312-50v13 Exam Online | Latest 312-50v13 Examprep
Posted at 1/9/2026 15:29:39
View149
Replies2
DOWNLOAD the newest VCETorrent 312-50v13 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1NUZ2K11JwUy3bs35DSA-t3vAp4AdxSPg
Based on high-quality products, our 312-50v13 guide torrent has high quality to guarantee your test pass rate, which can achieve 98% to 100%. 312-50v13 study tool is updated online by our experienced experts, and then sent to the user. So you dont need to pay extra attention on the updating of study materials. The data of our 312-50v13 Exam Torrent is forward-looking and can grasp hot topics to help users master the latest knowledge. If you are not reconciled and want to re-challenge yourself again, we will give you certain discount.
PDF format is pretty much easy to use for the ones who always have their smart devices and love to prepare for Certified Ethical Hacker Exam (CEHv13) (312-50v13) exam from them. Applicants can also make notes of printed 312-50v13 Exam Material so they can use it anywhere in order to pass Certified Ethical Hacker Exam (CEHv13) (312-50v13) with a good score.
Exam Questions for the ECCouncil 312-50v13 Exam 2026 - Pass EasilyThe ECCouncil expert team use their knowledge and experience to make out the latest short-term effective training materials. This training materials is helpful to the candidates. It allows you to achieve the desired results in the short term. Especially those who study 312-50v13 while working, you can save a lot of time easily. VCETorrent's training materials are the thing which you most wanted.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q711-Q716):NEW QUESTION # 711
While analyzing suspicious network activity, you observe a slow, stealthy scanning technique that is difficult to trace back to the attacker. Which scenario best describes the scanning technique being used?
- A. The attacker performs full TCP connect scans on all ports
- B. The attacker uses a "zombie" machine to perform scans, hiding their true identity
- C. The attacker sends packets with all TCP flags set
- D. The attacker sends FIN packets to infer port states based on responses
According to the CEH Network Scanning module, Idle Scanning (Zombie Scanning) is one of the most stealthy reconnaissance techniques. In this method, the attacker uses an idle third-party host (zombie) to probe the target indirectly.
Because all scan packets appear to originate from the zombie system, the true attacker remains hidden. CEH highlights that idle scans:
* Are extremely stealthy
* Generate minimal traffic from the attacker
* Make attribution very difficult
Option B is correct.
Option A (FIN scan) is stealthy but still traceable.
Option C is noisy and easily detected.
Option D describes a Xmas scan, which is detectable.
CEH classifies idle scanning as one of the hardest scanning techniques to trace.
NEW QUESTION # 712
A penetration tester identifies malware that monitors the activities of a user and secretly collects personal information, such as login credentials and browsing habits. What type of malware is this?
- A. Ransomware
- B. Worm
- C. Spyware
- D. Rootkit
CEH defines spyware as malware designed to covertly observe user behavior and transmit sensitive information to attackers without the victim's knowledge. Spyware commonly records keystrokes, browser activity, form submissions, application usage, and other personally identifiable information. CEH highlights that spyware often operates silently and may disguise itself as legitimate software, making detection difficult.
Unlike rootkits-which hide processes and files-or worms that self-replicate, spyware focuses exclusively on monitoring and data exfiltration. It is frequently installed through phishing, drive-by downloads, browser vulnerabilities, or malicious installers. Spyware can serve as a stepping stone for further system compromise by providing attackers with credentials for privilege escalation, lateral movement, or financial theft. CEH emphasizes the need for endpoint hardening, updated anti-malware engines, and behavioral analysis tools to detect such stealthy monitoring programs.
NEW QUESTION # 713
There have been concerns in your network that the wireless network component is not sufficiently secure.
You perform a vulnerability scan of the wireless network and find that it is using an old encryption protocol that was designed to mimic wired encryption, what encryption protocol is being used?
- A. WPA
- B. WPA3
- C. WEP
- D. RADIUS
Wired Equivalent Privacy (WEP) may be a security protocol, laid out in the IEEE wireless local area network (Wi-Fi) standard, 802.11b, that's designed to supply a wireless local area network (WLAN) with A level of security and privacy like what's usually expected of a wired LAN. A wired local area network (LAN) is usually protected by physical security mechanisms (controlled access to a building, for example) that are effective for a controlled physical environment, but could also be ineffective for WLANs because radio waves aren't necessarily bound by the walls containing the network. WEP seeks to determine similar protection thereto offered by the wired network's physical security measures by encrypting data transmitted over the WLAN. encoding protects the vulnerable wireless link between clients and access points; once this measure has been taken, other typical LAN security mechanisms like password protection, end-to-end encryption, virtual private networks (VPNs), and authentication are often put in situ to make sure privacy.
