Oracle 1Z0-1055-25 PDF VCE | 1Z0-1055-25 Official Cert Guide
Posted at 1/9/2026 02:10:26
What's more, part of that Dumpleader 1Z0-1055-25 dumps now are free: https://drive.google.com/open?id=1xDvCEqI9WvvjHguGpuAV4-VEjOcgDTYP
For candidates who will attend the exam, choose the right 1Z0-1055-25 exam torrent is important. We offer you the 1Z0-1055-25 exam dumps to help you pass the exam. With the skilled experts to compile the exam dumps, the 1Z0-1055-25 study materials of us contain the questions and answers, and you can get enough practicing by using them. Besides, the 1Z0-1055-25 Soft test engine stimulates the real exam environment, and you can know what the real exam is like by using this version.
Are you ready to take your career to the next level with the Oracle Fusion Cloud Financials: Payables and Expenses 2025 Implementation Professional (1Z0-1055-25)? Look no further than Dumpleader for all of your 1Z0-1055-25 exam needs. Our comprehensive and cost-effective solution includes regularly updated Oracle 1Z0-1055-25 Exam Questions, available in a convenient PDF format that can be downloaded on any device, including PC, laptop, mac, tablet, and smartphone.
1Z0-1055-25 Official Cert Guide, Latest 1Z0-1055-25 Test ReportIf you really want a learning product to help you, our 1Z0-1055-25 study materials are definitely your best choice, you can't find a product more perfect than it. And according to the data, our 1Z0-1055-25 exam questions have really helped a lot of people pass the exam and get their dreaming 1Z0-1055-25 Certification. As the quality of our 1Z0-1055-25 practice questions is high, the pass rate of our worthy customers is also high as 98% to 100%. It is hard to find in the market.
Oracle Fusion Cloud Financials: Payables and Expenses 2025 Implementation Professional Sample Questions (Q38-Q43):NEW QUESTION # 38
SIMULATION
MANAGE POLICIES BY EXPENSE CATEGORY
Create an Expense Policy for meals that raises a warning, if the expense exceeds the prescribed limit, without blocking the expense processing. Your expense policy should be ready to be associated with an expense type within an expense report template.
See the Explanation for Step by Step Solution
Step-by-Step Solution: Configuring an Expense Policy in Oracle Financials Cloud To configure this expense policy in Oracle Financials Cloud, follow these steps:
Step 1: Access the Expense Policies Setup Page
Log in to Oracle Financials Cloud with the appropriate Expense Manager or Financial Administrator role.
Navigate to Setup and Maintenance.
Select the Task: Manage Policies by Expense Category.
Step 2: Create or Locate the Meal Expense Category
Search for the Meals expense category.
If the Meals category does not exist:
Click Create Expense Category.
Category Name: "Meals".
Category Type: "Meals and Entertainment".
Save the entry.
Step 3: Define a Policy Rule for Raising a Warning
Select the Meals Expense Category and click Edit.
Navigate to the Policies and Limits tab.
Under Amount Limits, click Add New Rule.
Configure the Expense Policy Rule:
Description: "Meal Expense Warning Policy".
Limit Type: "Warning Only".
Limit Amount: Enter the prescribed limit (e.g., 50 USD).
Per: Select Day (or another relevant time frame).
Applies To: Select All Employees.
Location-Based Rules: Leave blank if not location-specific.
Set Warning Behavior:
Select Raise a Warning if the expense exceeds the prescribed limit.
Ensure the policy does not block submission or approval.
Click Save and Close.
Step 4: Associate the Policy with an Expense Report Template
Navigate to Setup and Maintenance > Manage Expense Report Templates.
Search for the Expense Report Template where the Meals category should be included.
Click Edit and go to the Expense Types section.
Add the Meals Expense Type and associate it with the newly created Meals Expense Warning Policy.
Step 5: Enable and Validate the Policy
Ensure the policy is marked as Active.
Click Submit to finalize the policy configuration.
Run the Validate and Deploy Expense Policies process.
Step 6: Testing the Policy
Simulate an Expense Report Submission:
Create a new expense report and select Meals as the expense type.
Enter an expense amount exceeding the limit (e.g., 55 USD).
Verify that a warning message appears, but the expense is still allowed to proceed.
