New MB-820 Study Notes, Trustworthy MB-820 Practice
Posted at 1/9/2026 11:47:45
View150
Replies5
2026 Latest PassCollection MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1svD3mK2-bPV0PC2RONi9GxMhVHwrWuC2
If you find someone around has a nice life go wild, it is because that they may have favored the use of study & work method different from normal people. MB-820 dumps torrent files may be the best method for candidates who are preparing for their IT exam and eager to clear exam as soon as possible. People's success lies in their good use of every change to self-improve. Our MB-820 Dumps Torrent files will be the best resources for your real test. If you choose our products, we will choose efficient & high-passing preparation materials.
PassCollection is an invisible assent that can give your advantage and get better life higher than your current situation and help you stand out among the average with the best and most accurate MB-820 study braindumps. For the great merit of our MB-820 Exam Guide is too many to count. Our experts have been dedicated in this area for more than ten years on compiling the content of our MB-820 training guide and keeping updating it to the latest.
The Key to Success: Proper Planning and the Right Microsoft MB-820 Exam QuestionsOur MB-820 Study Materials are recognized as the standard and authorized study materials and are widely commended at home and abroad. Our MB-820 study materials boost superior advantages and the service of our products is perfect. We choose the most useful and typical questions and answers which contain the key points of the test and we try our best to use the least amount of questions and answers to showcase the most significant information.
Microsoft MB-820 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
| | Topic 2 | - Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic. It also explains implementation of APIs.
| | Topic 3 | - Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
| | Topic 4 | - Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q37-Q42):NEW QUESTION # 37
A company has an on-premises Business Central instance named TEST The instance uses Windows authorization and a developer services port of 7149 Visual Studio Code is installed on the same server.
You create a new AL project but cannot download the symbols.
The launch json file contains the following code:
You need to download the symbols.
Which two actions should you perform? Each correct answer presents part of the solution.
- A. Add the port: 7149 parameter.
- B. Change the authentication parameter to UserPassword.
- C. Change the name parameter to TEST.
- D. Check which server the instance is installed on and replace http//localhost with the correct IP address.
- E. Change the server Instance parameter to TEST
Answer: A,E
You are working on an on-premises Business Central instance and unable to download symbols for a new AL project. The current configuration in launch.json does not allow you to download symbols, and you need to make corrections.
Key Points in the Scenario:
Instance name is TEST.
Developer services port is 7149.
Windows authentication is being used.
Correct Answers:
A . Change the server Instance parameter to TEST.
The serverInstance parameter must match the name of the Business Central instance, which is TEST in this scenario. You need to modify this to reflect the correct instance name.
B . Add the port: 7149 parameter.
Since the developer services are using port 7149, you need to specify this in the launch.json file by adding the port parameter with the value 7149.
Incorrect Options:
C . Change the name parameter to TEST: The name parameter is just a label and does not affect downloading symbols, so changing this won't help.
D . Change the authentication parameter to UserPassword: The authentication method is already set to Windows, which is valid for this scenario. Changing it to UserPassword is unnecessary unless specified by the system.
E . Check which server the instance is installed on and replace http://localhost with the correct IP address: Since the server is on the same machine as Visual Studio Code (as specified), localhost is correct.
NEW QUESTION # 38
You are developing a codeunit for a company that uses Business Central.
The code unit must be run only during installation of an extension package.
You need to create the codeunit.
How should you complete the code' To answer, select the appropriate options in the answer area.
Subtype: Install
Trigger: OnInstallAppPerCompany
You are developing a codeunit that should only run during the installation of an extension package.
Options:
* Subtype: The correct subtype is Install, as it indicates that the codeunit runs only when the extension is being installed.
* Trigger: The correct trigger for running during installation is OnInstallAppPerCompany, which handles code execution when the app is installed for a specific company.
NEW QUESTION # 39
You create a query that contains a procedure to display the top customers.
The procedure breaks at runtime.
You need to fix the code.
NEW QUESTION # 40
You plan to write unit test functions to test newly developed functionality in an app.
You must create a test codeunit to write the functions.
You need to select the property to use for the test codeunit.
Which property should you use to ensure that the requirements are fulfilled?
- A. SubType
- B. Access
- C. Description
When creating a test codeunit in Microsoft Dynamics 365 Business Central to write unit test functions, the SubType property (A) of the codeunit should be set to Test. This property is crucial for defining the codeunit's purpose and behavior within the application. By setting the SubType property to Test, you are indicating that the codeunit contains test functions intended to validate the functionality of other parts of the application, such as customizations or new developments.
This distinction ensures that the testing framework within Business Central recognizes the codeunit as a container for test functions, allowing it to execute these functions in a testing context, which can include setting up test data, running the tests, and cleaning up after the tests have completed.
