Plat-Admn-301独学書籍、Plat-Admn-301サンプル問題集
Posted at 1/9/2026 11:10:51
Plat-Admn-301の実際の学習ガイド資料は、より良いレビューを得るのに役立ちます。これは非常に直感的な標準ですが、包括的ではない場合があるため、テストPlat-Admn-301認定を取得することの重要性を知っておく必要があります。自分の能力を証明するのに十分な資格を持っている場合にのみ、厳しい現実の中で敵を打ち負かすことができます。 Plat-Admn-301の実際の質問は、Plat-Admn-301認定試験に合格し、認定資格をより迅速かつ効率的に取得するのに役立つと考えています。
Salesforce Plat-Admn-301 認定試験の出題範囲:| トピック | 出題範囲 | | トピック 1 | - Data and Analytics Management: This section of the exam measures skills of Salesforce Data Analyst and covers data quality assessment, data enrichment, and duplicate management. It explains how to choose appropriate reporting and analytics tools for advanced requirements, including custom report types, snapshots, formulas, joined reports, and dashboard configurations. It also covers methods for connecting external data sources using big objects, external objects, data warehouses, data lakes, and Salesforce Connect. Finally, it describes the suitable tools and methods for importing data, including Data Loader, Data Import Wizard, and external IDs.
| | トピック 2 | - Security and Access: This section of the exam measures the skills of Salesforce Administrator and covers how record-level access, field access, and sharing models impact data visibility across the system. It focuses on understanding controlled-by-parent relationships, territory management, role hierarchies, and access to reports, dashboards, and email folders. It also includes comparing custom profiles, permission sets, and delegated administration, along with evaluating different authentication methods. The section also addresses the structure of business models such as person accounts, standard accounts, contacts, and contact-to-multiple-account relationships.
| | トピック 3 | - Objects and Applications: This section of the exam measures the skills of a Salesforce Business Analyst and covers selecting appropriate object and application-level solutions to meet business needs. It focuses on identifying when to use master-detail relationships, lookups, junction objects, related lists, record types, Schema Builder, and Object Creator. The section also includes improving UI and user experience using App Manager, Lightning App Builder, Dynamic Forms, standard Lightning components, console apps, and tools like the Lightning page analyze button.
| | トピック 4 | - Auditing and Monitoring: This section of the exam measures skills of a Salesforce Support Specialist and covers the tools used to monitor system behavior and review user activity. It includes understanding debug logs, setup audit trail, and methods for ensuring sensitive data is handled correctly in both production and sandbox environments. It also explains how to review and troubleshoot security settings, including recognizing pending updates that might affect system access.
| | トピック 5 | - Cloud Applications: This section of the exam measures skills of Salesforce Consultant and covers the standard Salesforce capabilities that support sales and service operations. It includes features such as products, price books, schedules, orders, quotes, and the tools that help with forecasting and territory management. The section also describes how to create Salesforce Knowledge articles, manage entitlements, support service workflows, and enable interactions through chat, case feed, Omni-Channel, console apps, and Experience Cloud sites. It also introduces the broader Salesforce suite that extends core platform functionality.
実用的Plat-Admn-301独学書籍 & 資格試験のリーダー & 人気の有るPlat-Admn-301: Salesforce Certified Platform Administrator IIユーザーに多くの不必要なトラブルを保存するために、オンライン学習プラットフォームのPlat-Admn-301研究質問の研究と開発を完了しました。ユーザーはダウンロードしてインストールする必要はなく、デジタルデバイスにブラウザーがあれば必要です。 Plat-Admn-301テストガイドのオンライン操作。この種の学習方法は、特にPlat-Admn-301認定を取得するペースが速いときに、ユーザーにとって非常に便利です。 Plat-Admn-301トレーニング資料を使用すると、Plat-Admn-301学習資料のすべての操作を完全に適用できます。
Salesforce Certified Platform Administrator II 認定 Plat-Admn-301 試験問題 (Q49-Q54):質問 # 49
A user at Cloud Kicks has informed the administrator that they are unable to log in to Salesforce via multi- factor authentication.
Which two area should the administrator review to understand potential root causes?