Submit an expense below the limit (e.g., 45 USD) and ensure no warning appears.
Expected Outcome:
If the meal expense exceeds the limit, the system raises a warning but does not block the expense submission.
If the meal expense is within the limit, the system processes it without warnings.
The policy is successfully associated with an expense type in an expense report template.
Conclusion
By following these steps, you successfully configure an expense policy that raises a warning for meals exceeding a specified limit without blocking submission or processing. This ensures that employees are notified about policy violations while allowing flexibility in expense approvals.
NEW QUESTION # 39
Your cloud customer wants to use AI to automate key processes in Payables. You are tasked with setting up the required roles for AI apps.
When you create the user-defined AIAPPS_BIP_ROLE, which two role hierarchies should you add?
- A. BI_Integration
- B. BIP_DataModelDeveloper
- C. AIAPPS_Author
- D. BI_Author
- E. AIAPPS_Data_Model_Developer
Answer: C,E
Comprehensive and Detailed In-Depth
Oracle Adaptive Intelligence (AI) for Payables integrates with Oracle Payables Cloud to enhance automation and streamline invoice processing. To enable AI functionalities, certain roles must be assigned to users to allow them to access and configure AI-based reporting and automation tools.
AIAPPS_Author (Option A):
This role allows users to create and modify AI-based reports, dashboards, and analytics in Oracle Transactional Business Intelligence (OTBI) and BI Publisher.
AIAPPS_Data_Model_Developer (Option D):
This role is essential for developing AI-driven data models that power analytics and automation within AI for Payables.
Options B, C, and E Analysis:
BI_Integration (Option B):
While BI Integration supports data extraction and reporting in BI Publisher, it is not specifically required for AI-based automation in Payables.
Verdict: Not required for AIAPPS_BIP_ROLE.
BI_Author (Option C):
This role provides general BI report development access but does not grant access to AI-based configurations or data models.
BIP_DataModelDeveloper (Option E):
This role is related to BI Publisher Data Model Development but does not include AI model configuration.
Thus, the correct answers are A. AIAPPS_Author and D. AIAPPS_Data_Model_Developer.
NEW QUESTION # 40
A Payables user creates a manual invoice, and a Withholding Tax Classification Code defaults on the invoice line when the invoice is saved. Where does this Withholding Tax Classification Code default from?
- A. From the Site Assignments of the Supplier Site
- B. From the Party Tax Profile of the Third Party Site
- C. From the Ship-to Location selected on the invoice
A). From the Site Assignments of the Supplier Site (Correct Answer)
The Withholding Tax Classification Code can be assigned at the supplier site level in Oracle Financials Cloud.
When a supplier site has a predefined withholding tax classification, this automatically defaults onto the invoice line when an invoice is created for that supplier site.
This setup ensures that consistent withholding tax is applied to transactions related to that supplier.
According to Oracle documentation:
"For supplier sites that use withholding tax, the withholding tax classification that you define at the supplier site assignment level is used to populate the default tax classification on the invoice." (Oracle Financials Cloud Payables Guide) B). From the Party Tax Profile of the Third Party Site (Incorrect Answer) The Party Tax Profile contains tax-related settings for a supplier or third-party entity, including tax registration details.
However, it does not directly default the Withholding Tax Classification Code onto invoice lines.
Instead, the Party Tax Profile provides high-level tax configurations that may influence tax calculations but does not assign the default withholding tax classification.
C). From the Ship-to Location selected on the invoice (Incorrect Answer) The Ship-to Location on an invoice is used for logistics and sales tax calculations based on where goods are delivered.
It does not impact withholding tax, which is typically linked to the supplier or supplier site.
Therefore, the Withholding Tax Classification Code does not default from the Ship-to Location.
Final Conclusion:
The correct source of the default Withholding Tax Classification Code on an invoice line is the Supplier Site Assignment.
This ensures that withholding tax is consistently applied to transactions involving that supplier, reducing errors in tax calculations.
Oracle Financials Cloud Documentation - Withholding Tax Classifications in Payables (Oracle Documentation Link) Explanation:
In Oracle Financials Cloud, when a Payables user creates a manual invoice, the Withholding Tax Classification Code can default onto the invoice line from various sources depending on the system configurations. The correct source for defaulting this code is from the Site Assignments of the Supplier Site.
