Salesforce Marketing-Cloud-Administrator熱門考古題 &新版Marketing-Cloud-Administrat
Posted at 1/9/2026 05:09:35
順便提一下,可以從雲存儲中下載NewDumps Marketing-Cloud-Administrator考試題庫的完整版:https://drive.google.com/open?id=10xo057P_Up28A-0LxS8BaKBrURii788p
NewDumps可以為你提供捷徑,給你節約好多時間和精力換。NewDumps會為你的Salesforce Marketing-Cloud-Administrator認證考試提供很好的培訓工具,有效的幫助你通過Salesforce Marketing-Cloud-Administrator認證考試。如果你在其他網站也看到了可以提供相關資料,你可以繼續往下看,你會發現其實資料主要來源於NewDumps,而且NewDumps提供的資料最全面,而且更新得最快。
NewDumps是個可以滿足很多客戶的需求的網站。有些使用我們類比測試軟體已經通過相關IT認證考試的人成為了NewDumps的回頭客。NewDumps可以提供領先的Salesforce 培訓技術助你通過Salesforce Marketing-Cloud-Administrator 認證考試。
Marketing-Cloud-Administrator熱門考古題:Salesforce Certified Marketing Cloud Administrator Exam確定通過考試,Salesforce 新版Marketing-Cloud-Administrator考古題想通過學習Salesforce的Marketing-Cloud-Administrator認證考試的相關知識來提高自己的技能,讓別人更加認可你嗎?Salesforce的考試可以讓你更好地提升你自己。如果你取得了Marketing-Cloud-Administrator認證考試的資格,那麼你就可以更好地完成你的工作。雖然這個考試很難,但是你準備考試時不用那麼辛苦。使用NewDumps的Marketing-Cloud-Administrator考古題以後你不僅可以一次輕鬆通過考試,還可以掌握考試要求的技能。
最新的 Salesforce Marketers Marketing-Cloud-Administrator 免費考試真題 (Q106-Q111):問題 #106
Northern Trail Outfitters wants to drive additional online sales. They are interested in using Einstein to recommend similar items to customers during the checkout process.
Which two terms would they add to their website to accomplish this?
Choose 2 answers
- A. Collect Code
- B. Email Conversion Code
- C. Recommendation Code
- D. Conversion/Cart Code
答案:C
問題 #107
Choose 2 answers
- A. Conversion/Cart Code
- D. Collect Code
答案:A,D
解題說明:
To use Einstein to recommend similar items to customers during the checkout process, NTO needs to add two types of code to their website: Collect Code and Conversion/Cart Code2. Collect Code tracks customer behavior and preferences on the website, while Conversion/Cart Code tracks purchases and cart additions2. Recommendation Code is used to display product recommendations on the website, not during the checkout process2. Email Conversion Code is used to track conversions from email campaigns, not from website visits2.
問題 #108
An email marketing manager is planning to send a promotional email to one million subscribers.
Which data structure should be used?
- A. Publication List
- B. Group
- C. List
- D. Data Extension
答案:D
解題說明:
To send a promotional email to one million subscribers, NTO should use a data extension as their data structure. A data extension is a table that stores subscriber data in Marketing Cloud. A data extension can store up to 30 million records per data extension and up to 100 million records per account2. A data extension can also support advanced segmentation, personalization, and reporting features for email sends
問題 #109
Northern Trail Outfitters' employees are NOT receiving emails because the messages are being blocked by Spam filters.
How could the Marketing Cloud admin address this issue?
- A. Ensure employees have opted in to the test email list or data extension
- B. Ask employees to use personal email addresses instead of corporate email addresses
- C. Provide the IT team a list of relevant IP Addresses to whitelist in their spam filter
- D. Import employee email addresses into All Subscribers with an "Active status
答案:C
解題說明:
To address the issue of employees not receiving emails because the messages are being blocked by spam filters, the Marketing Cloud admin should provide the IT team a list of relevant IP addresses to whitelist in their spam filter. Whitelisting is a process that allows NTO to specify which IP addresses are trusted and can bypass the spam filter. By providing the IT team a list of relevant IP addresses, such as the ones used by Marketing Cloud to send emails, the admin can ensure that the emails from NTO will not be blocked or marked as spam by the employees' email servers. The other options are incorrect because:
* Import employee email addresses into All Subscribers with an "Active" status. This option will not address the issue, as it only affects the subscription status of the employees in Marketing Cloud, not in their email servers. Importing employee email addresses into All Subscribers with an "Active" status means that NTO can send emails to those employees from Marketing Cloud, but it does not guarantee that the emails will be delivered or received by the employees' email servers.
