[Hardware] Professional-Cloud-Network-Engineer Flexible Testing Engine | Professional-Cloud
91
【Hardware】 Professional-Cloud-Network-Engineer Flexible Testing Engine | Professional-Cloud
Posted at 1/9/2026 23:54:38      View:290 | Replies:6        Print      Only Author   [Copy Link] 1#
P.S. Free & New Professional-Cloud-Network-Engineer dumps are available on Google Drive shared by TrainingQuiz: https://drive.google.com/open?id=1p07wrtLve8VqPz97pLYoP73icMyWhy9P
In the major environment, people are facing more job pressure. So they want to get Google certification rise above the common herd. How to choose valid and efficient Professional-Cloud-Network-Engineer guide torrent should be the key topic most candidates may concern. So now, it is right, you come to us. Our company is famous for its high-quality Professional-Cloud-Network-Engineer Exam Questions in this field especially for Google certification exams. It has been accepted by thousands of candidates who practice our Professional-Cloud-Network-Engineer study materials for their exam.
Topics Assessed in Final TestYou can succeed in the actual Google Professional Cloud Network Engineer exam if you manage to demonstrate that you developed the following skills and expertise:
  • Ensuring network resources optimization.
  • Monitoring and managing network operations;
  • Discerning how to configure network services;
  • Implementing and configuring a Virtual Private Cloud using the GCP network;
  • Implementing and configuring hybrid interconnectivity;
  • Configuring Google Cloud features to implement network security;
Professional-Cloud-Network-Engineer Formal Test & Valid Professional-Cloud-Network-Engineer Exam SimsThe Google Professional-Cloud-Network-Engineer exam is necessary for you if you want to improve your professional career. Google Professional-Cloud-Network-Engineer exam questions changes from time to time so, it is important to check for updates regularly otherwise you can miss an important thing in the middle of your Google Professional-Cloud-Network-Engineer Questions preparation. After the purchase, you will get Professional-Cloud-Network-Engineer dumps' latest updates for up to 90 days as soon as they are available. If the TrainingQuiz introduces new updates to Professional-Cloud-Network-Engineer study material within 90 days of your purchase then you will get them free of cost.
Google Cloud Certified - Professional Cloud Network Engineer Sample Questions (Q21-Q26):NEW QUESTION # 21
You are responsible for enabling Private Google Access for the virtual machine (VM) instances in your Virtual Private Cloud (VPC) to access Google APIs. All VM instances have only a private IP address and need to access Cloud Storage. You need to ensure that all VM traffic is routed back to your on-premises data center for traffic scrubbing via your existing Cloud Interconnect connection. However, VM traffic to Google APIs should remain in the VPC. What should you do?
  • A. Delete the default route in your VPC.
    Create a private Cloud DNS zone for googleapis.com, create a CNAME for *.googleapis.com to restricted googleapis.com, and create an A record for restricted googleapis com that resolves to the addresses in 199.36.153.4/30.
    Create a static route in your VPC for the range 199.36.153.4/30 with the default internet gateway as the next hop.
  • B. Configure your on-premises router to advertise 0.0.0.0/0 via Border Gateway Protocol (BGP) with a lower priority (MED) than the default VPC route.
    Create a private Cloud DNS zone for googleapis.com, create a CNAME for * googieapis.com to private googleapis com, and create an A record for private.googleapis.com that resolves to the addresses in 199 .36.153.8/30.
    Create a static route in your VPC for the range 199.36. 153.8/30 with the default internet gateway as the next hop.
  • C. Delete the default route in your VPC and configure your on-premises router to advertise 0.0.0.0/0 via Border Gateway Protocol (BGP).
    Create a private Cloud DNS zone for googleapis.com, create a CNAME for * googieapis.com to Private googleapis.com, and create an A record for private.googleapis.com that resolves to the addresses in 199.36.153.8/30.
