PDII Top Dumps - PDII Brain Dumps
91
Posted at 1/9/2026 11:25:07      View:135 | Replies:4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TopExamCollection PDII dumps for free: https://drive.google.com/open?id=15-lXhXKl41jhMl6anFI7_tyonTPXPD-Y
Perhaps you are in a bad condition and need help to solve all the troubles. Don’t worry, once you realize economic freedom, nothing can disturb your life. Our PDII exam questions can help you out. Learning is the best way to make money. So you need to learn our PDII guide materials carefully after you have paid for them. And in fact, our PDII Practice Braindumps are quite interesting and enjoyable for our professionals have compiled them carefully with the latest information and also designed them to different versions to your needs.
As long as you free download the demos of our PDII exam braindumps, you will be surprised by the high quality. It is all about the superior concrete and precision of our PDII learning quiz that help. Every page and every points of knowledge have been written from professional experts who are proficient in this line who are being accounting for this line over ten years. Come and buy our PDII Study Guide, you will be benefited from it.
Free PDF Quiz PDII - Platform Developer II –The Best Top DumpsWith decades years in IT industry, TopExamCollection has gain millions of successful customers as for its high quality exam dumps. Now, Salesforce PDII study practice cram will give you new directions and help you to get your PDII certification in the easiest and fastest way. All the questions are selected from the PDII Original Questions pool, and then compiled and verified by our IT professionals for several times checkout. We promise you 100% pass rate.
Salesforce Platform Developer II Sample Questions (Q119-Q124):NEW QUESTION # 119
Which three actions must be completed in a Lightning web component for a JavaScript file In a static resource to be loaded? Choose 3 answers
  • A. Append the static resource to the DOM.
  • B. Import the static resource.
  • C. Call loadScript.
  • D. Import a method from the platformResourceLoader.
  • E. Reference the static resource in a <script> tag.
Answer: B,C,D
NEW QUESTION # 120
0f Universal Containers uses Big Objects to store almost a billion customer transactions called Customer_Transaction__b. These are the fields on Customer_Transaction__b: Account__c Program__c Points_Earned__c Location__c Transaction_Date__c The following fields have been identified as Index Fields for the Customer_Transaction__b object: Account__c, Program__c, and Transaction_Date__c. Which SOQL query is valid on the Customer_Transaction__b Big Object?
  • A. SELECT Account__c, Program__c, Transaction_Date__c FROM Customer_Transaction__b
    WHERE Account__c = '001R000000302D3' AND Program__c ='Shoppers' AND
    Transaction_Date__c=2019-05-31T00:00Z
  • B. SELECT Account__c, Program__c, Transaction_Date__c FROM Customer_Transaction__b WHERE
    Account__c = '001R000000302D3' AND Program__c INCLUDES ('Shoppers', 'Womens') AND
  • C. SELECT Account__c, Program__c, Transaction_Date__c FROM Customer_Transaction__b WHERE
    Account__c = '001R000000302D3' AND Program__c LIKE 'Shop%' AND Transaction_Date__c=2019-05-31T00:00Z
  • D. SELECT Account__c, Program__c, Transaction_Date__c FROM Customer_Transaction__b WHERE
    Account__c = '001R000000302D3' AND Program__c EXCLUDES ('Shoppers', 'Womens') AND
NEW QUESTION # 121
Universal Containers is leading a development team that follows the source-driven development approach in Salesforce. As part of their continuous integration and delivery (CL/CD) process, they need to automatically deploy changes to multiple environments, including sandbox and production.
'Which mechanism or tool would best support their CI/CD pipeline in source-driven development?
  • A. Ant Migration Tool
  • B. Change Sets
  • C. Salesforce Extensions for Visual Studio Code
  • D. Salesforce CLI with Salesforce DX
Salesforce CLI with Salesforce DX supports source-driven development and is designed for continuous integration and delivery (CI/CD) processes. It enables developers to automate deployments across multiple environments, including sandbox and production.
References: Salesforce DX Developer Guide
NEW QUESTION # 122
The Account after-update trigger fires whenever an Account's address is updated, and it updates every associated Contact with that address. The Contact after-update trigger fires on every edit, and it updates every Campaign Member record related to the Contact with the Contact's state. Consider the following: A mass update of 200 Account records' addresses, where each Account has 50 Contacts. Each Contact has one Campaign Member. This means there are 10,000 Contact records across th23e Accounts and 10,000 Campaign Member records across the contacts. What will happen when the mass update occurs?24252627
  • A. The mass update will fail, since the two triggers fire in the same35 context, thus exceeding the number of records.36
  • B. The mass update of Account address 28will succeed, but the Contact address updates wil29l fail due to exceeding number of records processed by DML statements.3031
  • C. There will be no32 error, since each trigger fires 33within its own context and each trigger does not exceed the limit of the number of records processed by DML statements.34
In Salesforce, all triggers that fire as a result of an initial DML operation ru39n within the same execution context and the same transaction. This means that all governor limits-such as the limit of 10,000 records processed by DML statements-are shared across the entire chain of events.