Choose 2 answers
- A. Debug Logs
- B. Identity Verification History
- C. Login History
- D. Setup Audit Trail
正解:B、C
Identity verification history and login history are two areas that the administrator can review to understand potential root causes of multi-factor authentication issues. Identity verification history shows the methods and results of identity verification attempts for a user, such as email verification, SMS verification, or app verification. Login history shows the status, source, and location of login attempts for a user, as well as any login errors or challenges that occurred. These two areas can help the administrator identify if the user entered the correct verification code, if the user's device or app is compatible with multi-factor authentication, or if there are any network or security issues that prevent successful verification. References: https://help.
salesforce.com/s/articleView?id=sf.identity_verification_history.htm&type=5 https://help.salesforce.com/s
/articleView?id=sf.monitoring_login_history.htm&type=5
質問 # 50
Cloud Kicks (CK) has a filed called Shoe Type Preference, CK,s product team wants to see a report that groups specific picklist values together into the one of two lists.
What functionality should the administrator use to fulfill the team's request?
- A. Matrix Report
- B. Bucket field
- C. PREVGROUPVALUE
- D. Summary Formula
Bucket field is a feature that allows administrators to group report values into categories without changing the data in Salesforce. Bucket field can help simplify reports and charts by reducing the number of values displayed and summarizing data based on criteria such as ranges or groups. Bucket field can be used to group specific picklist values together into one of two lists
質問 # 51
Cloud Kicks has two record-triggered flows on the same object. One flow creates a child record when criteria are met. The second record-triggered flow is based on criteria to check if the child record exists and updates a field. The field on the child record that needs to be updated Is still null after the second record trigger.
What should the administrator do to resolve this issue?
- A. Have the record-triggered flows fire on create or edit to update the field.
- B. Combine the two flows into one with checks to see which part of the flow needs to be run.
- C. flows into schedule flows and have them update the field.
- D. Make a new record-triggered flow on the child object to update the field on the parent record.
Flows are tools that automate business processes by collecting data and performing actions in your org or an external system. Flows can be triggered by various events such as record creation, updates, or invocations from other processes or flows. Flows can also have decision elements that evaluate conditions and determine which path to follow in the flow. By combining the two flows into one with decision elements, the administrator can ensure that the flow runs in the correct order and updates the field on the child record after it is created by the first flow. References: https://help.salesforce.com/s/articleView?id=sf.flow_concepts.
htm&type=5 https://help.salesforce.com/s/ar ... sion.htm&type=5
質問 # 52
An administrator at Clod Kicks has build a flow that delivers status update email to customers. Recently, there's been an increasae in support cases from customers reporting they had not received the email.
Where should the administrator look to investigate the issue?
- A. Email Logs
- B. Process Automation Setting
- C. Paused Flow Interviews
Email logs are files that provide information about email delivery and activity in your Salesforce org. Email logs contain details such as sender, recipient, subject, date, status, error code, and more for each email sent or received within a specified time range. You can use email logs to investigate issues with email delivery or performance in your org. In this case, you can use email logs to check if the status update emails were sent successfully or if there were any errors or failures. References: https://help.salesforce.com/s/articleView?id=sf.
email_logs.htm&type=5 https://help.salesforce.com/s/ar ... rmat.htm&type=5
質問 # 53
An administrator has created a flow that sends platform events whenever an opportunity is updated. An Apex developer has been tasked to write code that listens for these events. When reviewing the debug logs for a user, the developer can see that the flow ran, but the debug Information is missing.
What should the administrator recommend to assist with debugging?
- A. Set a debug log on the Automated Process entity.
- B. Platform events are unavailable for debugging.
- C. Select the Debug Enabled checkbox on platform events,
- D. Search the AppExchange to And a tool that assists with debugging.
