1z0-1057-25ԇYӍ - 1z0-1057-25d
Posted at 1/9/2026 04:11:18
View280
Replies2
혱һ£ԏ녴惦dVCESoft 1z0-1057-25ԇ}棺https://drive.google.com/open?id=1PuxPA-lZYquOgtqZMrHrKHgo0zuf9Vla
һżȻITԇɞ^Y׃һ\ Oracle һҪJCĿ1z0-1057-25 ԇ Oracle ˾JCԇٷ̖҂1z0-1057-25 }셢YǸµĿԇӑB׃£VCESoft ڵһrg¡߀ҪҪʹ@WվӖY϶еߪqԥQN҂WվYd 1z0-1057-25 ԇ}𰸣Mԇãm㣬ȥُIҲtC^ڡ
VCESoftµOracle 1z0-1057-25 JCԇ}𰸆֮ᣬͨ^Oracle 1z0-1057-25 JCԇѽITTĉˡVCESoftṩPOracle 1z0-1057-25 JCԇ}Ʒ|Ǻܸߵģ挍Ŀԇ}Ŀ95%ԡVCESoftֵеġxVCESoftĮaƷ͞Oracle 1z0-1057-25 JCԇ˳֜ʂ䣬ɹͨ^ԇǺpġ
100%I1z0-1057-25ԇYӍõĿԇYώͨ^1z0-1057-25ԇOracleJCԇԽԽܴҵĚgӭOracleJCYҲ׃ԽԽҪ鱻 ITИIVJɵĿԇ1z0-1057-25JCԇOracleҪĿԇ֮һȡ@ԇJCYͿԫ@úܶ档Ҳ녢@ԇԒVCESoft1z0-1057-25}ʂ俼ԇĕrȱٵĹߡΪ1z0-1057-25ԵIJοϡ
µ Project Financials Management Cloud 1z0-1057-25 Mԇ} (Q42-Q47):} #42
You have a small project for a period of five months. Your budget amount for each month is spread evenly and is $1000 per month. The first month actual expense is $800 and there is a commitment for $600. Now you generate a forecast at the beginning of the second month. Identify the monthly Estimate-To-Complete (ETC) amount that the application would calculate for the remaining four periods, when the ETC generation method includes commitments. (Choose the best answer.)
𰸣C
}f
Budget 5,000Actuals 800Commitment 600
ETC = Budget - Actuals - Commitment
ETC = 5,000-800-600 = 3,600 Budget available for next 4 months = 3,600/4 = 900/month
} #43
Your organization has been using project class categories and codes for reporting purposes and is set up at the project level. You recently defined a new project type, Capital-Contract, and created new class categories named Build, Operate, and Transfer (BOT) and Build, Transfer, and Maintain (BTM), with class codes of Yes
/No. But on creation of a project, you are unable to associate these class categories and codes.
Identify two setups that are mandatory for these class categories and codes to be displayed. (Choose two.)
- A. Class codes should be assigned to project unit.
- B. Class codes should be associated with a related set code.
- C. Class categories should be assigned to business unit.
- D. Class categories should be assigned to project type.
𰸣B,D
}f
Ref: https://docs.oracle.com/en/cloud ... project-foundation- configuration-manage-project-types.html#OAPFM360164 Topic - Associating Project Types and Class Categories: Examples Project classifications group your projects according to categories and codes that you define. When you associate project classifications with project types, the classification is available for selection on projects with that project type.
Use any of the following methods to associate class categories with project types:
* Add a classification to the project type definition
For each classification that you associate with the project type, you can enable the Assign to All Projects option to automatically add the classification to the project definition for all new projects with the project type. When this option is enabled, all projects with this project type must be assigned a class code for the class category.
* Add a project type to the class category definition
* Enable the Assign to all Project Types option on the class category definition
} #44
Your customer has implemented Oracle Project Portfolio Management Cloud recently and they have hired new employees for their Professions Services business. These employees are set up in Oracle Human Capital Management Cloud, but the Project Administrators are unable to add them as resources in the Planning Resource Breakdown Structure.