    Create a static route in your VPC for the range 199.36.153.8/30 with the default internet gateway as the next hop.
  • D. Delete the default route in your VPC and configure your on-premises router to advertise 0.0.0.0/0 via Border Gateway Protocol (BGP).
    Create a public Cloud DNS zone with a CNAME for *.google.com to private googleapis com, create a CNAME for * googleapis.com to private googleapis com, and create an A record for Private googleapis.com that resolves to the addresses in 199.36.153 8/30.
    Create a static route in your VPC for the range 199 .36.153.8/30 with the default internet gateway as the next hop.
NEW QUESTION # 22
You are troubleshooting an application in your organization's Google Cloud network that is not functioning as expected. You suspect that packets are getting lost somewhere. The application sends packets intermittently at a low volume from a Compute Engine VM to a destination on your on-premises network through a pair of Cloud Interconnect VLAN attachments. You validated that the Cloud Next Generation Firewall (Cloud NGFW) rules do not have any deny statements blocking egress traffic, and you do not have any explicit allow rules. Following Google-recommended practices, you need to analyze the flow to see if packets are being sent correctly out of the VM to isolate the issue. What should you do?
  • A. Create a packet mirroring policy that is configured with your VM as the source and destined to a collector. Analyze the packet captures.
  • B. Enable Firewall Rules Logging on your firewall rules and review the logs.
  • C. Enable VPC Flow Logs on the subnet that the VM is deployed in with sample_rate = 1.0, and run a query in Logs Explorer to analyze the packet flow.
  • D. Verify the network/attachment/egress_dropped_packet.s_count Cloud Interconnect VLAN attachment metric.
Explanation: Enabling VPC Flow Logs with sample_rate = 1.0 on the VM's subnet will give detailed information about network traffic flowing to and from your VM. You can then query this data in Logs Explorer to check whether packets are leaving the VM and reaching the intended destination. This is a recommended practice for troubleshooting such network issues.
: Google VPC Flow Logs Documentation
NEW QUESTION # 23
You have enabled HTTP(S) load balancing for your application, and your application developers have reported that HTTP(S) requests are not being distributed correctly to your Compute Engine Virtual Machine instances. You want to find data about how the request are being distributed.
Which two methods can accomplish this? (Choose two.)
  • A. In Stackdriver Monitoring, select Resources > Google Cloud Load Balancers and review the Key Metrics graphs in the dashboard.
  • B. In Stackdriver Monitoring, select Resources > Metrics Explorer and search for https/request_bytes_count metric.
  • C. In Stackdriver Monitoring, create a new dashboard and track the https/backend_request_count metric for the load balancer.
  • D. In Stackdriver Error Reporting, look for any unacknowledged errors for the Cloud Load Balancers service.
  • E. On the Load Balancer details page of the GCP Console, click on the Monitoring tab, select your backend service, and look at the graphs.
Answer: C,E
NEW QUESTION # 24
(You are managing the security configuration of your company's Google Cloud organization. The Operations team needs specific permissions on both a Google Kubernetes Engine (GKE) cluster and a Cloud SQL instance. Two predefined Identity and Access Management (IAM) roles exist that contain a subset of the permissions needed by the team. You need to configure the necessary IAM permissions for this team while following Google-recommended practices. What should you do?)
  • A. Grant the team the IAM roles of Kubernetes Engine Admin and Cloud SQL Admin.
  • B. Grant the team the two predefined IAM roles.
  • C. Create a custom IAM role that includes only the required permissions from the predefined roles.
  • D. Create a custom IAM role that combines the permissions from the two relevant predefined roles.
Answer: A,B,C
Granting more permissions than necessary violates the principle of least privilege, a fundamental security best practice. While option A grants the necessary permissions (as subsets exist in two predefined roles), it might also grant more permissions than the Operations team strictly requires for their tasks on GKE and Cloud SQL.
Option D is too broad; 'Admin' roles grant extensive permissions that likely exceed the specific needs.
