Salesforce - High Pass-Rate Plat-Arch-204 - Salesforce Certified Platform Integr
96
Posted at 1/9/2026 11:52:03      View236 | Replies5        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Prep4SureReview Plat-Arch-204 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Lq-vwZ85te6SxsoVfhjUkoKBZiPR62-v
Once you get the Plat-Arch-204 certificate, your life will change greatly. First of all, you will grow into a comprehensive talent under the guidance of our Plat-Arch-204 exam materials, which is very popular in the job market. Then you will form a positive outlook, which can aid you to realize your dreams through your constant efforts. Then our Plat-Arch-204 learning questions will aid you to regain confidence and courage with the certification as reward. So you will never regret to choose our Plat-Arch-204 study materials. Just browser our websites and choose our Plat-Arch-204 study materials for you.
All these three Salesforce Plat-Arch-204 exam questions formats contain the real and updated Plat-Arch-204 exam questions. These Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam questions are being presented in practice test software and PDF dumps file formats. The Plat-Arch-204 desktop practice test software is easy to use and install on your desktop computers. Whereas the other Salesforce Plat-Arch-204 web-based practice test software is concerned, this is a simple browser-based application that works with all operating systems. Both practice tests are customizable, simulate actual exam scenarios, and help you overcome mistakes.
Plat-Arch-204 Valid Study Guide & Test Plat-Arch-204 DurationIn modern society, everything is changing so fast with the development of technology. If you do no renew your knowledge and skills, you will be wiped out by others. Our Plat-Arch-204 guide materials also keep up with the society. After all, new technology has been applied in many fields. So accordingly our Plat-Arch-204 Exam Questions are also applied with the latest technologies to be up to date. You can free download the demos to check that how wonderful our Plat-Arch-204 learning praparation is!
Salesforce Certified Platform Integration Architect Sample Questions (Q79-Q84):NEW QUESTION # 79
A company that is a leading provider of courses and training delivers courses using third-party trainers. The trainer for the company has to be verified by 10 different training accreditation verification agencies before providing training for the company. Each training accreditation agency has its own response time, which means it could take days to confirm a trainer. The company decided to automate the trainer accreditation verification process by integrating it with the agency's web service1s. What is the recommended approach to automa2te this process?3456
  • A. Use Salesforce External Service to make the callout; Salesforce External Service should check the verification agencies until the result is verified. Then, update the trainer status to "verified".
  • B. Make an Apex callout using @future annotation to make the callout to all different agencies.
  • C. Use middleware to handl7e the callout to the 10 different verific8ation services; the middleware will handle the business logic of con9solidating the verification resu10lt from the 10 services. Then, make a call-in to Salesforce and update the verification status to "verified".
In this scenario, the primary architectural challenge is managing high-latency, multi-step orchestration involving 10 disparate external systems. Each agency has a varying response time that can span several days, making a synchronous "Request-Reply" pattern within Salesforce technically impossible due to transaction timeout limits (maximum 120 seconds).
The recommended approach is to leverage Middleware as the orchestration and state-management layer. Middleware (such as an ESB or iPaaS) is specifically designed for Process Choreography. Salesforce initiates a single "Fire and Forget" request to the middleware. The middleware then takes responsibility for:
Sequential or Parallel Callouts: Initiating the requests to all 10 verification agencies.
Callback Management: Handling the asynchronous responses from each agency as they arrive over a period of days.
Aggregation Logic: Consolidating the results and determining when the "Business Process" is complete (e.g., all 10 agencies have approved).
Once the consolidation logic is satisfied, the middleware performs a Remote Call-In to the Salesforce REST API to update the trainer's record. This pattern keeps Salesforce "clean" by moving complex, long-running orchestration logic off-platform, preventing the consumption of excessive Apex CPU time and ensuring that Salesforce only receives a single, final status update.
Option B (External Services) is unsuitable for a multi-day asynchronous process as it is designed for real-time, synchronous Flow actions. Option C (@future) is restricted by the same 120-second timeout and cannot handle the "waiting" state required for days of verification. Using middleware provides the necessary Quality of Service (QoS), durability, and error handling required for such a critical enterprise compliance process.
NEW QUESTION # 80
An enterprise customer with more than 10 million customers has a landscape including an Enterprise Billing System (EBS), a Document Management System (DMS), and Salesforce CRM. Customer Support needs seamless access to customer billing information from the EBS and generated bills from the DMS. Which authorization and authentication need should an integration consultant consider while integrating the DMS and EBS with Salesforce?
