[General] DP-300 Valid Test Vce & Real DP-300 Exam
72
General DP-300 Valid Test Vce & Real DP-300 Exam
Posted at 1/8/2026 22:04:17      View205 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that PassExamDumps DP-300 dumps now are free: https://drive.google.com/open?id=16e3cKZSy8Pm0eH9-UIQ1N3eGC5IgXcpy
This Administering Relational Databases on Microsoft Azure (DP-300) certification is a valuable credential that is designed to validate your expertise all over the world. After successfully competition of DP-300 exam you can gain several personal and professional benefits. All these Administering Relational Databases on Microsoft Azure (DP-300) certification exam benefits will not only prove your skills but also assist you to put your career on the right track and achieve your career objectives in a short time period.
Skills measured
  • Plan and implement a High Availability and Disaster Recovery (HADR) environment (15-20%)
  • Optimize query performance (5-10%)
  • Plan and implement data platform resources (15-20%)
  • Perform automation of tasks (10-15%)
To pass the Microsoft DP-300 Exam, candidates must have a good understanding of database administration concepts and practices, as well as a strong knowledge of Azure services and features. They should be familiar with the tools and technologies used to manage databases on Azure, such as Azure Command-Line Interface, Azure Portal, and Azure PowerShell. Candidates should also be able to troubleshoot and resolve issues related to database performance, connectivity, and security.
Real DP-300 Exam | DP-300 Exam RegistrationPassExamDumps also has a Microsoft Practice Test engine that can be used to simulate the genuine DP-300 exam. This online practice test engine allows you to answer questions in a simulated environment, giving you a better understanding of the exam's structure and format. With the help of this tool, you may better prepare for the Administering Relational Databases on Microsoft Azure (DP-300) test.
Microsoft Administering Relational Databases on Microsoft Azure Sample Questions (Q25-Q30):NEW QUESTION # 25
You have SQL Server on an Azure virtual machine.
You review the query plan shown in the following exhibit.
For each of the following statements, select yes if the statement is true. Otherwise, select no.
https://docs.microsoft.com/en-us ... ing-the-query-store
NEW QUESTION # 26
You have an Azure subscription that contains the resources shown in the following table.
You need to configure a connection between VM1 and MIL The solution must meet the following requirements:
* The connection must be encrypted.
* Network latency must be minimized.
What should you implement?
  • A. service endpoints
  • B. private endpoints
  • C. virtual network peering
  • D. a site-to-site VPN
NEW QUESTION # 27
You have an Azure SQL database.
You are reviewing a slow performing query as shown in the following exhibit.
https://docs.microsoft.com/en-us ... ew=sql-server-ver15
NEW QUESTION # 28
You have an Azure SQL database that contains a table named Customer. Customer has the columns shown in the following table.
You plan to implement a dynamic data mask for the Customer_Phone column. The mask must meet the following requirements:
The first six numerals of each customer's phone number must be masked.
The last four digits of each customer's phone number must be visible.
Hyphens must be preserved and displayed.
How should you configure the dynamic data mask? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... ynamic-data-masking
NEW QUESTION # 29
You create all of the tables and views for ResearchDB1.
You need to implement security for ResearchDB1. The solution must meet the security and compliance requirements.
1 - Register ResearchApp1 to Azure AD.
2 - Create an Azure Key Vault instance and configure an access policy.
3 - Run the Always Encrypted wizard.
https://docs.microsoft.com/en-us ... bs=azure-powershell
Topic 2, Contoso Ltd
Existing Environment
Contoso, Ltd. is a financial data company that has 100 employees. The company delivers financial data to customers.
Active Directory
Contoso has a hybrid Azure Active Directory (Azure AD) deployment that syncs to on-premises Active Directory.
Database Environment
Contoso has SQL Server 2017 on Azure virtual machines shown in the following table.
SQL1 and SQL2 are in an Always On availability group and are actively queried. SQL3 runs jobs, provides historical data, and handles the delivery of data to customers.
The on-premises datacenter contains a PostgreSQL server that has a 50-TB database.
Current Business Model
Contoso uses Microsoft SQL Server Integration Services (SSIS) to create flat files for customers. The customers receive the files by using FTP.
Requirements
Planned Changes
Contoso plans to move to a model in which they deliver data to customer databases that run as platform as a service (PaaS) offerings. When a customer establishes a service agreement with Contoso, a separate resource group that contains an Azure SQL database will be provisioned for the customer. The database will have a complete copy of the financial data. The data to which each customer will have access will depend on the service agreement tier. The customers can change tiers by changing their service agreement.
The estimated size of each PaaS database is 1 TB.
Contoso plans to implement the following changes:
Business Goals
Contoso identifies the following business requirements:
Technical Requirements
Contoso identifies the following technical requirements:
Monitoring Requirements
Contoso identifies the following monitoring requirements:
PaaS Prototype
During prototyping of the PaaS solution in Azure, you record the compute utilization of a customer's Azure SQL database as shown in the following exhibit.
Role Assignments
For each customer's Azure SQL Database server, you plan to assign the roles shown in the following exhibit.
NEW QUESTION # 30
Nowadays, using electronic DP-300 exam materials to prepare for the exam has become more and more popular, so now, you really should not be restricted to paper materials any more, our electronic Microsoft DP-300 preparation dumps will surprise you with their effectiveness and usefulness. I can assure you that you will pass the exam as well as getting the related DP-300 Certification under the guidance of our DP-300 training materials as easy as pie.
Real DP-300 Exam: https://www.passexamdumps.com/DP-300-valid-exam-dumps.html
P.S. Free & New DP-300 dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=16e3cKZSy8Pm0eH9-UIQ1N3eGC5IgXcpy
