100% Pass Quiz 2026 SAP P_SAPEA_2023 Updated New Test Test
Posted at 1/10/2026 02:17:59
View315
Replies5
2026 Latest ActualTestsIT P_SAPEA_2023 PDF Dumps and P_SAPEA_2023 Exam Engine Free Share: https://drive.google.com/open?id=1229rf-t9iR6kXbkZI_PlfwrioWWY5a_i
With these adjustable SAP Certified Professional - SAP Enterprise Architect (P_SAPEA_2023) mock exams, you can focus on weaker concepts that need improvement. This approach identifies your mistakes so you can remove them to master the SAP Certified Professional - SAP Enterprise Architect (P_SAPEA_2023) exam questions of ActualTestsIT give you a comprehensive understanding of P_SAPEA_2023 Real Exam format. Self-evaluation by taking practice exams makes your SAP P_SAPEA_2023 exam preparation flawless and strengthens enough to crack the test in one go.
SAP P_SAPEA_2023 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - SAP Enterprise Architecture Framework and toolset: The focal point of this topic is the company's business strategy. It also covers SAP Reference Architecture content, IT requirements, business requirements and (SAP) solution space, and SAP Enterprise Architecture-related artifacts.
| | Topic 2 | - Architecture vision and roadmap: It focuses on developing the architecture vision and roadmap for a company. The topic also covers existing and future business models and capabilities and target business
- solution architecture roadmap.
| | Topic 3 | - Application, Data, and Technical Architecture: This topic evaluates your knowledge about artifact content, stakeholders, best practices of SAP Reference Content, the SAP Integration Advisory Methodology, and SAP Clean Core principles and strategy.
| | Topic 4 | - Business Architecture: The topic of business architecture discusses business capability mapping and end-to-end processes.
SAP P_SAPEA_2023 Upgrade Dumps | P_SAPEA_2023 Exam SamplePractice tests (desktop and web-based) are simulations of actual SAP P_SAPEA_2023 PDF Questions designed to help individuals prepare and improve their performance for the SAP P_SAPEA_2023 certification test. ActualTestsIT facilitates the customers with customizable practice tests which means they can adjust the number of questions and set the time of the test according to themselves which will help them in order to feel the real-based exam pressure and control it.
SAP Certified Professional - SAP Enterprise Architect Sample Questions (Q14-Q19):NEW QUESTION # 14
Which artifact from the SAP Reference Solution Architecture shows which data objects are exchanged between SAP application components in a given end-to-end scenario?
- A. SAP Data Component Diagram, which is available in SAP Signavio Process Explorer
- B. SAP Data Object Diagram, which is available from SAP API Business Accelerator Hub (api.sap.com)
- C. SAP Data Flow Diagram, which is available from SAP API Business Accelerator Hub (api sap.com)
The SAP Data Flow Diagram (DFD) is an artifact from the SAP Reference Solution Architecture that shows which data objects are exchanged between SAP application components in a given end-to-end scenario. The DFD uses a graphical representation to show the flow of data between different components of a system.
The SAP Data Object Diagram (DOD) is also an artifact from the SAP Reference Solution Architecture, but it does not show the flow of data between different components. The DOD shows the structure of data objects, including their attributes and relationships.
The SAP Data Component Diagram (DCD) is an artifact from SAP Signavio Process Explorer, which is a tool for modeling business processes. The DCD shows the different components of a system, including their relationships.
Therefore, the correct answer is option B.
Here is a table that summarizes the different artifacts and their purposes:
According to the SAP Reference Architecture Content: An Overview - Part 2 , the SAP Data Flow Diagram is an artifact that shows the flow of data through the SAP solution, from the source to the destination. It also shows which data objects are exchanged between the different components and services of the SAP solution, such as master data, transactional data, analytical data, or configuration data. The SAP Data Flow Diagram can help you to understand and communicate how data is created, transformed, and consumed in a SAP solution, and to identify and optimize the data integration points and dependencies.
