[General] Valid free SOA-C02 test questions and answers, Amazon SOA-C02 practice test
73
General Valid free SOA-C02 test questions and answers, Amazon SOA-C02 practice test
Posted at 1/10/2026 02:15:45      View364 | Replies7        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon SOA-C02 dumps are available on Google Drive shared by Actual4dump: https://drive.google.com/open?id=1SnPADDEvUBkePeifEYU0B0rlzVmnctE6
In order to make your exam easier for every candidate, our SOA-C02 exam prep is capable of making you test history and review performance, and then you can find your obstacles and overcome them. In addition, once you have used this type of SOA-C02 exam question online for one time, next time you can practice in an offline environment. The SOA-C02 test torrent also offer a variety of learning modes for users to choose from, which can be used for multiple clients of computers and mobile phones to study online, as well as to print and print data for offline consolidation. Therefore, for your convenience, more choices are provided for you, we are pleased to suggest you to choose our SOA-C02 Exam Question for your exam.
We always learned then forget, how to solve this problem, the answer is to have a good memory method, our SOA-C02 exam question will do well on this point. Our SOA-C02 real exam materials have their own unique learning method, abandon the traditional rote learning, adopt diversified memory patterns, such as the combination of text and graphics memory method, to distinguish between the memory of knowledge. Our SOA-C02 learning reference files are so scientific and reasonable that you can buy them safely.
Reliable SOA-C02 Study Guide, Popular SOA-C02 ExamsWe also provide timely and free update for you to get more SOA-C02 questions torrent and follow the latest trend. The SOA-C02 exam torrent is compiled by the experienced professionals and of great value. You can master them fast and easily. We provide varied versions for you to choose and you can find the most suitable version of SOA-C02 Exam Materials. So it is convenient for the learners to master the SOA-C02 questions torrent and pass the SOA-C02 exam in a short time.
Amazon AWS Certified SysOps Administrator - Associate (SOA-C02) Sample Questions (Q271-Q276):NEW QUESTION # 271
A company has mandated the use of multi-factor authentication (MFA) for all IAM users, and requires users to make all API calls using the CLI. However. users are not prompted to enter MFA tokens, and are able to run CLI commands without MFA. In an attempt to enforce MFA, the company attached an IAM policy to all users that denies API calls that have not been authenticated with MFA.
What additional step must be taken to ensure that API calls are authenticated using MFA?
  • A. Require users to use temporary credentials from the get-session token command to sign API calls.
  • B. Restrict the IAM users to use of the console, as MFA is not supported for CLI use.
  • C. Ask the IAM users to log into the AWS Management Console with MFA before making API calls using the CLI.
  • D. Enable MFA on IAM roles, and require IAM users to use role credentials to sign API calls.
To enforce MFA for API calls using the AWS CLI, the users must use temporary security credentials obtained through the get-session-token command. Here's how to do it:
Enable MFA for IAM Users:
Ensure that MFA is enabled and properly configured for each IAM user.
Configure IAM Policy for MFA Enforcement:
Attach an IAM policy that denies API calls unless MFA is used. This policy should be attached to all users.
Obtain Temporary Security Credentials Using MFA:
Users need to use the aws sts get-session-token command to obtain temporary credentials. This command requires the MFA token.
sh
Copy code
aws sts get-session-token --serial-number arn:aws:iam::123456789012:mfa/user --token-code 123456 Use Temporary Credentials for API Calls:
After obtaining the temporary credentials, set them as environment variables or configure them in the AWS CLI profile to make API calls.
export AWS_ACCESS_KEY_ID=...
export AWS_SECRET_ACCESS_KEY=...
export AWS_SESSION_TOKEN=...
Enabling MFA for IAM Users
Using Temporary Security Credentials
AWS CLI get-session-token
NEW QUESTION # 272
A company runs an application on an Amazon EC2 instance A SysOps administrator creates an Auto Scaling group and an Application Load Balancer (ALB) to handle an increase in demand However, the EC2 instances are failing tie health check.
What should the SysOps administrator do to troubleshoot this issue?
  • A. Verify the maximum number of instances in the Auto Scaling group Change the number if necessary
  • B. Verity that the Auto Scaling group is configured to use all AWS Regions.
  • C. Verily that the application is running on the protocol and the port that the listens is expecting.
