[General] CWNA-109 Reliable Exam Camp - CWNA-109 Test Duration
87
【General】 CWNA-109 Reliable Exam Camp - CWNA-109 Test Duration
Posted at 1/9/2026 23:33:45      View:144 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpExam CWNA-109 dumps for free: https://drive.google.com/open?id=1HAqWrWLkt8Q-lHI2qJ0P_6ij53X8H5_P
As a busy working person it will cost a lot of time and energy to prepare for upcoming test, what's to be done? You can try our latest CWNP CWNA-109 practice exam online materials. You can know more about exam information and master all valid exam key knowledge points. CWNA-109 Practice Exam Online is excellent product of all examination questions with high passing rate. It will improve your studying efficiency and low exam cost.
They provide you the best learning prospects, by employing minimum exertions through the results are satisfyingly surprising, beyond your expectations. Despite the intricate nominal concepts, CWNA-109 CWNA-109 exam dumps questions have been streamlined to the level of average candidates, pretense no obstacles in accepting the various ideas. For the additional alliance of your erudition, Our DumpExam offer an interactive CWNA-109 Exam testing software. This startling exam software is far more operational than real-life exam simulators.
CWNP CWNA-109 Test Duration, Vce CWNA-109 FreeDuring your transitional phrase to the ultimate aim, our CWNA-109 study engine as well as these updates is referential. Those CWNA-109 training materials can secede you from tremendous materials with least time and quickest pace based on your own drive and practice to win. Those updates of our CWNA-109 Exam Questions will be sent to you accordingly for one year freely. And we make sure that you can pass the exam.
CWNP Wireless Network Administrator (CWNA) Sample Questions (Q77-Q82):NEW QUESTION # 77
802. 11ax (HE) introduces Resource Units that can be used to allow communications with multiple devices at the same time, on the same channel, in the same BSS. What feature of 802.1 lax provides this functionality?
  • A. Wi-Fi-LTE
  • B. TWT
  • C. OFDMA
  • D. 6 GHz support
The feature of 802.11ax (HE) that provides this functionality is OFDMA. OFDMA stands for Orthogonal Frequency Division Multiple Access and is a technology that allows multiple devices to communicate simultaneously on the same channel in the same BSS. OFDMA works by dividing a channel into smaller subchannels called Resource Units (RUs), which are composed of groups of subcarriers or tones. Each RU can be assigned to a different device based on its bandwidth requirement and signal quality. This way, OFDMA can increase the efficiency and capacity of the channel by reducing overhead, contention, and latency. OFDMA can also support both uplink and downlink multi-user transmissions using trigger frames and buffer status reports. 6 GHz support, TWT, and Wi-Fi-LTE are not features of 802.11ax that provide this functionality. References: [CWNP Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 226; [CWNA: Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 216.
NEW QUESTION # 78
Which unit of measurement, as formally defined, is an absolute unit that is used to quantify received signal power levels on a logarithmic scale?
  • A. dBm
  • B. dBi
  • C. VSWR
  • D. SNI
The unit of measurement that is an absolute unit and is used to quantify received signal power levels on a logarithmic scale is dBm. dBm stands for decibel-milliwatt and represents the power level relative to 1 milliwatt (mW). dBm is an absolute unit because it has a fixed reference point and does not depend on the input power level. dBm is used to measure the received signal power levels on a logarithmic scale because it can express large variations in power levels with small numbers and make calculations easier. For example, a
10 dB increase in power level means a 10-fold increase in power, and a 20 dB increase means a 100-fold increase in power. References: [CWNP Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 66; [CWNA: Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 56.
NEW QUESTION # 79
You are a small business wireless network consultant and provide WLAN services for various companies.
You receive a call from one of your customers stating that their laptop computers suddenly started experiencing much slower data transfers while connected to the WLAN. This company is located in a multi- tenant office building and the WLAN was designed to support laptops, tablets and mobile phones. What could cause a sudden change in performance for the laptop computers?
  • A. The sky was not as cloudy that day as it typically is and the sun also radiates electromagnetic waves.
  • B. The antennas in the laptops have been repositioned.
  • C. A few of your customer's users have Bluetooth enabled wireless headsets.
  • D. A new tenant in the building has set their AP to the same RF channel that your customer is using.
A possible cause of a sudden change in performance for the laptop computers is that a new tenant in the building has set their AP to the same RF channel that your customer is using. This can create co-channel interference (CCI), which is a situation where two or more APs or devices use the same or overlapping channels in the same area. CCI can degrade the performance of WLANs by increasing contention, collisions, retransmissions, and latency. CCI can also reduce the effective range and throughput of WLANs by lowering the signal-to-noise ratio (SNR). To avoid or mitigate CCI, it is recommended to use non-overlapping channels, adjust transmit power levels, or implement channel management techniques such as dynamic frequency selection (DFS) or load balancing. The sky condition, antenna position, or Bluetooth headset are not likely to cause a sudden change in performance for the laptop computers. References: [CWNP Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 81; [CWNA: Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 71.
NEW QUESTION # 80
A WLAN is implemented using wireless controllers. The APs must locate the controllers when powered on and connected to the network. Which one of the following methods is commonly used to locate the controllers by the APs?
