[General] JN0-481 exams questions and answers & dumps PDF for Data Center, Specialist
80
General JN0-481 exams questions and answers & dumps PDF for Data Center, Specialist
Posted at 1/8/2026 21:06:56      View268 | Replies3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Test4Sure JN0-481 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-KrUMGPlvJUMbfrTcVvtqf_6KGC1o3qp
It is known to us that more and more companies start to pay high attention to the JN0-481 certification of the candidates. Because these leaders of company have difficulty in having a deep understanding of these candidates, may it is the best and fast way for all leaders to choose the excellent workers for their company by the JN0-481 Certification that the candidates have gained. There is no doubt that the JN0-481 certification has become more and more important for a lot of people. And with our JN0-481 exam questions. you can get the JN0-481 certification easily.
Juniper certification can be used in different IT Company and it will be your access to the IT elites. But you may find that the JN0-481 study materials are difficult for you. You need much time to prepare and the cost of the JN0-481 Practice Exam is high, you wonder it will be a great loss for you when fail the exam. It will be bad thing. Test4Sure will help you to reduce the loss and save the money and time for you.
JN0-481 Latest Exam Test & JN0-481 Exam Paper PdfCompared with those practice materials which are to no avail and full of hot air, our JN0-481 guide tests outshine them in every aspect. If you make your decision of them, you are ready to be thrilled with the desirable results from now on. The passing rate of our JN0-481 Exam Torrent is up to 98 to 100 percent, and this is a striking outcome staged anywhere in the world. They are appreciated with passing rate up to 98 percent among the former customers. So they are in ascendant position in the market.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q49-Q54):NEW QUESTION # 49
What are two formats that the cabling map can be exported as? (Choose two.)
  • A. CSV
  • B. HTML
  • C. XML
  • D. JSON
NEW QUESTION # 50
In the case of IP Clos data center five-stage fabric design, what are two rotes of the super spines? (Choose two.)
  • A. Super spines are always connected to an external data center gateway.
  • B. Super spines connect to all spine devices within the five-stage architecture.
  • C. Super spines are used to interconnect two different data center pods.
  • D. Super spines are used to connect leaf nodes within a data center pod.
In the case of IP Clos data center five-stage fabric design, the super spines are the devices that provide the highest level of aggregation in the network. They have two main roles:
Super spines are used to interconnect two different data center pods. A pod is a cluster of leaf and spine devices that form a 3-stage Clos topology. A 5-stage Clos topology consists of multiple pods that are connected by the super spines. This allows for scaling the network to support more devices and bandwidth.
Super spines connect to all spine devices within the five-stage architecture. The spine devices are the devices that provide the second level of aggregation in the network. They connect to the leaf devices, which are the devices that provide access to the end hosts. The super spines connect to all the spine devices in the network, regardless of which pod they belong to. This provides any-to-any connectivity between the pods and enables optimal routing and load balancing.
NEW QUESTION # 51
What is one indicator in the Apstra UI that implies that changes to a blueprint are ready to be committed?
  • A. Each assigned device has been set to Deploy mode.
  • B. Interface maps have been assigned through Device Profiles.
  • C. The Staged tab turns yellow
  • D. The Staged tab turns green
NEW QUESTION # 52
Referring to the exhibit, what needs to change in the IP fabric to make it a valid IP fabric?
  • A. The connection between the two spine nodes must be removed.
  • B. The connection between the two spine nodes must be increased to 40 Gbps.
  • C. The IP fabric connections must be increased to a speed greater than 10 Gbps.
  • D. The IP fabric must consist of only one device model throughout the fabric.
To make the IP fabric a valid IP fabric, the connection between the two spine nodes must be removed. This is because an IP fabric is a network topology that uses a spine-leaf architecture, where the spine devices are only connected to the leaf devices, and the leaf devices are only connected to the spine devices. This creates a non-blocking, high-performance, and scalable network that supports Layer 3 routing protocols such as BGP or OSPF. The connection between the two spine nodes in the exhibit violates the spine-leaf design principle and introduces unnecessary complexity and potential loops in the network.
