[General] SPLK-3002 Valid Test Cram | SPLK-3002 Valid Test Notes
85
General SPLK-3002 Valid Test Cram | SPLK-3002 Valid Test Notes
Posted at 1/9/2026 11:20:08      View295 | Replies6        Print      Only Author   [Copy Link] 1#
P.S. Free & New SPLK-3002 dumps are available on Google Drive shared by VCEPrep: https://drive.google.com/open?id=1y63AQeV84ocjJwg6IN0qzr39IF7ocoaW
SPLK-3002 dump at VCEPrep are always kept up to date. Every addition or subtraction of SPLK-3002 exam questions in the exam syllabus is updated in our brain dumps instantly. Practice on real SPLK-3002 exam questions and we have provided their answers too for your convenience. If you put just a bit of extra effort, you can score the highest possible score in the Real SPLK-3002 Exam because our SPLK-3002 exam preparation dumps are designed for the best results.
To prepare for the SPLK-3002 Exam, candidates can take the Splunk IT Service Intelligence Fundamentals course or the Splunk IT Service Intelligence Admin course. SPLK-3002 courses provide comprehensive training in using ITSI to manage IT services, and they cover all the topics tested in the exam. Additionally, candidates can take practice exams and review the Splunk documentation to reinforce their knowledge.
Take Your Splunk SPLK-3002 Practice Exam In Different FormatsYou know, the SPLK-3002 certification is tough and difficult IT certification. In order to get a better life, many people as you still want to chase after it. There is a useful and reliable study material of Splunk SPLK-3002 actual test for you. The SPLK-3002 Pdf Dumps will teach you the basic technology and tell you how to affectively prepare for the SPLK-3002 real test. In a word, SPLK-3002 updated dumps is the best reference for you preparation.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q34-Q39):NEW QUESTION # 34
Which of the following is a characteristic of base searches?
  • A. It is possible to filter to entities assigned to the service for calculating the metrics for the service's KPIs.
  • B. Search expression, entity splitting rules, and thresholds are configured at the base search level.
  • C. The base search will execute whether or not a KPI needs it.
  • D. The fewer KPIs that share a common base search, the more efficiency a base search provides, and anomaly detection is more efficient.
A base search is a search definition that can be shared across multiple KPIs that use the same data source. Base searches can improve search performance and reduce search load by consolidating multiple similar KPIs. One of the characteristics of base searches is that it is possible to filter to entities assigned to the service for calculating the metrics for the service's KPIs. This means that you can use entity filtering rules to specify which entities are relevant for each KPI based on the base search results. Reference: Create KPI base searches in ITSI, [Filter entities for KPIs based on base searches]
NEW QUESTION # 35
Reference: https://docs.splunk.com/Documentation/ITSI/4.10.2/SI/BaseSearch A base search is a search definition that can be shared across multiple KPIs that use the same data source.
Base searches can improve search performance and reduce search load by consolidating multiple similar KPIs. One of the characteristics of base searches is that it is possible to filter to entities assigned to the service for calculating the metrics for the service's KPIs. This means that you can use entity filtering rules to specify which entities are relevant for each KPI based on the base search results. References: Create KPI base searches in ITSI, [Filter entities for KPIs based on base searches]
NEW QUESTION # 36
Where are KPI search results stored?
  • A. The default index.
  • B. Output to a CSV lookup.
  • C. KV Store.
  • D. The itsi_summary index.
Search results are processed, created, and written to the itsi_summary index via an alert action.
NEW QUESTION # 37
There are two departments using ITSI. Finance and Sales. Analysts in each department should not be allowed to see each other's services. What are the role configuration steps required to accomplish this?
  • A. itoa_finance_admin, inherited from itoa_team_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_analyst.
  • B. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_team_analyst.
  • C. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_analyst.
  • D. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_team_analyst; itoa_sales_analyst, inherited from itoa_team_analyst.
