Authoritative Latest 1z0-1042-24 Practice Materials - 100% Pass 1z0-1042-24 Exam
Posted at 1/9/2026 11:42:55
BONUS!!! Download part of NewPassLeader 1z0-1042-24 dumps for free: https://drive.google.com/open?id=1sLiYPg7xBFa08Jwl8RT8zItYibOaQyWZ
Generally speaking, the clients will pass the test if they have finished learning our 1z0-1042-24 test guide with no doubts. The odds to fail in the test are approximate to zero. But to guarantee that our clients won’t suffer the loss we will refund the clients at once if they fail in the test unexpectedly. The procedures are very simple and the clients only need to send us their proofs to fail in the 1z0-1042-24 test and the screenshot or the scanning copies of the clients’ failure scores. The clients can consult our online customer staff about how to refund, when will the money be returned backed to them and if they can get the full refund or they can send us mails to consult these issues.
Oracle 1z0-1042-24 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Using OIC Connections & Adapters: Candidates must demonstrate their ability to create and configure OIC connections, including trigger and invoke connections. They should be familiar with the Connectivity Agent, which facilitates on-premises connectivity to OIC services.
| | Topic 2 | - Testing, Monitoring, and Troubleshooting Integrations: This section assesses candidates abilities in testing, monitoring, and troubleshooting integrations within the OIC.
| | Topic 3 | - Creating Orchestrated Integrations: This part of the exam evaluates the candidate's skills in creating and managing orchestrated integrations using OIC. Candidates should be able to manage OIC lookups, use the OIC Data Mapper, and incorporate custom JavaScript libraries into their integrations.
| | Topic 4 | - Getting Started with OIC Integrations: This section tests the ability of IT professionals and integration specialists to understand the fundamental components and concepts of Oracle Integration Cloud (OIC). Candidates are expected to describe the key features of OIC integration and explain core integration concepts.
| | Topic 5 | - Creating Scheduled Integrations: In this section of the exam, candidates are evaluated based on their skills in managing scheduled integrations. This includes converting scheduled integrations to app-driven integrations and understanding the scheduling options within the OIC.
Training 1z0-1042-24 For Exam - Practice 1z0-1042-24 TestA good learning platform should not only have abundant learning resources, but the most intrinsic things are very important, and the most intuitive things to users are also indispensable. The 1z0-1042-24 test material is professional editorial team, each test product layout and content of proofreading are conducted by experienced professionals, so by the editor of fine typesetting and strict check, the latest 1z0-1042-24 Exam Torrent is presented to each user's page is refreshing, and ensures the accuracy of all kinds of 1z0-1042-24 learning materials is extremely high.
Oracle Cloud Infrastructure 2024 Application Integration Professional Sample Questions (Q74-Q79):NEW QUESTION # 74
Which operation is NOT supported by an Oracle Integration Cloud (OIC) connection resource configured with FTP Adapter in the Invoke role?
- A. Write File
- B. Download File
- C. Read File in Segments
- D. Read File
- E. Delete File
The OIC FTP Adapter in theInvoke rolefacilitates interactions with an FTP server from an integration flow.
Let's break down each operation with exhaustive detail:
* Option A: Write File
* Supported:The FTP Adapter allows writing files to an FTP server. For example, you could use a Stage File action to prepare a CSV file and then invoke the FTP Adapter to write it to a remote directory like /inbound. This is a core capability for outbound file transfers.
* Option B: Read File
* Supported:Reading an entire file from an FTP server is possible in Invoke mode. You specify a file path (e.g., /outbound/data.csv), and the adapter retrieves itscontents, useful for processing complete files in one go, like a daily report.
* Option C: Read File in Segments
* Not Supported (Answer):This operation, which processes large files incrementally (e.g., 100 records at a time), is exclusive to theTrigger roleor Stage File actions, not the Invoke role of the FTP Adapter. In Invoke mode, the adapter doesn't support segmented reading because it's designed for direct, one-shot operations rather than iterative processing. For segmented reads, you'd use a File Adapter in Trigger mode or Stage File with a Connectivity Agent.