NEW QUESTION # 53
What is the purpose of an interface map in Juniper Apstra?
  • A. An interface map specifies the connections between racks in a template.
  • B. An interface map specifies the number of ports and the port speeds of a logical device
  • C. An interface map specifies a connection between the interfaces of two devices.
  • D. An interface map associates a logical device with a device profile.
An interface map is a configuration template that maps interfaces between logical devices and physical hardware devices (represented with device profiles) while adhering to vendor specifications. An interface map specifies a connection between the interfaces of two devices, such as a leaf and a spine, a leaf and a server, or a leaf and an external gateway. An interface map can also specify port transformations, such as breaking out a 40 GbE port into four 10 GbE ports, or disabling unused ports. An interface map can be used to achieve the intended network configuration rendering and to enable features such as LAG, ESI-LAG, or MLAG.
NEW QUESTION # 54
When preparing for the JN0-481 exam, a good source of information is what candidates need most, and the price of the materials is one of the important factors to be considered when a candidate choosing. In contrast to most exam preparation materials available online, our JN0-481 exam materials of Test4Sure can be obtained at a reasonable price so that each candidate who prepares to take the JN0-481 exam can afford it. It will not let any one of the candidates be worried about the price issue, and its quality and advantages exceed all our competitors' similar products. We will never reduce the quality of our JN0-481 Exam Questions because the price is easy to bear by candidates and the quality of our exam questions will not let you down. They will prove the best choice for your time and money.
JN0-481 Latest Exam Test: https://www.test4sure.com/JN0-481-pass4sure-vce.html
Everybody knows that JN0-481 is an influential company with high-end electronic products and best-quality service, High efficiency, Juniper JN0-481 Test Free That is because our company beholds customer-oriented tenets that guide our everyday work, Juniper JN0-481 Test Free Note: don't forget to check your spam.) One year free update after purchase, All our JN0-481 exam questions and answers are valid and latest.
Since March of this year, Erik has been working JN0-481 for a local IT company as a helpdesk technician, and enjoys it immensely, The Math Behind the Eyedroppers, Everybody knows that JN0-481 is an influential company with high-end electronic products and best-quality service.
Free PDF Quiz 2026 Juniper JN0-481: Data Center, Specialist (JNCIS-DC) Fantastic Test FreeHigh efficiency, That is because our company beholds customer-oriented JN0-481 Test Free tenets that guide our everyday work, Note: don't forget to check your spam.) One year free update after purchase.
What's more, part of that Test4Sure JN0-481 dumps now are free: https://drive.google.com/open?id=1-KrUMGPlvJUMbfrTcVvtqf_6KGC1o3qp
Posted at 1/19/2026 05:40:08        Only Author  2#
Im sincerely grateful for your article, it left a strong impression. This C_P2WFI_2023 valid exam voucher helped me get promoted and enjoy a salary raise. Now its available to you for free. Hope you all advance soon!
Posted at 1/23/2026 13:32:32        Only Author  3#
INST1-V8ɤϡ|{ˤȷͨơयL줿`{ˤ뤳Ȥ狼ޤˡʌTҥ`ब뤿ᡢ`ҪsʹäǤޤ INST1-V8ȥȤΜʂϡ|η˻ŤФȤǤvB֪RȽMߺϤ碌ơYԇYvBһBҪʽYՓYՓޤ INST1-V8ƥYϤϡΥȥԥå᰸΃A_yϤINST1-V8ԇY˺ϸ񤹤Τޤ
Posted at 2/23/2026 21:16:02        Only Author  4#
Im deeply moved by your article, thank you for sharing this insight! Upgrade your IT skills with free Valid study FCP_FAC_AD-6.5 questions free. Wishing you good luck in your exams!
