[General] Juniper JN0-336 Exam | JN0-336 Test Simulator - Spend your Little Time and Energ
81
【General】 Juniper JN0-336 Exam | JN0-336 Test Simulator - Spend your Little Time and Energ
Posted at 1/9/2026 12:30:05      View:128 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-336 dumps are available on Google Drive shared by TorrentVCE: https://drive.google.com/open?id=1dCXT2NPrS9eSc3xqc0xmNsvN5yL3lD_3
We provide free update to the client and the discounts to the old client. We provide free update of our JN0-336 exam materials within one year and after one year the client can enjoy the 50% discounts. The old clients enjoy some certain discounts when they buy our JN0-336 exam torrent. Our experts check whether there is the update of the test bank every day and if there is the system will send to the client automatically. We choose the most typical questions and answers which seize the focus and important information and the questions and answers are based on the real exam. So you can master the most important JN0-336 Exam Torrent in the shortest time and finally pass the exam successfully.
If you visit our website TorrentVCE, then you will find that our JN0-336 practice questions are written in three different versions: PDF version, Soft version and APP version. All types of JN0-336 training questions are priced favorably on your wishes. Obtaining our JN0-336 Study Guide in the palm of your hand, you can achieve a higher rate of success. Besides, there are free demos of our JN0-336 learning guide for your careful consideration to satisfy individual needs.
Exam JN0-336 Introduction & Latest JN0-336 Test ObjectivesEach question and answer of our JN0-336 training questions are researched and verified by the industry experts. Our team updates the JN0-336 certification material periodically and the updates include all the questions in the past thesis and the latest knowledge points. So our service team is professional and top-tanking on the JN0-336 Exam braindump. And if you have any questions on our study guide, our services will help you with the right and helpful suggestions. Just have a try on our JN0-336 learning prep!
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q40-Q45):NEW QUESTION # 40
Which method does the loT Security feature use to identify traffic sourced from IoT devices?
  • A. The SRX Series device identifies loT devices using their MAC address.
  • B. The SRX Series device identifies loT devices from metadata extracted from their transit traffic.
  • C. The SRX Series device streams metadata from the loT device transit traffic to Juniper ATP Cloud Juniper ATP Cloud.
  • D. The SRX Series device streams transit traffic received from the IoT device to Juniper ATP Cloud.
The metadata is used to identify the type of device, its associated activities and its threat profile. This information is used to determine the appropriate security policy for the device. For more information on loT Security, please refer to the Juniper Security, Specialist (JNCIS-SEC) study guide.
NEW QUESTION # 41
Exhibit
Referring to the exhibit, which two statements are true? (Choose two.)
  • A. The IP address of Nancy's client PC is 172.25.11.
  • B. Nancy logged in to the juniper.net Active Directory domain.
  • C. Nancy is a member of the Active Directory sales group.
  • D. The IP address of the authenticating domain controller is 172.25.11.140.
NEW QUESTION # 42
Which three statements about SRX Series device chassis clusters are true? (Choose three.)
  • A. Chassis cluster member devices synchronize configuration using the control link.
  • B. Chassis cluster control links must be configured using RFC 1918 IP addresses.
  • C. A control link failure causes the secondary cluster node to be disabled.
  • D. Heartbeat messages verify that the chassis cluster control link is working.
  • E. Recovery from a control link failure requires that the secondary member device be rebooted.
Answer: A,C,D
B: Chassis cluster member devices synchronize configuration using the control link: This statement is correct because the control link is used for configuration synchronization among other functions.
C: A control link failure causes the secondary cluster node to be disabled: This statement is correct because a control link failure causes the secondary node to become ineligible for primary role and remain in secondary role until the control link is restored.
E: Heartbeat messages verify that the chassis cluster control link is working: This statement is correct because heartbeat messages are sent periodically over the control link to monitor its status.
NEW QUESTION # 43
You have deployed an SRX300 Series device and determined that files have stopped being scanned.
In this scenario, what is a reason for this problem?
  • A. The software license is a free model and only scans executable type files.