The other options (A and C) are not correct for the artifact from the SAP Reference Solution Architecture that shows which data objects are exchanged between SAP application components in a given end-to-end scenario, because they either do not exist or do not show the data flow. For example:
Option A is not correct because there is no such artifact as SAP Data Object Diagram in the SAP Reference Solution Architecture content. The SAP API Business Accelerator Hub (api.sap.com) is a platform that provides access to SAP APIs, events, and related resources, but it does not provide any diagrams that show the data objects exchanged between SAP application components.
Option C is not correct because the SAP Data Component Diagram is not an artifact that shows the data flow, but rather an artifact that shows the main components and services that constitute the target application architecture, as well as their relationships and interactions. The SAP Data Component Diagram does not show which data objects are exchanged between the different components and services of the SAP solution. The SAP Signavio Process Explorer is a tool that helps you to model, analyze, and optimize business processes, but it does not provide any diagrams that show the data flow.
NEW QUESTION # 15
Select the most appropriate sequence of critical Business Capabilities for the Business Architecture Roadmap.
NEW QUESTION # 16
While discussing the Smart Battery initiative in greater detail with the appropriate stakeholder, as Chief Enterprise Architect of Wanderlust, you discover that several key areas such as value proposition, cost structure, revenue streams, partners, and channels have been worked upon in isolation and therefore do not tally with each other. Which artifact would you recommend to bring all the above key dimensions together in a single window, to have a unified, consistent, holistic view of the Smart Battery initiative?
- A. Architecture Principles
- B. Business Strategy Map
- C. Statement of Architecture Work
- D. Business Model Canvas
A Business Model Canvas is a strategic management and entrepreneurial tool that allows you to describe, design, challenge, invent, and pivot your business model1. A Business Model Canvas consists of nine building blocks that cover the four main areas of a business: customers, offer, infrastructure, and financial viability2.
These building blocks are:
Value Proposition: The value that you deliver to your customers and the problem that you solve for them.
Customer Segments: The different groups of people or organizations that you aim to reach and serve.
Channels: The ways that you communicate with and deliver value to your customers.
Customer Relationships: The types of relationships that you establish and maintain with your customers.
Revenue Streams: The sources of income that you generate from your value proposition.
Key Resources: The most important assets that you need to create and deliver your value proposition.
Key Activities: The most important things that you do to create and deliver your value proposition.
Key Partnerships: The network of suppliers and partners that help you create and deliver your value proposition.
Cost Structure: The most significant costs that you incur to create and deliver your value proposition.
A Business Model Canvas is a useful artifact to bring all the key dimensions of the Smart Battery initiative together in a single window, to have a unified, consistent, holistic view of the initiative. By using a Business Model Canvas, you can:
Visualize the entire business model of the Smart Battery initiative on one page.
Identify the gaps, inconsistencies, or conflicts among the different elements of the business model.
Align the value proposition, cost structure, revenue streams, partners, and channels with the customer segments and their needs.
Test and validate your assumptions and hypotheses about the business model.
Iterate and improve your business model based on feedback and data.
Verified References: 1: https://www.strategyzer.com/canvas/business-model-canvas | 2:
https://www.investopedia.com/terms/b/business-model-canvas.asp
NEW QUESTION # 17
The online marketing channel is targeted only to individual customers, who should be able to choose any of the 50 combinations that Wanderlust offers for its electric cars. Every confirmed online order must be first checked for ready stock availability and, if unavailable, must go for production scheduling. As Chief Enterprise Architect of Wanderlust, along with the SAP Enterprise Architect, you have identified Lead to Cash (L2C) as the key E2E process. However, you have found out that the SAP Reference Business Architecture content has several Business Process Variants of the L2C process, from which you are supposed to choose one suitable variant for Wanderlust's product range and business model. Which of the following combinations of L2C Business Process Variants and business reasons are the most suitable? Note: There are 2 correct answers to this question.
- A. Variant: Lead to Cash - Business to Business (B2B) with Make to Stock Business reason: Each corporate customer may order in bulk for the same variants repeatedly, which may be available in existing stock and met from there.
- B. Variant: Lead to Cash-B2C with Make to Stock/Business reason: Each individual customer may order their preferred variant, which may be available in existing stock and met from there.
- C. Variant: Lead to Cash-B2B with Make to Order/Business reason: Each corporate customer may order different variants, which can be produced only upon receipt of customer order.