* Ensure employees have opted in to the test email list or data extension. This option will not address the issue, as it only affects the consent of the employees to receive emails from NTO, not their email servers. Ensuring employees have opted in to the test email list or data extension means that NTO has permission to send emails to those employees, but it does not guarantee that the emails will be delivered or received by the employees' email servers.
* Ask employees to use personal email addresses instead of corporate email addresses. This option will
* not address the issue, as it only shifts the problem from one email server to another, not solving it.
Asking employees to use personal email addresses instead of corporate email addresses means that NTO will send emails to different email servers, but it does not guarantee that those email servers will not block or mark the emails as spam.
問題 #110
Northern Trail Outfitters wants a data model in Marketing Cloud which will prevent them from duplicating, or even triplicating, records.
How should the unique identifier of the data model be setup if the Mobile Push and Email channels are used within the same account?
- A. Use a third-party system to identify and delete duplicate Contact Keys.
- B. Strategically control the Contact Key values and tie records together across channels using this key.
- C. Use the auto-generated keys supplied by Marketing Cloud at time of record creation for each channel used.
- D. Strategically control the Contact Key values in email, but let Marketing Cloud automatically tie records as needed from Mobile Push.
答案:B
解題說明:
The best way to prevent duplicate records in Marketing Cloud is to strategically control the Contact Key values and tie records together across channels using this key. The Contact Key is a unique identifier for each contact in Marketing Cloud, and it can be set by the admin or automatically generated by Marketing Cloud. If the same Contact Key is used for a contact in both email and mobile push channels, then the contact will be unified and not duplicated.
問題 #111
當你準備Marketing-Cloud-Administrator考試的時候,盲目地學習與考試相關的知識是很不理想的學習方法。其實想要通過考試是有竅門的。如果你使用了好的工具,不僅可以節省很多的時間,還能得到輕鬆通過考試的保證。如果你想问什么工具,那当然是NewDumps的Marketing-Cloud-Administrator考古題了。
新版Marketing-Cloud-Administrator考古題: https://www.newdumpspdf.com/Marketing-Cloud-Administrator-exam-new-dumps.html
Marketing-Cloud-Administrator考試名稱:Salesforce Marketers,隨著21世紀資訊時代的洪流到來,人們不斷提高自己的知識來適應這個時代,但遠遠不夠,就IT行業來說,Salesforce的Marketing-Cloud-Administrator考試認證是IT行業必不可少的認證,想要通過這項考試培訓是必須的,因為這項考試是有所困難的,通過了它,就可以受到國際的認可及接受,你將有一個美好的前程及拿著受人矚目的高薪,NewDumps網站有全世界最可靠的IT認證培訓資料,有了它你就可以實現你美好的計畫,我們保證你100%通過認證,參加Salesforce的Marketing-Cloud-Administrator考試認證的考生們,你們還在猶豫什麼呢,趕緊行動吧,我們的NewDumps 新版Marketing-Cloud-Administrator考古題提供的試題及答案和真正的試題有95%的相似性,想要通過Marketing-Cloud-Administrator認證考試並不是僅僅依靠與考試相關的書籍就可以辦到的。
但是首先,該行業及其發展令人著迷,他沒有明確拒絕,這事估計有門,Marketing-Cloud-Administrator考試名稱:Salesforce Marketers,隨著21世紀資訊時代的洪流到來,人們不斷提高自己的知識來適應這個時代,但遠遠不夠,就IT行業來說,Salesforce的Marketing-Cloud-Administrator考試認證是IT行業必不可少的認證,想要通過這項考試培訓是必須的,因為這項考試是有所困難的,通過了它,就可以受到國際的認可及接受,你將有一個美好的前程及拿著受人矚目的高薪,NewDumps網站有全世界最可靠的IT認證培訓資料,有了它你就可以實現你美好的計畫,我們保證你100%通過認證,參加Salesforce的Marketing-Cloud-Administrator考試認證的考生們,你們還在猶豫什麼呢,趕緊行動吧!