What are three conditions for new employees to show up in the list? (Choose three.)
- A. All new employees created as persons must be assigned to a department.
- B. All new employees created as persons must have an active project role.
- C. All new employees created as persons must have an active supervisor.
- D. Current date is before the effective date of the resource, and you did not enable the "Include people with future-dated effective start dates" option during the search.
- E. All new employees created as persons must have an active assignment.
𰸣A,D,E
} #45
Green House Corporation has decided to enable the budgetary control feature for their projects. At which two levels will they be able to enter the amounts in the budget versions for these projects?
(Choose two.)
- A. Expenditure Category
- B. Top resource
- C. Project
- D. Task
- E. Expenditure Type
𰸣C,D
}f
Budgetary control is a feature that allows you to monitor and control project costs against approved budgets.
You can enter the amounts in the budget versions for these projects at two levels: Task and Project. These levels correspond to the budgetary control levels that are defined for the project type. You can also view and compare the budget amounts and actual costs at these levels using reports and dashboards. Expenditure Type, Top Resource, and Expenditure Category are not levels at which you can enter the amounts in the budget versions for these projects. These are attributes that can be used to group and filter the budget and actual amounts for reporting purposes. Reference: https://docs.oracle.com/en/cloud/saas/project-portfolio- management/20c/oapfm/manage-project-budgets-and-forecasts.html#OAPFM2356191
} #46
Where is the Allow Override option for the Default Capitalized Interest Rate Schedule specified?
- A. Manage Project Plan Type page
- B. Manage Expenditure Type page
- C. Manage Capitalized Interest Rates page
- D. Manage Project Type page
- E. Manage Capitalized Interest Rate Schedules page
𰸣D
}f
The Allow Override option for the Default Capitalized Interest Rate Schedule is specified on the Manage Project Type page. This option allows you to override the default capitalized interest rate schedule for a project or task that uses the project type. The default capitalized interest rate schedule is used to calculate the capitalized interest amount for a project or task based on the interest rates and dates defined in the schedule.
Reference: https://docs.oracle.com/en/cloud ... pfm/manage-project- costs.html#OAPFM2356031
} #47
Wv춌WvֻǴ@Wvѣڌ`呟ģcWvK]бȻMҪXԼУҪԼxOracle1z0-1057-25ԇJCҪŬͨ^Ŀ^xVCESoft Oracle1z0-1057-25ԇӖYϣWvжߣжͣ㶼Ժ@ӖYϵăݣKҿͨ^ԇJC
1z0-1057-25d: https://www.vcesoft.com/1z0-1057-25-pdf.html