* Option D: Delete File
* Supported eleting a file on the FTP server (e.g., /archive/oldfile.txt) is a standard Invoke operation, often used for cleanup after processing.
* Option E: Download File
* Supported ownloading retrieves a file to OIC for further processing, similar to Read File but typically implies storing it locally in the integration flow (e.g., staging it).
Why C is the answer:The Invoke role focuses on discrete actions (write, read, delete, download), not iterative tasks like segmented reading, which requires a polling mechanism better suited to Trigger roles or Stage File actions.
Edge Case:If you need segmented reading from an FTP server, you'd download the file first using Invoke, then use a Stage File action to process it in segments- a workaround, not a direct capability.
Use Case Example:An integration writing a sales report to FTP (A), downloading a log file (E), and deleting an old backup (D) works fine, but attempting to read a 10GB file in segments (C) fails in Invoke mode.
NEW QUESTION # 75
Which two statements are true regarding messaging adapters in Oracle Integration Cloud?
- A. It is not mandatory to install a Connectivity agent to use the OCI Streaming Adapter for inbound polling.
- B. The OCI Streaming Adapter does not support consuming messages from a specified consumer group.
- C. The Apache Kafka adapter can be configured to support Transactions in case of Producer.
- D. Both the Apache Kafka and OCI Streaming adapter support XML, JSON, and Avro message formats.
Both Apache Kafka and OCI Streaming adapters support various message formats like XML, JSON, and Avro. The Apache Kafka adapter also supports transactional messaging for producers.
NEW QUESTION # 76
Which certificate type involves the uploading of a keystore (.jks) file to Oracle Integration (OIC) to facilitate two-way SSL communication with external services?
- A. PGP
- B. SAML
- C. X.509
- D. Signing key
Certificates in OIC secure communications:
* C:True-X.509 with .jks file for two-way SSL.
NEW QUESTION # 77
In an Oracle Integration (OIC) project, you are asked to leverage a custom JavaScript library function to be used within an Application pattern integration flow. Which set of steps should you follow to handle this requirement?
- A. Import the JavaScript library file to the project, then use the JavaScript action within the integration flow to reference the library function.
- B. Import the JavaScript library file into your OIC instance's database schema, then use a Local Invoke action to call the function.
- C. Use the Function Call action within the integration flow to reference the external URL that is hosting the JavaScript library function.
- D. Copy and paste the JavaScript function code into a new JavaScript stage within the integration flow, then map the inbound and outbound data elements in the corresponding Map action.
JS Library:
* B:True-import and reference is standard.
NEW QUESTION # 78
You can group one or more Oracle Integration Cloud (OIC) integrations into a single structure called a package.
Which statement is NOT true about OIC packages?
- A. You can import packages directly from the Oracle Marketplace.
- B. All packages must include at least one integration.
- C. Integrations do not need to be part of a package.
- D. New packages can be created by clicking the Create button on the Packages page in the console.
- E. Packages enable you to easily import and export a group of integrations to and from OIC.
- F. Packages cannot be locked to deny other users access to your integrations.
Answer: F
Packages in OIC cannot be locked to prevent other users from accessing the integrations. The other statements are true, including the ability to create, import, and manage integrations within packages.
NEW QUESTION # 79
Choose 1z0-1042-24 exam Topics Pdf to prepare for your coming test, and you will get unexpected results. 1z0-1042-24 pdf version is very convenient to read and review. If you like to choose the paper file for study, the 1z0-1042-24 pdf file will be your best choice. The Oracle 1z0-1042-24 Pdf Dumps can be printed into papers, so that you can read and do marks as you like. Thus when you open your dumps, you will soon find the highlights in the 1z0-1042-24 papers. What's more, the 99% pass rate can help you achieve your goals.
