC_AR-7.6һغϸ-ΤNSE7_SOC_AR-7.6ߥ`} 🦩 ▛ [url]www.goshiken.com ▟ǣ NSE7_SOC_AR-7.6 ơoϤǥ`ɤƤNSE7_SOC_AR-7.6¥ƥ[/url]
- NSE7_SOC_AR-7.6Y} 🚀 NSE7_SOC_AR-7.6ϸ 👗 NSE7_SOC_AR-7.6ģԇ 🍌 { [url]www.mogiexam.com }➠ NSE7_SOC_AR-7.6 🠰}`NSE7_SOC_AR-7.6ձZԇY[/url]
- NSE7_SOC_AR-7.6Y} 🤙 NSE7_SOC_AR-7.6ӢZ 👴 NSE7_SOC_AR-7.6ԇYο 😒 ➠ NSE7_SOC_AR-7.6 🠰oϤǥ`ɡ [url]www.goshiken.com ֥ȤNSE7_SOC_AR-7.6ϸYӛ[/url]
- gõĤNSE7_SOC_AR-7.6ԇY-ԇYΜʂ䷽-¤NSE7_SOC_AR-7.6ߥ`} 🎡 ⇛ jp.fast2test.com ⇚ǣ NSE7_SOC_AR-7.6 ơoϤǺg˥`ɤǤޤNSE7_SOC_AR-7.6¥ƥ
- NSE7_SOC_AR-7.6Y} 🚨 NSE7_SOC_AR-7.6ӢZ 🔎 NSE7_SOC_AR-7.6JԇY 🌼 [ [url]www.goshiken.com ]ˤϟoϤ☀ NSE7_SOC_AR-7.6 ️☀️}ޤNSE7_SOC_AR-7.6^ȥ[/url]
- NSE7_SOC_AR-7.6ģԇ 👣 NSE7_SOC_AR-7.6JԇYȥ` 🚆 NSE7_SOC_AR-7.6Y 🐣 ➽ [url]www.jpexam.com 🢪{ NSE7_SOC_AR-7.6 }oϤǥ`ɤƤNSE7_SOC_AR-7.6ձZ憖}h[/url]
- [url=https://umvie.com/?s=NSE7_SOC_AR-7.6%e5%87%ba%e9%a1%8c%e7%af%84%e5%9b%b2%20%f0%9f%98%ae%20NSE7_SOC_AR-7.6%e8%b3%87%e6%a0%bc%e5%95%8f%e9%a1%8c%e9%9b%86%20%f0%9f%94%8f%20NSE7_SOC_AR-7.6%e5%90%88%e6%a0%bc%e7%8e%87%20%f0%9f%a5%90%20%e2%96%9b%20www.goshiken.com%20%e2%96%9f%e3%81%af%e3%80%81[%20NSE7_SOC_AR-7.6%20]%e3%82%92%e7%84%a1%e6%96%99%e3%81%a7%e3%83%80%e3%82%a6%e3%83%b3%e3%83%ad%e3%83%bc%e3%83%89%e3%81%99%e3%82%8b%e3%81%ae%e3%81%ab%e6%9c%80%e9%81%a9%e3%81%aa%e3%82%b5%e3%82%a4%e3%83%88%e3%81%a7%e3%81%99NSE7_SOC_AR-7.6%e5%90%88%e6%a0%bc%e5%8f%97%e9%a8%93%e8%a8%98]NSE7_SOC_AR-7.6} 😮 NSE7_SOC_AR-7.6Y} 🔏 NSE7_SOC_AR-7.6ϸ 🥐 ▛ www.goshiken.com ▟ϡ[ NSE7_SOC_AR-7.6 ]oϤǥ`ɤΤmʥȤǤNSE7_SOC_AR-7.6ϸYӛ[/url]
- NSE7_SOC_AR-7.6Ʒ|NSE7_SOC_AR-7.6ԇYԇYΜʂ䷽Fortinet NSE 7 - Security Operations 7.6 Architectߥ`} 🦀 [ [url]www.mogiexam.com ]ǡ NSE7_SOC_AR-7.6 ơoϤǺg˥`ɤǤޤNSE7_SOC_AR-7.6ϸYӛ[/url]
- NSE7_SOC_AR-7.6ģԇ 🥏 NSE7_SOC_AR-7.6ϸ 🛵 NSE7_SOC_AR-7.6yY 🌎 ➠ [url]www.goshiken.com 🠰➤ NSE7_SOC_AR-7.6 ⮘ơoϤǥ`ɤƤNSE7_SOC_AR-7.6}[/url]
- ԇYΜʂ䷽-¤NSE7_SOC_AR-7.6ԇY-Ʒ|NSE7_SOC_AR-7.6ߥ`} 🕳 ▛ [url]www.xhs1991.com ▟ǣ NSE7_SOC_AR-7.6 oϤǥ`ɤƤNSE7_SOC_AR-7.6^ȥ[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, confengine.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, chemerah.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, techlearnersacademy.com, Disposable vapes