A research group from the University of California at Berkeley recently published a report citing "major security flaws" in WEP that left WLANs using the protocol susceptible to attacks (called wireless equivalent privacy attacks). within the course of the group's examination of the technology, they were ready to intercept and modify transmissions and gain access to restricted networks. The Wireless Ethernet Compatibility Alliance (WECA) claims that WEP - which is included in many networking products - was never intended to be the only security mechanism for a WLAN, and that, in conjunction with traditional security practices, it's very effective.
NEW QUESTION # 714
Gavin owns a white-hat firm and is performing a website security audit. He begins with a scan looking for misconfigurations and outdated software versions. Which tool is he most likely using?
- A. Nikto
- B. Nmap
- C. Armitage
- D. Metasploit
Nikto is an open-source web server scanner that:
Checks for common vulnerabilities
Detects outdated software versions
Flags insecure configurations and files
It is widely used for quick and comprehensive web vulnerability assessments.
From CEH v13 Courseware:
Module 10: Web Application Hacking # Web Vulnerability Scanning Tools
Reference:Nikto Project Page - https://cirt.net/Nikto2
NEW QUESTION # 715
George is a security professional working for iTech Solutions. He was tasked with securely transferring sensitive data of the organization between industrial systems. In this process, he used a short-range communication protocol based on the IEEE 203.15.4 standard. This protocol is used in devices that transfer data infrequently at a low rate in a restricted area, within a range of 10-100 m. What is the short-range wireless communication technology George employed in the above scenario?
- A. NB-IoT
- B. LPWAN
- C. MQTT
- D. Zigbee
Zigbee could be a wireless technology developed as associate open international normal to deal with the unique desires of affordable, low-power wireless IoT networks. The Zigbee normal operates on the IEEE
802.15.4 physical radio specification and operates in unauthorised bands as well as a pair of.4 GHz, 900 MHz and 868 MHz.
The 802.15.4 specification upon that the Zigbee stack operates gained confirmation by the Institute of Electrical and physical science Engineers (IEEE) in 2003. The specification could be a packet-based radio protocol supposed for affordable, battery-operated devices. The protocol permits devices to speak in an exceedingly kind of network topologies and may have battery life lasting many years.
The Zigbee three.0 Protocol
The Zigbee protocol has been created and ratified by member corporations of the Zigbee Alliance.Over three hundred leading semiconductor makers, technology corporations, OEMs and repair corporations comprise the Zigbee Alliance membership. The Zigbee protocol was designed to supply associate easy-to-use wireless information answer characterised by secure, reliable wireless network architectures.
THE ZIGBEE ADVANTAGE
The Zigbee 3.0 protocol is intended to speak information through rip-roaring RF environments that area unit common in business and industrial applications. Version 3.0 builds on the prevailing Zigbee normal however unifies the market-specific application profiles to permit all devices to be wirelessly connected within the same network, no matter their market designation and performance. what is more, a Zigbee 3.0 certification theme ensures the ability of product from completely different makers. Connecting Zigbee three.0 networks to the information science domain unveil observance and management from devices like smartphones and tablets on a local area network or WAN, as well as the web, and brings verity net of Things to fruition.
Zigbee protocol options include:
Support for multiple network topologies like point-to-point, point-to-multipoint and mesh networks Low duty cycle - provides long battery life Low latency Direct Sequence unfold Spectrum (DSSS) Up to 65,000 nodes per network
128-bit AES encryption for secure information connections
Collision avoidance, retries and acknowledgements
This is another short-range communication protocol based on the IEEE 203.15.4 standard. Zig-Bee is used in devices that transfer data infrequently at a low rate in a restricted area and within a range of 10-100 m.
NEW QUESTION # 716
If you buy the 312-50v13 learning materials from our company, we are glad to provide you with the high quality 312-50v13 study question and the best service. The philosophy of our company is "quality is life, customer is god." We can promise that our company will provide all customers with the perfect quality guarantee system and sound management system. It is not necessary for you to have any worry about the quality and service of the 312-50v13 Learning Materials from our company. If you decide to buy the 312-50v13 study question from our company, you will receive a lot beyond your imagination.
Latest 312-50v13 Examprep: https://www.vcetorrent.com/312-50v13-valid-vce-torrent.html
ECCouncil 312-50v13 Exam Online Believe me, No Pass, Full Refund, No excuse, Our aim is helping every candidate to pass ECCouncil Latest 312-50v13 Examprep exam with less time and money, Once we release version for our valid 312-50v13 guide torrent, users can download automatically on your computer to ensure you get updated pool of real questions, Fortunately, VCETorrent Latest 312-50v13 Examprep can provide you the most reliable training tool for you.
