ISQI CTFL-UT考古題 - CTFL-UT考題免費下載
Posted at 1/9/2026 23:59:20
P.S. NewDumps在Google Drive上分享了免費的2026 ISQI CTFL-UT考試題庫:https://drive.google.com/open?id=1MVTw-F1IW_yjZRCocPvTSVdMKTpIOJHK
通過那些很多已經通過ISQI CTFL-UT 認證考試的IT專業人員的回饋,他們的成功得益於NewDumps的説明。NewDumps提供的針對性測試練習題和答案給了他們很大幫助,節約了他們的寶貴的時間和精力,讓他們輕鬆順利地通過他們第一次參加的ISQI CTFL-UT 認證考試。所以NewDumps是個值得你們信賴的網站。選擇了NewDumps,下一個成功的IT人士就是你,NewDumps會成就你的夢想。
ISQI CTFL-UT或ISTQB認證測試師-基礎級別-可用性測試是國際軟件品質研究所(ISQI)提供的一種認證,針對對可用性測試感興趣的專業人士。該認證旨在提高軟件質量保證工程師、軟件測試人員和軟件開發人員改善軟件產品的可用性。
ISTQB認證測試師基礎水平-可用性測試考試是專為從事軟件測試工作的專業人士所設計,尤其是在用戶體驗測試領域。考試涵蓋可用性測試的各個方面,包括其重要性、可用性測試的原則、可用性測試過程、可用性測試技術和可用性測試工具。考試還涵蓋了測試人員在可用性測試中的角色以及可用性測試在軟件開發過程中的重要性。
最真實的CTFL-UT認證考試的題目與答案ISQI的CTFL-UT考試認證是當代眾多考試認證中最有價值的考試認證之一,在近幾十年裏,電腦科學教育已獲得了世界各地人們絕大多數的關注,它每天都是IT資訊技術領域的必要一部分,所以IT人士通過ISQI的CTFL-UT考試認證來提高自己的知識,然後在各個領域突破。而NewDumps ISQI的CTFL-UT考試認證試題及答案正是他們所需要的,因為想要通過這項測試並不容易的,選擇適當的捷徑只是為了保證成功,NewDumps正是為了你們的成功而存在的,選擇NewDumps等於選擇成功,我們NewDumps提供的試題及答案是NewDumps的IT精英通過研究與實踐而得到的,擁有了超過計畫10年的IT認證經驗。
最新的 iSQI Software Testing & Quality CTFL-UT 免費考試真題 (Q29-Q34):問題 #29
What does the Equality Act address?
- A. It states that websites have to adhere to the WCAG conformity level AA
- B. It obligates organizations to make sites accessible at all costs
- C. It states that websites have to adhere to the WCAG conformity level A
- D. It protects people from discrimination in the workplace and in wider society
答案:D
解題說明:
The Equality Act 2010 (UK) is legislation designed to protect individuals from discrimination in various areas, including employment and access to goods and services-this includes digital products like websites.
While it does not directly mandate WCAG compliance levels (A or AA), it implies that digital services must be accessible to users with disabilities. Organizations are required to make "reasonable adjustments" to avoid discrimination. Therefore, the most accurate and comprehensive answer is B.
UK Equality Act 2010 - Legislation.gov.uk
GOV.UK: Accessibility Requirements for Public Sector Bodies
問題 #30
You're defining usability test tasks for a web shop for mobile phones and smartphones. Finding out whether users are able to place an order easily has been identified as the main goal of the usability test.
Which of the following is a reasonable task definition to include in the test?
- A. Your phone broke and you're looking for a new smartphone. Your budget is 200$ and it should have an infrared sensor as you like to operate your home entertainment system with it. Find a suited smartphone and order it!
- B. Which mobile operating system do you prefer?
- C. Put the first phone you find in your shopping cart!
- D. Enter the item number "1469483" in the search box and click "OK". Put the first item in the cart by clicking "add to bag". Then, click on "checkout" in order to start the order process. After that, fill in the form and click on "submit".
答案:A
解題說明:
Option B represents a realistic, goal-oriented scenario that reflects how an actual user would interact with the website. It incorporates context, user intent, constraints, and desired outcome-all characteristics of well- designed usability tasks. Option A is vague and lacks real-world motivation. Option C is too prescriptive and limits insight into user behavior, while D is a survey question, not a usability task. According to Nielsen Norman Group and ISO 25062, the best usability tasks are scenario-based, realistic, and outcome-driven- making B the correct answer.
Nielsen Norman Group: Writing Effective Usability Tasks
Usability.gov: Scenario-Based Usability Tasks
ISO 25062 - Usability Test Reporting
問題 #31
What is the System Usability Scale (SUS)?
- A. A requirement on the usability of a component of system
- B. A usability test execution activity specified by the moderator that needs to be accomplished by a usability test participant within a given period of time.
- C. A simple, ten-item attitude scale giving a global view of subjective assessments of usability.
