[General] Clear NGFW-Engineer Exam | NGFW-Engineer Exam Simulator
66
General Clear NGFW-Engineer Exam | NGFW-Engineer Exam Simulator
Posted at 1/9/2026 19:32:06      View186 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Palo Alto Networks NGFW-Engineer dumps are available on Google Drive shared by Real4dumps: https://drive.google.com/open?id=13YAT-qgHgYBz_C3MqTxqRB-2DadlOdT1
Our company in the field of the NGFW-Engineer exam bootcamp for years, we also enjoy high reputation in the business. You choose us, we will give you the best we have, and your right choice will also bring the benefits to you. With the high reputation in the field, we can guarantee the quality of the NGFW-Engineer Exam Dumps. It also contains the free update for one year for you. It can save your money for updating, and the update version will send to your mailbox automatically.
Palo Alto Networks NGFW-Engineer Exam Syllabus Topics:
  • Integration and Automation: This section measures the skills of Automation Engineers in deploying and managing Palo Alto Networks NGFWs across various environments. It includes the installation of PA-Series, VM-Series, CN-Series, and Cloud NGFWs. The use of APIs for automation, integration with third-party services like Kubernetes and Terraform, centralized management with Panorama templates and device groups, as well as building custom dashboards and reports in Application Command Center (ACC) are key topics.
  • PAN-OS Networking Configuration: This section of the exam measures the skills of Network Engineers in configuring networking components within PAN-OS. It covers interface setup across Layer 2, Layer 3, virtual wire, tunnel interfaces, and aggregate Ethernet configurations. Additionally, it includes zone creation, high availability configurations (active
  • active and active
  • passive), routing protocols, and GlobalProtect setup for portals, gateways, authentication, and tunneling. The section also addresses IPSec, quantum-resistant cryptography, and GRE tunnels.
  • PAN-OS Device Setting Configuration: This section evaluates the expertise of System Administrators in configuring device settings on PAN-OS. It includes implementing authentication roles and profiles, and configuring virtual systems with interfaces, zones, routers, and inter-VSYS security. Logging mechanisms such as Strata Logging Service and log forwarding are covered alongside software updates and certificate management for PKI integration and decryption. The section also focuses on configuring Cloud Identity Engine User-ID features and web proxy settings.
Pass Guaranteed Quiz High-quality Palo Alto Networks - NGFW-Engineer - Clear Palo Alto Networks Next-Generation Firewall Engineer ExamOur Palo Alto Networks NGFW-Engineer exam questions have gained wide popularity among candidates. Almost all customers are willing to introduce our NGFW-Engineer practice quiz to their classmates and friends. And sometimes, they may buy our exam products together. After they have tried our study materials, most of them have successfully passed the Palo Alto Networks NGFW-Engineer Exam and made a lot of money.
Palo Alto Networks Next-Generation Firewall Engineer Sample Questions (Q21-Q26):NEW QUESTION # 21
By default, which type of traffic is configured by service route configuration to use the management interface?
  • A. Virtual system (VSYS)
  • B. Security zone
  • C. IPSec tunnel
  • D. Autonomous Digital Experience Manager (ADEM)
By default, the Autonomous Digital Experience Manager (ADEM) traffic is configured to use the management interface in a Palo Alto Networks firewall. The management interface is typically used for management-related traffic, such as monitoring and logging, and it is configured to handle ADEM-related traffic for the optimal performance of digital experience monitoring features.
This default configuration helps ensure that ADEM traffic does not interfere with regular traffic that may traverse other interfaces, such as traffic from security zones or IPSec tunnels.
NEW QUESTION # 22
What are the phases of the Palo Alto Networks AI Runtime Security: Network Intercept solution?
  • A. Policy Generation, Discovery, Enforcement, Logging
  • B. Discovery, Deployment, Detection, Prevention
  • C. Scanning, Isolation, Whitelisting, Logging
  • D. Profiling, Policy Generation, Enforcement, Reporting
The phases of the Palo Alto Networks AI Runtime Security: Network Intercept solution are designed to help identify and protect against potential threats in real time by using AI to detect and prevent malicious activities within the network.
Discovery: Identifying applications, services, and behaviors within the network to understand baseline activity.
Deployment: Implementing the solution into the network and integrating with existing security measures.
Detection: Monitoring traffic and activities to identify abnormal or malicious behavior.
Prevention: Taking action to stop threats once detected, such as blocking malicious traffic or stopping exploit attempts.
NEW QUESTION # 23
What is a result of enabling split tunneling in the GlobalProtect portal configuration with the "Both Network Traffic and DNS" option?