In this scenario, the transaction begins with the update of 200 Accounts. The Account trigger then attempts to update 10,000 related Contacts (50 Contacts per Account across 200 Accounts). This update of 10,000 Contacts then fires the Contact trigger, which attempts to update 10,000 related Campaign Members. When the system attempts to process these updates, the total number of records processed via DML in a single transaction will exceed the platform limit of 10,000 rows.
Even though the Account update is only 200 records, the subsequent cascading updates (10,000 Contacts +
10,000 Campaign Members) bring the total DML count to 20,200. This triggers a LimitException, and because Apex transactions are atomic, the entire operation will fail and roll back. To resolve this, the developer would need to handle these updates asynchronously (e.g., using Batch Apex or Queueable) to split the cascading updates into separate transactions with their own sets of governor limits.
NEW QUESTION # 123
Given a list of Opportunity records named opportunityList, which code snippet is best for querying all Contacts of the Opportunity's Account?
A)
B)
C)
D)
  • A. Option D
  • B. Option A
  • C. Option B
  • D. Option C
NEW QUESTION # 124
We provide online customer service to the customers for 24 hours per day and we provide professional personnel to assist the client in the long distance online. If you have any questions and doubts about the Platform Developer II guide torrent we provide before or after the sale, you can contact us and we will send the customer service and the professional personnel to help you solve your issue about using PDII Exam Materials. If the clients have any problems or doubts about our PDII exam materials you can contact us by sending mails or contact us online and we will reply and solve the client’s problems as quickly as we can.
PDII Brain Dumps: https://www.topexamcollection.com/PDII-vce-collection.html
Salesforce PDII Top Dumps Why Pay For Exams One-by-One If You Can Get Unlimited Access To ALL of Them and SAVE, Salesforce PDII Top Dumps You need to purchase the practice exam, which is quite steep ($99) but still it shows you how the exam will be and what to expect, Now, you can study the material you get, if there is any update, you can learn more knowledge about the PDII Brain Dumps - Platform Developer II actual test, Salesforce PDII Top Dumps I don't know whether you are the one in the tide of job losses, if you are a member of the unemployed, you have to think about improving yourself.
As in everything, planning and preparation are required ahead of time, And you will find that you will get benefited from PDII Exam Braindumps far beyond you can image.
Why Pay For Exams One-by-One If You Can Get Unlimited Access To ALL of Them PDII Brain Dumps and SAVE, You need to purchase the practice exam, which is quite steep ($99) but still it shows you how the exam will be and what to expect.
Popular PDII Study Materials Give You Excellent Exam Braindumps - TopExamCollectionNow, you can study the material you get, if there PDII Brain Dumps is any update, you can learn more knowledge about the Platform Developer II actual test, I don't know whether you are the one in the tide of job PDII losses, if you are a member of the unemployed, you have to think about improving yourself.
So it is quite rewarding investment.
DOWNLOAD the newest TopExamCollection PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=15-lXhXKl41jhMl6anFI7_tyonTPXPD-Y
Posted at 1/11/2026 02:40:09        Only Author  2#
Your article was amazing, I’m truly grateful for it. I’m giving you access to the Latest Analytics-Arch-201 exam camp pdf test that helped me achieve a promotion and salary raise. It's free today—wishing you success!
Posted at 1/14/2026 16:37:46        Only Author  3#
This article is amazing, thank you for sharing it with us! Books AP-207 PDF has outstanding content, and I hope it helps you, at no cost.
Posted at 1/14/2026 17:39:42        Only Author  4#
SAP C_C4H56_2411덤프의 유효성을 보장해드릴수 있도록 저희 기술팀은 오랜시간동안SAP C_C4H56_2411시험에 대하여 분석하고 연구해 왔습니다. SAP C_C4H56_2411 덤프를 한번 믿고SAP C_C4H56_2411시험에 두려움없이 맞서보세요. 만족할수 있는 좋은 성적을 얻게 될것입니다.
Posted at 2/20/2026 13:48:52        Only Author  5#
Your article was amazing, I’m truly grateful for it. About to sit the Test AACE-PSP voucher exam – let’s hope it goes well!
