[General] Pass Guaranteed Quiz Microsoft - Pass-Sure SC-200 - Microsoft Security Operation
81
【General】 Pass Guaranteed Quiz Microsoft - Pass-Sure SC-200 - Microsoft Security Operation
Posted at 1/9/2026 12:46:34      View:217 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ValidDumps SC-200 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1oxwd-xRNcH4GWpAIlK3xoSbu4gyDQ3xe
This challenge of SC-200 study quiz is something you do not need to be anxious with our practice materials. If you make choices on practice materials with untenable content, you may fail the exam with undesirable outcomes. Our SC-200 guide materials are totally to the contrary. Confronting obstacles or bottleneck during your process of reviewing, our SC-200 practice materials will fix all problems of the exam and increase your possibility of getting dream opportunities dramatically.
Microsoft SC-200 Exam is aimed at security professionals who want to enhance their skills and knowledge in the security operations domain. SC-200 exam measures the candidate's ability to perform tasks such as analyzing security data, detecting and responding to security incidents, and implementing security controls. Microsoft Security Operations Analyst certification is ideal for individuals who work in roles such as security analyst, incident responder, or SOC analyst. Microsoft Security Operations Analyst certification also helps professionals to stand out in a competitive job market and opens up new career opportunities.
SC-200 Reliable Exam Price | New SC-200 Exam FormatMany clients worry that after they bought our SC-200 exam simulation they might find the exam questions are outdated and waste their time, money and energy. There are no needs to worry about that situation because our SC-200 study materials boost high-quality and it is proved by the high passing rate and hit rate. And we keep updating our SC-200 learing quiz all the time. We provide the best SC-200 practice guide and hope our sincere service will satisfy all the clients.
Microsoft SC-200 Certification Exam is an excellent credential for security professionals who are interested in validating their security operations skills. By passing the exam, you will demonstrate your ability to identify and mitigate security threats, analyze security data, and respond to security incidents. Microsoft Security Operations Analyst certification is a valuable credential that can help you advance your career and demonstrate your commitment to staying current with the latest security best practices and methodologies.
Microsoft Security Operations Analyst Sample Questions (Q59-Q64):NEW QUESTION # 59
You have an Azure subscription that uses Microsoft Sentinel and contains a user named User1.
You need to ensure that User1 can enable User and Entity Behavior Analytics (UEBA) for entity behavior in the Microsoft Entra tenant. The solution must use the principle of least privilege.
Which roles should you assign to User1? To answer, select the appropriate options in the answer area.
Enabling User and Entity Behavior Analytics (UEBA) in Microsoft Sentinel requires specific permissions in both Microsoft Entra ID (Azure AD) and the Azure Sentinel workspace. The goal is to grant the least privilege necessary for the user (User1) to enable UEBA and manage entity behavior analytics.
Microsoft's documentation for UEBA setup specifies that to enable UEBA for an Entra tenant, the user must have access to identity-related signals and security settings within the Microsoft Entra environment.
Specifically:
"To enable UEBA and connect Microsoft Entra ID data, the user must be assigned the Security Administrator role in Microsoft Entra ID. This role allows management of security-related features without granting full directory or global admin privileges." The Security Administrator role provides just enough access to security configurations, alerts, and risk data, aligning with the principle of least privilege.
Other roles:
* Global Administrator is overly privileged.
* Security Operator can only view alerts, not configure settings.
* Identity Governance Administrator focuses on access reviews and entitlement management, not UEBA setup.
Hence, the correct Entra role is Security Administrator.
For the Azure side, Microsoft's official Sentinel RBAC guidance states:
"To enable or configure UEBA in a Sentinel workspace, the user must have the Microsoft Sentinel Contributor role. This role allows enabling and configuring UEBA, managing analytics, and viewing data within Sentinel." The Sentinel Contributor role grants permissions to configure data connectors, UEBA settings, and entity analytics features but not workspace-wide administrative rights.
Other options:
* Microsoft Sentinel Automation Contributor is limited to playbook and automation configurations.
* Security Admin and Security Assessment Contributor roles apply to Microsoft Defender for Cloud and general Azure security posture, not UEBA configuration.
# Final Correct Roles:
* Microsoft Entra role: Security Administrator
* Azure role: Microsoft Sentinel Contributor
NEW QUESTION # 60
You need to use an Azure Resource Manager template to create a workflow automation that will trigger an automatic remediation when specific security alerts are received by Azure Security Center.
How should you complete the portion of the template that will provision the required Azure resources? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... rt-automation-alert
NEW QUESTION # 61
You need to configure DC1 to meet the business requirements.
1 - log in to https://portal.atp.azure.com as a global admin
2 - Create the instance
3 - Connect the instance to Active Directory
4 - Download and install the sensor.
NEW QUESTION # 62
You have two Azure subscriptions that use Microsoft Defender for Cloud.
You need to ensure that specific Defender for Cloud security alerts are suppressed at the root management group level. The solution must minimize administrative effort.
What should you do in the Azure portal?
  • A. Modify the Workload protections settings in Defender for Cloud.
  • B. Modify the alert settings in Defender for Cloud.
  • C. Create an Azure Policy assignment.
  • D. Create an alert rule in Azure Monitor.
You can use alerts suppression rules to suppress false positives or other unwanted security alerts from Defender for Cloud.
Note: To create a rule directly in the Azure portal:
1. From Defender for Cloud's security alerts page:
Select the specific alert you don't want to see anymore, and from the details pane, select Take action.
Or, select the suppression rules link at the top of the page, and from the suppression rules page select Create new suppression rule:
2. In the new suppression rule pane, enter the details of your new rule.
Your rule can dismiss the alert on all resources so you don't get any alerts like this one in the future.
Your rule can dismiss the alert on specific criteria - when it relates to a specific IP address, process name, user account, Azure resource, or location.
3. Enter details of the rule.
4. Save the rule.
Reference: https://docs.microsoft.com/en-us ... s-suppression-rules
NEW QUESTION # 63
You need to use an Azure Sentinel analytics rule to search for specific criteria in Amazon Web Services (AWS) logs and to generate incidents.
a Microsoft 365 E5
1 - Add the Amazon Web Services connector
2 - From Analytics in Azure Sentinel, create a custom analytics rule that uses a scheduled query
3 - Set the alert logic
https://docs.microsoft.com/en-us ... tect-threats-custom
NEW QUESTION # 64
SC-200 Reliable Exam Price: https://www.validdumps.top/SC-200-exam-torrent.html
What's more, part of that ValidDumps SC-200 dumps now are free: https://drive.google.com/open?id=1oxwd-xRNcH4GWpAIlK3xoSbu4gyDQ3xe
Posted at 1/15/2026 20:21:04        Only Author  2#
That article was a goldmine of information. Improve your IT abilities and access free Reliable exam 77202T sample online. Best of luck with your exams!
Posted at 1/20/2026 17:14:29        Only Author  3#
Your article was truly eye-catching and impressive, thank you! Wish me the best of luck for the upcoming Marketing-Cloud-Administrator valid practice questions files exam!
Posted at 2/8/2026 16:21:39        Only Author  4#
I am deeply inspired by this article, thanks for sharing! Using the Valid C-BCBAI-2502 exam dumps.zip, I achieved a promotion and salary raise. It’s now free to everyone. Wishing you all success in your career journey!
