New Salesforce-Data-Cloud Dumps Book & Salesforce-Data-Cloud Learning Engine
Posted at 1/9/2026 23:59:28
DOWNLOAD the newest FreeDumps Salesforce-Data-Cloud PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1QGQTt4R6pMMsq0mttk6s8x-oH36j2BfX
Our Salesforce-Data-Cloud exam questions own a lot of advantages that you can't imagine. First of all, all content of our Salesforce-Data-Cloud study guide is accessible and easy to remember, so no need to spend a colossal time to practice on it. Second, our Salesforce-Data-Cloud training quiz is efficient, so you do not need to disassociate yourself from daily schedule. Just practice with our Salesforce-Data-Cloud learning materials on a regular basis and everything will be fine.
If you have tried on our Salesforce-Data-Cloud exam questions, you may find that our Salesforce-Data-Cloud study materials occupy little running memory. So it will never appear flash back. If you want to try our Salesforce-Data-Cloud learning prep, just come to free download the demos which contain the different three versions of the Salesforce-Data-Cloud training guide. And you will find every version is charming. Follow your heart and choose what you like best on our website.
Authoritative New Salesforce-Data-Cloud Dumps Book - Find Shortcut to Pass Salesforce-Data-Cloud ExamTo be convenient for the learners, our Salesforce-Data-Cloud certification questions provide the test practice software to help the learners check their learning results at any time. You can use your smart phones, laptops, the tablet computers or other equipment to download and learn our Salesforce-Data-Cloud learning materials. Moreover, our customer service team will reply the clients' questions on the Salesforce-Data-Cloud Exam Questions patiently and in detail at any time and the clients can contact the online customer service. The clients at home and abroad can purchase our Salesforce-Data-Cloud certification questions online.
Salesforce Data Cloud Accredited Professional Exam Sample Questions (Q146-Q151):NEW QUESTION # 146
Cumulus Financial uses Service Cloud as its CRM and stores mobile phone, home phone, and work phone as three separate fields for its customers on the Contact record. The company plans to use Data Cloud and ingest the Contact object via the CRM Connector.
What is the most efficient approach that a consultant should take when ingesting this data to ensure all the different phone numbers are properly mapped and available for use in activation?
- A. Ingest the Contact object and map the Work Phone, Mobile Phone, and Home Phone to theContact Point Phone data map object from the Contact data stream.
- B. Ingest the Contact object and use streaming transforms to normalize the phone numbers fromthe Contact data stream into a separate Phone data lake object (DLO) that contains three rows,and then map this new DLO to the Contact Point Phone data map object.
- C. Ingest the Contact object and create formula fields in the Contact data stream on the phonenumbers, and then map to the Contact Point Phone data map object.
- D. Ingest the Contact object and then create a calculated insight to normalize the phone numbers,and then map to the Contact Point Phone data map object.
The most efficient approach that a consultant should take when ingesting this data to ensure all the different phone numbers are properly mapped and available for use in activation is B. Ingest the Contact object and use streaming transforms to normalize the phone numbers from the Contact data stream into a separate Phone data lake object (DLO) that contains three rows, and then map this new DLO to the Contact Point Phone data map object. This approach allows the consultant to use the streaming transforms feature of Data Cloud, which enables data manipulation and transformation at the time of ingestion, without requiring any additional processing or storage. Streaming transforms can be used to normalize the phone numbers from the Contact data stream, such as removing spaces, dashes, or parentheses, and adding country codes if needed. The normalized phone numbers can then be stored in a separate Phone DLO, which can have one row for each phone number type (work, home, mobile). The Phone DLO can then be mapped to the Contact Point Phone data map object, which is a standard object that represents a phone number associated with a contact point.
This way, the consultant can ensure that all the phone numbers are available for activation, such as sending SMS messages or making calls to the customers.