  • B. You have exceeded the maximum files submission for your SRX platform size.
  • C. The file is too small to have a virus.
  • D. The infected host communicated with a command-and-control server, but it did not download malware.
You have exceeded the maximum files submission for your SRX platform size: This statement is correct because file scanning on SRX300 Series device has a limit on the number of files that can be submitted per minute based on the platform size3. For example, SRX320 has a limit of 10 files per minute3.
NEW QUESTION # 44
Your company is using the Juniper ATP Cloud free model. The current inspection profile is set at 10 MB You are asked to configure ATP Cloud so that executable files up to 30 MB can be scanned while at the same time minimizing the change in scan time for other file types.
Which configuration should you use in this scenario?
  • A. Use the CLI to create a custom profile and increase the scan limit.
  • B. Use the ATP Cloud Ul to change the default profile to increase the scan limit for all files to 30 MB.
  • C. Use the ATP Cloud Ul to update a custom profile and increase the scan limit for executable files to 30 MB.
  • D. Use the CLI to change the default profile to increase the scan limit for all files to 30 MB.
In this scenario, you should use the ATP Cloud Ul to create a custom profile and update the scan limit for executable files to 30 MB. This will ensure that executable files up to 30 MB can be scanned, while at the same time minimizing the change in scan time for other file types. To do this, log in to the ATP Cloud Ul and go to the Profiles tab. Click the Create button to create a new profile, and then adjust the scan limits for executable files to 30 MB. Once you have saved the custom profile, you can apply it to the desired systems and the new scan limit will be in effect.
NEW QUESTION # 45
Thus, we come forward to assist them in cracking the Juniper JN0-336 examination. Don't postpone purchasing Juniper JN0-336 exam dumps to pass the crucial examination. TorrentVCE study material is available in three versions: Juniper JN0-336 Pdf Dumps, desktop practice exam software, and a web-based Juniper JN0-336 practice test.
Exam JN0-336 Introduction: https://www.torrentvce.com/JN0-336-valid-vce-collection.html
You can download JN0-336 PDF in your Computer or any other device and start study, Juniper JN0-336 Test Simulator Free demos as preview, Juniper JN0-336 Test Simulator So our products are beneficial to your exam, When you pass the Juniper JN0-336 exam and enter an enormous company, you can completely display your talent and become social elites, To be specific, you can receive our Juniper Exam JN0-336 Introduction Exam JN0-336 Introduction - Security, Specialist (JNCIS-SEC) test training simulator within only 5 to 10 minutes after payment, which marks the fastest delivery speed in this field.
That slogan would also make good advice to managers when it comes to JN0-336 Real Braindumps giving annual performance reviews, Collaborative playlists let multiple music lovers team up to share their musical likes and dislikes.
Juniper JN0-336 Web-Based Practice Test QuestionsYou can Download JN0-336 Pdf in your Computer or any other device and start study, Free demos as preview, So our products are beneficial to your exam, When you pass the Juniper JN0-336 exam and enter an enormous company, you can completely display your talent and become social elites.
To be specific, you can receive our Juniper Security, Specialist (JNCIS-SEC) test JN0-336 training simulator within only 5 to 10 minutes after payment, which marks the fastest delivery speed in this field.
BTW, DOWNLOAD part of TorrentVCE JN0-336 dumps from Cloud Storage: https://drive.google.com/open?id=1dCXT2NPrS9eSc3xqc0xmNsvN5yL3lD_3
Posted at 1/10/2026 08:00:59        Only Author  2#
I’m so thankful for your article, it was a real game-changer. Strengthen your IT expertise with free Portworx-Enterprise-Professional latest practice questions free. Best of luck in your studies!
Posted at 1/19/2026 23:05:36        Only Author  3#
I’m not hesitating; this content gets my like. Here’s the free Valid exam ASIS-PSP questions explanations test content. Wishing you success!
Posted at 1/21/2026 02:50:48        Only Author  4#
Thank you for your article; it truly shocked me! The PCA reliable test dumps free helped me land a promotion and salary increase. It’s free for everyone now. Best of luck with your promotions!