To debug platform events in Apex code, you need to set a debug log on the Automated Process entity. This entity represents an automated process user that runs flows and processes in your org. By setting a debug log on this entity, you can capture the events that are published and consumed by your flow and Apex code, as well as any errors or exceptions that occur during the execution. References: https://developer.salesforce.com
/docs/atlas.en-us.platform_events.meta/platform_events/platform_events_debug.htm https://help.salesforce.
com/s/articleView?id=sf.code_add_users_debug_log.htm&type=5
質問 # 54
各製品には試用版があり、当社の製品も例外ではありません。つまり、Plat-Admn-301準備ガイドのWebサイトを閲覧すると、Plat-Admn-301ガイド急流が無料のデモを提供できることを意味します。お客様が事前に当社の製品について理解を深めることができます。さらに、スケジュールよりも前に進んでいる場合は、Plat-Admn-301試験トレントがあなたに適しているかどうかを検討できます。
Plat-Admn-301サンプル問題集: https://www.xhs1991.com/Plat-Admn-301.html
- 権威のあるPlat-Admn-301独学書籍 - 合格スムーズPlat-Admn-301サンプル問題集 | 正確的なPlat-Admn-301認定資格 🐉 ➤ [url]www.xhs1991.com ⮘には無料の➡ Plat-Admn-301 ️⬅️問題集がありますPlat-Admn-301日本語版復習指南[/url]
- 実用的-最新のPlat-Admn-301独学書籍試験-試験の準備方法Plat-Admn-301サンプル問題集 🚙 今すぐ【 [url]www.goshiken.com 】で⇛ Plat-Admn-301 ⇚を検索して、無料でダウンロードしてくださいPlat-Admn-301日本語版復習指南[/url]
- Plat-Admn-301日本語版参考書 🦼 Plat-Admn-301最速合格 🎀 Plat-Admn-301オンライン試験 🔯 ⇛ [url]www.mogiexam.com ⇚を入力して( Plat-Admn-301 )を検索し、無料でダウンロードしてくださいPlat-Admn-301コンポーネント[/url]
- 信頼できるPlat-Admn-301独学書籍一回合格-高品質なPlat-Admn-301サンプル問題集 🔑 ( Plat-Admn-301 )の試験問題は⏩ [url]www.goshiken.com ⏪で無料配信中Plat-Admn-301日本語版対応参考書[/url]
- Plat-Admn-301日本語版対応参考書 🦠 Plat-Admn-301日本語対策 🏐 Plat-Admn-301日本語版復習指南 🕙 ウェブサイト( [url]www.shikenpass.com )を開き、➤ Plat-Admn-301 ⮘を検索して無料でダウンロードしてくださいPlat-Admn-301日本語対策[/url]
- Plat-Admn-301日本語版対応参考書 🙇 Plat-Admn-301認証試験 👼 Plat-Admn-301日本語版対応参考書 🐚 最新➽ Plat-Admn-301 🢪問題集ファイルは➥ [url]www.goshiken.com 🡄にて検索Plat-Admn-301日本語版参考書[/url]
- 試験の準備方法-認定するPlat-Admn-301独学書籍試験-実際的なPlat-Admn-301サンプル問題集 🦌 【 [url]www.passtest.jp 】で使える無料オンライン版“ Plat-Admn-301 ” の試験問題Plat-Admn-301ソフトウエア[/url]
- Plat-Admn-301認証試験 🧚 Plat-Admn-301日本語版復習指南 🔱 Plat-Admn-301ソフトウエア 🐯 【 [url]www.goshiken.com 】で▶ Plat-Admn-301 ◀を検索し、無料でダウンロードしてくださいPlat-Admn-301日本語版対応参考書[/url]
- 試験の準備方法-実用的なPlat-Admn-301独学書籍試験-効率的なPlat-Admn-301サンプル問題集 ☑ 「 [url]www.jptestking.com 」にて限定無料の[ Plat-Admn-301 ]問題集をダウンロードせよPlat-Admn-301ソフトウエア[/url]
- Plat-Admn-301日本語版参考書 😪 Plat-Admn-301日本語対策 🕧 Plat-Admn-301認証試験 📉 “ [url]www.goshiken.com ”の無料ダウンロード⮆ Plat-Admn-301 ⮄ページが開きますPlat-Admn-301日本語対策[/url]
- Plat-Admn-301最新な問題集 ☂ Plat-Admn-301最速合格 🤬 Plat-Admn-301ソフトウエア 🔖 最新▛ Plat-Admn-301 ▟問題集ファイルは⇛ [url]www.mogiexam.com ⇚にて検索Plat-Admn-301最速合格[/url]
- www.stes.tyc.edu.tw, edusq.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.wcs.edu.eu, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, building.lv, Disposable vapes