C is the correct answer because teams are a feature of ITSI that allow you to restrict access to service content in UI views based on user roles. To create separate teams for finance and sales analysts, you need to create custom roles that inherit from the itoa_analyst role, which has read-only access to ITSI content. For example, you can create itoa_finance_analyst and itoa_sales_analyst roles that inherit from itoa_analyst. Then, you need to create custom teams that include these roles and assign them to the relevant services. For example, you can create a finance team that includes the itoa_finance_analyst role and assign it to the finance services.
Similarly, you can create a sales team that includes the itoa_sales_analyst role and assign it to the sales services. This way, analysts in each department can only see their own services and not each other's.
References: Create teams in ITSI, Assign teams to services in ITSI
NEW QUESTION # 38
Which of the following best describes a default deep dive?
  • A. It initially shows all of the KPIs for a selected service.
  • B. It initially shows all the entity swim lanes.
  • C. It initially shows the health scores for all services.
  • D. It initially shows the highest importance KPIs.
Reference: https://docs.splunk.com/Documentation/ITSI/4.10.2/SI/DeepDives C is the correct answer because a default deep dive initially shows all of the KPIs for a selected service. You can create a default deep dive by drilling down from another dashboard or by selecting a service from the deep dive lister page. A default deep dive does not show health scores, importance scores, or entity swim lanes by default. References: [Create default deep dives for services in ITSI]
NEW QUESTION # 39
We all harness talents with processional skills. Mastering the certificate of the SPLK-3002 practice exam is essential for you. With all instability of the society, those knowledge and profession certificate mean a lot for you. So it is unquestionable the SPLK-3002 learning questions of ours can do a big favor. And we have become the most popular exam braindumps provider in this career and supported by numerous of our loyal customers. You will be satisfied with our SPLK-3002 study guide as well.
SPLK-3002 Valid Test Notes: https://www.vceprep.com/SPLK-3002-latest-vce-prep.html
Posted at 1/14/2026 09:00:03        Only Author  2#
That article was a huge benefit to me. Upgrade your IT expertise with free FCSS_SDW_AR-7.4 reliable test sims. Wishing you success!
Posted at 1/19/2026 01:18:47        Only Author  3#
Tech4Exam饤ȤC-BCBTM-2502ѧYϤ3ĤΥЩ`ṩPDFЩ`PCЩ`APP饤Щ`󤬺ޤޤ ʤЩ`ϡSAPԤȥ᥽åɤʹäѺޤ C-BCBTM-2502ԇYȥȤݤͬǤ饤ȤȤˮʤЩ`mƤޤ ȤСPCЩ`C-BCBTM-2502ѧ̲ĤϡWindowsƥdԥ``򥵥ݩ`ȤޤˤϡgHβԇYh򥷥ߥ`ȤԇY򥷥ߥ`ȤǤg޶ԇY˲μӤǤ뤳ȤǤ ơЩ`󤬺ΤǤ졢``Է֤ϲӤC-BCBTM-2502SAP Certified Associate - Positioning SAP Business Transformation Management Solutionsɼѧ֤ȤǤޤ ȥȻشͬǤꡢԥ``ޤЯԒޤϥåץȥåפuƷʹäǤޤ
Posted at 1/21/2026 03:37:34        Only Author  4#
Thank you for your article, it truly shocked me! The High CAS-004 quality test played a big part in my career growth, and Im offering it to you for free today!
Posted at 2/4/2026 16:43:56        Only Author  5#
The content of the article is very practical, and I have gained a lot of knowledge. Unlock your potential with free 1Z0-340-25 valid exam study guide questionspromotion and salary increases await!
Posted at 2/7/2026 15:25:02        Only Author  6#
This article is truly exceptional, thank you for sharing it with us. Dont miss out on the GNFA latest exam study guide questionsfree and essential for your promotion and salary increase!
Posted at 2/23/2026 05:29:31        Only Author  7#
Im deeply grateful for your article, it was truly eye-opening. Ready for the C_THR81_2505 download demo exam C hope I pass with flying colors!