The other options are not as efficient as option B. Option A is incorrect because it does not normalize the phone numbers, which may cause issues with activation or identity resolution. Option C is incorrect because it requires creating a calculated insight, which is an additional step that consumes more resources and time than streaming transforms. Option D is incorrect because it requires creating formula fields in the Contact data stream, which may not be supported by the CRM Connector or may cause conflicts with the existing fields in the Contact object. References: Salesforce Data Cloud Consultant Exam Guide, Data Ingestion and Modeling, Streaming Transforms, Contact Point Phone
NEW QUESTION # 147
Cumulus Financial segregates its sales CRM data based on Region for its Data Cloud users. Multiple data spaces are configured: a default space and two additional spaces tailored for EMEA and APAC regions.
EME A sales reps who need temporary access to visualize data for both regions say that they cannot visualize APAC data. APAC sales reps can visualize the corresponding segmented data.
Which statement describes the cause of this issue?
- A. The APAC data space Is not associated with any profile.
- B. The EMEA sales reps have not been assigned to the profile associated with the APAC data space.
- C. The EMEA sales reps have not been assigned to the permission set associated with the APAC data space.
- D. The APAC data space is not associated with any permission set.
The issue arises because the EMEA sales reps cannot visualize APAC data, while APAC sales reps can access their segmented data. The root cause is that the EMEA sales reps lack the necessary permissions to access the APAC data space. Here's why:
Understanding the Issue
Cumulus Financial uses data spaces to segregate CRM data by region (default, EMEA, APAC).
EMEA sales reps need temporary access to APAC data but are unable to view it.
APAC sales reps can access their corresponding segmented data without issues.
Why Permission Sets?
Data Space Access Control :
Data spaces in Salesforce Data Cloud are secured using profiles and permission sets .
Users must be explicitly granted access to a data space via their assigned profiles or permission sets.
Root Cause Analysis :
Since APAC sales reps can access their data, the APAC data space is properly configured.
The issue lies with the EMEA sales reps, who likely do not have the required permission set granting access to the APAC data space.
Temporary Access :
Temporary access can be granted by assigning the appropriate permission set to the EMEA sales reps.
Steps to Resolve the Issue
Step 1: Identify the Required Permission Set
Navigate to Setup > Permission Sets and locate the permission set associated with the APAC data space.
Step 2: Assign the Permission Set
Assign the APAC data space permission set to the EMEA sales reps requiring temporary access.
Step 3: Verify Access
Confirm that the EMEA sales reps can now visualize APAC data.
Step 4: Revoke Temporary Access
Once the temporary access period ends, remove the permission set from the EMEA sales reps.
Why Not Other Options?
A). The EMEA sales reps have not been assigned to the profile associated with the APAC data space rofiles are typically broader and less flexible than permission sets for managing temporary access.
B). The APAC data space is not associated with any permission set :This is incorrect because APAC sales reps can access their data, indicating the data space is properly configured.
C). The APAC data space is not associated with any profile :Similar to Option B, this is incorrect because APAC sales reps can access their data.
Conclusion
The issue is resolved by ensuring that the EMEA sales reps are assigned the permission set associated with the APAC data space . This grants them temporary access to visualize APAC data.
NEW QUESTION # 148
What component of Calculated Insights can be included as attribute data in an activation?
- A. Filters
- B. Metrics and Dimensions
- C. Metrics
- D. Dimensions
Dimensions are attributes that can be used to group or filter data in calculated insights. You can include dimensions as attribute data in an activation by selecting them from the available attributes list. References:
https://help.salesforce.com/s/ar ... ghts.htm&type=5
NEW QUESTION # 149
Which data model subject area should be used for any Organization, Individual, or Member in the Customer
360 data model?
- A. Individual
- B. Global Account
- C. Membership
- D. Party
The party subject area should be used for any organization, individual, or member in the Customer 360 data model. It includes information such as name, address, email, phone, and loyalty membership.
References:https://help.salesforce.com/s/ar ... arty.htm&type=5
NEW QUESTION # 150
Which permission setting should an administrator check if the custom CRM object is not available in New Data Stream configuration?
