[Hardware] Real Microsoft AZ-800 Testing Environment | AZ-800 Exam Actual Tests
66
Hardware Real Microsoft AZ-800 Testing Environment | AZ-800 Exam Actual Tests
Posted at 1/9/2026 19:43:11      View202 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft AZ-800 dumps are available on Google Drive shared by SureTorrent: https://drive.google.com/open?id=1C3h9wFGAhneqYNHf0yPdBAddk-YM9S8u
Now we live in a highly competitive world. If you want to find a decent job and earn a high salary you must own excellent competences and rich knowledge. Under this circumstance, owning a AZ-800 guide torrent is very important because it means you master good competences in certain areas and can handle the job well. The AZ-800 exam prep we provide can help you realize your dream to pass exam and then own a AZ-800 exam torrent. SureTorrent provide high pass rate materials that are compiled by experts with profound experiences according to the latest development in the theory and the practice so they are of great value. Please firstly try out our AZ-800 Exam Materials demo before you decide to buy our product. It is worthy for you to buy our AZ-800 exam preparation not only because it can help you pass the exam successfully but also because it saves your time and energy.
The reality is that developing skills is a must, and earning a certification from a worldly-renowned vendor is one of the variants. If your aim is to get a position as a Windows Server Hybrid Administrator, then passing the AZ-800 exam is what you need to do first of all. The second exam that you will need to sit for is AZ-801. Still, lets have a closer look at the AZ-800 test also known as Administering Windows Server Hybrid Core Infrastructure.
Use Real Microsoft AZ-800 Dumps PDF To Get SuccessOur company has dedicated ourselves to develop the AZ-800 latest practice materials for all candidates to pass the exam easier, also has made great achievement after more than ten years' development. As the certification has been of great value, a right AZ-800 exam guide can be your strong forward momentum to help you pass the AZ-800 Exam like a hot knife through butter. And our AZ-800 exam questions are exactly the right one for you as our high quality of AZ-800 learning guide is proved by the high pass rate of more than 98%.
Microsoft Administering Windows Server Hybrid Core Infrastructure Sample Questions (Q216-Q221):NEW QUESTION # 216
Your company has offices in Boston and Montreal. The offices are connected by using a 10-Mbps WAN link that is often saturated The office in Boston contains the following:
* An Active Directory Domain Services (AD DS) domain controller named DC1.
* A server named Server1 that runs Windows Server and has the File Server role installed The office in Montreal contains 20 client computers that run Windows 10 Montreal does NOT have any servers.
The company plans to deploy a new line of business (LOB) application to all the client computers. The installation source files for the application are in \ServerApps.
NEW QUESTION # 217
You have a server named Server1 that runs Windows Server and has the Active Directory Federation Services role installed.
You plan to deploy Web Application Proxy to a server named Server2.
You export the Active Directory Federation Services (AD FS) certificate from Server1.
Which actions should you perform on Server2 in sequence? To answer, drag the appropriate actions to the correct order. Each action may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NOTF: Each correct selection is worth one point.
<Step 1: Install the Remote Access role.
Step 2: Import the AD FS certificate to Server2.
Step 3: Run the Web Application Proxy Configuration Wizard.
In Administering Windows Server Hybrid Core Infrastructure, the Web Application Proxy (WAP) component is documented as a role service of the Remote Access role and is deployed on an edge or perimeter server to publish AD FS and other web apps. The guide states that before configuring WAP, you must install the Remote Access role with the Web Application Proxy role service on the proxy server. It further explains that WAP must establish trust with the existing AD FS farm by using the AD FS service communications certificate: "Import the federation service SSL certificate (with private key) on the proxy server and place it in the local computer's personal store." After the certificate is present, you run the Web Application Proxy Configuration Wizard to "specify the Federation Service name, provide AD FS credentials, and complete the trust and configuration." The materials also clarify that you do not install the AD FS role on the proxy and Microsoft Application Request Routing (ARR) is not required for WAP. The AD FS Configuration Wizard applies to federation servers, not proxies. Therefore, the minimal and correct sequence on Server2 is: Install Remote Access (WAP) # Import the AD FS cert # Run the Web Application Proxy Configuration Wizard, which configures the trust and enables publishing of the AD FS endpoint.
NEW QUESTION # 218
You need to meet the technical requirements for VM3
On which volumes can you enable Data Deduplication?
  • A. D, E, and F only
  • B. C, D, E, and F
  • C. D and E only
  • D. D and E only
  • E. D only
Answer: E
In the Windows Server exam materials for Administering Windows Server Hybrid Core Infrastructure (AZ-
800), Microsoft documents that Data Deduplication is supported only on data volumes and specifically on NTFS-formatted volumes, and it cannot be enabled on the system or boot volume. The study text states:
"Data Deduplication is applied at the volume level and supports NTFS data volumes. You cannot enable deduplication on the system or boot volume." It further clarifies unsupported targets: "ReFS volumes and FAT
/exFAT volumes are not supported for Data Deduplication in general-purpose server scenarios," and emphasizes that deduplication is "not available for the operating system volume." Applying these rules to VM3:
* C: NTFS but it is the OS/system volume # not eligible.
* D: NTFS data volume # eligible.
* E: ReFS # not supported for general-purpose dedup in this context.
* F: exFAT # not supported.
Therefore, the only volume on which you can enable Data Deduplication to meet the requirement is volume D.
NEW QUESTION # 219
Which groups can you add to Group3 and Group5? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... ory-security-groups
NEW QUESTION # 220
SIMULATION
You need to run a container that uses the mcr.microsoft.com/windows/servercore/iis image on SRV1. Port 80 on the container must be published to port 5001 on SRV1 and the container must run in the background.
To complete this task, sign in to the required computer or computers.
NEW QUESTION # 221
Administering Windows Server Hybrid Core Infrastructure (AZ-800) exam dumps offers are categorized into several categories, so you can find the one that's right for you. AZ-800 practice exam software uses the same testing method as the real AZ-800 exam. With AZ-800 exam questions, you can prepare for your Administering Windows Server Hybrid Core Infrastructure (AZ-800) certification exam. Job proficiency can be evaluated through AZ-800 Exam Dumps that include questions that relate to a company's ideal personnel. These Microsoft AZ-800 practice test feature questions similar to conventional scenarios, making scoring questions especially applicable for entry-level recruits and mid-level executives.
AZ-800 Exam Actual Tests: https://www.suretorrent.com/AZ-800-exam-guide-torrent.html
What's more, part of that SureTorrent AZ-800 dumps now are free: https://drive.google.com/open?id=1C3h9wFGAhneqYNHf0yPdBAddk-YM9S8u
Posted at 1/14/2026 17:48:11        Only Author  2#
The article is excellently written, and it has benefited me greatly. Free access to C_ARSUM_2508 valid test questions fee, full of rich content, is available to enhance your studies.
