¡¾General¡¿
Actual Palo Alto Networks NGFW-Engineer Exam Questions¨CKey To Success
Posted at 1/9/2026 12:34:43
View£º211
Replies£º4
2026 Latest ITdumpsfree NGFW-Engineer PDF Dumps and NGFW-Engineer Exam Engine Free Share: https://drive.google.com/open?id=10AUBsqhGjGfb79dI60SCYSG_7NrzxhPx
Practicing for an Palo Alto Networks Next-Generation Firewall Engineer (NGFW-Engineer) exam is one of the best ways to ensure success. It helps students become familiar with the format of the actual NGFW-Engineer practice test. It also helps to identify areas where more focus and attention are needed. Furthermore, it can help reduce the anxiety and stress associated with taking an Palo Alto Networks Next-Generation Firewall Engineer (NGFW-Engineer) exam as it allows students to gain confidence in their knowledge and skills.
To help candidates overcome this challenge, ITdumpsfree offers authentic, accurate, and genuine Palo Alto Networks NGFW-Engineer PDF Dumps. When preparing for the Palo Alto Networks Next-Generation Firewall Engineer (NGFW-Engineer) certification exam, candidates need not worry about their preparation notes or the format of the NGFW-Engineer Exam because ITdumpsfree offers updated Palo Alto Networks Next-Generation Firewall Engineer (NGFW-Engineer) practice test material.
NGFW-Engineer Latest Test Cram and Palo Alto Networks Latest NGFW-Engineer Dumps Book: Palo Alto Networks Next-Generation Firewall Engineer Pass CertifyThe ITdumpsfree experts regularly add these changes in the ITdumpsfree NGFW-Engineer exam dumps questions so that you do not miss a single NGFW-Engineer exam update. With the purchasing of ITdumpsfree NGFW-Engineer exam practice questions you get an opportunity to get free ITdumpsfree NGFW-Engineer Exam Dumps questions updates for up to 1 year from the date of ITdumpsfree NGFW-Engineer exam questions purchase.
Palo Alto Networks NGFW-Engineer Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Integration and Automation: This section measures the skills of Automation Engineers in deploying and managing Palo Alto Networks NGFWs across various environments. It includes the installation of PA-Series, VM-Series, CN-Series, and Cloud NGFWs. The use of APIs for automation, integration with third-party services like Kubernetes and Terraform, centralized management with Panorama templates and device groups, as well as building custom dashboards and reports in Application Command Center (ACC) are key topics.
| | Topic 2 | - PAN-OS Device Setting Configuration: This section evaluates the expertise of System Administrators in configuring device settings on PAN-OS. It includes implementing authentication roles and profiles, and configuring virtual systems with interfaces, zones, routers, and inter-VSYS security. Logging mechanisms such as Strata Logging Service and log forwarding are covered alongside software updates and certificate management for PKI integration and decryption. The section also focuses on configuring Cloud Identity Engine User-ID features and web proxy settings.
| | Topic 3 | - PAN-OS Networking Configuration: This section of the exam measures the skills of Network Engineers in configuring networking components within PAN-OS. It covers interface setup across Layer 2, Layer 3, virtual wire, tunnel interfaces, and aggregate Ethernet configurations. Additionally, it includes zone creation, high availability configurations (active
- active and active
- passive), routing protocols, and GlobalProtect setup for portals, gateways, authentication, and tunneling. The section also addresses IPSec, quantum-resistant cryptography, and GRE tunnels.
Palo Alto Networks Next-Generation Firewall Engineer Sample Questions (Q22-Q27):NEW QUESTION # 22
A large enterprise wants to implement certificate-based authentication for both users and devices, using an on-premises Microsoft Active Directory Certificate Services (AD CS) hierarchy as the primary certificate authority (CA). The enterprise also requires Online Certificate Status Protocol (OCSP) checks to ensure efficient revocation status updates and reduce the overhead on its NGFWs. The environment includes multiple Active Directory forests, Panorama management for several geographically dispersed firewalls, GlobalProtect portals and gateways needing distinct certificate profiles for users and devices, and strict Security policies demanding frequent revocation checks with minimal latency.
Which approach best addresses these requirements while maintaining consistent policy enforcement?
- A. Obtain wildcard certificates from a public CA for both user and device authentication, and configure firewalls to perform CRL polling at the default update interval. Manually install user certificates on endpoints and synchronize firewall certificate stores through frequent manual SSH updates to maintain consistency.
- B. Distribute the root and intermediate CA certificates via Panorama as shared objects to ensure all firewalls have a consistent trust chain. Configure OCSP responder profiles on each firewall to offload revocation checks to an internal OCSP server while keeping CRL checks as a fallback. Maintain separate certificate profiles for user and device authentication and use an automated enrollment method - such as Group Policy or SCEP - to deploy certificates to endpoints.