- A. Create object permission enabled in Data Cloud org
- B. Ingest Object permission is enabled in the CRM org
- C. View All object permission enabled in source CRM org
- D. Modify Allobject permission enabled in Data Cloud org
This permission setting should be checked if the custom CRM object is not available in New Data Stream configuration. The user who connects the Salesforce CRM connector must have View All permission for the custom object in the source CRM org.
References:https://help.salesforce.com/s/ar ... _crm.htm&type=5
NEW QUESTION # 151
Mess of Salesforce-Data-Cloud exam candidates have inclined towards our practice test trains due to extremely beneficial features and appositive learning techniques applied through various learning modes. Thoroughly test your cognition level on Salesforce-Data-Cloud exam domains with the help of our practice test sessions. Take free trial for our practice test demos; get recognized about the key perspective and unique composition of our Salesforce-Data-Cloud Practice Test products. FreeDumps practice tests preeminently affluence your knowledge level and upbraids your efficiency to tackle with all sort of uncertain scenarios. Salesforce-Data-Cloud exams requirements are well embraced through our Salesforce-Data-Cloud products, keeping your learning tendency on the rise and fulfilling the success promise.
Salesforce-Data-Cloud Learning Engine: https://www.freedumps.top/Salesforce-Data-Cloud-real-exam.html
Our Salesforce-Data-Cloud training materials are known as instant access to download, you can receive downloading link within ten minutes, and if you don’t receive, you can contact us, and we will give you reply as soon as we can, Salesforce New Salesforce-Data-Cloud Dumps Book You can choose any exam and install/activate up-to 5 different exam engines of your choice per month, We provide 100% passing guarantee, and we are confident that you will pass the exam with the help of Salesforce-Data-Cloud products.
Free demo for Salesforce-Data-Cloud exam dumps are available, we recommend you to have a try before buying, so that you can have a deeper understanding of what you are going to buy.
The user experience suffers as a consequence, Our Salesforce-Data-Cloud Training Materials are known as instant access to download, you can receive downloading link within ten minutes, and Salesforce-Data-Cloud if you don’t receive, you can contact us, and we will give you reply as soon as we can.
New Release Salesforce Salesforce-Data-Cloud Dumps To Get Excellent Marks In Exam 2026You can choose any exam and install/activate up-to 5 different exam engines of your choice per month, We provide 100% passing guarantee, and we are confident that you will pass the exam with the help of Salesforce-Data-Cloud products.
It is never an easy task for the workers, since the actual exam is so difficult without Salesforce Data Cloud Accredited Professional Exam exam training vce, The moment you get our Salesforce-Data-Cloud study materials, you can take full advantage of them as soon as possible.
- Salesforce-Data-Cloud Actual Lab Questions: Salesforce Data Cloud Accredited Professional Exam - Salesforce-Data-Cloud Study Guide 😛 Search for ➡ Salesforce-Data-Cloud ️⬅️ and easily obtain a free download on ➠ [url]www.practicevce.com 🠰 🕧Reliable Salesforce-Data-Cloud Test Bootcamp[/url]
