[General] Salesforce OmniStudio-Developer Exam Torrent, New OmniStudio-Developer Test Ques
79
【General】 Salesforce OmniStudio-Developer Exam Torrent, New OmniStudio-Developer Test Ques
Posted at 1/8/2026 21:25:59      View:192 | Replies:4        Print      Only Author   [Copy Link] 1#
P.S. Free & New OmniStudio-Developer dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=1ETi6RfjDfheY1YGroTUWFaE7RlnYTp-y
Prep4cram is a leading platform that is committed to offering to make the Salesforce Exam Questions preparation simple, smart, and successful. To achieve this objective Prep4cram has got the services of experienced and qualified OmniStudio-Developer Exam trainers. They work together and put all their efforts and ensure the top standard of Prep4cram Salesforce OmniStudio-Developer exam dumps all the time.
Salesforce OmniStudio platform is a powerful tool that allows developers to build and manage complex business processes within Salesforce. It provides a suite of tools and services that enable developers to create customized solutions that meet the unique needs of their organizations. The platform helps businesses automate their processes, streamline their operations, and improve their overall efficiency. With the Salesforce OmniStudio-Developer Certification, developers can demonstrate their ability to leverage the platform to deliver these benefits to their clients and organizations.
OmniStudio-Developer Real Braindumps Materials are Definitely Valuable Acquisitions - Prep4cramIn the era of informational globalization, the world has witnessed climax of science and technology development, and has enjoyed the prosperity of various scientific blooms. In 21st century, every country had entered the period of talent competition, therefore, we must begin to extend our OmniStudio-Developer personal skills, only by this can we become the pioneer among our competitors. At the same time, our competitors are trying to capture every opportunity and get a satisfying job. In this case, we need a professional OmniStudio-Developer Certification, which will help us stand out of the crowd and knock out the door of great company.
Salesforce Certified OmniStudio Developer Sample Questions (Q87-Q92):NEW QUESTION # 87
Refer to the following row-versioned calculation matrix.
The developer needs to delete the row that contains the Code CA-SF.
If the developer deletes that row in Version 3, whatis the result?
  • A. The row isdeletedonly in Version 3.
  • B. The row is deleted In Versions 2 and 3 but will remain in Version 1.
  • C. The row is deleted in all versions
  • D. The row is deleted in Version 3 and Version 1.
Deleting a row in Version 3 will only affect that version, not any previous or future versions. The row that contains the Code CA-SF will remain in Versions 1 and 2, as well as any versions created after Version 3.
Theother options are incorrect because they imply that deleting a row in one version will affect other versions as well.
NEW QUESTION # 88
Refer to the exhibit below. What JSON code correctly represents the step in the OmniScript Structure panel shown?
  • A.
  • B.
  • C.
  • D.
The JSON code correctly represents the step in the OmniScript Structure panel shown. The JSON code has the following properties:
* The type is "Step", which indicates that this is a step element in the OmniScript.
* The label is "Step 1", which matches the label shown in the panel.
* The name is "Step1", which matches the name shown in the panel.
* The elements property is an array that contains one element, which is a text field.
* The text field element has the following properties:
* The type is "Text", which indicates that this is a text field element.
* The label is "Text Field 1", which matches the label shown in the panel.
* The name is "TextField1", which matches the name shown in the panel.
* The value property is an empty string, which indicates that this text field has no default value.
NEW QUESTION # 89
A customer sets up to LWC Omniscripts, one embedded into another. Account is set in a Set Values element in the parent Omniscript.
The AccountId set in the parent Omniscript is used to another Set Values element ContextAccountid in the embedded OmniScript. The embedded Omniscript is activated.
While previewing the OmniScript flow from the parent, it is found that Account is set correctly in the parent OmniScript. However. ContextAccountId in the embedded OmniScript is not set with the AccountId from parent Omniscript. On previewing the embedded OmniScript individually, it is found that ContextAccountId is set correctly.
What is the reason for this? Refer to the exhibit below.
  • A. The flag passDataJSON in the parent OmniScript in not configured correctly.
  • B. The LWC PubSub Message flag in the Set Values action of the parent has not been set.
  • C. A developer failed to include a Navigation Element to pass data from the parent OmniScript.
  • D. Both parent and embedded OmniScripts have the same element name for the Set values element.
NEW QUESTION # 90
Users receive an APEC CPU limit Exceeded error when running an OmniScript in a Salesfoce Community.
The OmniScript includes an Integration Procedure that contains two DataRaptors.
Which two Location should the developer check to troubleshoot the issue?
Choose 2 answers
  • A. Action Debugger
  • B. DataRaptor configuration
  • C. Script configuration
  • D. Community logs
NEW QUESTION # 91
In which two fields in an Integration Procedure or DataRaptor can you use a function like CONCAT or DATEDIFF? Choose 2 answers
  • A. In a Set Values Action in a Value field.
  • B. In a Remote Action in an Additional Output value field.
  • C. In a DataRaptor in an Output Tab Output JSON Path.
  • D. In a DataRaptor Action in an Input Parameters value field.
NEW QUESTION # 92
With all types of OmniStudio-Developer test guide selling in the market, lots of people might be confused about which one to choose. Many people can’t tell what kind of OmniStudio-Developer study dumps and software are the most suitable for them. Our company can guarantee that our OmniStudio-Developer Actual Questions are the most reliable. Having gone through about 10 years’ development, we still pay effort to develop high quality OmniStudio-Developer study dumps and be patient with all of our customers, therefore you can trust us completely.
New OmniStudio-Developer Test Question: https://www.prep4cram.com/OmniStudio-Developer_exam-questions.html
BONUS!!! Download part of Prep4cram OmniStudio-Developer dumps for free: https://drive.google.com/open?id=1ETi6RfjDfheY1YGroTUWFaE7RlnYTp-y
Posted at 1/12/2026 10:37:13        Only Author  2#
After reading this article, my understanding of the field has become more comprehensive. Thanks to the Useful H12-811_V1.0-ENU dumps exam, I reached a new level in my career. Now I’m sharing it for free with all of you!
Posted at 1/13/2026 11:33:10        Only Author  3#
Your article was truly remarkable, thank you for sharing it with me. We’ve made C_CPI_2506 reliable braindumps questions available, free of charge, to provide you with helpful content.
Posted at 1/16/2026 01:50:17        Only Author  4#
I'm deeply inspired by this article, thank you for sharing it! I’m sharing the F5CAB4 pass guarantee test that helped me get promoted and receive a salary increase. It’s free for you today—wishing you success in your career!
Posted at 1/18/2026 18:23:28        Only Author  5#
Your article is absolutely outstanding, thank you for sharing it! Thanks to Latest test Associate-Google-Workspace-Administrator experience, I climbed the career ladder and earned more—today, I’m giving it away for free!
