[General] Exam Cisco 300-620 Practice | Key 300-620 Concepts
81
【General】 Exam Cisco 300-620 Practice | Key 300-620 Concepts
Posted at 1/9/2026 22:54:49      View:174 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PDF4Test 300-620 dumps from Cloud Storage: https://drive.google.com/open?id=1YASEF4qxPUJcCQ4SZUCBVPaKVnZWA3am
Visit PDF4Test and find out the best features of updated 300-620 exam dumps that is available in three user-friendly formats. We guarantee that you will be able to ace the Implementing Cisco Application Centric Infrastructure 300-620 examination on the first attempt by studying with our actual Cisco 300-620 exam questions.
To be eligible to take the Cisco 300-620 exam, candidates must have a strong understanding of data center technologies, including networking, storage, virtualization, and security. Candidate must also have some experience in the implementation and management of Cisco’s Application Centric Infrastructure. It is recommended that candidates attend the Implementing Cisco Application Centric Infrastructure (DCACI) course before taking the exam.
Cisco 300-620 exam evaluates the candidate's ability to configure, manage, and troubleshoot ACI environments. 300-620 Exam covers a range of topics, including Cisco ACI architecture, policies and access control, fabric discovery, and network topology. Candidates are expected to demonstrate proficiency in working with Cisco ACI fabric, deploying ACI security policies, and configuring Layer 4 to Layer 7 services. Passing 300-620 exam indicates that the candidate has the skills and knowledge necessary to deploy and manage Cisco ACI environments, making them a valuable asset to any organization that uses ACI.
300-620 Exam Guide and 300-620 Exam Prep - 300-620 Exam TorrentThe main key to passing the 300-620 exam is to use your time affectionately and grasp every topic so you can attempt the maximum number of questions in the actual 300-620 Exam. By studying the questions mentioned in the prep material, the candidates have control over the exam anxiety in no time.
PrerequisitesThough the knowledge areas covered by 300-420 exam are wide and extensive, its related certification never put any prerequisites. Anyone can go for this test. However, the vendor states that it is wise to gain three to five years of expertise in data center solution designing before launching this path. With such a background, the exam journey can become a lot more simplified and easy-to-accomplish.
Cisco Implementing Cisco Application Centric Infrastructure Sample Questions (Q208-Q213):NEW QUESTION # 208
Which setting prevents the learning of Endpoint IP addresses whose subnet does not match the bridge domain subnet?
  • A. "Limit IP learning to subnet" setting within the bridge domain.
  • B. "Limit IP learning to network" setting within the EPG.
  • C. "Limit IP learning to network" setting within the bridge domain.
  • D. "Limit IP learning to subnet" setting within the EPG.
The setting that prevents the learning of Endpoint IP addresses whose subnet does not match the bridge domain subnet is the "Limit IP learning to subnet" setting within the bridge domain1. This setting ensures that only IP addresses belonging to the subnets configured on the bridge domain are learned, preventing mis-learning of IP addresses that may not belong to the fabric1.
NEW QUESTION # 209
Which two actions extend a Layer 2 domain beyond the ACI fabric? (Choose two.)
  • A. creating an external physical network
  • B. extending the routed domain out of the ACI fabric
  • C. extending the EPG out of the ACI fabric
  • D. creating a single homed Layer 3 Out
  • E. extending the bridge domain out of the ACI fabric
Answer: C,E
The two actions that extend a Layer 2 domain beyond the ACI fabric are extending the bridge domain out of the ACI fabric (Option D) and extending the EPG out of the ACI fabric (Option E)34. Extending the bridge domain involves creating a Layer 2 outside connection, while extending the EPG involves statically assigning a port with a VLAN ID to an EPG34.
NEW QUESTION # 210
An engineer configures an L30ut in VRF-1 that was configured for Import Route Control Enforcement. The L30ut uses OSPF to peer with a core switch. The L30ut has one external EPG, it has been configured with a subnet 10.1.0.0/24. Which scope must be set to force 10.1.0.0/24 to populate in the routing table for VRF-1?
  • A. Shared Route for External EPG
  • B. External Subnet for External EPG
  • C. Export Route Control Subnet
  • D. Import Route Control Subnet
The "Import Route Control Subnet" scope is used to control which external routes are imported into the ACI fabric's routing table
NEW QUESTION # 211
Refer to the exhibit. Which Adjacency Type value should be set when the client endpoint and the service node interface are in a different subnet?
  • A. L3Out
  • B. Unicast
  • C. Routed
  • D. L3
Section: External Network Connectivity
Explanation/Reference:
NEW QUESTION # 212
Which two protocols support accessing backup files on a remote location from the APIC?
(Choose two.)
  • A. SMB
  • B. SFTP
  • C. FTP
  • D. HTTPS
  • E. TFTP
https://www.cisco.com/c/en/us/td ... nter/aci/apic/sw/1- x/troubleshooting/b_APIC_Troubleshooting/ b_APIC_Troubleshooting_appendix_010011.html
NEW QUESTION # 213
Key 300-620 Concepts: https://www.pdf4test.com/300-620-dump-torrent.html
2026 Latest PDF4Test 300-620 PDF Dumps and 300-620 Exam Engine Free Share: https://drive.google.com/open?id=1YASEF4qxPUJcCQ4SZUCBVPaKVnZWA3am
Posted at 2/14/2026 05:37:42        Only Author  2#
Your article really made an impression, thank you so much. Premium SPLK-1002 files questions shared for free—unlock promotions and salary increases!