Google Cloud's best practices strongly recommend adhering to the principle of least privilege. Creating a custom role allows you to precisely define the set of permissions the Operations team needs for their specific tasks on the GKE cluster and the Cloud SQL instance, without granting any unnecessary permissions. This minimizes the potential blast radius in case of accidental or malicious actions.
Google Cloud Documentation References:
IAM best practices: https://cloud.google.com/iam/docs/best-practices - This document explicitly recommends granting the minimum necessary permissions.
Creating and managing custom roles: https://cloud.google.com/iam/docs/creating-managing-custom-roles - This explains how to create roles tailored to specific job functions.
Understanding roles: https://cloud.google.com/iam/docs/understanding-roles - This outlines the concepts of predefined and custom roles and their use cases.
NEW QUESTION # 25
You need to create a new VPC network that allows instances to have IP addresses in both the 10.1.1.0/24 network and the 172.16.45.0/24 network.
What should you do?
  • A. Create unique DNS records for each service that sends traffic to the desired IP address.
  • B. Configure an alias-IP range of 172.16.45.0/24 on the virtual instances within the VPC subnet of 10.1.1.0
    /24.
  • C. Use VPC peering to allow traffic to route between the 10.1.0.0/24 network and the 172.16.45.0/24 network.
  • D. Configure global load balancing to point 172.16.45.0/24 to the correct instance.
NEW QUESTION # 26
Our Professional-Cloud-Network-Engineer exam prep will give you a complete after-sales experience. You can consult online no matter what problems you encounter. You can get help anywhere, anytime in our Professional-Cloud-Network-Engineer test material. Professional-Cloud-Network-Engineer test questions have very high quality services in addition to their high quality and efficiency. If you use Professional-Cloud-Network-Engineer test material, you will have a very enjoyable experience while improving your ability. We have always advocated customer first. If you use our learning materials to achieve your goals, we will be honored. Professional-Cloud-Network-Engineer exam prep look forward to meeting you.
Professional-Cloud-Network-Engineer Formal Test: https://www.trainingquiz.com/Professional-Cloud-Network-Engineer-practice-quiz.html
P.S. Free 2026 Google Professional-Cloud-Network-Engineer dumps are available on Google Drive shared by TrainingQuiz: https://drive.google.com/open?id=1p07wrtLve8VqPz97pLYoP73icMyWhy9P
Posted at 1/10/2026 13:02:17        Only Author  2#
I’m really grateful for your article, it left an indelible mark. The C_TFG61_2405 reliable exam registration test was a key factor in my professional growth, and now I’m sharing it with you for free!
Posted at 1/16/2026 05:51:14        Only Author  3#
Thank you for your powerful article, it made a deep impression. We’re providing JN0-351 valid exam tutorial at no cost, packed with rich material to support your learning.
Posted at 1/16/2026 08:50:21        Only Author  4#
The article was a real source of inspiration. The Latest study guide C_BCSCX_2502 pdf exam questions are available for free. Wishing you the best in your exams!
Posted at 1/23/2026 18:29:09        Only Author  5#
Thank you for your wonderful share; this article really opened my eyes! Latest ITIL-4-Transition exam discount voucher provides free, rich resources aimed at helping you achieve your goals.
Posted at 2/23/2026 02:25:08        Only Author  6#
I truly appreciate your article, it really left a deep impression on me. I’m just about to take the H35-211_V2.5 latest exam objectives pdf exam. Wish me success!
Posted at 3/7/2026 05:23:44        Only Author  7#
もし弊社のAdobeのAD0-E605「Adobe Real-Time CDP Business Practitioner Professional」認証試験について問題集に興味があったら、購入するまえにインターネットで弊社が提供した無料な部分問題集をダウンロードして、君の試験に役に立つかどうかのを自分が判断してください。それにPassTestは一年の無料な更新のサービスを提供いたします。
