[General] 1Z0-1084-25 Latest Test Labs - 1Z0-1084-25 Valid Exam Experience
70
【General】 1Z0-1084-25 Latest Test Labs - 1Z0-1084-25 Valid Exam Experience
Posted at 1/9/2026 23:32:39      View:162 | Replies:5        Print      Only Author   [Copy Link] 1#
P.S. Free & New 1Z0-1084-25 dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=1kI7_4dCGohoGI5HpNrP5uQypx9522h1D
The 1Z0-1084-25 certification is the way to go in the modern Oracle era. Success in the Oracle Cloud Infrastructure 2025 Developer Professional exam of this certification plays an essential role in an individual's future growth. Nowadays, almost every tech aspirant is taking the test to get 1Z0-1084-25 certification and find well-paying jobs or promotions. But the main issue that most of the candidates face is not finding updated Oracle 1Z0-1084-25 Practice Questions to prepare successfully for the Oracle 1Z0-1084-25 certification exam in a short time.
Oracle 1Z0-1084-25 Exam Syllabus Topics:
  • Cloud Native Applications and Containerization: This section of the exam covers containerization technologies for cloud-native applications. It explains Docker architecture, its components, and the process of pulling and pushing container images using Oracle Cloud Infrastructure Registry (OCIR). It also explores container orchestration, deploying applications on Oracle Kubernetes Engine (OKE), and using OCI Service Mesh for Kubernetes deployments.
  • Testing and Securing Cloud-Native Applications: This section focuses on testing strategies and security for cloud-native applications. It discusses different testing methodologies, securing sensitive information using OCI Vault, and implementing security measures to address cloud-native development challenges.
  • Leveraging Serverless Technologies for Cloud Native Development: This section of the exam measures the skills of professionals in serverless development within OCI. It covers creating serverless applications using Oracle Functions, building API gateways for routing traffic, and integrating systems through OCI Streaming Service. Additionally, it explores event-driven architectures using OCI Event Service and how OCI Queue enables asynchronous messaging between microservices.
  • Monitoring & Troubleshooting Cloud-Native Applications: This section of the exam focuses on monitoring and troubleshooting cloud-native applications. It covers using OCI Monitoring to track metrics, OCI Logging for managing logs and performing tasks related to monitoring, logging, and tracing for better observability and issue resolution.
Topic 5
  • Cloud Native Fundamentals: This section of the exam measures the skills of target audience and covers the essential principles of cloud-native development. It explains the core concepts, key pillars, and advantages of cloud-native applications. The section also focuses on microservices architecture, including its design methodology and how it supports scalable, distributed applications.
100% Pass Quiz 2026 Oracle 1Z0-1084-25: High Hit-Rate Oracle Cloud Infrastructure 2025 Developer Professional Latest Test LabsOur Oracle 1Z0-1084-25 practice test software is the most distinguished source for the Oracle 1Z0-1084-25 exam all over the world because it facilitates your practice in the practical form of the 1Z0-1084-25 Certification Exam. Moreover, you do not need an active internet connection to utilize Oracle Cloud Infrastructure 2025 Developer Professional practice exam software.
Oracle Cloud Infrastructure 2025 Developer Professional Sample Questions (Q25-Q30):NEW QUESTION # 25
From a DevOps process standpoint, it is a good practice to keep changes to an application under version control. Which of the following allows changes to a Docker image to be stored in a version control system?
  • A. Updating Dockerfile
  • B. Executing docker commit
  • C. Executing docker save
  • D. Updating docker-compose.yml
The option that allows changes to a Docker image to be stored in a version control system is: docker commit The docker commit command is used to create a new image from a container's changes. It takes a running container as input, captures the changes made to it, and creates a new image with those changes. This new image can then be tagged and pushed to a registry, or saved locally. By using docker commit, you can effectively capture the changes made to a container as a new image and store it in a version control system along with the Dockerfile and other project files. This allows for reproducibility and traceability of changes to the Docker image over time.
NEW QUESTION # 26
Which of the following step is NOT required for setting up the Container Engine for Kubernetes (OKE) cluster access using a local installation of kubectl?
