DP-420 Pass Guaranteed & Free DP-420 Vce Dumps
Posted at 1/9/2026 01:42:15
2026 Latest FreeCram DP-420 PDF Dumps and DP-420 Exam Engine Free Share: https://drive.google.com/open?id=1HKQT0A-iy9p-YIctpeT18-KQP-4CD5e4
The 24/7 support team is just an e-mail away for our customers so that they can contact us anytime. Our team will solve all of their issues as quickly as possible. Free demos and up to 1 year of free updates of our Microsoft Exams are also available at FreeCram. Buy updated and Real DP-420 Exam Questions now and earn your dream DP-420 certification with FreeCram!
Microsoft DP-420 certification exam is designed for professionals who want to demonstrate their ability to design and implement cloud-native applications using Microsoft Azure Cosmos DB. DP-420 Exam is intended for individuals who have a strong understanding of Azure Cosmos DB and have experience working with cloud-native applications.
Authoritative DP-420 Pass Guaranteed & Leader in Certification Exams Materials & Trusted Free DP-420 Vce DumpsIn order to meet the different demands of the different customers, these experts from our company have designed three different versions of the DP-420 reference guide. All customers have the right to choose the most suitable version according to their need after buying our study materials. The PDF version of the DP-420 exam prep has many special functions, including download the demo for free, support the printable format and so on. We can make sure that the PDF version of the DP-420 Test Questions will be very convenient for all people. Of course, if you choose our study materials, you will have the chance to experience our PDF version.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q47-Q52):NEW QUESTION # 47
You have an Azure Cosmos DB Core (SQL) API account named account1 that has the disableKeyBasedMetadataWriteAccess property enabled.
You are developing an app named App1 that will be used by a user named DevUser1 to create containers in account1. DevUser1 has a non-privileged user account in the Azure Active Directory (Azure AD) tenant.
You need to ensure that DevUser1 can use App1 to create containers in account1.
https://docs.microsoft.com/en-us ... cure-access-to-data
https://docs.microsoft.com/en-us/rest/api/resources/
NEW QUESTION # 48
You have an Azure Cosmos DB for NoSQL account. The account hosts a container that has the change feed enabled. You are building an app by using the Azure Cosmos DB SDK. The app will read items from the change feed by using a pull model. You need to ensure that multiple threads can read the change feed in parallel. What should you include?
- A. the Pagesize value
- B. the changeFeedStartFew value
- C. a stream-based iterator
- D. the FeedRange value
NEW QUESTION # 49
You have an Azure Cosmos DB account named account1.
You have several apps that connect to account1 by using the account's secondary key.
You then configure the apps to authenticate by using service principals.
You need to ensure that account1 will only allow apps to connect by using an Azure AD identity.
Which account property should you modify?
- A. disableKeyBasedMetadataWriteAccess ,
- B. disableLocalAuth
- C. userAssignedldentatxe
- D. allowedOrxgins
The disableLocalAuth property is a boolean flag that indicates whether local authentication methods such as primary/secondary keys are disabled for the Azure Cosmos DB account. Setting this property to true improves security by ensuring that Azure Cosmos DB accounts exclusively require Azure Active Directory identities for authentication1.
NEW QUESTION # 50
You have an Azure Cosmos DB account named account1 that has a default consistency level of session.
You have an app named App1.
You need to ensure that the read operations of App1 can request either bounded staleness or consistent prefix consistency.
What should you modify for each consistency level? To answer, select the appropriate options in the answer area.
Box 1 = The request level options
Azure Cosmos DB offers five well-defined consistency levels: strong, bounded staleness, session, consistent prefix and eventual. You can configure the default consistency level on your Azure Cosmos DB account at any time2. The default consistency level applies to all databases and containers under that account1. You can also override the default consistency level for a specific request by using the request options2.
Box 2 = The request level options
To modify the consistency level of a read operation in Azure Cosmos DB, you can use request-level options to override the account's default consistency setting. Therefore, to ensure that the read operations of App1 can request either consistent prefix or session consistency, you need to modify the request-level options for each operation. Reference: - https://docs.microsoft.com/en-us ... /consistency-levels
NEW QUESTION # 51
You have a database in an Azure Cosmos DB for NoSQL account that is configured for multi-region writes.
You need to use the Azure Cosmos DB SDK to implement the conflict resolution policy for a container. The solution must ensure that any conflict sent to the conflict feed.
