{Enjoy 50% Discount} On Oracle 1Z0-1042-25 Questions With {Free 365-days Updates
Posted at 1/9/2026 10:42:23
View460
Replies9
DOWNLOAD the newest Itcerttest 1Z0-1042-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1M2i79y_DEaxw8IhSO14PLS6TohfOVAKY
Once the clients order our 1Z0-1042-25 cram training materials we will send the 1Z0-1042-25 exam questions quickly by mails. The clients abroad only need to fill in correct mails and then they get our 1Z0-1042-25 training guide conveniently. Our 1Z0-1042-25 cram training materials provide the version with the language domestically and the version with the foreign countries' language so that the clients at home and abroad can use our 1Z0-1042-25 Study Tool conveniently. And after study for 20 to 30 hours, you can pass the 1Z0-1042-25 exam with ease.
Oracle 1Z0-1042-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
| | Topic 2 | - Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
| | Topic 3 | - Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
| | Topic 4 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
| | Topic 5 | - Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OICs integration capabilities.
1Z0-1042-25 Brain Dump Free | Latest 1Z0-1042-25: Oracle Cloud Infrastructure 2025 Application Integration Professional 100% PassOur 1Z0-1042-25 exam torrent is finalized after being approved by industry experts and 1Z0-1042-25 Practice Materials are tested by professionals with a high pass rate as 99%. Besides, 1Z0-1042-25 Learning Guide helps establish your confidence and avoid wasting time. That is because our 1Z0-1042-25 Practice Test can serve as a conducive tool for you make up for those hot points you have ignored, you will have every needed 1Z0-1042-25 exam questions and answers in the actual exam to pass it.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q32-Q37):NEW QUESTION # 32
CSV-formatted data has been extracted from ERP Cloud by invoking a web service using the SOAP Adapter, and the data extracted has been returned as an MTOM attachment. You now need to send this CSV file to an external REST API that supports accepting this content as a Base64 encoded string. Which XPath mapper function should be used to map the SOAP MTOM attachment to the Base64 element present in the target REST API payloads?
- A. decodeBase64
- B. decodeBase64ToReference
- C. encodeBase64
- D. encodeReferenceToBase64
Transforming MTOM to Base64:
C:encodeReferenceToBase64 converts an MTOM attachment reference to Base64, ideal for REST payloads.
NEW QUESTION # 33
You need to create an Oracle Integration (OIC) integration that processes many records individually that are contained within a single large file. You have been advised to use an implementation approach that uses the Download File operation of an FTP adapter in conjunction with the Stage File action Read File in Segments operation to mitigate issues with memory consumption. When using this approach, which is a valid consideration regarding the use of the Read File in Segments operation?
- A. You must provide the actual filename because file references cannot be processed by the Read File in Segments operation.
- B. The Read File in Segments operation allows you to process the segments sequentially or in parallel.
- C. Segment sizes can be configured from 1-200 records.
- D. You need to explicitly configure a Scope action for this operation if you want to add additional actions during the processing of each segment.
Segmented Processing:
A:True-Scope required for custom actions.
NEW QUESTION # 34
Which Oracle Integration Cloud (OIC) XPath function can be used to retrieve data from an OIC lookup within the Data Mapper tool?
- A. getLookup
- B. get-value-from-lookup
- C. get-content-as-string
- D. lookupValue
In OIC's Data Mapper, XPath functions handle transformations:
Option B:lookupValue is the correct function to retrieve values from a lookup table, taking parameters like lookup name and key.
Option A:Not a valid OIC function.
Option C:get-content-as-string processes content, not lookups.
Option D:getLookup doesn't exist; the function is lookupValue.
B is the standard method for lookup access.
NEW QUESTION # 35
Which four are key features of Oracle Integration Cloud Enterprise (OIC)?
- A. OCI VPC endpoints
- B. Business to Business (B2B)
- C. Web and Mobile application creation
- D. Application Integration
- E. Data stream analytics
- F. Enterprise Service Bus (ESB)
Answer: B,D,E,F
The four key features of Oracle Integration Cloud Enterprise (OIC) are:
Application Integration: OIC excels at integrating various applications, on-premises systems, and cloud services.
Enterprise Service Bus (ESB): OIC provides a central hub for managing communication between services, enabling message routing, transformation, and security enforcement.
Business to Business (B2B): OIC enables secure and reliable B2B communication.
Stream Analytics: OIC includes Stream Analytics, which allows real-time event analysis in Apache Spark-based systems.
Web and Mobile Application Creation is not a direct feature of OIC.
OCI VPC Endpoints enhance security but are not core to OIC itself.
NEW QUESTION # 36
Your organization maintains two SOA cloud service instances used separately for testing and production. What is the best practice for defining the property values and endpoint addresses unique to each environment when deploying the same SOA composite application archive to both instances?
- A. You cannot deploy the same archive to two different environments. Define the specific properties and endpoint addresses statically within two separate SOA archives.