Explanation of Each Option:
NEW QUESTION # 41
As an Expenses Administrator, you can control which expense values you do not want to automatically populate on the Create Expense Item page. You have therefore created the profile option EXM_DFLT_FROM_PREV_EXPENSE at the user level and set it to N (No).
Which three values will no longer populate from a previous expense item when a user enters a new expense item?
- A. Template
- B. Project and Task Number
- C. Currency
- D. Expense Location
Answer: A,B,D
In Oracle Expenses, the profile option EXM_DFLT_FROM_PREV_EXPENSE determines whether certain fields on the Create Expense Item page are automatically populated with values from the previously entered expense item.
By default, when this profile option is set to 'Y' (Yes), the application carries over several fields from the last entered expense item to streamline data entry. These fields include:
Date
Template
Expense Location
Currency (both ledger and reimbursement currency)
Company and Department
Project Number and Task Number
However, when the profile option is set to 'N' (No) at the user level, the system stops carrying over certain fields from the previous expense item.
Fields That Will No Longer Auto-Populate:
Expense Location - Users must manually enter the expense location for each new entry.
Template - Expense templates (if used) will not be pre-filled from the previous expense item.
Project and Task Number - Users must reselect the project and task number for each new expense entry.
Fields That Will Still Populate With Defaults:
Currency - Defaults to the ledger currency as configured in Human Capital Management (HCM).
Company and Department - These values will be retrieved from the user's default expense account setup in HCM.
Thus, the correct answer is: A, B, D because the Expense Location, Template, and Project & Task Number will no longer populate from a previous expense item when a user enters a new one.
Oracle Financials Cloud: Implementing Expenses
NEW QUESTION # 42
Previously, cash advances were applied automatically to expenses when the auditor ran the expense reimbursement process. Now, Oracle Expenses allows employees to have the ability to manually apply their cash advances to the relevant expense report. As an Application Implementation Consultant, you advise your client to enable this feature and allow employees to perform manual application of cash advances to their expense reports for the US Business Unit.
Which statement is NOT true about this feature?
- A. Unused cash advance amounts are applied to the next expense report or refunded to the company by the employee.
- B. If approvers or auditors reject expense reports, the cash advances that are applied to the reports are automatically removed and returned to the employee's available cash advances.
- C. Auditors can make changes to cash advances that are applied to an expense report.
- D. Employees need to include a justification if they don't apply an available cash advance when submitting an expense report.
NEW QUESTION # 43
Our PDF format is great for those who prefer to print out the questions. Oracle 1Z0-1055-25 dumps come in a downloadable PDF format that you can print out and prepare at your own pace. The PDF works on all smart devices, which means you can go through Oracle 1Z0-1055-25 Dumps at your convenience. The ability to print out the 1Z0-1055-25 PDF dumps enables users who find it easier and more comfortable than working on a computer.
1Z0-1055-25 Official Cert Guide: https://www.dumpleader.com/1Z0-1055-25_exam.html
We will follow the sequence of customers’ payment to send you our 1Z0-1055-25 guide questions to study right away with 5 to 10 minutes, Oracle 1Z0-1055-25 PDF VCE However, no matter how fierce the competition is, as long as you have the strength, you can certainly stand out, Oracle 1Z0-1055-25 PDF VCE Currently, the awareness about the importance of specialized qualification and professional career skills increase and attract our attention, If you prepare for the exams using our Dumpleader 1Z0-1055-25 Official Cert Guide testing engine, It is easy to succeed for all certifications in the first attempt.
The goal of the index is to measure how much confidence 1Z0-1055-25 PDF VCE startups have in their business and the economy, Using a separate layer for dodging and burning, We will follow the sequence of customers’ payment to send you our 1Z0-1055-25 Guide questions to study right away with 5 to 10 minutes.
Three High-in-Demand Dumpleader Oracle 1Z0-1055-25 Practice Questions FormatsHowever, no matter how fierce the competition 1Z0-1055-25 is, as long as you have the strength, you can certainly stand out, Currently, theawareness about the importance of specialized Latest 1Z0-1055-25 Test Report qualification and professional career skills increase and attract our attention.
If you prepare for the exams using our Dumpleader Valid 1Z0-1055-25 Cram Materials testing engine, It is easy to succeed for all certifications in the first attempt, We have received many good feedbacks from our customers, and they think highly of our 1Z0-1055-25 exam torrent.