- D. Variant: Lead to Cash - Business to Consumer (B2C) with Make to Order Business reason: Each Individual customer may order their preferred variant, which can be produced upon receipt of customer order, if stock is not readily available.
Considering Wanderlust's product range and business model, which targets individual customers and offers a wide range of electric car combinations, the Lead to Cash-B2C with Make to Stock variant would be suitable for orders that can be met from existing stock. Similarly, the Lead to Cash-B2C with Make to Order variant would fit the business model when an individual customer orders a combination not available in stock, necessitating production scheduling. Both variants cater to the business-to-consumer (B2C) model and account for the direct sales approach to individual customers.
Reference = These variants would be documented in SAP's Business Process Architecture content, which includes various Lead to Cash process scenarios, adjusted for different business contexts.
NEW QUESTION # 18
Which runtime environments does SAP directly support an SAP BTP?
- A. Kubemetes/SAP Business Technology Platform (BTP), ABAP environment
- B. SAP BTP, Cloud Foundry environment/SAP Business Technology Platform (BTP), ABAP environment/SAP BTP, Kyma runtime
- C. OpenJDK for Java applications/Openshift for Kubernetes
SAP Business Technology Platform (BTP) is a suite of cloud-based platform-as-a-service (PaaS) offerings from SAP. BTP provides a variety of runtime environments for running applications, including:
SAP BTP, Cloud Foundry environment: This is a popular runtime environment for running Java, Node.js, and Python applications.
SAP Business Technology Platform (BTP), ABAP environment: This is a runtime environment for running ABAP applications.
SAP BTP, Kyma runtime: This is a runtime environment for running Kubernetes-based applications.
In addition to these runtime environments, BTP also provides a number of other services, such as:
Database services: BTP provides a variety of database services, including SAP HANA, MySQL, and PostgreSQL.
Messaging services: BTP provides a variety of messaging services, such as SAP Cloud Platform Integration and SAP Cloud Platform Event Mesh.
Storage services: BTP provides a variety of storage services, such as SAP Cloud Platform Object Storage and SAP Cloud Platform File Storage.
BTP is a comprehensive platform that provides a variety of services for running applications and managing data. The different runtime environments available in BTP allow you to choose the right environment for your specific needs.
SAP BTP supports multiple runtime environments for different purposes and skill sets. A runtime environment is any runtime that hosts applications and services. An SAP BTP environment provides integration into the SAP BTP account model, cockpit, and permissions management10. The following are the runtime environments that SAP directly supports on SAP BTP:
SAP BTP, Cloud Foundry environment: This environment allows you to create polyglot cloud applications in Cloud Foundry. It supports various programming languages, such as Java, Node.js, Python, Go, and PHP. It also provides a code-to-container packaging and deployment model, platform-managed application security patching and updates, automatic application routing, load balancing, health checks, and multilevel self-healing.
It also supports the Cloud Application Programming Model (CAP), which is an opinionated framework for developing business applications.
SAP Business Technology Platform (BTP), ABAP environment: This environment allows you to create ABAP-based cloud applications within the Cloud Foundry environment. It supports the ABAP programming language and the ABAP RESTful Programming Model (RAP), which is a framework for developing RESTful services and user interfaces. It also provides an integrated development lifecycle and enables you to reuse existing on-premise ABAP assets.
SAP BTP, Kyma runtime: This environment provides a fully managed cloud-native Kubernetes application runtime based on the open-source project "Kyma". It supports various programming languages and models, such as Node.js, Python, Go, Java, CAP, and serverless functions. It also provides a built-in service mesh, eventing framework, API gateway, service catalog, and service binding capabilities. It enables you to develop highly scalable, microservice-based applications and user-centric process extensions.
Verified References: 10:
https://help.sap.com/docs/btp/ar ... ns/runtimes-environ
| : https://help.sap.com/docs/btp/sa ... atform/environments
NEW QUESTION # 19
ActualTestsIT's SAP P_SAPEA_2023 exam training materials is the best training materials. If you are an IT staff, it will be your indispensable training materials. Do not take your future betting on tomorrow. ActualTestsIT's SAP P_SAPEA_2023 exam training materials are absolutely trustworthy. We are dedicated to provide the materials to the world of the candidates who want to participate in IT exam. To get the SAP P_SAPEA_2023 Exam Certification is the goal of many IT people & Network professionals. The pass rate of ActualTestsIT is incredibly high. We are committed to your success.