使用100%通過率的Salesforce Marketing-Cloud-Administrator熱門考古題學習您的Salesforce Marketing-Cloud-Administrator考試,一定通過我們的NewDumps提供的試題及答案和真正的試題有95%的相似性,想要通過Marketing-Cloud-Administrator認證考試並不是僅僅依靠與考試相關的書籍就可以辦到的,以我們NewDumps在IT行業中的高信譽度可以給你提供100%的保障,為了讓你更安心的選擇購買我們,你可以先嘗試在網上下載我們提供的關於Salesforce Marketing-Cloud-Administrator認證考試的部分考題及答案。
- 最新版的Marketing-Cloud-Administrator熱門考古題,免費下載Marketing-Cloud-Administrator學習資料得到妳想要的Salesforce證書 🔓 ⮆ [url]www.testpdf.net ⮄上的《 Marketing-Cloud-Administrator 》免費下載只需搜尋Marketing-Cloud-Administrator在線考題[/url]
- 一流的Marketing-Cloud-Administrator熱門考古題&保證Salesforce Marketing-Cloud-Administrator考試成功 - 熱門的新版Marketing-Cloud-Administrator考古題 🍳 到《 [url]www.newdumpspdf.com 》搜索➽ Marketing-Cloud-Administrator 🢪輕鬆取得免費下載Marketing-Cloud-Administrator在線考題[/url]
- 確保通過的Marketing-Cloud-Administrator熱門考古題 |第一次嘗試輕鬆學習並通過考試和完美的Marketing-Cloud-Administrator:Salesforce Certified Marketing Cloud Administrator Exam ❗ 到➠ tw.fast2test.com 🠰搜索⏩ Marketing-Cloud-Administrator ⏪輕鬆取得免費下載Marketing-Cloud-Administrator題庫分享
- Marketing-Cloud-Administrator考古題分享 🎈 Marketing-Cloud-Administrator認證題庫 🔹 最新Marketing-Cloud-Administrator題庫資訊 😕 開啟“ [url]www.newdumpspdf.com ”輸入[ Marketing-Cloud-Administrator ]並獲取免費下載Marketing-Cloud-Administrator考古題分享[/url]
- Marketing-Cloud-Administrator題庫下載 ▶ Marketing-Cloud-Administrator考試指南 🟢 Marketing-Cloud-Administrator考試指南 🚂 ✔ [url]www.pdfexamdumps.com ️✔️是獲取☀ Marketing-Cloud-Administrator ️☀️免費下載的最佳網站Marketing-Cloud-Administrator考試內容[/url]
- 最有效的Marketing-Cloud-Administrator熱門考古題,真實還原Salesforce Marketing-Cloud-Administrator考試內容 👭 立即到▶ [url]www.newdumpspdf.com ◀上搜索⮆ Marketing-Cloud-Administrator ⮄以獲取免費下載Marketing-Cloud-Administrator熱門題庫[/url]
- Marketing-Cloud-Administrator在線考題 🐸 Marketing-Cloud-Administrator認證考試 ⭕ Marketing-Cloud-Administrator熱門題庫 😨 複製網址⮆ [url]www.testpdf.net ⮄打開並搜索[ Marketing-Cloud-Administrator ]免費下載Marketing-Cloud-Administrator題庫更新[/url]
- 最新Marketing-Cloud-Administrator題庫 📗 Marketing-Cloud-Administrator認證 😠 Marketing-Cloud-Administrator考試指南 🐄 ▶ [url]www.newdumpspdf.com ◀提供免費➡ Marketing-Cloud-Administrator ️⬅️問題收集Marketing-Cloud-Administrator熱門題庫[/url]
- Marketing-Cloud-Administrator考試內容 🚠 Marketing-Cloud-Administrator題庫下載 🛷 最新Marketing-Cloud-Administrator題庫資訊 🥄 立即打開⇛ tw.fast2test.com ⇚並搜索{ Marketing-Cloud-Administrator }以獲取免費下載Marketing-Cloud-Administrator試題
- 最新Marketing-Cloud-Administrator題庫 🍳 Marketing-Cloud-Administrator考古題分享 🎌 Marketing-Cloud-Administrator證照考試 🐷 到▷ [url]www.newdumpspdf.com ◁搜尋【 Marketing-Cloud-Administrator 】以獲取免費下載考試資料最新Marketing-Cloud-Administrator題庫資源[/url]
- Marketing-Cloud-Administrator熱門題庫 🥺 Marketing-Cloud-Administrator考古題更新 🚜 Marketing-Cloud-Administrator試題 🏮 ⮆ [url]www.vcesoft.com ⮄上搜索“ Marketing-Cloud-Administrator ”輕鬆獲取免費下載Marketing-Cloud-Administrator題庫下載[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, oderasbm.com, faithlife.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, ncon.edu.sa, Disposable vapes
P.S. NewDumps在Google Drive上分享了免費的2026 Salesforce Marketing-Cloud-Administrator考試題庫:https://drive.google.com/open?id=10xo057P_Up28A-0LxS8BaKBrURii788p
