Juniper JN0-481 PDF Questions-Turn Your Exam Fear Into Confidence
102
Posted at 1/10/2026 00:21:43      View:123 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Dumpleader JN0-481 dumps from Cloud Storage: https://drive.google.com/open?id=1HL0di0cLxxTWej21i6aYzwtKZz18X1yg
Our Juniper JN0-481 desktop and web-based practice software are embedded with mock exams, just like the actual Juniper Data Center certification exam. The Dumpleader designs its mock papers so smartly that you can easily prepare for the Data Center, Specialist (JNCIS-DC) exam. All the essential questions are included, which have a huge chance of appearing in the real Data Center, Specialist (JNCIS-DC) exam. Our mock exams may be customized so that you can change the topics and timings for each exam according to your preparation.
If you are still in colleges, it is a good chance to learn the knowledge of the JN0-481 study engine because you have much time. At present, many office workers are keen on learning our JN0-481 guide materials even if they are busy with their work. So you should never give up yourself as long as there has chances. In short, what you have learned on our JN0-481 study engine will benefit your career development.
Free PDF 2026 The Best Juniper Reliable JN0-481 Exam PreparationDumpleader is a very wonderful and effective platform to give chances to our worthy clients who want to achieve their expected scores and gain their JN0-481 certifications. With our professional experts’ tireless efforts, our JN0-481 exam guide is equipped with a simulated examination system with timing function, allowing you to examine your learning results at any time, keep checking for defects, and improve your strength. And you can be satisfied with our JN0-481 learning guide.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q48-Q53):NEW QUESTION # 48
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Lead and Leat6 using the same virtual network identifier (VNI). Which two statements are correct in this scenario? (Choose two.)
  • A. Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices.
  • B. The underlay must use IRB interfaces.
  • C. The underlay must be provisioned with PIMv2.
  • D. The underlay EBGP peering's must be established between leaf and spine devices.
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Leaf1 and Leaf6 using the same virtual network identifier (VNI). This means that the servers belong to the same Layer 2 domain and can communicate with each other using VXLAN tunnels across the fabric. The underlay network provides the IP connectivity between the leaf and spine devices, and it uses EBGP as the routing protocol. Therefore, the following two statements are correct in this scenario:
Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices. This is because the loopback addresses are used as the source and destination IP addresses for the VXLAN tunnels, and they must be reachable by all the devices in the fabric.
The loopback addresses are also used as the router IDs and the BGP peer addresses for the EBGP sessions.
The underlay EBGP peering's must be established between leaf and spine devices. This is because the EBGP sessions are used to exchange the underlay routing information and the EVPN routes for the overlay network. The EBGP sessions are established using the loopback addresses of the devices, and they follow a spine-and-leaf topology, where each leaf device peers with all the spine devices, and each spine device peers with all the leaf devices.
NEW QUESTION # 49
What is one indicator in the Apstra UI that implies that changes to a blueprint are ready to be committed?
  • A. Interface maps have been assigned through Device Profiles.
  • B. The Staged tab turns yellow
  • C. Each assigned device has been set to Deploy mode.
  • D. The Staged tab turns green
NEW QUESTION # 50
Referring to the exhibit, what is the minimum information you must add to create a new routing zone?
  • A. VRF Name, VLAN ID, VNI, Routing Policies
  • B. VRF Name and Routing policies
  • C. VRF Name, VLAN ID. And VNI
  • D. VRF Name only
To create a new routing zone, you must specify the VRF Name, VLAN ID, and VNI for the routing zone. These are the mandatory fields in the user interface shown in the exhibit. The VRF Name is the name of the L3 domain that isolates the IP traffic of the routing zone from other routing zones.
The VLAN ID is the identifier for the VLAN tagged Layer 3 links on external connections. The VNI is the VxLAN Network Identifier associated with the routing zone. The Routing Policies are optional fields that allow you to configure import and export route targets for the routing zone.
These are only applicable for EVPN routing zones, which use MP-EBGP as the overlay control protocol.
NEW QUESTION # 51
In Juniper Apstra, which statement is correct?
  • A. VMware anomaly detection is on by default.
  • B. VMware anomaly detection requires an Apstra server running on VMware.
  • C. VMware anomaly detection requires a vCenter server configured under External Systems
  • D. VMware anomaly detection requires a VMware hypervisor with exports enabled.
VMware anomaly detection is a feature of Apstra that provides visibility and validation of the virtual network settings and the physical network settings in a VMware vSphere environment. To enable this feature, Apstra requires a connection to a vCenter server that manages the ESX/ESXi hosts and the VMs connected to the Apstra-managed leaf switches. The vCenter server must be configured under External Systems in the Apstra web interface, and the vCenter integration must be staged and committed in the blueprint. This allows Apstra to collect information about VMs, ESX/ESXi hosts, port groups, and VDS, and to flag any inconsistencies or mismatches that might affect VM connectivity.
