[Hardware] Exam 1Z0-1042-25 Quizzes & 1Z0-1042-25 Exam Cram
122
【Hardware】 Exam 1Z0-1042-25 Quizzes & 1Z0-1042-25 Exam Cram
Posted at 1/9/2026 22:10:08      View:120 | Replies:5        Print      Only Author   [Copy Link] 1#
2026 Latest Actual4Labs 1Z0-1042-25 PDF Dumps and 1Z0-1042-25 Exam Engine Free Share: https://drive.google.com/open?id=1DE1voQDA1dqD-FgcBYWTKIv5bJB9BI74
Our website provides the most up to date and accurate Oracle 1Z0-1042-25 learning materials which are the best for clearing 1Z0-1042-25 real exam. It is best choice to accelerate your career as a professional in the information technology industry. We are proud of our reputation of helping people clear 1Z0-1042-25 Actual Test in your first attempt. Our pass rate reached almost 86% in recent years.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Topic 5
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
1Z0-1042-25 Exam Cram & Latest 1Z0-1042-25 Test PdfAfter successful competition of the Oracle 1Z0-1042-25 certification, the certified candidates can put their career on the right track and achieve their professional career objectives in a short time period. For the recognition of skills and knowledge, more career opportunities, professional development, and higher salary potential, the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) certification exam is the proven way to achieve these tasks quickly.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q88-Q93):NEW QUESTION # 88
You have built an integration that includes an ERP Cloud Adapter connection. After the development has been completed, there is now a requirement to include newly added custom objects and custom attributes as part of the mappings. Which is the most efficient way to handle this requirement?
  • A. Check the Refresh Metadata option for the ERP Cloud Connection, navigate back to your integration, then delete and recreate the map action to include the new custom objects and attributes.
  • B. Delete the integration and recreate it to include the new custom objects and attributes in the mapaction.
  • C. Check the Refresh Metadata option for the ERP Cloud Connection, navigate back to your integration, then edit the map action to include the new custom objects and attributes.
  • D. Delete the invoke action to the ERP Cloud, re-create it, then edit the map action to include the new custom objects and attributes.
ERP Updates:
B:True-refresh and edit is efficient.
NEW QUESTION # 89
Integration Insight in Oracle Integration Cloud (OIC) dramatically simplifies the process of modeling and extracting meaningful business metrics, allowing business executives to understand, monitor, and react quickly to changing demands.
After a model has been activated, which is NOT a valid model instance state?
  • A. Healthy
  • B. Successful
  • C. Recoverable
  • D. Failed
  • E. Terminated
Answer: E
"Terminated" is not a valid state for Integration Insight model instances. Valid states include Failed, Successful, Healthy, and Recoverable.
NEW QUESTION # 90
Which statement is NOT true about schedule parameters in Oracle Integration Cloud (OIC) integration flow?
  • A. Updates to Schedule Parameter values can be made manually when starting a schedule.
  • B. Updates to schedule parameters value made dynamically in an Assign action will not persist on to the next instance run of the integration.
  • C. Updates to schedule parameters value can be made manually before submitting an ad hoc request.
  • D. Schedule parameters are always visible as an additional data source in the sources section of the mappers and expression editors within the integration.
Parameters:
B:False-dynamic updates persist in some cases.
NEW QUESTION # 91
Your team is responsible for an OIC package that contains five integrations. Currently, three of these integrations are active while the other two are inactive. Which statement is valid if you were to replace a connection used in this package?
  • A. You can only replace the connections used by the three active integrations.
  • B. You cannot replace connections unless all integrations in the package are in an active state.
  • C. You cannot replace connections unless all integrations in the package are in an inactive state.
  • D. You can only replace the connections used by the two inactive integrations.
OIC packages group integrations:
Option A:True-replacing a connection requires all dependent integrations to be inactive to avoid runtime conflicts.
Option B:False-active integrations can't have connections replaced without deactivation.
Option C:False-replacement isn't limited to inactive ones; all must be inactive.
Option D:False-active state prevents replacement, opposite of the requirement.
A ensures stability during configuration changes.
NEW QUESTION # 92
Which action cannot be performed from the Oracle Integration Cloud (OIC) monitoring Dashboard?
  • A. Download Design-time Audit Records
  • B. View Current Email Count
  • C. View Design-time Metrics
  • D. View Connectivity Agent Group Status
  • E. Download OIC Lookup
Answer: E
The OIC Monitoring Dashboard provides operational insights:
Option B:Audit records can be downloaded for compliance.
Option Cesign-time metrics (e.g., integration stats) are viewable.
Option D:Email counts track notification quotas.
Option E:Agent status is monitorable for hybrid setups.
Option Aookups (static mapping tables) are managed in the Designer, not downloadable from the Monitoring Dashboard, making it the correct answer.
NEW QUESTION # 93
Overall obtaining 1Z0-1042-25 certificate can be a valuable investment in your professional career. As it can help you to stand out in a competitive market, more career opportunities, and advancement of your career. To gain all these advantages you just need to enroll in the Oracle 1Z0-1042-25 Certification Exam and put all your efforts to pass this challenging 1Z0-1042-25 exam with flying colors.
1Z0-1042-25 Exam Cram: https://www.actual4labs.com/Oracle/1Z0-1042-25-actual-exam-dumps.html
BTW, DOWNLOAD part of Actual4Labs 1Z0-1042-25 dumps from Cloud Storage: https://drive.google.com/open?id=1DE1voQDA1dqD-FgcBYWTKIv5bJB9BI74
Posted at 1/10/2026 03:43:37        Only Author  2#
ExamPassdump의Microsoft인증 MB-820시험덤프 공부가이드는 시장에서 가장 최신버전이자 최고의 품질을 지닌 시험공부자료입니다.IT업계에 종사중이라면 IT자격증취득을 승진이나 연봉협상의 수단으로 간주하고 자격증취득을 공을 들여야 합니다.회사다니면서 공부까지 하려면 몸이 힘들어 스트레스가 많이 쌓인다는것을 헤아려주는ExamPassdump가 IT인증자격증에 도전하는데 성공하도록Microsoft인증 MB-820시험대비덤프를 제공해드립니다.
Posted at 1/25/2026 01:37:40        Only Author  3#
The article is truly inspiring, thank you for sharing! The Nonprofit-Cloud-Consultant valid exam registration exam is almost here. Hope I ace it!
Posted at 1/25/2026 13:51:51        Only Author  4#
After reading this article, I have a more in-depth understanding of the related topics. The content in CNPA dump file is rich and free of charge, created with your success in mind.
Posted at 1/28/2026 05:06:19        Only Author  5#
Thank you for your article, it’s been a real eye-opener for me. The CloudSec-Pro hot spot questions helped me earn a promotion and salary increase. I’m now sharing it for free with everyone. Wishing you all success in your careers!
Posted at 1/31/2026 22:21:00        Only Author  6#
I was really impressed by the depth of the article. Using this C-S4PM2-2507 valid exam answers, I secured a promotion and salary boost. Now it’s free for everyone. Wishing you all success in your professional paths!