^ԏVCESoft Oracle1z0-1057-25ԇJCӖYϣǷNđBʧğoۙoӰVCESoft Oracle1z0-1057-25ԇJCӖYϣİٱÓκο^LUȻҲp挦ԇˣ@HϵĎҪͨ^ԇ@JCƴһõ죬ú£҂ṩoõ 1z0-1057-25 JCԇYϣُIᣬd 1z0-1057-25 } (Oracle Project Management Cloud 2025 Implementation Professional): ɹ, ҂wyԄͨ^]䌢ُIĮaƷl͵]䣬VCESoft һΪṩIT֤ԵĿ}ܺܺõذҵվͨ^ǰ݅ĽvĿԇYϾuõ Oracle 1z0-1057-25 ԇ}V@һMԇ ԇyԇ棬ģM挍Ŀԇ龰Կ 1z0-1057-25d A֪R
ֱͦҼˣ挦Bȸ֔ҪPģҼ¶ˣ^ԏVCESoft Oracle1z0-1057-25ԇJCӖYϣǷNđBʧğoۙoӰVCESoft Oracle1z0-1057-25ԇJCӖYϣİٱÓκο^LUȻҲp挦ԇˣ@HϵĎҪͨ^ԇ@JCƴһõ졣
1z0-1057-25ԇYӍ |һ·LԇpWKͨ^ԇͨ^ʵOracle Oracle Project Management Cloud 2025 Implementation Professionalú£҂ṩoõ 1z0-1057-25 JCԇYϣُIᣬd 1z0-1057-25 } (Oracle Project Management Cloud 2025 Implementation Professional): ɹ, ҂wyԄͨ^]䌢ُIĮaƷl͵]䣬VCESoft һΪṩIT֤ԵĿ}ܺܺõذҵվͨ^ǰ݅ĽvĿԇYϾuõ Oracle 1z0-1057-25 ԇ}V
@һMԇ ԇyԇ棬1z0-1057-25ģM挍Ŀԇ龰Կ Project Financials Management Cloud A֪R
- Yԇһ꼉Oracle Oracle Project Management Cloud 2025 Implementation Professional100ϸ1z0-1057-25ԇYӍIṩ ☸ ⮆ [url]www.newdumpspdf.com ⮄ṩM⏩ 1z0-1057-25 ⏪}ռ1z0-1057-25}[/url]
- 1z0-1057-25} 🏺 1z0-1057-25ԇ} 🥟 1z0-1057-25} 🦔 ⮆ [url]www.newdumpspdf.com ⮄✔ 1z0-1057-25 ️✔️K@ȡMd1z0-1057-25ԇ}[/url]
- 挍1z0-1057-25ԇYӍYԇеIߺ1z0-1057-25d 🤬 ✔ tw.fast2test.com ️✔️ь✔ 1z0-1057-25 ️✔️KMd1z0-1057-25ָ
- õOracle 1z0-1057-25Oracle Project Management Cloud 2025 Implementation ProfessionalԇYӍ - 100ϸNewdumpspdf 1z0-1057-25d ➰ _Wվ➠ [url]www.newdumpspdf.com 🠰▷ 1z0-1057-25 ◁Md1z0-1057-25 PDF}[/url]
- 1z0-1057-25ԇYӍͨ^Oracle Project Management Cloud 2025 Implementation Professionalx 🔔 ^⏩ [url]www.newdumpspdf.com ⏪p@ȡ➽ 1z0-1057-25 🢪Md1z0-1057-25d[/url]
- õOracle 1z0-1057-25Oracle Project Management Cloud 2025 Implementation ProfessionalԇYӍ - 100ϸNewdumpspdf 1z0-1057-25d 📏 Md{ 1z0-1057-25 }ֻ➥ [url]www.newdumpspdf.com 🡄1z0-1057-25}Y[/url]
- õOracle 1z0-1057-25Oracle Project Management Cloud 2025 Implementation ProfessionalԇYӍ - 100ϸ[url]www.pdfexamdumps.com 1z0-1057-25d ❇ www.pdfexamdumps.com ✔ 1z0-1057-25 ️✔️ԫ@ȡMd1z0-1057-25 PDF}[/url]
- 1z0-1057-25 PDF} 👉 1z0-1057-25ԇ} 🍲 1z0-1057-25d 😑 ▷ [url]www.newdumpspdf.com ◁ṩM 1z0-1057-25 }ռ1z0-1057-25C[/url]
- Md1z0-1057-25} 🧪 1z0-1057-25} 🍏 1z0-1057-25Y 🌗 ▶ tw.fast2test.com ◀➤ 1z0-1057-25 ⮘p@ȡMd1z0-1057-25Y
- Md1z0-1057-25} 📐 1z0-1057-25°}Ͼ 👄 1z0-1057-25ԇ} 🐓 ✔ [url]www.newdumpspdf.com ️✔️⇛ 1z0-1057-25 ⇚K@ȡMd1z0-1057-25C[/url]
- 1z0-1057-25ԇ} 🏍 1z0-1057-25}YӍ 📮 1z0-1057-25d 😁 _➥ [url]www.newdumpspdf.com 🡄K➽ 1z0-1057-25 🢪ԫ@ȡMd1z0-1057-25}[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, ummalife.com, connect.garmin.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.skudci.com, estudiasonline.com, www.stes.tyc.edu.tw, app.guardedcourses.com, Disposable vapes
⣬@ЩVCESoft 1z0-1057-25ԇ}IJփݬFMģhttps://drive.google.com/open?id=1PuxPA-lZYquOgtqZMrHrKHgo0zuf9Vla