  • A. It specifies when the secondary DNS server is used for resolution to allow access to specific domains that are not managed by the VPN.
  • B. It specifies which domains are resolved by the VPN-assigned DNS servers and which domains are resolved by the local DNS servers.
  • C. It allows users to access internal resources when connected locally and external resources when connected remotely using the same FQDN.
  • D. lt allows devices on a local network to access blocked websites by changing which DNS server resolves certain domain names.
When split tunneling is enabled with the "Both Network Traffic and DNS" option in the GlobalProtect portal configuration, it allows the firewall to control which traffic is sent over the VPN tunnel and which is not. Specifically, it determines which domains are resolved by the VPN-assigned DNS servers (for domains requiring VPN access) and which are resolved by local DNS servers (for domains that can be accessed without the VPN tunnel).
NEW QUESTION # 24
A multinational organization wants to use the Cloud Identity Engine (CIE) to aggregate identity data from multiple sources (on premises AD, Azure AD, Okta) while enforcing strict data isolation for different regional business units. Each region's firewalls, managed via Panorama, must only receive the user and group information relevant to that region. The organization aims to minimize administrative overhead while meeting data sovereignty requirements.
Which approach achieves this segmentation of identity data?
  • A. Create one CIE tenant, aggregate all identity data into a single view, and redistribute the full dataset to all firewalls. Rely on per-firewall Security policies to restrict access to out-of-scope user and group information.
  • B. Disable redistribution of identity data entirely. Instead, configure each regional firewall to pull user and group details directly from its local identity providers (IdPs).
  • C. Deploy a single CIE tenant that collects all identity data, then configure segments within the tenant to filter and redistribute only the relevant user/group sets to each regional firewall group.
  • D. Establish separate CIE tenants for each business unit, integrating each tenant with the relevant identity sources. Redistribute user and group data from each tenant only to the region's firewalls, maintaining a strict one-to-one mapping of tenant to business unit.
To meet the requirement of data isolation for different regional business units while minimizing administrative overhead, the best approach is to establish separate Cloud Identity Engine (CIE) tenants for each business unit. Each tenant would be integrated with the relevant identity sources (such as on-premises AD, Azure AD, and Okta) for that specific region. This ensures that the identity data for each region is kept isolated and only relevant user and group data is distributed to the respective regional firewalls.
By maintaining a strict one-to-one mapping between CIE tenants and business units, the organization ensures that each region's firewall only receives the user and group data relevant to that region, thus meeting data sovereignty requirements and minimizing administrative complexity.
NEW QUESTION # 25
For which two purposes is an IP address configured on a tunnel interface? (Choose two.)
  • A. Redistribution of User-ID
  • B. Use of peer IP
  • C. Tunnel monitoring
  • D. Use of dynamic routing protocols
Use of dynamic routing protocols: An IP address is needed on the tunnel interface to participate in dynamic routing protocols (like OSPF, BGP, etc.) over the tunnel. This allows the firewall to advertise routes and receive updates over the tunnel.
Tunnel monitoring: The IP address on the tunnel interface can also be used for monitoring the tunnel's status. Tunnel monitoring (such as IPSec tunnel monitoring) requires an IP address on the tunnel interface to check the health and availability of the tunnel.
NEW QUESTION # 26
We provide free update to the client and the discounts to the old client. We provide free update of our NGFW-Engineer exam materials within one year and after one year the client can enjoy the 50% discounts. The old clients enjoy some certain discounts when they buy our NGFW-Engineer exam torrent. Our experts check whether there is the update of the test bank every day and if there is the system will send to the client automatically. We choose the most typical questions and answers which seize the focus and important information and the questions and answers are based on the real exam. So you can master the most important NGFW-Engineer Exam Torrent in the shortest time and finally pass the exam successfully.
NGFW-Engineer Exam Simulator: https://www.real4dumps.com/NGFW-Engineer_examcollection.html
What's more, part of that Real4dumps NGFW-Engineer dumps now are free: https://drive.google.com/open?id=13YAT-qgHgYBz_C3MqTxqRB-2DadlOdT1
Posted at 1/20/2026 21:04:00        Only Author  2#
Thank you so much for your article, its something Ill remember. Here's the AD0-E409 latest exam study guide test that helped me land my promotion and raise. It's free todaygood luck with your career progress!
Posted at 1/26/2026 21:49:22        Only Author  3#
This article has given me a new understanding of this field, and its truly inspiring. The MSP-Practitioner valid practice questions exam is approaching. Hope I ace it!