- New Salesforce-Data-Cloud Braindumps Ebook ⏹ Salesforce-Data-Cloud Valid Learning Materials 🦇 Salesforce-Data-Cloud Study Reference 🆔 Open ➽ [url]www.pdfvce.com 🢪 enter ⏩ Salesforce-Data-Cloud ⏪ and obtain a free download 🥶Test Salesforce-Data-Cloud Voucher[/url]
- Salesforce-Data-Cloud Accurate Prep Material 🩳 Test Salesforce-Data-Cloud Quiz 🦌 Salesforce-Data-Cloud Latest Exam Duration 🕜 Open ⮆ [url]www.examcollectionpass.com ⮄ and search for ☀ Salesforce-Data-Cloud ️☀️ to download exam materials for free 💆Test Salesforce-Data-Cloud Quiz[/url]
- Realistic Salesforce New Salesforce-Data-Cloud Dumps Book Quiz 🏳 Search for ➥ Salesforce-Data-Cloud 🡄 on ( [url]www.pdfvce.com ) immediately to obtain a free download 🧅Test Salesforce-Data-Cloud Voucher[/url]
- Realistic Salesforce New Salesforce-Data-Cloud Dumps Book Quiz 📌 Open website [ [url]www.examcollectionpass.com ] and search for ✔ Salesforce-Data-Cloud ️✔️ for free download 🧘Test Salesforce-Data-Cloud Quiz[/url]
- High-quality New Salesforce-Data-Cloud Dumps Book - Useful Tips to help you pass Salesforce-Data-Cloud: Salesforce Data Cloud Accredited Professional Exam 🕟 Easily obtain ⇛ Salesforce-Data-Cloud ⇚ for free download through ▛ [url]www.pdfvce.com ▟ 🤫Exam Salesforce-Data-Cloud Online[/url]
- Exam Salesforce-Data-Cloud Online 🎻 Salesforce-Data-Cloud Latest Exam Fee ⌨ Test Salesforce-Data-Cloud Preparation ☮ Search for ⇛ Salesforce-Data-Cloud ⇚ and obtain a free download on ➥ [url]www.dumpsmaterials.com 🡄 🥅Study Salesforce-Data-Cloud Material[/url]
- Salesforce-Data-Cloud Test Braindumps: Salesforce Data Cloud Accredited Professional Exam - Salesforce-Data-Cloud Quiz Materials - Salesforce-Data-Cloud Exam Torrent 🧞 Search for “ Salesforce-Data-Cloud ” and download exam materials for free through ➠ [url]www.pdfvce.com 🠰 🦰Salesforce-Data-Cloud Review Guide[/url]
- Salesforce-Data-Cloud Valid Learning Materials 🧅 Latest Salesforce-Data-Cloud Braindumps 🤵 Exam Salesforce-Data-Cloud Online 🩸 Search on ➡ [url]www.vce4dumps.com ️⬅️ for 《 Salesforce-Data-Cloud 》 to obtain exam materials for free download 📖Salesforce-Data-Cloud Latest Exam Fee[/url]
- [url=https://www.jcirma.com/?s=High%20Pass-Rate%20New%20Salesforce-Data-Cloud%20Dumps%20Book%20offer%20you%20accurate%20Learning%20Engine%20|%20Salesforce%20Data%20Cloud%20Accredited%20Professional%20Exam%20%f0%9f%8d%aa%20Go%20to%20website%20%e2%9e%a1%20www.pdfvce.com%20%ef%b8%8f%e2%ac%85%ef%b8%8f%20open%20and%20search%20for%20[%20Salesforce-Data-Cloud%20]%20to%20download%20for%20free%20%f0%9f%98%b4Exam%20Salesforce-Data-Cloud%20Online]High Pass-Rate New Salesforce-Data-Cloud Dumps Book offer you accurate Learning Engine | Salesforce Data Cloud Accredited Professional Exam 🍪 Go to website ➡ www.pdfvce.com ️⬅️ open and search for [ Salesforce-Data-Cloud ] to download for free 😴Exam Salesforce-Data-Cloud Online[/url]
- Salesforce-Data-Cloud Actual Lab Questions: Salesforce Data Cloud Accredited Professional Exam - Salesforce-Data-Cloud Study Guide 📅 Immediately open ✔ [url]www.practicevce.com ️✔️ and search for ▶ Salesforce-Data-Cloud ◀ to obtain a free download 😵Latest Salesforce-Data-Cloud Braindumps[/url]
- sltskills.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.skudci.com, www.stes.tyc.edu.tw, bbs.3927dj.com, multihubedu.com, elearning.eauqardho.edu.so, rdcvw.q711.myverydz.cn, www.stes.tyc.edu.tw, sc.cbb.ink, Disposable vapes
BTW, DOWNLOAD part of FreeDumps Salesforce-Data-Cloud dumps from Cloud Storage: https://drive.google.com/open?id=1QGQTt4R6pMMsq0mttk6s8x-oH36j2BfX