  • A. GRE
  • B. SNMP
  • C. DHCP
  • D. NTP
DHCP (Dynamic Host Configuration Protocol) is a commonly used method to locate the controllers by the APs in a WLAN that is implemented using wireless controllers. DHCP is a protocol that allows a device to obtain an IP address and other network configuration parameters from a server. In a wireless controller scenario, the APs can use DHCP to request an IP address from a DHCP server, which can also provide the IP address or hostname of the wireless controller as an option in the DHCP response. This way, the APs can discover the wireless controller and establish a connection with it. Alternatively, the APs can also use other methods to locate the wireless controller, such as DNS (Domain Name System), broadcast or multicast discovery, or manual configuration. References: 1, Chapter 8, page 309; 2, Section 5.2
NEW QUESTION # 81
When using a spectrum to look for non Wi-Fi interference sources, you notice significant interference across the entire 2.4 GHz band (not on a few select frequencies) within the desktop area of a users workspace, but the interference disappears quickly after just 2 meters. What is the most likely cause of this interference?
  • A. Unintentional radiation from the PC power supply
  • B. USB 3 devices in the user's work area
  • C. Excess RF energy from a nearby AP
  • D. Bluetooth devices in the user's work area
USB 3 devices in the user's work area are the most likely cause of this interference when using a spectrum analyzer to look for non-Wi-Fi interference sources. A spectrum analyzer is a tool that measures and visualizes the radio frequency activity and interference in the wireless environment. A spectrum analyzer can show the spectrum usage and energy levels on each frequency band or channel and help identify and locate the sources of interference. Interference is any unwanted signal that disrupts or degrades the intended signal on a wireless channel. Interference can be caused by various sources, such as other Wi-Fi devices, non-Wi-Fi devices, or natural phenomena. Interference can affect WLAN performance and quality by causing signal loss, noise, distortion, or errors. USB 3 devices are non-Wi-Fi devices that use USB 3.0 technology to transfer data at high speeds between computers and peripherals, such as hard drives, flash drives, cameras, or printers.
USB 3 devices can generate electromagnetic radiation that interferes with Wi-Fi signals in the 2.4 GHz band, especially when they are close to Wi-Fi devices or antennas. USB 3 devices can cause significant interference across the entire 2.4 GHz band (not on a few select frequencies) within the desktop area of a user's workspace, but the interference disappears quickly after just 2 meters. This is because USB 3 devices emit broadband interference that affects all channels in the 2.4 GHz band with a high intensity near the source but a low intensity at a distance due to attenuation. The other options are not likely to cause this interference pattern when using a spectrum analyzer to look for non-Wi-Fi interference sources. Bluetooth devices in the user's work area are non-Wi-Fi devices that use Bluetooth technology to communicate wirelessly between computers and peripherals, such as keyboards, mice, headphones, or speakers. Bluetooth devices can cause interference with Wi-Fi signals in the 2.4 GHz band, but they use frequency hopping spread spectrum (FHSS) technique that changes frequencies rapidly and randomly within a range of 79 channels. Therefore, Bluetooth devices do not cause significant interference across the entire 2.4 GHz band (not on a few select frequencies), but rather intermittent interference on some channels at different times. Excess RF energy from a nearby AP is not a non-Wi-Fi interference source but rather a Wi-Fi interference source that occurs when an AP transmits more power than necessary for its coverage area. Excess RF energy from a nearby AP can cause co- channel interference (CCI) with other APs or client devices that use the same channel within range of each other. CCI reduces performance and capacity because it causes contention and collisions on the wireless medium,
NEW QUESTION # 82
PayPal is the safer and world-widely using in the international online trade. We hope all candidates can purchase CWNA-109 latest exam braindumps via PayPal. Though PayPal require that sellers should be "Quality first, integrity management", if your products and service are not like what you promise, PayPal will block sellers' account. But PayPal can guarantee sellers and buyers' account safe while paying for CWNA-109 Latest Exam braindumps with extra tax. SWREG will cost extra tax such as intellectual property taxation.
CWNA-109 Test Duration: https://www.dumpexam.com/CWNA-109-valid-torrent.html
CWNP CWNA-109 Reliable Exam Camp This ways will cut off your preparation time, Choose from an extensive collection of products that suits every CWNA-109 certification aspirant, CWNP CWNA-109 Reliable Exam Camp You can test online by our soft, To suit your demands, our company has launched the CWNP CWNA-109 exam materials especially for office workers, You will build a complete knowledge structure about the CWNA-109 exam, which is very important for you to pass the exam.
Wearing Other Smart Clothing, If you have other types of assets, CWNA-109 such as sound or video, you might want to create separate folders for those too, This ways will cut off your preparation time.
CWNA-109 best CWNP certification exam questions and answers free downloadChoose from an extensive collection of products that suits every CWNA-109 certification aspirant, You can test online by our soft, To suit your demands, our company has launched the CWNP CWNA-109 exam materials especially for office workers.
P.S. Free 2026 CWNP CWNA-109 dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1HAqWrWLkt8Q-lHI2qJ0P_6ij53X8H5_P
