[Linux] MIPI error: err2: 0x00010000
15
Linux MIPI error: err2: 0x00010000
Posted at 10/6/2020 00:08:50      View6717 | Replies8        Print      Only Author   [Copy Link] 1#
I'm trying to get a custom MIPI camera solution going using an OV2740, but I can't get anything out of the ISP. My image sensor is configured for 1920x1080@10bit RAW, at 60 fps, 2 lanes, 400 MHz (800 Mbps) transfer rate. I've tested with 4 lanes at 200 MHz (400 Mbps) with the same problem. I've verified the correct number of lanes are outputting at the correct clock rate using an oscilloscope, so I know the PX30's MIPI PHY should be receiving data, but it seems completely dead.
I tried using gstreamer:
  1. gst-launch-1.0 rkisp device=/dev/video0 io-mode=4 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=60/1 ! kmssink
Copy the code
This produces this output:
  1. [XCORE]:XCAM ERROR rkisp_device.cpp:74: atomisp device (/dev/video0) try subdev format failed
  2. [XCORE]:XCAM ERROR v4l2_device.cpp:618: device(/dev/video0) get dma buf(0) failed
  3. Caught SIGSEGV
  4. exec gdb failed: No such file or directory
Copy the code
I tried testing it with v4l2src instead of rkisp:
  1. gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! kmssink
Copy the code
As well as the qcamera demo and this v4l2-ctl command:
  1. v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080
  2. ,pixelformat=NV12 --stream-mmap=3 --stream-to=/root/raw.out --stream-count=1000
  3. --stream-poll
Copy the code
In any case, I get this output, after enabling (and added) some logging messages:
  1. [  364.391006] rkisp1: waiting on params stream on event timeout
  2. [  364.391597] rkisp1 ff4a0000.rkisp1: can not get first iq setting in stream on
  3. [b][  364.392419] rkisp1: MIPI error: err2: 0x00010000[/b]
  4. [  364.394693] rockchip-mipi-dphy-rx ff2f0000.mipi-dphy-rx0: data rate hsfreq range set to 899 mbps
  5. [  364.395541] rockchip-mipi-dphy-rx ff2f0000.mipi-dphy-rx0: enabled 2 lanes for reception
  6. [  364.396334] ov2740 2-0030: __ov2740_start_stream() called
  7. [  364.396898] ov2740 2-0030: ov2740_set_ctrl() V4L2_CID_VBLANK called
  8. [  364.397504] ov2740 2-0030: ov2740_set_ctrl() V4L2_CID_VBLANK=8
  9. [  364.399508] ov2740 2-0030: ov2740_set_ctrl() V4L2_CID_EXPOSURE=1080
  10. [  364.401722] ov2740 2-0030: ov2740_set_ctrl() V4L2_CID_ANALOGUE_GAIN=16
  11. [  364.402412] ov2740 2-0030: ov2740_set_ctrl() V4L2_CID_TEST_PATTERN called
  12. [  364.403109] ov2740 2-0030: Disabling test pattern
  13. [b]select timeout[/b]
  14. [b][  367.410019] rkisp1: waiting on event return error 0[/b]
  15. [  367.411561] rockchip-mipi-dphy-rx ff2f0000.mipi-dphy-rx0: disabled reception
  16. [  367.412254] ov2740 2-0030: __ov2740_stop_stream() called
  17. [  367.430933] ov2740 2-0030: ov2740_s_power() called
Copy the code
It doesn't matter if I use /dev/video0 or /dev/video1 (main path or self path). I get the same errors.
What should I be looking at to fix this? I looked at Part1 and Part2 of the TRM, but there doesn't appear to be any information about the MIPI D-PHY in it, so I don't know what error code 0x00010000 represents.
I'm using an HTS of 1928 and a VTS of 1088, though the original sample code I received had perplexing HTS/VTS values of 1080 and 1125, respectively. It seems like if it were a timing parameter issue, the ISP would report that, and/or give me a garbled image.
Posted at 10/7/2020 04:57:51        Only Author  2#
I think maybe I was missing MIPI data for a bit while I was testing the other day. I'm now getting MIPI error: err2: 0x00030000. Same symptoms. I tried reducing my settings to 30 fps with a 400 Mbps (200 MHz) MIPI clock, but it's still not working.
Any ideas?
Posted at 1/9/2026 14:27:12        Only Author  3#
XK0-006인증시험은CompTIA사의 인중시험입니다.CompTIA인증사의 시험을 패스한다면 it업계에서의 대우는 달라집니다. 때문에 점점 많은 분들이CompTIA인증XK0-006시험을 응시합니다.하지만 실질적으로XK0-006시험을 패스하시는 분들은 너무 적습니다.전분적인 지식을 터득하면서 완벽한 준비하고 응시하기에는 너무 많은 시간이 필요합니다.하지만 우리KoreaDumps는 이러한 여러분의 시간을 절약해드립니다.
Posted at 1/10/2026 07:48:19        Only Author  4#
Um Ihre Zertifizierungsprfungen reibungslos erfolgreich zu meistern, brauchen Sie nur unsere Prfungsfragen und Antworten zu Databricks Databricks-Certified-Data-Analyst-Associate Databricks Certified Data Analyst Associate Examauswendigzulernen. Viel Erfolg!
Posted at 1/10/2026 08:15:10        Only Author  5#
The article is really inspiring; thank you for sharing! Here are the free Test PRINCE2Practitioner simulator fee materials! Best of luck to everyone!
Posted at 1/10/2026 21:29:15        Only Author  6#
SAP֤äƤuƷʤˤդ路ʤȸФ뤳ȤϤ褯ޤ SAP`˥󥰥ɤʹä뤳Ȥ˛Q᤿ϡ}뤳ȤϛQƤʤȤ򤪁˼ޤ ˽ν̲ĤϡʤڴǤʤC-BCSSS-2502Ʒ|֤äƤޤ ѧ̲ĤΥ󥹤ǽUYeȡǰC-BCSSS-2502rgM䤵餫Positioning SAP Sustainability Solutions as part of SAP Business SuiteMiФ뤳ȤǤޤޤSAPƥȥMiĤȤ狼ޤ
Posted at 1/23/2026 17:56:08        Only Author  7#
That article was a huge benefit to me. Free NSE4_FGT_AD-7.6 valid exam cram pdf resourcesyour key to career advancement and salary growth!
Posted at 1/24/2026 15:50:22        Only Author  8#
JPTestKingϥ֥ȤǤʤaߤΤΌTĤѧĩ`ȤƤʹäǤޤ ˤʤޤNCA-GENLȥ`˥YϤθ߶Ȥ\åƥʹäơNVIDIA͘٤ٶȤ^Ǥʤ͘΂ԄӵĤ˱o뤳ȤǤޤ ˡ؜ΌTåդ٤ƤΤ͘24rgПoݤNCA-GENLԇYNVIDIA Generative AI LLMs}v륪饤󥢥ե``ӥṩޤ ơNCA-GENLѧɤκϸʤ99〜100Ǥ NCA-GENLʂJȡäޤ
Posted at 2/17/2026 21:21:59        Only Author  9#
Thank you for sharing such an insightful and uplifting article! Free Test PSP book test papersyour ticket to promotions and a higher salary!
