[General] JN0-363 Test Guide Online | JN0-363 Latest Guide Files
48
General JN0-363 Test Guide Online | JN0-363 Latest Guide Files
Posted at 1/8/2026 20:48:12      View242 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Juniper JN0-363 dumps are available on Google Drive shared by ExamsReviews: https://drive.google.com/open?id=1J-Rl4jQjvRsFqprusNXrdXV97QuczRoD
The client can try out and download our Juniper JN0-363 Training Materials freely before their purchase so as to have an understanding of our product and then decide whether to buy them or not. The website pages of our product provide the details of our Service Provider Routing and Switching, Specialist (JNCIS-SP) learning questions.
The JN0-363 Exam is a comprehensive assessment of a candidate's understanding of service provider routing and switching technologies, including Junos OS fundamentals, routing policy and firewall filters, MPLS and multicast protocols, and high availability and scaling techniques. JN0-363 exam is available in English and Japanese and consists of multiple-choice questions, drag-and-drop questions, and simulation questions.
The JN0-363 exam is an important certification for professionals who are looking to advance their careers in the service provider industry. Service Provider Routing and Switching, Specialist (JNCIS-SP) certification demonstrates that the candidate has a strong understanding of various routing and switching technologies, and is able to apply this knowledge to design and maintain a service provider network. Service Provider Routing and Switching, Specialist (JNCIS-SP) certification is also valuable for organizations that are looking to hire professionals with specialized skills in service provider routing and switching.
Juniper JN0-363 Latest Guide Files & Certification JN0-363 DumpIf you are not aware of your problem, please take a good look at the friends around you! Now getting an international JN0-363 certificate has become a trend. If you do not hurry to seize the opportunity, you will be far behind others! Now the time cost is so high, choosing JN0-363 Exam Prep will be your most efficient choice. You can pass the JN0-363 exam in the shortest possible time to improve your strength.
Juniper JN0-363 Certification is an important Service Provider Routing and Switching, Specialist (JNCIS-SP) certification intended for individuals who already have some knowledge and experience in switching and routing. Service Provider Routing and Switching, Specialist (JNCIS-SP) certification validates the knowledge and skills required to work with Juniper Networks, making it a valuable addition to the resumes of networking professionals.
Juniper Service Provider Routing and Switching, Specialist (JNCIS-SP) Sample Questions (Q64-Q69):NEW QUESTION # 64
Click the Exhibit button.
Referring to the exhibit, the GRE tunnel between R-1 and R-2 allows connectivity between User-1 and Server-1. When User-1 communicates with Server-2 with packets that are 1472 bytes in size, no packet fragmentation occurs. User-1 can communicate with Server-1 with packets that are up to 1448 bytes in size with no packet fragmentation. However, if the packet size is larger than 1448 bytes, packet fragmentation occurs.
Why is the packet fragmentation occurring between User-1 and Server-1 in this scenario?
  • A. The IP header adds 20 bytes to the packet
  • B. The IP header adds 24 bytes to the packet
  • C. The GRE header adds 20 bytes to the packet
  • D. The GRE header adds 24 bytes to the packet
NEW QUESTION # 65
Exhibit
Referring to the exhibit, internal BGP between R1 and R2 is not establishing.
What is the problem In this scenario?
  • A. R1 needs to be configured with a next-hop self policy.
  • B. R1 needs to be configured with an explicit router ID.
  • C. R1 does not have a route to 192.168.200.2.
  • D. R1 and R2 must each have unique AS numbers.
NEW QUESTION # 66
Click the exhibit.
You have configured OSPF between two routers. The OSPF adjacency will not form.
Referring to the exhibit, what is the problem?
  • A. Router is not receiving hellos on the configured interface.
  • B. The OSPF version does not match on the configured interfaces.
  • C. The router is not sending hellos on the configured interface.
  • D. The area does not match on the configured interfaces.
NEW QUESTION # 67
Exhibit
Referring to the exhibit, what will happen to untagged frames?
  • A. The untagged frames are dropped.
  • B. The untagged frames are load balanced between VLAN 10 and VLAN 20.
  • C. The untagged frames are associated with VLAN 20.
  • D. The untagged frames are associated with VLAN 10.
NEW QUESTION # 68
Exhibit
Referring to the exhibit, which two statements are correct? (Choose two.)
  • A. The ge-0/0'1.0 Interface is configured as passive.
  • B. The OSPF Interfaces are configured as point-to-point.
  • C. Junos OS default OSPF hello timers and dead intervals are used on all interfaces.
  • D. The R2 device is an ABR.
You can see area 0.0.0.1 set for one interface and area 0.0.0.0 for the other interface. This means the router communicates in the backbone and area 1, thus it is an ABR.
Default hello timer and dead intervals are configured
hello-interval-Specifies the length of time, in seconds, before the routing device sends a hello packet out of an interface. By default, the routing device sends hello packets every 10 seconds. The range is from 1 through 255 seconds.
dead-interval-Specifies the length of time, in seconds, that the routing device waits before declaring that a neighboring routing device is unavailable. This is an interval during which the routing device receives no hello packets from the neighbor. By default, the routing device waits 40 seconds (four times the hello interval). The range is 1 through 65,535 seconds.
https://www.juniper.net/document ... ng-ospf-timers.html
C). The R2 device is shown as having interfaces in two different OSPF areas (Area 0 and another area not specified), which makes it an Area Border Router (ABR).D. The OSPF hello and dead intervals are set to their default values of 10 and 40 seconds, respectively.
Understanding OSPF Areas and ABRs, Juniper TechLibrary
OSPF Configuration Guide, Juniper TechLibrary
NEW QUESTION # 69
JN0-363 Latest Guide Files: https://www.examsreviews.com/JN0-363-pass4sure-exam-review.html
BONUS!!! Download part of ExamsReviews JN0-363 dumps for free: https://drive.google.com/open?id=1J-Rl4jQjvRsFqprusNXrdXV97QuczRoD
Posted at 1/10/2026 05:28:38        Only Author  2#
Your article really stuck with me, Im sincerely grateful. Sharing the Latest test 1Y0-205 questions answers test materials with you allbest of luck!
Posted at 1/28/2026 12:10:21        Only Author  3#
Your article was incredibly insightful, and Im truly thankful for it. The L4M6 technical training test questions are free! Wishing you all the best of luck in your exams!