NEW QUESTION # 41
You are developing an app that will be published to Microsoft AppSource.
The app requires code analyzers to enforce some rules. You plan to add the analyzers to the settings.json file.
You need to activate the analyzers for the project.
Which three code analyzers should you activate to develop the app for AppSource? Each correct answer presents part of the solution.
- A. AppSourceCop
- B. UICop
- C. CodeCop
- D. a custom rule set
- E. PerTenantExtensionCop
Answer: A,B,C
PerTenantExtensionCop and AppSourceCop conflicts with each other. Code is for Appsource, so no need for PerTenantExtensionCop.
NEW QUESTION # 42
If you want to pass the shortest time to pass you exam, just find us. Our MB-820 Training Materials will have the collective of the questions and answers, it will help you to have a good command of the knowledge point, therefore make it possible for you to pass the exam. Besides money back guarantee if you fail to pass it, or we can change another exam dumps for you for free. All we do is just want to serve you better. Choose us and you will never regret.
Trustworthy MB-820 Practice: https://www.passcollection.com/MB-820_real-exams.html
- Microsoft MB-820 Exam | New MB-820 Study Notes - Help you Pass MB-820: Microsoft Dynamics 365 Business Central Developer Exam 🐡 Open website ▛ [url]www.prepawayexam.com ▟ and search for MB-820 for free download 🗜Dumps MB-820 Guide[/url]
- Latest Microsoft Dynamics 365 Business Central Developer dumps pdf, MB-820 valid torrent 🎣 The page for free download of { MB-820 } on [ [url]www.pdfvce.com ] will open immediately ☕MB-820 Reliable Exam Preparation[/url]
- Valid MB-820 Exam Testking 😞 Valid Exam MB-820 Preparation 🎾 MB-820 Reliable Exam Preparation 👿 Search for ⮆ MB-820 ⮄ and download it for free on [url]www.troytecdumps.com website 🌤MB-820 Latest Exam Registration[/url]
- 2026 New MB-820 Study Notes | Pass-Sure Trustworthy MB-820 Practice: Microsoft Dynamics 365 Business Central Developer 🤹 Immediately open ▷ [url]www.pdfvce.com ◁ and search for ➥ MB-820 🡄 to obtain a free download 📓MB-820 Reliable Exam Preparation[/url]
- Exam MB-820 Guide Materials ⛺ Reliable MB-820 Study Guide K MB-820 Latest Mock Test 🐎 Search for MB-820 and download it for free on ➽ [url]www.practicevce.com 🢪 website 🖊Guaranteed MB-820 Questions Answers[/url]
- Microsoft's MB-820 Exam Questions Offer Realistic Practice and Accurate Answers for Your Success 💂 Search for ➤ MB-820 ⮘ and download it for free on [url]www.pdfvce.com website 💝MB-820 Exam Sample Online[/url]
- Take Microsoft MB-820 Web-Based Practice Test on Popular Browsers 🟠 Open website ➤ [url]www.troytecdumps.com ⮘ and search for [ MB-820 ] for free download ⛳MB-820 Exam Sample Online[/url]
- MB-820 Latest Exam Registration 🔢 Vce MB-820 Download 🍼 MB-820 Exam Forum 👪 Immediately open ➡ [url]www.pdfvce.com ️⬅️ and search for MB-820 to obtain a free download 🐯MB-820 Reliable Exam Preparation[/url]
- 2026 New MB-820 Study Notes | Pass-Sure Trustworthy MB-820 Practice: Microsoft Dynamics 365 Business Central Developer 🏳 Search for ➡ MB-820 ️⬅️ and download it for free immediately on ✔ [url]www.vce4dumps.com ️✔️ 🏉Free MB-820 Exam Questions[/url]
- Take Microsoft MB-820 Web-Based Practice Test on Popular Browsers 🆗 Open ▶ [url]www.pdfvce.com ◀ and search for ➤ MB-820 ⮘ to download exam materials for free 💠Free MB-820 Exam Questions[/url]
- 2026 New MB-820 Study Notes | Pass-Sure Trustworthy MB-820 Practice: Microsoft Dynamics 365 Business Central Developer 🍊 Download ⮆ MB-820 ⮄ for free by simply searching on ➤ [url]www.examcollectionpass.com ⮘ 🎭Valid MB-820 Exam Testking[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, zenwriting.net, www.competize.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, demo.xinxiuvip.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
BTW, DOWNLOAD part of PassCollection MB-820 dumps from Cloud Storage: https://drive.google.com/open?id=1svD3mK2-bPV0PC2RONi9GxMhVHwrWuC2