Solution: You set ConfilictResolutionMode to Custom. You Set ResolutionProcedures to a custom stored procedure. You configure the custom stored procedure to use the isTomstone parameter to resolve conflict.
Does this meet the goal?
The solution is incorrect because there is no "isTom" parameter in the Azure Cosmos DB SDK. The correct parameter is "isTombstone".
NEW QUESTION # 52
Here our DP-420 exam braindumps are tailor-designed for you. Unlike many other learning materials, our Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB guide torrent is specially designed to help people pass the exam in a more productive and time-saving way, and such an efficient feature makes it a wonderful assistant in personal achievement as people have less spare time nowadays. On the other hand, DP-420 Exam Braindumps are aimed to help users make best use of their sporadic time by adopting flexible and safe study access.
Free DP-420 Vce Dumps: https://www.freecram.com/Microsoft-certification/DP-420-exam-dumps.html
- Quiz 2026 Latest Microsoft DP-420 Pass Guaranteed 🛷 The page for free download of ➡ DP-420 ️⬅️ on ( [url]www.vceengine.com ) will open immediately 🔘Free DP-420 Practice Exams[/url]
- Free PDF Quiz 2026 Microsoft Updated DP-420 Pass Guaranteed 🦸 Immediately open ➠ [url]www.pdfvce.com 🠰 and search for ▶ DP-420 ◀ to obtain a free download 📏Reliable DP-420 Exam Online[/url]
- Realistic DP-420 Pass Guaranteed - Free Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Vce Dumps 🕙 Search for ➡ DP-420 ️⬅️ and obtain a free download on ☀ [url]www.troytecdumps.com ️☀️ ⚠Latest DP-420 Exam Dumps[/url]
- DP-420 Latest Exam Registration 🙉 Latest DP-420 Exam Dumps 🛒 Practice DP-420 Questions 🤕 Search for ✔ DP-420 ️✔️ on ➽ [url]www.pdfvce.com 🢪 immediately to obtain a free download 🐠DP-420 Test Engine[/url]
- Pass Leader DP-420 Dumps 🔻 Pass Leader DP-420 Dumps 🧪 Pass Leader DP-420 Dumps ♿ Download ➽ DP-420 🢪 for free by simply entering 【 [url]www.examdiscuss.com 】 website 🙊DP-420 Pass4sure[/url]
- DP-420 Valid Braindumps Questions 🦌 DP-420 Valid Braindumps Questions 📔 DP-420 Real Sheets 🐬 Enter ▷ [url]www.pdfvce.com ◁ and search for ➥ DP-420 🡄 to download for free 📌DP-420 Real Sheets[/url]
- DP-420 Latest Exam Registration ⬅ Downloadable DP-420 PDF 🛕 DP-420 Pass4sure 🔰 Search for ( DP-420 ) on ➥ [url]www.prepawaypdf.com 🡄 immediately to obtain a free download 🙃DP-420 Test Engine[/url]
- Free PDF Quiz 2026 Microsoft Updated DP-420 Pass Guaranteed 🎲 Search for “ DP-420 ” and easily obtain a free download on ✔ [url]www.pdfvce.com ️✔️ ⬆DP-420 Exam Course[/url]
- DP-420 Exam Certification 🪒 DP-420 Pass4sure 🎋 DP-420 Exam Certification ✳ Open website ➤ [url]www.prepawayete.com ⮘ and search for ( DP-420 ) for free download 🐷DP-420 Valid Exam Braindumps[/url]
- Valid DP-420 Exam Voucher 💢 Free DP-420 Practice Exams 🚅 DP-420 Valid Braindumps Questions 💄 Go to website ➤ [url]www.pdfvce.com ⮘ open and search for 【 DP-420 】 to download for free 🟦DP-420 Test Engine[/url]
- Cost Effective DP-420 Dumps 🥩 DP-420 Exam Cram Pdf 🦕 DP-420 Real Sheets 👗 「 [url]www.examcollectionpass.com 」 is best website to obtain 《 DP-420 》 for free download ☘Free DP-420 Practice Exams[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, e-learning.gastroinnovation.eu, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, salamancaebookstore.com, Disposable vapes
P.S. Free 2026 Microsoft DP-420 dumps are available on Google Drive shared by FreeCram: https://drive.google.com/open?id=1HKQT0A-iy9p-YIctpeT18-KQP-4CD5e4