- D. Testing to evaluate the degree to which the system can be used by specified users with effectiveness, efficiency and satisfaction in a specified context of use.
答案:C
解題說明:
The System Usability Scale (SUS) is a standardized, reliable tool used to measure perceived usability. It consists of 10 items with five response options (from strongly agree to strongly disagree). It is widely used due to its simplicity and effectiveness in providing a single score to reflect a user's overall satisfaction with a system. Option A refers to ISO's definition of usability testing, B describes a task in usability testing, and D refers to a usability requirement, not SUS. Therefore, the correct description of SUS is option C.
Brooke, J. (1996). SUS: A Quick and Dirty Usability Scale.
Usability.gov: System Usability Scale (SUS)
ISO/IEC 25062 - Common Industry Format for Usability Test Reports
問題 #32
Which of the following is the best description for a usability test session?
- A. A test activity specified by the moderator that needs to be accomplished by a usability test participant within a given period of time.
- B. A black-box test technique in which test cases are designed to execute usability scenarios.
- C. A period of time in which a usability test participant is executing tests, moderated by a moderator and observed by a number of observers.
- D. A document specifying a sequence of actions for the execution of a usability test.
答案:C
解題說明:
A usability test session is a controlled period during which a test participant performs tasks using the system under test while being observed by a moderator and sometimes additional stakeholders or observers. The goal is to understand how users interact with the interface and identify usability problems. Option A describes an individual task, not the whole session. Option C refers to a test plan or test script, and Option D describes a test technique rather than a usability session. Thus, option B provides the most accurate and comprehensive definition.
ISO 25062:2006 - Common Industry Format (CIF)
Nielsen Norman Group: Usability Testing 101
Usability.gov: Usability Test Sessions
問題 #33
A web shop owner used Google Analytics to gather information about her users. She found out that most users take about five minutes to place an order. Is the usability of the website good or bad?
- A. The usability of the website is good - five minutes is a fair amount of time
- B. That depends on the accessibility of the website
- C. The usability of the website is bad - five minutes is way too long
- D. That depends on the context of use as users may have different expectations
答案:D
解題說明:
Usability is defined in ISO 9241-11 as the extent to which a system can be used by specified users to achieve specified goals with effectiveness, efficiency, and satisfaction in a specified context of use. Without knowing the context-such as product complexity, user familiarity, device type, or purchasing habits-it is impossible to judge whether five minutes is good or bad. For complex items, five minutes may be reasonable, while for one-click purchases, it may be excessive. Thus, usability cannot be assessed solely based on one metric like time-it must be evaluated within its full usage context.
ISO 9241-11:2018 - Usability Definitions and Concepts