P_SAPEA_2023 Upgrade Dumps: https://www.actualtestsit.com/SAP/P_SAPEA_2023-exam-prep-dumps.html
- Pass-Sure New P_SAPEA_2023 Test Test Help You to Get Acquainted with Real P_SAPEA_2023 Exam Simulation 🦌 Search for P_SAPEA_2023 and download exam materials for free through ▛ [url]www.verifieddumps.com ▟ 🎋
_SAPEA_2023 Valid Braindumps Pdf[/url] - P_SAPEA_2023 Valid Braindumps Pdf 🐍 Latest P_SAPEA_2023 Dumps 🕸 Valid P_SAPEA_2023 Exam Labs 🥾 Download ⮆ P_SAPEA_2023 ⮄ for free by simply searching on ⮆ [url]www.pdfvce.com ⮄ 📬
_SAPEA_2023 Relevant Exam Dumps[/url] - Valid Test P_SAPEA_2023 Fee 📸 P_SAPEA_2023 Vce Torrent 📠 Latest P_SAPEA_2023 Dumps 🌖 Simply search for P_SAPEA_2023 for free download on [url]www.troytecdumps.com 🐱
_SAPEA_2023 Relevant Exam Dumps[/url] - SAP P_SAPEA_2023 Practice Test Software for Desktop ❤ Search for ⇛ P_SAPEA_2023 ⇚ and download exam materials for free through [url]www.pdfvce.com 📳Test P_SAPEA_2023 Voucher[/url]
- 2026 SAP P_SAPEA_2023 Latest New Test Test ❓ Download ▶ P_SAPEA_2023 ◀ for free by simply entering { [url]www.practicevce.com } website 🤘Latest P_SAPEA_2023 Dumps[/url]
- Pass Guaranteed Quiz 2026 SAP P_SAPEA_2023: The Best New SAP Certified Professional - SAP Enterprise Architect Test Test 🌅 The page for free download of ▷ P_SAPEA_2023 ◁ on ➠ [url]www.pdfvce.com 🠰 will open immediately ❕
_SAPEA_2023 Valid Braindumps Files[/url] - New P_SAPEA_2023 Exam Answers 🐰 P_SAPEA_2023 Relevant Exam Dumps 🌿 Examinations P_SAPEA_2023 Actual Questions 📖 Search on { [url]www.torrentvce.com } for ☀ P_SAPEA_2023 ️☀️ to obtain exam materials for free download 🧵Reliable P_SAPEA_2023 Exam Price[/url]
- P_SAPEA_2023 Reliable Exam Sims ⤴ Reliable P_SAPEA_2023 Exam Price 🥾 Valid P_SAPEA_2023 Exam Materials 😀 Search for ✔ P_SAPEA_2023 ️✔️ and download exam materials for free through [url]www.pdfvce.com 🕯Valid P_SAPEA_2023 Exam Materials[/url]
- SAP P_SAPEA_2023 Practice Test Software for Desktop 🖍 Immediately open [url]www.easy4engine.com and search for P_SAPEA_2023 to obtain a free download 💿Reliable P_SAPEA_2023 Test Book[/url]
- SAP certification P_SAPEA_2023 the latest exam questions and answers 😼 Open ⏩ [url]www.pdfvce.com ⏪ and search for ⇛ P_SAPEA_2023 ⇚ to download exam materials for free 🌼Test P_SAPEA_2023 Voucher[/url]
- P_SAPEA_2023 Learning Materials: SAP Certified Professional - SAP Enterprise Architect- P_SAPEA_2023 Exam braindumps 🔰 Open [ [url]www.vce4dumps.com ] and search for P_SAPEA_2023 to download exam materials for free 🟠Reliable P_SAPEA_2023 Exam Price[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, maitriboutique.in, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, kuailezhongwen.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, shortcourses.russellcollege.edu.au, www.stes.tyc.edu.tw, Disposable vapes