- C. Deploy self-signed certificates at each site to simplify local certificate validation and reduce dependencies on a centralized CA. Turn off certificate revocation checks for lower overhead, rely on IP-based rules for GlobalProtect authentication, and use a single certificate profile for both users and devices.
- D. Configure each firewall independently to trust the root and intermediate CA certificates. Rely only on manual CRL checks for certificate revocation, and import both user and device certificates directly into each firewall's local certificate store for authentication.
This approach best addresses the enterprise's requirements for certificate-based authentication, OCSP checks, and consistent policy enforcement:
Distributing the root and intermediate CA certificates via Panorama ensures that all firewalls in the enterprise are consistent in their trust chain and can validate certificates properly.
Configuring OCSP responder profiles on each firewall offloads the revocation checks to an internal OCSP server, which reduces the overhead on the firewalls and ensures fast, real-time certificate status checks.
Using CRL checks as a fallback ensures reliability in case the OCSP responder is unavailable.
Separate certificate profiles for users and devices ensure that the firewall can enforce different security policies based on the type of certificate (user vs. device).
Automated certificate enrollment methods such as Group Policy or SCEP streamline certificate distribution to endpoints, ensuring efficient management of certificates across geographically dispersed firewalls.
NEW QUESTION # 23
What is a result of enabling split tunneling in the GlobalProtect portal configuration with the "Both Network Traffic and DNS" option?
- A. It specifies which domains are resolved by the VPN-assigned DNS servers and which domains are resolved by the local DNS servers.
- B. It allows users to access internal resources when connected locally and external resources when connected remotely using the same FQDN.
- C. lt allows devices on a local network to access blocked websites by changing which DNS server resolves certain domain names.
- D. It specifies when the secondary DNS server is used for resolution to allow access to specific domains that are not managed by the VPN.
When split tunneling is enabled with the "Both Network Traffic and DNS" option in the GlobalProtect portal configuration, it allows the firewall to control which traffic is sent over the VPN tunnel and which is not. Specifically, it determines which domains are resolved by the VPN-assigned DNS servers (for domains requiring VPN access) and which are resolved by local DNS servers (for domains that can be accessed without the VPN tunnel).
NEW QUESTION # 24
What must be configured before a firewall administrator can define policy rules based on users and groups?
- A. User Mapping profile
- B. LDAP Server profile
- C. Group mapping settings
- D. Authentication profile
Before a firewall administrator can define policy rules based on users and groups, the Group Mapping settings must be configured. These settings enable the firewall to map users to their respective Active Directory (AD) groups. This mapping allows the firewall to use user and group information to create policy rules based on group membership.
NEW QUESTION # 25
Palo Alto Networks NGFWs use SSL/TLS profiles to secure which two types of connections? (Choose two.)
- A. User Authentication
- B. NAT tables
- C. GlobalProtect Gateways
- D. GlobalProtect Portal
Palo Alto Networks Next-Generation Firewalls (NGFWs) use SSL/TLS profiles to secure connections for services such as GlobalProtect Gateways and GlobalProtect Portals. These profiles are used to manage the SSL/TLS encryption and decryption for secure communication between the firewall and clients (such as VPN clients for GlobalProtect). This helps ensure the confidentiality and integrity of the data during transmission.
NEW QUESTION # 26
Without performing a context switch, which set of operations can be performed that will affect the operation of a connected firewall on the Panorama GUI?
- A. Modification of pre-security rules, modification of a virtual router, modification of an IKE Gateway Network Profile
- B. Modification of local security rules, modification of a Layer 3 interface, modification of the firewall device hostname
- C. Modification of post NAT rules, creation of new views on the local firewall ACC tab, creation of local custom reports
- D. Restarting the local firewall, running a packet capture, accessing the firewall CLI
In Panorama, without performing a context switch, the administrator can perform local configuration tasks directly on the connected firewall. The following operations can be done:
Modification of local security rules: Security rules can be modified directly on the connected firewall from the Panorama GUI.
Modification of a Layer 3 interface: Changes to the Layer 3 interfaces on the connected firewall can be done from Panorama, without needing to switch to the firewall's local interface.
Modification of the firewall device hostname: The firewall's hostname can be changed via Panorama.