  • D. Verify the listener priority in the ALB Change the priority if necessary.
When EC2 instances fail health checks from the Application Load Balancer (ALB), it's often due to a mismatch between what the ALB is checking for and what the application is providing. Ensuring that the application is correctly configured to respond on the expected protocol and port is crucial.
Steps:
* Check ALB Health Check Configuration:
* Open the Amazon EC2 console.
* Navigate to the Load Balancers section.
* Select your ALB and go to the "Health Checks" tab.
* Verify the protocol (HTTP/HTTPS) and port specified in the health check configuration.
* Verify Application Configuration:
* Ensure that the application on the EC2 instances is running and listening on the same protocol and port configured in the ALB health check.
* Check firewall settings, security groups, and network ACLs to ensure that traffic is allowed on the specified port.
* Test Connectivity:
* Use tools like curl or telnet from another instance or from within the same instance to ensure the application responds correctly to health check requests.
* Review Health Check Logs:
* Look at the logs for the application and the ALB to identify any errors or misconfigurations.
* ALB Health Check Configuration
* Troubleshooting ALB Health Checks
NEW QUESTION # 273
A company hosts its website on Amazon EC2 instances behind an Application Load Balancer.
The company manages its DNS with Amazon Route 53 and wants to point its domain's zone apex to the website.
Which type of record should be used to meet these requirements?
  • A. An A record for the domain's zone apex
  • B. An AAAA record for the domain's zone apex
  • C. A CNAME record for the domain's zone apex
  • D. An alias record for the domain's zone apex
Route 53 supports redirection of zone apex to the ALB via alias.
https://docs.aws.amazon.com/Rout ... cord-sets-choosing- alias-non-alias.html
https://docs.aws.amazon.com/Rout ... -load-balancer.html
NEW QUESTION # 274
A company is running an application on premises and wants to use AWS for data backup All of the data must be available locally The backup application can write only to block-based storage that is compatible with the Portable Operating System Interface (POSIX) Which backup solution will meet these requirements?
  • A. Use AWS Storage Gateway, and configure it to use gateway-cached volumes
  • B. Configure the backup software to use Amazon S3 as the target for the data backups
  • C. Use AWS Storage Gateway, and configure it to use gateway-stored volumes
  • D. Configure the backup software to use Amazon S3 Glacier as the target for the data backups
https://docs.aws.amazon.com/stor ... atewayConcepts.html
NEW QUESTION # 275
A company manages an application that uses Amazon ElastiCache for Redis with two extra-large nodes spread across two different Availability Zones. The company's IT team discovers that the ElastiCache for Redis cluster has 75% freeable memory. The application must maintain high availability.
What is the MOST cost-effective way to resize the cluster?
  • A. Deploy a new ElastiCache for Redis cluster that uses large node types. Take a backup from the original cluster, and restore the backup in the new cluster. After the process is complete, shut down the original cluster.
  • B. Decrease the number of nodes in the ElastiCache for Redis cluster from 2 to 1.
  • C. Deploy a new ElastiCache for Redis cluster that uses large node types. Migrate the data from the original cluster to the new cluster. After the process is complete, shut down the original duster.
  • D. Perform an online resizing for the ElastiCache for Redis cluster. Change the node types from extra-large nodes to large nodes.
NEW QUESTION # 276
It is SOA-C02 exam qualification certification that gives you capital of standing in society and serving your company. Nowadays, using the Internet to study on our SOA-C02 exam questions has been a new trend of making people access to knowledge and capability-building. Our SOA-C02 Preparation materials display a brand-new learning model and a comprehensive knowledge structure on our official exam bank, which aims at improving your technical skills and creating your value to your future.
Reliable SOA-C02 Study Guide: https://www.actual4dump.com/Amazon/SOA-C02-actualtests-dumps.html
Amazon Latest SOA-C02 Test Camp To lead a respectable life, our experts made a rigorously study of professional knowledge about this exam, We believe that our study materials will have the ability to help all people pass their SOA-C02 exam and get the related exam in the near future, We take into account all aspects on the SOA-C02 exam braindumps and save you as much time as possible, SOA-C02 AWS Certified Associate certification exam is the replacement of the older SOA-C02 AWS Certified SysOps Administrator - Associate (SOA-C02) certification exam.