However, if the number of queries is sublinear e.g, Everyone Test 312-50v13 Free sits back at first, preparing for the information deluge, Believe me, No Pass, Full Refund, No excuse!
Our aim is helping every candidate to pass 312-50v13 ECCouncil exam with less time and money, Once we release version for our valid 312-50v13 guide torrent, users can download 312-50v13 Frenquent Update automatically on your computer to ensure you get updated pool of real questions.
312-50v13 Exam Preparation & 312-50v13 Study Guide & 312-50v13 Best QuestionsFortunately, VCETorrent can provide you the most Test 312-50v13 Free reliable training tool for you, If you choose us, you will 100% pass the exam for sure.
- Free PDF 2026 ECCouncil 312-50v13 CValid Exam Online 🩲 Open [url]www.practicevce.com and search for ▶ 312-50v13 ◀ to download exam materials for free 🖱Advanced 312-50v13 Testing Engine[/url]
- ECCouncil 312-50v13 Dumps [2026] C312-50v13 Exam Questions 🏯 Search for 312-50v13 and download it for free immediately on ➡ [url]www.pdfvce.com ️⬅️ 🚥Training 312-50v13 Kit[/url]
- Marvelous 312-50v13 Exam Online by [url]www.practicevce.com 🚮 Immediately open ➥ www.practicevce.com 🡄 and search for 312-50v13 to obtain a free download 🆚312-50v13 Latest Braindumps Questions[/url]
- 312-50v13 Cert Guide ⛽ 312-50v13 New Dumps Ebook 📢 312-50v13 Valid Test Materials ☸ Immediately open ▶ [url]www.pdfvce.com ◀ and search for 312-50v13 to obtain a free download 🔳312-50v13 Exam Vce Format[/url]
- Pass Guaranteed Quiz 2026 312-50v13: Perfect Certified Ethical Hacker Exam (CEHv13) Exam Online 🔤 Search for ⏩ 312-50v13 ⏪ and obtain a free download on ▶ [url]www.prepawaypdf.com ◀ 🚢Advanced 312-50v13 Testing Engine[/url]
- 312-50v13 Learning Engine 🏹 312-50v13 Learning Engine 🏡 Customizable 312-50v13 Exam Mode 🕌 Search for [ 312-50v13 ] on [url]www.pdfvce.com immediately to obtain a free download 🌝312-50v13 New Dumps Ebook[/url]
- ECCouncil 312-50v13 Dumps [2026] C312-50v13 Exam Questions 🔂 { [url]www.exam4labs.com } is best website to obtain ➡ 312-50v13 ️⬅️ for free download 👯Free 312-50v13 Braindumps[/url]
- [url=https://kimika.net/?s=ECCouncil%20312-50v13%20Dumps%20[2026]%20%e2%80%93312-50v13%20Exam%20Questions%20%f0%9f%91%bf%20Search%20for%20%e2%9e%a5%20312-50v13%20%f0%9f%a1%84%20and%20download%20exam%20materials%20for%20free%20through%20%e3%80%8a%20www.pdfvce.com%20%e3%80%8b%20%f0%9f%95%9c312-50v13%20Valid%20Torrent]ECCouncil 312-50v13 Dumps [2026] C312-50v13 Exam Questions 👿 Search for ➥ 312-50v13 🡄 and download exam materials for free through www.pdfvce.com 🕜312-50v13 Valid Torrent[/url]
- Test 312-50v13 Centres 🍪 Test 312-50v13 Lab Questions 🎾 312-50v13 Exam Material ⛴ Search on [url]www.prepawaypdf.com for ➥ 312-50v13 🡄 to obtain exam materials for free download 🕠Advanced 312-50v13 Testing Engine[/url]
- 312-50v13 Exam Material 🐾 312-50v13 Learning Engine 🍺 Exam 312-50v13 Forum 💞 Open ▛ [url]www.pdfvce.com ▟ and search for 312-50v13 to download exam materials for free 🐒
DF 312-50v13 Cram Exam[/url] - 312-50v13 New Dumps Ebook 🍟 312-50v13 Exam Quick Prep 💐 PDF 312-50v13 Cram Exam 🦦 Open { [url]www.vce4dumps.com } and search for ▛ 312-50v13 ▟ to download exam materials for free 👋312-50v13 Cert Guide[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.skudci.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, elearnzambia.cloud, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