  • A. Consider options to migrate DMS and EBS into Salesforce.
  • B. Identify options to maintain DMS and EBS authentication and authorization details in Salesforce.
  • C. Consider Enterprise security needs for access to DMS and EBS.
When integrating Salesforce with high-security enterprise systems like an Enterprise Billing System (EBS) and a Document Management System (DMS), the primary architectural concern is respecting the Enterprise security needs for access control. These systems often contain highly sensitive financial data and are governed by strict regulatory requirements (e.g., PCI-DSS or GDPR).
The integration consultant must evaluate how to extend existing enterprise identity and authorization policies to Salesforce users. This often involves a Identity Federation strategy using protocols like SAML 2.0 or OpenID Connect. Instead of maintaining separate credentials in Salesforce (which Option A suggests and is generally an "anti-pattern" for 10 million records), the consultant should consider using a central Identity Provider (IdP).
By considering enterprise security needs, the architect ensures that when a support agent clicks a link in Salesforce to view a bill, the request is authenticated against the enterprise's security gateway. This allows for Single Sign-On (SSO) while ensuring that authorization (who can see what) remains mastered in the source systems or the central IdP. Migration (Option C) is physically and technically unfeasible for systems handling 10 million customers' historical bills and real-time processing. The focused objective is to build a "window" into these systems from Salesforce while maintaining the integrity of the enterprise's existing security perimeter.
NEW QUESTION # 81
An enterprise architect has requested the Salesforce integration architect to review the following (see diagram and description) and provide recommendations after carefully considering all constraints of the enterprise systems and Salesforce Platform limits.
There are multiple eligibility systems that provide this service and are hosted externally.34 However, their current response times could take up to 90 seconds to process and return.
These eligibility systems can be acc8essed through APIs orchestrated via ESB (MuleSoft).
All requests from Salesforce must traverse the customer's API Gateway layer, which imposes a constraint of timing out requests after 9 seconds.
Which recommendation should the integration architect make?
  • A. Use Continuation callouts to make the eligibility check request from Salesforce Lightning UI at page load.
  • B. Recommend synchronous Apex callouts from Lightning UI to External Systems via Mule and implement polling on an API Gateway timeout.
  • C. Create a platform event in Salesforce via Remote Call-In and use the empAPI in the Lightning UI to serve 3,000 concurrent users when responses are received by Mule.
NEW QUESTION # 82
A company's security assessment noted vulnerabilities on the unmanaged packages in its Salesforce orgs; notably, secrets that are easily accessible and in plain text, such as usernames, passwords, and OAuth tokens used in callouts from Salesforce. Which persistence mechanisms should an integration architect require to be used to ensure that secrets are protected from deliberate or inadvertent exposure?
  • A. Named Credentials and Protected Custom Settings
  • B. Protected Custom Metadata Types and Named Credentials
  • C. Encrypted Custom Fields and Protected Custom Settings
The scenario highlights vulnerabilities in unmanaged packages where secrets (usernames, passwords, OAuth tokens) are stored in plain text and easily accessible. The goal is to protect these secrets from exposure in callouts, especially in unpackaged or unmanaged code contexts.
Why A (Protected Custom Metadata Types and Named Credentials)?
Named Credentials is the primary Salesforce-recommended mechanism for securely storing authentication details (including passwords, tokens, and secrets) for HTTP callouts. Secrets are encrypted, not visible in debug logs, and Salesforce handles authentication without exposing them in Apex code.
However, in Named Credentials, admins with "Customize Application" permission can view/edit the secrets.
To further protect secrets (e.g., hide them completely from admins or in packaged scenarios), use Protected Custom Metadata Types (preferably in a managed package). These allow Apex code in the same namespace/package to access the secrets while hiding them from users, API queries, or subscriber orgs.
This combination addresses both standard callouts (via Named Credentials) and cases needing maximum obfuscation (via Protected Custom Metadata), directly mitigating plain-text exposure in unmanaged packages.
Why not B (Encrypted Custom Fields and Protected Custom Settings)?
Encrypted Custom Fields are suitable for sensitive data like PII (e.g., credit cards, SSNs) but explicitly not recommended for storing authentication secrets or credentials used in callouts (per Salesforce Secure Coding guidelines).
Protected Custom Settings offer similar protection to Protected Custom Metadata but are less preferred for configuration-like data (secrets are configuration). Custom Metadata is deployable as metadata, better for packaging and migrations.
Why not C (Named Credentials and Protected Custom Settings)?