NEW QUESTION # 27
The authoritative, efficient, and thoughtful service of NGFW-Engineer learning question will give you the best user experience, and you can also get what you want with our NGFW-Engineer study materials. I hope our study materials can accompany you to pursue your dreams. If you can choose NGFW-Engineer test guide, we will be very happy. We look forward to meeting you. You can choose your favorite our study materials version according to your feelings. When you use NGFW-Engineer Test Guide, you can also get our services at any time. We will try our best to solve your problems for you. I believe that you will be more inclined to choose a good service product, such as NGFW-Engineer learning question. After all, everyone wants to be treated warmly and kindly, and hope to learn in a more pleasant mood.
Latest NGFW-Engineer Dumps Book: https://www.itdumpsfree.com/NGFW-Engineer-exam-passed.html
- NGFW-Engineer Downloadable PDF 🚓 Study NGFW-Engineer Material 📚 Exam NGFW-Engineer Guide 🕒 Simply search for ▷ NGFW-Engineer ◁ for free download on ✔ [url]www.testkingpass.com ️✔️ ⏰Accurate NGFW-Engineer Answers[/url]
- Study NGFW-Engineer Material 🐀 Reliable NGFW-Engineer Test Cost 💌 Reliable NGFW-Engineer Test Cost 🏕 Search for ⮆ NGFW-Engineer ⮄ and easily obtain a free download on ➽ [url]www.pdfvce.com 🢪 🟢NGFW-Engineer Downloadable PDF[/url]
- NGFW-Engineer Latest Test Cram - Valid Palo Alto Networks Latest NGFW-Engineer Dumps Book: Palo Alto Networks Next-Generation Firewall Engineer 🦜 Enter ⮆ [url]www.prep4away.com ⮄ and search for ➡ NGFW-Engineer ️⬅️ to download for free 📴Accurate NGFW-Engineer Answers[/url]
- Pass Guaranteed Quiz 2026 Valid NGFW-Engineer: Palo Alto Networks Next-Generation Firewall Engineer Latest Test Cram 💳 Go to website [ [url]www.pdfvce.com ] open and search for ¡¶ NGFW-Engineer ¡· to download for free 🖤NGFW-Engineer Test Engine Version[/url]
- Free PDF Quiz The Best NGFW-Engineer - Palo Alto Networks Next-Generation Firewall Engineer Latest Test Cram 📞 Search on ➡ [url]www.troytecdumps.com ️⬅️ for { NGFW-Engineer } to obtain exam materials for free download 🧇NGFW-Engineer Latest Exam Experience[/url]
- NGFW-Engineer Valid Dumps Pdf 🤰 Accurate NGFW-Engineer Answers 🎄 Exam NGFW-Engineer Guide 🎻 Enter ▛ [url]www.pdfvce.com ▟ and search for ✔ NGFW-Engineer ️✔️ to download for free 🔺NGFW-Engineer Exam Bible[/url]
- NGFW-Engineer Downloadable PDF 🛑 Study NGFW-Engineer Material 💻 NGFW-Engineer Latest Demo 🟥 Easily obtain free download of ¡¶ NGFW-Engineer ¡· by searching on ⮆ [url]www.examcollectionpass.com ⮄ 💕New NGFW-Engineer Test Braindumps[/url]
- NGFW-Engineer Test Engine Version 🏁 NGFW-Engineer Valid Dumps Pdf 🚉 Exam NGFW-Engineer Guide 📓 Download ➡ NGFW-Engineer ️⬅️ for free by simply entering { [url]www.pdfvce.com } website 👙NGFW-Engineer Latest Test Fee[/url]
- 100% Pass 2026 NGFW-Engineer: Latest Palo Alto Networks Next-Generation Firewall Engineer Latest Test Cram 🍙 Open { [url]www.prep4away.com } and search for ⇛ NGFW-Engineer ⇚ to download exam materials for free 🐲Exam NGFW-Engineer Study Guide[/url]
- Study NGFW-Engineer Material 🆒 Exam NGFW-Engineer Guide 😗 NGFW-Engineer Downloadable PDF 👏 Search for { NGFW-Engineer } and obtain a free download on ➥ [url]www.pdfvce.com 🡄 🐜New NGFW-Engineer Test Braindumps[/url]
- Providing You Pass-Sure NGFW-Engineer Latest Test Cram with 100% Passing Guarantee 🏜 Go to website ▶ [url]www.vce4dumps.com ◀ open and search for ➠ NGFW-Engineer 🠰 to download for free 🐕New NGFW-Engineer Test Braindumps[/url]
- shortcourses.russellcollege.edu.au, www.stes.tyc.edu.tw, www.mixcloud.com, pedulihati.yukcollab.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, hub.asifulfat.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of ITdumpsfree NGFW-Engineer dumps from Cloud Storage: https://drive.google.com/open?id=10AUBsqhGjGfb79dI60SCYSG_7NrzxhPx