- Newest 1Z0-1055-25 PDF VCE for Real Exam 🦝 Go to website ⇛ [url]www.troytecdumps.com ⇚ open and search for 「 1Z0-1055-25 」 to download for free ⚒Training 1Z0-1055-25 For Exam[/url]
- 1Z0-1055-25 Exam Bootcamp - 1Z0-1055-25 Dumps Torrent - 1Z0-1055-25 Exam Simulation 🏎 Simply search for ➥ 1Z0-1055-25 🡄 for free download on ➽ [url]www.pdfvce.com 🢪 🏙Valid 1Z0-1055-25 Exam Pdf[/url]
- 1Z0-1055-25 Study Group 🛸 1Z0-1055-25 Valid Test Camp 😽 Valid 1Z0-1055-25 Exam Pdf 🏈 Copy URL 「 [url]www.vce4dumps.com 」 open and search for ▶ 1Z0-1055-25 ◀ to download for free 🐋1Z0-1055-25 Study Group[/url]
- Training 1Z0-1055-25 Tools 🎥 Training 1Z0-1055-25 For Exam 🤐 New 1Z0-1055-25 Test Practice 🙄 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for ( 1Z0-1055-25 ) to obtain a free download 🍣Certified 1Z0-1055-25 Questions[/url]
- 1Z0-1055-25 Exam Simulations 😝 Best 1Z0-1055-25 Practice 🙏 Exam 1Z0-1055-25 Lab Questions ✍ Search for “ 1Z0-1055-25 ” and download exam materials for free through ➤ [url]www.practicevce.com ⮘ 🧤Exam 1Z0-1055-25 Lab Questions[/url]
- New 1Z0-1055-25 Test Tips 🙉 Certified 1Z0-1055-25 Questions 🐸 Valid 1Z0-1055-25 Exam Pdf 🥦 Easily obtain free download of ➥ 1Z0-1055-25 🡄 by searching on ➽ [url]www.pdfvce.com 🢪 🧉Advanced 1Z0-1055-25 Testing Engine[/url]
- Oracle 1Z0-1055-25 Exam Questions - Easy Way To Prepare [2026] 🎩 Open ▶ [url]www.prep4sures.top ◀ and search for ▶ 1Z0-1055-25 ◀ to download exam materials for free ⚓Exam 1Z0-1055-25 Lab Questions[/url]
- Pass Guaranteed 2026 Oracle 1Z0-1055-25: Oracle Fusion Cloud Financials: Payables and Expenses 2025 Implementation Professional –Professional PDF VCE 🥋 Search on ▛ [url]www.pdfvce.com ▟ for ▛ 1Z0-1055-25 ▟ to obtain exam materials for free download 📂Advanced 1Z0-1055-25 Testing Engine[/url]
- New 1Z0-1055-25 Test Tips 🤫 Reliable 1Z0-1055-25 Test Cost 🎍 1Z0-1055-25 Guaranteed Questions Answers 🦺 Simply search for 【 1Z0-1055-25 】 for free download on ➤ [url]www.pass4test.com ⮘ 🆘Training 1Z0-1055-25 Tools[/url]
- 1Z0-1055-25 Exam Bootcamp - 1Z0-1055-25 Dumps Torrent - 1Z0-1055-25 Exam Simulation ⚠ Open 【 [url]www.pdfvce.com 】 enter ➤ 1Z0-1055-25 ⮘ and obtain a free download 🎭Best 1Z0-1055-25 Practice[/url]
- Pass Guaranteed 2026 Oracle 1Z0-1055-25: Oracle Fusion Cloud Financials: Payables and Expenses 2025 Implementation Professional –Professional PDF VCE 🦍 Easily obtain ⇛ 1Z0-1055-25 ⇚ for free download through ▶ [url]www.pdfdumps.com ◀ 🙌Exam 1Z0-1055-25 Lab Questions[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, writeablog.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dorahacks.io, www.competize.com, www.competize.com, Disposable vapes
P.S. Free 2026 Oracle 1Z0-1055-25 dumps are available on Google Drive shared by Dumpleader: https://drive.google.com/open?id=1xDvCEqI9WvvjHguGpuAV4-VEjOcgDTYP