While Named Credentials are ideal, pairing with Protected Custom Settings is valid but suboptimal. Salesforce documentation and Trailhead modules favor Protected Custom Metadata Types over Custom Settings for secret storage due to better deployability, caching, and metadata API support.
This aligns with Salesforce Trailhead ("Securely Store Secrets with Salesforce Features") and secure coding guidelines, emphasizing Named Credentials for callouts and Protected Custom Metadata for high-security secret storage in packages. For unmanaged code vulnerabilities, migrating to these mechanisms (ideally with packaging) prevents exposure.
NEW QUESTION # 83
Northern Trail Outfitters is planning to perform nightly batch loads into Salesforce using the Bulk API. The CIO is curious about monitoring recommendations for the jobs from the technical architect. Which recommendation should help meet the requirements?
  • A. Write the error response from the Bulk API status to a custom error logging object in Salesforce using an Apex trigger, and create reports on the object.
  • B. Visually monitor in the Salesforce UI using the "Bulk Data Load Jobs" in Salesforce in the setup menu.
  • C. Set the Salesforce debug logs level to "finest", and add the user ID running the job to monitor in the "Debug Logs" in the setup menu.
NEW QUESTION # 84
Prep4SureReview Plat-Arch-204 exam dumps are audited by our certified subject matter experts and published authors for development. Plat-Arch-204 exam dumps are one of the highest quality Plat-Arch-204 Q&AS in the world. It covers nearly 96% real questions and answers, including the entire testing scope. Prep4SureReview guarantees you Pass Plat-Arch-204 Exam at first attempt.
Plat-Arch-204 Valid Study Guide: https://www.prep4surereview.com/Plat-Arch-204-latest-braindumps.html
With this kind of version, you can flip through the pages at liberty to quickly finish the check-up of Plat-Arch-204 exam preparatory: Salesforce Certified Platform Integration Architect, Since the Plat-Arch-204 exam dumps are of high accuracy and high quality, and it can ensure you pass the exam successfully, Salesforce Plat-Arch-204 Latest Study Questions At meantime, we will provide after-service for you, Salesforce Plat-Arch-204 Latest Study Questions On the other hand, all of your personal information will be encrypted immediately after payment by our advanced operation system.
Send alert to all log files  use with caution Exam Plat-Arch-204 Consultant Authpriv, On a development team, several people may work with the same Flash document, With this kind of version, you can flip through the pages at liberty to quickly finish the check-up of Plat-Arch-204 Exam preparatory: Salesforce Certified Platform Integration Architect.
Pass Guaranteed Quiz 2026 Plat-Arch-204: High Hit-Rate Salesforce Certified Platform Integration Architect Latest Study QuestionsSince the Plat-Arch-204 exam dumps are of high accuracy and high quality, and it can ensure you pass the exam successfully, At meantime, we will provide after-service for you.
On the other hand, all of your personal information Plat-Arch-204 will be encrypted immediately after payment by our advanced operation system, If you want to pass the test effectively, take a comprehensive look of the features of Plat-Arch-204 test simulate as follow: Concrete contents.
2026 Latest Prep4SureReview Plat-Arch-204 PDF Dumps and Plat-Arch-204 Exam Engine Free Share: https://drive.google.com/open?id=1Lq-vwZ85te6SxsoVfhjUkoKBZiPR62-v
Posted at 1/12/2026 08:25:55        Only Author  2#
SAP C-S4CS-2508인증시험을 패스하고 자격증 취득으로 하여 여러분의 인생은 많은 인생역전이 이루어질 것입니다. 회사, 생활에서는 물론 많은 업그레이드가 있을 것입니다. 하지만C-S4CS-2508시험은SAP인증의 아주 중요한 시험으로서C-S4CS-2508시험패스는 쉬운 것도 아닙니다.
Posted at 1/15/2026 15:09:00        Only Author  3#
Tip: the author has been banned or deleted automatically shield
Posted at 1/24/2026 09:46:08        Only Author  4#
Your article was such an eye-opener, thank you for this fresh perspective. Free CTS-I reliable exam answers test papers for everyonepromotions and salary raises await!
Posted at 2/13/2026 20:48:58        Only Author  5#
Your article was incredibly insightful, thank you! The SC-900 pass test guide helped me move forward in my career with a promotion and salary increase. Now, Im sharing it for free. Wishing you career success!
Posted at 2/15/2026 11:57:40        Only Author  6#
It opened my mind in ways I didnt expect. Heres the Test 220-1201 experience test that got me promoted and raised. Today, it's free for everyone! Hope you achieve your professional goals!