- B. Edit each application's deployment descriptor to dynamically retrieve values for properties and endpoint addresses from the environment upon deployment.
- C. Create two separate configuration plans that contain the environment-specific values and then associate the appropriate plan with the SOA archive deployment.
- D. Manually update any required values for unique properties or endpoint addresses in Fusion Middleware Control following deployment.
Creating two separate configuration plans for each environment is the best practice. This keeps environment-specific details separate from the SOA archive and promotes reusability and maintainability. Other methods are error-prone or inefficient.
NEW QUESTION # 37
If you want to sharpen your skills, and get the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) certification done within the target period, it is important to get the best Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam questions. You must try the Itcerttest Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) practice exam that will help you get the Oracle 1Z0-1042-25 Certification. Itcerttest hires the top industry experts to draft the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam dumps and help the candidates to clear their Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam easily. Itcerttest plays a vital role in their journey to get the 1Z0-1042-25 certification.
1Z0-1042-25 Reliable Exam Dumps: https://www.itcerttest.com/1Z0-1042-25_braindumps.html
- Exam 1Z0-1042-25 Testking 🔖 Vce 1Z0-1042-25 Exam 🔫 Reliable 1Z0-1042-25 Dumps Ebook 🚎 Open [url]www.testkingpass.com and search for ➤ 1Z0-1042-25 ⮘ to download exam materials for free 🍃Reliable 1Z0-1042-25 Dumps Ebook[/url]
- Guaranteed 1Z0-1042-25 Success 🍛 Free 1Z0-1042-25 Test Questions 🚠 Reliable 1Z0-1042-25 Guide Files 🗣 [url]www.pdfvce.com is best website to obtain ✔ 1Z0-1042-25 ️✔️ for free download 🍟Reliable 1Z0-1042-25 Dumps Ebook[/url]
- Start Exam Preparation with Real and Valid Oracle 1Z0-1042-25 Exam Questions 🤣 Download 1Z0-1042-25 for free by simply entering [url]www.dumpsquestion.com website 🔘1Z0-1042-25 Test Review[/url]
- New 1Z0-1042-25 Test Experience 🍇 1Z0-1042-25 Test Review 🕳 Reliable 1Z0-1042-25 Dumps Ebook 😜 The page for free download of ➠ 1Z0-1042-25 🠰 on [url]www.pdfvce.com will open immediately ❣1Z0-1042-25 Exam Vce Free[/url]
- New Soft 1Z0-1042-25 Simulations 🧯 1Z0-1042-25 Latest Test Questions 🥕 1Z0-1042-25 Exam Vce Free 🔪 The page for free download of ➤ 1Z0-1042-25 ⮘ on [url]www.vce4dumps.com will open immediately 🌈New Soft 1Z0-1042-25 Simulations[/url]
- Quiz Marvelous 1Z0-1042-25 - Oracle Cloud Infrastructure 2025 Application Integration Professional Brain Dump Free 🟫 Download 1Z0-1042-25 for free by simply searching on [url]www.pdfvce.com 🐊New 1Z0-1042-25 Test Experience[/url]
- Start Exam Preparation with Real and Valid Oracle 1Z0-1042-25 Exam Questions 🚏 Open ⇛ [url]www.vce4dumps.com ⇚ and search for { 1Z0-1042-25 } to download exam materials for free 🍌1Z0-1042-25 Study Guide[/url]
- Exam 1Z0-1042-25 Testking 🧉 1Z0-1042-25 Exam Certification Cost 🩺 Reliable 1Z0-1042-25 Dumps Ebook 😄 Easily obtain 1Z0-1042-25 for free download through ▷ [url]www.pdfvce.com ◁ 🚠Reliable 1Z0-1042-25 Dumps Ebook[/url]
- Fantastic Oracle 1Z0-1042-25 Brain Dump Free | Try Free Demo before Purchase 📰 Easily obtain ⮆ 1Z0-1042-25 ⮄ for free download through [url]www.exam4labs.com 👯1Z0-1042-25 Valid Test Experience[/url]
- Reliable 1Z0-1042-25 Dumps Ebook 🥼 New 1Z0-1042-25 Test Experience 🧪 1Z0-1042-25 Valid Test Experience 🗼 Search for ▷ 1Z0-1042-25 ◁ and download it for free on [url]www.pdfvce.com website 🤞1Z0-1042-25 Latest Test Questions[/url]
- 1Z0-1042-25 Test Review 🎤 1Z0-1042-25 Latest Test Questions 🕌 Reliable 1Z0-1042-25 Study Notes 🪔 Open ▶ [url]www.practicevce.com ◀ and search for ▷ 1Z0-1042-25 ◁ to download exam materials for free 💒1Z0-1042-25 Study Guide[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, pastebin.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, mavenmarg.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Itcerttest 1Z0-1042-25 dumps from Cloud Storage: https://drive.google.com/open?id=1M2i79y_DEaxw8IhSO14PLS6TohfOVAKY