  • A. Generate an API signing key pair (if you do not already have one) and upload the public key of the API signing key pair.
  • B. Set up the kubeconfig file.
  • C. Generate Auth token from the OCI console to access the OKE cluster using kubectl.
  • D. Install and configure the Oracle Cloud Infrastructure (OCI) CLI.
The step that is NOT required for setting up the Container Engine for Kubernetes (OKE) cluster access using a local installation of kubectl is to generate an Auth token from the OCI console. The authentication for accessing the OKE cluster using kubectl can be performed using the OCI CLI configuration, specifically the API signing key pair and the kubeconfig file. Here are the correct steps for setting up the OKE cluster access using a local installation of kubectl: Set up the kubeconfig file: The kubeconfig file contains the necessary information to authenticate and access the OKE cluster using kubectl. It includes details such as the cluster endpoint, authentication method, and credentials. Generate an API signing key pair (if you do not already have one) and upload the public key of the API signing key pair: The API signing key pair is used for authentication with the OCI services. The public key of the key pair needs to be uploaded to the OCI Console to associate it with your user account. Install and configure the Oracle Cloud Infrastructure (OCI) CLI: The OCI CLI provides a command-line interface to interact with the OCI services. It needs to be installed and configured with your OCI credentials, including the user's OCID, tenancy OCID, region, and the path to the API signing key pair. By completing these steps, you can configure kubectl to access and manage your OKE clusters from your local machine using the OCI CLI authentication configuration.
NEW QUESTION # 27
You are creating an API deployment in Oracle Cloud Infrastructure (OCI) API Gateway and you want to configure request policies to control access. Which is NOT available in OCI API Gateway?
  • A. Controlling access to the backend OCI resources.
  • B. Limiting the number of requests sent to the backend services.
  • C. Enabling Cross-Origin Resource Sharing (CORS) support.
  • D. Providing authentication and authorization.
The correct answer is: Controlling access to the backend OCI resources. OCI API Gateway does not provide direct control over access to backend OCI resources. It primarily focuses on managing and securing access to APIs exposed through the gateway. The gateway acts as a front-end for APIs and provides features such as authentication, authorization, rate limiting, and CORS support. While you can configure authentication and authorization policies, limit the number of requests, and enable CORS support in OCI API Gateway, it does not directly control access to backend OCI resources. Access to backend resources is typically managed through other means, such as IAM policies, network security rules, or resource-specific access controls.
NEW QUESTION # 28
As a Cloud Native developer, you have written a web service for your company. However, your security team has suggested that your web service should address Distributed Denial-of-Service (DDoS) attack. You are time-constrained and you need to ensure that this is implemented as soon as possible. What should you do in this scenario? (Choose the best answer.)
  • A. Use the OCI Virtual Cloud Network (VCN) segregation to control DDoS.
  • B. Use a third party service integration to Implement DDoS attack mitigation.
  • C. Re-write your web service and implement rate limiting.
  • D. Use the OCI API Gateway service and configure rate limiting.
The correct answer in this scenario is to use the OCI API Gateway service and configure rate limiting. Using the OCI API Gateway service and configuring rate limiting is an effective approach to address Distributed Denial-of-Service (DDoS) attacks. By implementing rate limiting, you can control the number of requests that can be made to your web service within a specific time frame. This helps to prevent overload and ensures that your service can handle legitimate traffic while mitigating the impact of DDoS attacks. By leveraging the OCI API Gateway service, you can easily configure rate limiting rules to restrict the number of requests per second or per minute. This allows you to set appropriate thresholds and safeguard your web service from being overwhelmed by excessive requests. The API Gateway acts as a protective layer, filtering out malicious traffic and ensuring the smooth operation of your service. While options like OCI Virtual Cloud Network (VCN) segregation and third-party service integrations may contribute to overall security, they do not specifically address DDoS attacks as efficiently as rate limiting. VCN segregation focuses more on network segmentation and isolation, while third-party service integration may introduce additional dependencies and complexities. Re-writing your web service and implementing rate limiting is a viable option, but it may not be feasible considering the time constraints mentioned. Leveraging the OCI API Gateway service provides a quicker and easier solution to implement DDoS attack mitigation through rate limiting.