Training 1z0-1042-24 For Exam: https://www.newpassleader.com/Oracle/1z0-1042-24-exam-preparation-materials.html
- Comprehensive Oracle 1z0-1042-24 Exam Questions in PDF Format ⏭ ✔ [url]www.exam4labs.com ️✔️ is best website to obtain ➤ 1z0-1042-24 ⮘ for free download 💻1z0-1042-24 Exam Cram Questions[/url]
- Free PDF Quiz Oracle - Valid 1z0-1042-24 - Latest Oracle Cloud Infrastructure 2024 Application Integration Professional Practice Materials 🔙 Easily obtain free download of ➽ 1z0-1042-24 🢪 by searching on ✔ [url]www.pdfvce.com ️✔️ 📈1z0-1042-24 Reliable Test Sims[/url]
- Use Oracle 1z0-1042-24 Exam Dumps To Ace Exam Quickly 🛃 Open website ( [url]www.vceengine.com ) and search for ➤ 1z0-1042-24 ⮘ for free download ⏭Test 1z0-1042-24 Assessment[/url]
- 1z0-1042-24 Related Content 🧩 1z0-1042-24 Interactive EBook 🍚 Valid 1z0-1042-24 Test Blueprint 🏐 Open website ➽ [url]www.pdfvce.com 🢪 and search for ⇛ 1z0-1042-24 ⇚ for free download 😟Valid 1z0-1042-24 Test Blueprint[/url]
- 1z0-1042-24 Reliable Exam Pattern 🥵 1z0-1042-24 Exam Cram Questions 🤣 Test 1z0-1042-24 Questions 🍷 Open website 「 [url]www.examcollectionpass.com 」 and search for ➤ 1z0-1042-24 ⮘ for free download 😙Valid 1z0-1042-24 Test Blueprint[/url]
- Reliable 1z0-1042-24 Exam Labs 🏂 Exam 1z0-1042-24 Simulations 🧂 1z0-1042-24 Exam Cram Questions 🖼 Download ▷ 1z0-1042-24 ◁ for free by simply searching on ➤ [url]www.pdfvce.com ⮘ 📼Latest 1z0-1042-24 Test Pdf[/url]
- Test 1z0-1042-24 Questions 😒 1z0-1042-24 Reliable Exam Pattern ⏮ 1z0-1042-24 Sample Questions Answers 🌋 Go to website ⇛ [url]www.pass4test.com ⇚ open and search for ▶ 1z0-1042-24 ◀ to download for free 🥟Latest 1z0-1042-24 Exam Labs[/url]
- 1z0-1042-24 Sample Questions Answers 🤳 1z0-1042-24 Actual Questions 🌞 Valid 1z0-1042-24 Test Blueprint 🃏 Go to website ➠ [url]www.pdfvce.com 🠰 open and search for ⇛ 1z0-1042-24 ⇚ to download for free 🥁Test 1z0-1042-24 Engine[/url]
- 1z0-1042-24 Interactive EBook ⌛ 1z0-1042-24 Actual Questions 💍 Valid 1z0-1042-24 Test Camp 🚒 The page for free download of ➡ 1z0-1042-24 ️⬅️ on ( [url]www.troytecdumps.com ) will open immediately 🕑1z0-1042-24 Reliable Test Braindumps[/url]
- 1z0-1042-24 Latest Practice Materials - Realistic Oracle Cloud Infrastructure 2024 Application Integration Professional 100% Pass Quiz 🕦 Search on ( [url]www.pdfvce.com ) for ▷ 1z0-1042-24 ◁ to obtain exam materials for free download 🙈1z0-1042-24 Related Content[/url]
- Use Oracle 1z0-1042-24 Exam Dumps To Ace Exam Quickly 🅰 ✔ [url]www.prepawayete.com ️✔️ is best website to obtain 「 1z0-1042-24 」 for free download ➡1z0-1042-24 Reliable Test Sims[/url]
- bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, github.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, techwavedy.xyz, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, houseoflashesandbrows.co.uk, Disposable vapes
What's more, part of that NewPassLeader 1z0-1042-24 dumps now are free: https://drive.google.com/open?id=1sLiYPg7xBFa08Jwl8RT8zItYibOaQyWZ
