[General] Free PDF Quiz High Hit-Rate Salesforce - Test Platform-App-Builder Answers
75
【General】 Free PDF Quiz High Hit-Rate Salesforce - Test Platform-App-Builder Answers
Posted at 1/9/2026 09:42:29      View:143 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest ITdumpsfree Platform-App-Builder PDF Dumps and Platform-App-Builder Exam Engine Free Share: https://drive.google.com/open?id=1Kl7K_Dbra-CjWeNONUnrPrLAcW_Fa4zp
Have you signed up for Salesforce Platform-App-Builder Exam? Will masses of reviewing materials and questions give you a headache? ITdumpsfree can help you to solve this problem. It is absolutely trustworthy website. Only if you choose to use exam dumps ITdumpsfree provides, you can absolutely pass your exam successfully. You spend lots of time on these reviewing materials you don't know whether it is useful to you, rather than experiencing the service ITdumpsfree provides for you. So, hurry to take action.
The Salesforce Platform-App-Builder exam covers a range of topics related to app building on the Salesforce platform, including data modeling, security, user interface design, business logic, and automation. Candidates must demonstrate their understanding of the Salesforce platform and its various features, as well as their ability to use these features to build effective and efficient applications. Platform-App-Builder exam consists of 60 multiple-choice questions and must be completed within two hours.
Salesforce Platform-App-Builder Exam is part of the Salesforce Certified Platform App Builder certification. Salesforce Certified Platform App Builder certification is aimed at individuals who want to demonstrate their skills in building custom applications on the Salesforce platform. Salesforce Certified Platform App Builder certification covers a range of topics, including data modeling, security, user interface design, and business logic.
Valid Platform-App-Builder Test Book & Platform-App-Builder Dump CheckA Salesforce Certified Platform App Builder (Platform-App-Builder) practice questions is a helpful, proven strategy to crack the Salesforce Certified Platform App Builder (Platform-App-Builder) exam successfully. It helps candidates to know their weaknesses and overall performance. ITdumpsfree software has hundreds of Salesforce Certified Platform App Builder (Platform-App-Builder) exam dumps that are useful to practice in real-time. The Salesforce Certified Platform App Builder (Platform-App-Builder) practice questions have a close resemblance with the actual Salesforce Certified Platform App Builder (Platform-App-Builder) exam.
Salesforce Certified Platform App Builder Sample Questions (Q257-Q262):NEW QUESTION # 257
The Service Manager provided the app builder with color code requirements for case age on open cases.
New cases populate a green circle
Day-old cases populate a yellow circle
Three-day-old cases populate a red circle
How should an app builder implement this requirement?
  • A. Lightning Web Component
  • B. Custom Button
  • C. Quick Action
  • D. Formula Field
A formula field is a read-only field that derives its value from a formula expression you define. The formula field is updated when any of the source fields change. You can use formula fields to display images based on certain conditions. In this case, a formula field can be used to display a green, yellow, or red circle image based on the case age.
NEW QUESTION # 258
An app builder wants to streamline the user experience by reflecting summarized calculation of specific fields on various objects.
Which three fields types should be used in roll-up summary fields to accomplish this?
Choose 3 answer
  • A. Date
  • B. Time
  • C. Currency
  • D. Checkbox
  • E. Percent
Answer: A,C,E
NEW QUESTION # 259
Due to the complexity of the Universal Containers sandbox release schedule and requirements, it is advised that change sets are used as often as possible to migrate from one environment to another.
Which three common items can an app builder move when using a change set?
Choose 3 answers
  • A. Web-to-lead
  • B. Apex class
  • C. Standard fields
  • D. Custom field
  • E. Custom object
Answer: B,D,E
The common items that can be moved using a change set are custom object, Apex class, and custom field.
These are metadata components that can be deployed from one environment to another using change sets.
Web-to-lead and standard fields are not metadata components that can be moved using change sets.
NEW QUESTION # 260
Universal Containers has a custom assessment object used by three divisions. Each division wants to track different information on the assessments, including different values for the status picklist. Division managers do not want their teams to be able to create another division's assessment.
How can this be accomplished?
  • A. Create additional custom assessment objects, one for each division, to track their assessments so information can be tracked separately. Use profiles to restrict access to the three custom objects.
  • B. Create separate assessment record types for each division and use them to limit picklist values. Create separate page layouts for each record type and use profiles to restrict record type access.
  • C. Create three page layouts to determine the fields and picklist values for each user based on the division indicated on their user record. Use field-level security to restrict access to each division's fields.
  • D. Create a separate page layout for each division and assign them profiles. Use the profile setting to configure each division's custom field list and picklist values for assessments.
NEW QUESTION # 261
Universal Containers created a 'New Task' custom action on the Opportunity object. The action was added to all page layouts in the Mobile & Lightning Actions section.
Which Lightning component should the app builder add to the layout to display the action?
  • A. Activities
  • B. Related lists
  • C. Highlights panel
  • D. Related record
The best Lightning component to add to the layout to display the 'New Task' custom action is Highlights panel. This component shows key information and actions for a record, such as its name, owner, and custom actions. Related record, related lists, and activities are not Lightning components that display custom actions.
See [this article] for more information on Highlights panel.
NEW QUESTION # 262
The Platform-App-Builder Exam practice software is based on the real Platform-App-Builder exam dumps. The interface of Platform-App-Builder exam practice software is user-friendly so you will not face any difficulty to become familiar with it. Practice test software contains simulated real Platform-App-Builder exam scenario. It has numerous self-learning and self-assessment features to test their learning. Our software exam offers you statistical reports which will upkeep the students to find their weak areas and work on them. We guarantee if you trust the Platform-App-Builder Exam Practice test software, getting the highest score in the actual Platform-App-Builder exam will not be difficult anymore.
Valid Platform-App-Builder Test Book: https://www.itdumpsfree.com/Platform-App-Builder-exam-passed.html
What's more, part of that ITdumpsfree Platform-App-Builder dumps now are free: https://drive.google.com/open?id=1Kl7K_Dbra-CjWeNONUnrPrLAcW_Fa4zp
Posted at 1/14/2026 23:27:24        Only Author  2#
The article is truly inspiring, thank you for posting it! The XSIAM-Engineer test notes test questions are free for all—your key to a successful career!
Posted at 1/26/2026 18:26:29        Only Author  3#
Wenn Sie PrüfungFrage wählen, versprechen wir Ihnen eine 100%-Pass-Garantie zur Amazon AWS-Certified-Developer-Associate Zertifizierungsprüfung. Sonst erstatteten wir Ihnen Ihre an uns geleisteten Zahlung.