Your iPad Won't Turn Off, Nowadays, it is hard to find a desirable SOA-C02 job, To lead a respectable life, our experts made a rigorously study of professional knowledge about this exam.
We believe that our study materials will have the ability to help all people pass their SOA-C02 Exam and get the related exam in the near future, We take into account all aspects on the SOA-C02 exam braindumps and save you as much time as possible.
Hot Latest SOA-C02 Test Camp | Latest Reliable SOA-C02 Study Guide: AWS Certified SysOps Administrator - Associate (SOA-C02) 100% PassSOA-C02 AWS Certified Associate certification exam is the replacement of the older SOA-C02 AWS Certified SysOps Administrator - Associate (SOA-C02) certification exam, Besides, our staff treasures all your constructive opinions and recommends, we can be better our services in all respects.
2026 Latest Actual4dump SOA-C02 PDF Dumps and SOA-C02 Exam Engine Free Share: https://drive.google.com/open?id=1SnPADDEvUBkePeifEYU0B0rlzVmnctE6
Posted at 1/11/2026 06:12:54        Only Author  2#
Wenn Sie Ihre IT-Fähigkeiten erhöhen und die EMC D-ECS-DY-23 Zertifizierungsprfung einmalig bestehen möchten, können Sie auf EchteFrage vertrauen. Denn EchteFrage kann Ihnen helfen, das Prfungszertifikat zu bekommen, indem wir Ihnen die zutreffendesten und genauesten Fragenkataloge zur EMC D-ECS-DY-23 Zertifizierungsprfung anbieten. Wenn Sie mit dem Kaufen noch zögern, können Sie die Demo auf unserer Webseite EchteFrage herunterladen. Wir sind sicher, dass Sie nicht enttäuscht sein werden.
Posted at 1/11/2026 17:52:37        Only Author  3#
Wollen Sie durch die VMware 2V0-17.25 Zertifizierungsprfung Ihre Position in der heutigen kunkurrenzfähigen IT-Branche und Ihre beruflichen Fähigkeiten verstärken? Dann mssen Sie mit breiten fachlichen Kenntnissen ausgerstet sein. Und es ist nicht so einfach, die VMware 2V0-17.25 Zertifizierungsprfung zu bestehen. Vielleicht ist die VMware 2V0-17.25 Zertifizierungsprfung ein Sprungbrett, um im IT-Bereich befördert zu werden. Aber man braucht doch nicht, sich mit so viel Zeit und Energie fr die Prfung verwenden. Sie können unsere Fast2test Produkte wählen, die speziellen Schulungsunterlagen fr die IT-Zertifizierungsprfungen bieten.
Posted at 1/23/2026 04:04:07        Only Author  4#
Microsoft MS-700-KR시험을 어떻게 패스할가 고민그만하시고 Itexamdump의Microsoft MS-700-KR시험대비덤프를 데려가 주세요. 가격이 착한데 비해 너무나 훌륭한 덤프품질과 높은 적중율은 Itexamdump가 아닌 다른곳에서 찾아볼수 없는 혜택입니다. Microsoft MS-700-KR 덤프구매전 데모부터 다운받아 공부해보세요.
Posted at 2/1/2026 13:43:39        Only Author  5#
Thank you for your wonderful article; it was truly shocking! Sharpen your IT skills by accessing free ICF-ACC reliable test sample. Wishing you all the best!
Posted at 2/6/2026 13:06:19        Only Author  6#
I really appreciate the inspiration in this article, thank you for sharing! FC0-U71 reliable exam dumps free provides a variety of useful content, freely offered to support your learning.
Posted at 3/7/2026 06:56:49        Only Author  7#
Per EchteFrage können Sie die neuesten Fragen und Antworten zur SAP C-SIGPM-2403-German Zertifizierungsprfung bekommen. Bitte kaufen Sie die Produkte schnell, so dass Sie die Prfung zum ersten mal bestehen können. Zur Zeit besitzt nur PassTest die krzlich aktualisierten SAP C-SIGPM-2403-German Prfungsfragen und Antworten .
Posted at 3/8/2026 21:26:43        Only Author  8#
Your article is truly amazing; I appreciate your sharing! The S2000-022 reliable APP simulations questions were key in securing my promotion and raisenow its your turn! Get them for free!