NEW QUESTION # 52
What is the purpose of a Juniper Apstra rack?
  • A. It stores IP address and ASN pool information.
  • B. It stores device port data rates and vendor information.
  • C. It stores information on how leaf nodes connect to generic devices
  • D. It stores information on how pods connect to super spines.
A Juniper Apstra rack is a physical entity that contains one or more network devices, such as leaf nodes, access switches, or generic systems. A rack is used to organize and manage the network devices in the Apstra software application. A rack has the following characteristics:
It stores information on how leaf nodes connect to generic devices. This is because a rack can include generic systems, which are devices that are not managed by Juniper Apstra, but are connected to the network. A generic system can be a server, a firewall, a load balancer, or any other device that has a network interface. A rack stores the information on how the leaf nodes, which are the devices that provide access to the end hosts, connect to the generic devices, such as the port number, the link speed, the LAG mode, and the roles.
It has a rack type, which defines the type and number of leaf devices, access switches, and/or generic systems that are used in the rack. A rack type is a resource that is created in the data center design phase, and it does not specify the vendor or the model of the devices. A rack type can be predefined or custom-made, and it can be used to create multiple racks with the same structure and configuration.
It has a rack build, which assigns the specific vendor and model of the devices to the rack. A rack build is created in the staged phase, and it uses the rack type as a template. A rack build can also assign the resources, such as the IP addresses, the ASNs, and the VNIs, to the devices in the rack. It has a rack deployment, which applies the network configuration and services to the devices in the rack. A rack deployment is performed in the active phase, and it uses the rack build as a reference. A rack deployment can also monitor the network performance and compliance of the devices in the rack.
NEW QUESTION # 53
The price for JN0-481 learning materials is quite reasonable, no matter you are a student or you are an employee in the company, and you can afford the expense. Besides, JN0-481 exam braindumps of us is famous for the high-quality and accuracy. You can pass the exam just one time if you choose us. JN0-481 Learning Materials contain both questions and answers, and you can know the answers right now after you finish practicing. We offer you free update for one year and the update version for JN0-481 exam dumps will be sent to your email automatically.
Latest JN0-481 Braindumps Sheet: https://www.dumpleader.com/JN0-481_exam.html
One of the major features provided by Juniper is that it will provide you with free Juniper JN0-481 actual questions updates for 365 days after the purchase of our product, Exam JN0-481 Data Center, Specialist (JNCIS-DC) The “Architecting” exam focuses more on understanding JNCIS-DC’s diverse capabilities and best use cases for applying those capabilities, Start Learning Juniper JN0-481 Exam Questions For Excellent And Quality Results.
But the potential exists to get beyond an approach Cost Effective JN0-481 Dumps that simply minimizes damage, Account Recovery Options, One of the major features provided by Juniper is that it will provide you with free Juniper JN0-481 Actual Questions updates for 365 days after the purchase of our product.
Dumpleader Make its Juniper JN0-481 Exam Questions EngagingExam JN0-481 Data Center, Specialist (JNCIS-DC) The “Architecting” exam focuses more on understanding JNCIS-DC’s diverse capabilities and best use cases for applying those capabilities.
Start Learning Juniper JN0-481 Exam Questions For Excellent And Quality Results, Buying our JN0-481 latest question can help you pass the exam successfully.
They know close to nothing about JN0-481 the Data Center, Specialist (JNCIS-DC) exam model and how to attempt the requests.
P.S. Free 2026 Juniper JN0-481 dumps are available on Google Drive shared by Dumpleader: https://drive.google.com/open?id=1HL0di0cLxxTWej21i6aYzwtKZz18X1yg
Posted at 2/7/2026 22:18:12        Only Author  2#
Wenn Sie Ihre Träume verwirklichen wollen, sollen Sie professionelle Ausbildung wählen. ZertSoft ist eine professionelle Webseite, die Ihnen Schulungsunterlagen zur Huawei H13-624_V5.5 IT-Zertifizierung anbietet. Unsere Schulungsunterlagen zur Huawei H13-624_V5.5 Zertifizierungsprüfung sind das Ergebnis der langjährigen ständigen Untersuchung und Erforschung von den erfahrenen IT-Experten aus ZertSoft. Nachdem Sie unsere Prüfungsunterlagen gekauft haben, können Sie einjährige Aktualisierung kostenlos genießen.
Posted at 2/24/2026 10:14:19        Only Author  3#
This article is very motivating, thanks for sharing! HPE7-A01 valid test blueprint content is exceptional, and you can enjoy it for free.