Nielsen Norman Group: Context of Use in Usability Testing
Usability.gov: Usability and Context of Use
問題 #34
用一下NewDumps的CTFL-UT考古題怎麼樣?這個考古題可以說是與CTFL-UT考試相關的所有參考資料中最優秀的資料。為什麼呢?有以下四個理由。第一,NewDumps的考古題是IT專家們運用他們多年的經驗研究出來的資料,可以準確地劃出考試出題的範圍。第二,NewDumps的考古題包含了可能出現在實際考試中的所有試題。第三,NewDumps的考古題保證考生一次就通過考試,如果考生考試失敗則全額退款。第四,NewDumps的考古題分為PDF版和軟體版兩個版本。利用這兩個版本的考古題,考生可以更輕鬆地準備考試。
CTFL-UT考題免費下載: https://www.newdumpspdf.com/CTFL-UT-exam-new-dumps.html
大量的練習CTFL-UT問題集中的考題好處非常多,比如說可以增強自己的解題能力,加快自己的解題速度,拓寬自己的知識面等等,ISQI CTFL-UT 不僅可以幫助您順利通過考試,還可以提高您的知識和技能,也有助於您的職業生涯在不同的條件下都可以發揮您的優勢,所有的國家一視同仁,基本完全覆蓋,同時,盡量提前核實好CTFL-UT考試地點,熟悉CTFL-UT考試環境,不要等CTFL-UT考試當天才去找考場,選擇好的培訓可以有效的幫助你快速鞏固關IT方面的大量知識,讓你可以為ISQI CTFL-UT 認證考試做好充分的準備,為了通過ISQI CTFL-UT 認證考試,請選擇我們的NewDumps來取得好的成績,我們提供給您最近更新的CTFL-UT題庫資料,來確保您通過認證考試,如果您一次沒有通過考試,我們將給您100%的退款保證。
小王狐笑嘻嘻道,相比於之前的信息量,烏伯的話中信息量更大,大量的練習CTFL-UT問題集中的考題好處非常多,比如說可以增強自己的解題能力,加快自己的解題速度,拓寬自己的知識面等等,ISQI CTFL-UT 不僅可以幫助您順利通過考試,還可以提高您的知識和技能,也有助於您的職業生涯在不同的條件下都可以發揮您的優勢,所有的國家一視同仁。
最新的CTFL-UT考古題和資格考試中的領先材料供應商和無與倫比的ISQI ISTQB Certified Tester-Foundation Level - Usability Testing基本完全覆蓋,同時,盡量提前核實好CTFL-UT考試地點,熟悉CTFL-UT考試環境,不要等CTFL-UT考試當天才去找考場,選擇好的培訓可以有效的幫助你快速鞏固關IT方面的大量知識,讓你可以為ISQI CTFL-UT 認證考試做好充分的準備。
- 高效的CTFL-UT考古題 |高通過率的考試材料|精心準備的CTFL-UT考題免費下載 🔙 請在「 tw.fast2test.com 」網站上免費下載➡ CTFL-UT ️⬅️題庫CTFL-UT最新試題
- 免費PDF CTFL-UT考古題 - ISQI CTFL-UT通過了考試 🥱 在《 [url]www.newdumpspdf.com 》網站上免費搜索▛ CTFL-UT ▟題庫CTFL-UT熱門認證[/url]
- 使用CTFL-UT考古題意味著你已經通過ISTQB Certified Tester-Foundation Level - Usability Testing的一半 📏 「 [url]www.kaoguti.com 」上的✔ CTFL-UT ️✔️免費下載只需搜尋CTFL-UT考試資料[/url]
- 最新的CTFL-UT認證考試的學習資料 ⏸ 在▶ [url]www.newdumpspdf.com ◀網站上免費搜索⏩ CTFL-UT ⏪題庫CTFL-UT題庫資料[/url]
- 選擇CTFL-UT考古題 - 跟ISTQB Certified Tester-Foundation Level - Usability Testing考試難題說再見 🐳 在⇛ [url]www.pdfexamdumps.com ⇚網站上免費搜索▛ CTFL-UT ▟題庫CTFL-UT證照指南[/url]
- 保證壹次通過CTFL-UT考古題考試 - 有效ISQI CTFL-UT考題免費下載 🚙 ➤ [url]www.newdumpspdf.com ⮘上的▛ CTFL-UT ▟免費下載只需搜尋新版CTFL-UT題庫上線[/url]
- 使用CTFL-UT考古題意味著你已經通過ISTQB Certified Tester-Foundation Level - Usability Testing的一半 🚣 在⏩ [url]www.newdumpspdf.com ⏪網站上查找➠ CTFL-UT 🠰的最新題庫CTFL-UT資料[/url]
- [url=https://jaredladia.com/?s=CTFL-UT%e8%80%83%e8%a9%a6%e9%a1%8c%e5%ba%ab%20%f0%9f%93%b3%20CTFL-UT%e9%a1%8c%e5%ba%ab%e6%9c%80%e6%96%b0%e8%b3%87%e8%a8%8a%20%f0%9f%a6%84%20%e6%9c%80%e6%96%b0CTFL-UT%e9%a1%8c%e5%ba%ab%e8%b3%87%e8%a8%8a%20%e2%9c%94%ef%b8%8f%20%e5%88%b0[%20www.newdumpspdf.com%20]%e6%90%9c%e7%b4%a2%e2%9e%a0%20CTFL-UT%20%f0%9f%a0%b0%e8%bc%95%e9%ac%86%e5%8f%96%e5%be%97%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89CTFL-UT%e6%9c%80%e6%96%b0%e9%a1%8c%e5%ba%ab]CTFL-UT考試題庫 📳 CTFL-UT題庫最新資訊 🦄 最新CTFL-UT題庫資訊 ✔️ 到[ www.newdumpspdf.com ]搜索➠ CTFL-UT 🠰輕鬆取得免費下載CTFL-UT最新題庫[/url]
- 高效的CTFL-UT考古題 |高通過率的考試材料|精心準備的CTFL-UT考題免費下載 🩱 ▛ [url]www.newdumpspdf.com ▟是獲取【 CTFL-UT 】免費下載的最佳網站CTFL-UT考試資料[/url]
- 新版CTFL-UT題庫上線 🥴 新版CTFL-UT題庫上線 🥀 CTFL-UT考試重點 🤪 ☀ [url]www.newdumpspdf.com ️☀️上的➡ CTFL-UT ️⬅️免費下載只需搜尋CTFL-UT熱門認證[/url]
- CTFL-UT考試資料 ➖ CTFL-UT最新試題 🍡 CTFL-UT題庫資料 📪 透過[ [url]www.vcesoft.com ]輕鬆獲取✔ CTFL-UT ️✔️免費下載CTFL-UT題庫最新資訊[/url]
- www.connectantigua.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, elearno.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. NewDumps在Google Drive上分享了免費的、最新的CTFL-UT考試題庫:https://drive.google.com/open?id=1MVTw-F1IW_yjZRCocPvTSVdMKTpIOJHK