NEW QUESTION # 29
A service you are deploying to Oracle Cloud Infrastructure (OCI) Container Engine for Kubernetes (OKE) uses a docker image from a private repository in OCI Registry (OCIR). Which configuration is necessary to provide access to this repository from OKE?
  • A. Create a docker-registry secret for OCIR with identity Auth Token on the cluster, and specify the imagePullSecret property in the application deployment manifest.
  • B. Create a dynamic group for nodes in the cluster, and a policy that allows the dynamic group to read repositories in the same compartment.
  • C. Add a generic secret on the cluster containing your identity credentials. Then specify a registryCredentials property in the deployment manifest.
  • D. Create a docker-registry secret for OCIR with API key credentials on the cluster, and specify the imagePullSecret property in the application deployment manifest.
The necessary configuration to provide access to a private repository in OCI Registry (OCIR) from OCI Container Engine for Kubernetes (OKE) is to create a docker-registry secret for OCIR with an identity Auth Token on the cluster and specify the imagePullSecret property in the application deployment manifest. Here's the breakdown of the steps: Create a docker-registry secret for OCIR with an identity Auth Token: In order to authenticate with the private repository in OCIR, you need to create a secret in your OKE cluster that contains the necessary credentials. This can be done by generating an identity Auth Token from the OCI Console and creating a secret in the cluster using the kubectl command. Specify the imagePullSecret property in the application deployment manifest: In your application's deployment manifest (such as a Kubernetes Deployment or StatefulSet YAML file), you need to include the imagePullSecret property and specify the name of the secret you created in the previous step. This allows the OKE cluster to use the credentials from the secret to pull the docker image from the private repository in OCIR during deployment. By following these steps, you can ensure that your OKE cluster has the necessary access to the private repository in OCIR, and your application can successfully pull the required docker image during deployment.
NEW QUESTION # 30
Due to its unique features, it is ideal for the majority of the students. It provides them complete assistance for understanding of the syllabus. It contains the comprehensive 1Z0-1084-25 exam questions that are not difficult to understand. By using these aids you will be able to modify your skills to the required limits. Your 1Z0-1084-25 Certification success is just a step away and is secured with 100% money back guarantee.
1Z0-1084-25 Valid Exam Experience: https://www.newpassleader.com/Oracle/1Z0-1084-25-exam-preparation-materials.html
BONUS!!! Download part of NewPassLeader 1Z0-1084-25 dumps for free: https://drive.google.com/open?id=1kI7_4dCGohoGI5HpNrP5uQypx9522h1D
Posted at 1/12/2026 19:05:00        Only Author  2#
What an extraordinary article, I’m so appreciative of your sharing. This is the Reliable PL-900 test online exam that played a role in my promotion and pay raise, now shared with you for free today. Best wishes on your career development!
Posted at 1/23/2026 22:04:44        Only Author  3#
Heutztage, wo die Zeit besonders geschätzt wird, ist es kostengünstig, ZertFragen zum Bestehen der Huawei H11-861_V4.0 Zertifizierungsprüfung zu wählen. Wenn Sie ZertFragen wählen, würden wir mit äußerster Kraft Ihnen helfen, die Huawei H11-861_V4.0 Prüfung zu bestehen. Außerdem bieten wir Ihnen einen einjährigen kostenlosen Update-Service. Fallen Sie in der Prüfung durch, zahlen wir Ihnen gesammte Einkaufsgebühren zurück.
Posted at 1/24/2026 08:51:25        Only Author  4#
Your article is magnificent, thank you for sharing it with us! Access the comprehensive content of Project-Planning-Design reliable test collection file for free, designed to help you achieve your goals.
Posted at 2/7/2026 03:10:47        Only Author  5#
Your article is astonishing, I truly appreciate you sharing it! The C1000-173 updated demo resources are excellent, and they’re available to you free of charge.
Posted at 2/18/2026 14:07:33        Only Author  6#
This is a phenomenal article, thank you for sharing your thoughts. The Latest C_BCBAI_2502 test camp file content is incredibly helpful, and it’s available to you for free.
