2026 Salesforce PDI: Platform Developer I (PDI)¨CValid New Test Testking
86
Posted at 1/10/2026 02:54:11      View£º165 | Replies£º2        Print      Only Author   [Copy Link] 1#
P.S. Free & New PDI dumps are available on Google Drive shared by VCEDumps: https://drive.google.com/open?id=1XNqbceSCisNlfaf5_kao3Aadd_YfMyLW
Our PDI test questions are available in three versions, including PDF versions, PC versions, and APP online versions. Each version has its own advantages and features, PDI test material users can choose according to their own preferences. The most popular version is the PDF version of PDI exam prep. The PDF version of PDI Test Questions can be printed out to facilitate your learning anytime, anywhere, as well as your own priorities. The PC version of PDI exam prep is for Windows users. If you use the APP online version, just download the application. Program, you can enjoy our PDI test material service.
Are you still satisfied with your present job? Do you still have the ability to deal with your job well? Do you think whether you have the competitive advantage when you are compared with people working in the same field? If your answer is no£¬you are a right place now. Because our PDI Exam Torrent will be your good partner and you will have the chance to change your work which you are not satisfied with, and can enhance your ability by our PDI guide questions, you will pass the exam and achieve your target.
Salesforce New PDI Test Testking: Platform Developer I (PDI) - VCEDumps Help you Pass for SureOur third format is the desktop practice PDI exam software which can be used easily after installing it on your Windows laptop and computers. These formats are there so that applicants with different study styles can use them to attempt the Platform Developer I (PDI) (PDI) PRACTICE QUESTIONS successfully. The practice material of VCEDumps can be instantly accessed just after purchasing it.
Salesforce Platform Developer I (PDI) Sample Questions (Q175-Q180):NEW QUESTION # 175
A developer is designing a new application on the Salesforce platform and wants to ensure it can support multiple tenants effectively.
Which design framework should the developer consider to ensure scalability and maintainability?
  • A. Model-View-Controller (MVC)
  • B. Waterfall Model
  • C. Flux (view, action, dispatcher, and store)
  • D. Agile Development
* MVC: The Model-View-Controller design pattern is ideal for Salesforce development as it separates the business logic (model), user interface (view), and controller logic, ensuring scalability and maintainability.
* Salesforce's architecture inherently supports MVC, with sObjects as the model, Visualforce or Lightning components as the view, and Apex controllers as the controller.
Why not other options?
* A: The Waterfall model is a development methodology, not a design framework.
* B: Flux is a front-end application architecture and not relevant to Salesforce.
* D: Agile is a development methodology, not a design framework.
* Salesforce MVC Architecture
NEW QUESTION # 176
A Licensed_Professional__c custom object exist in the system with two Master-Detail fields for the following objects: Certification__c and Contact. Users with the "Certification Representative" role can access the Certification records they own and view the related Licensed Professionals records, however users with the "Salesforce representative" role report they cannot view any Licensed professional records even though they own the associated Contact record. What are two likely causes of users in the "Sales Representative" role not being able to access the Licensed Professional records? Choose 2 answers
  • A. The organization recently modified the Sales representative role to restrict Read/Write access to Licensed_Professional__c
  • B. The organization's sharing rules for Licensed_Professional__c have not finished their recalculation process.
  • C. The organization has a private sharing model for Certification__c, and Contact is the primary relationship in the Licensed_Professional__c object
  • D. The organization has a private sharing model for Certification__c, and Certification__c is the primary relationship in the Licensed_Professional__c object.
NEW QUESTION # 177
A developer created a custom order management app that uses an Apex class. The order is represented by an Order object and an OrderlItem object that has a master-detail relationship to Order. During order processing, an order may be split into multiple orders.
What should a developer do to allow their code to move some existing OrderItem records to a new Order record?
  • A. Create a junction object between OrderItem and Order.
  • B. Select the Allow reprinting option on the master-detail relationship.
  • C. Change the master-detail relationship to an external lookup relationship.
  • D. Add without sharing to the Apex class declaration.
* Allow Reparenting in Master-Detail Relationships:
* In a master-detail relationship, the child record (in this case, OrderItem) is tightly bound to the parent record (Order).
* By default, child records cannot be reassigned to a different parent record in master-detail relationships. However, enabling the "Allow Reparenting" option on the master-detail field allows the child record (OrderItem) to be reparented to a different master record (Order).
* This is the correct solution as it ensures that OrderItem records can be reassigned to a new Order without changing the structure of the relationship.
* Why not the other options?
* A. Add without sharing to the Apex class declaration:
* Adding without sharing modifies sharing rules but does not affect the ability to reparent child records. This is unrelated to the issue described.
* B. Change the master-detail relationship to an external lookup relationship:
* Changing the relationship type is not necessary. Additionally, doing so could introduce unintended side effects, as master-detail relationships have features like roll-up summaries that are lost with a lookup relationship.
* C. Create a junction object between OrderItem and Order:
* Introducing a junction object is not required. This adds unnecessary complexity and deviates from the intended use of master-detail relationships.
* Master-Detail Relationship Documentation
* Allow Reparenting Option
NEW QUESTION # 178
Which two statements are true regarding formula fields? Choose 2 answers
  • A. Fields that are referenced by formula field can not be deleted until the formula is modified or deleted.
  • B. When concatenating fields, line breaks can be added to improve readability.
  • C. Formula fields may reference formula field on the same object to a level of one deep.
  • D. When using the & operator to concatenate strings, the result is automatically truncated to fit the destination.
NEW QUESTION # 179
The following code snippet is executed by a Lightning web component in an environment with more than 2,000 lead records:
Which governor limit will likely be exceeded within the Apex transaction?
  • A. Total number of records retrieved by SOQL queries
  • B. Total number of DML statements issued
  • C. Total number of SOQL queries issued
  • D. Total number of records processed as a result of DML statements
NEW QUESTION # 180
PDI exam training allows you to pass exams in the shortest possible time. If you do not have enough time, our study material is really a good choice. In the process of your learning, our study materials can also improve your efficiency. If you don't have enough time to learn, PDI test guide will make the best use of your spare time, and the scattered time will add up. The service of PDI Test Guide is very prominent. It always considers the needs of customers in the development process. There are three versions of our PDI learning question, PDF, PC and APP. Each version has its own advantages. You can choose according to your needs.
PDI Reliable Exam Topics: https://www.vcedumps.com/PDI-examcollection.html
Here for our Salesforce PDI exam study guide, you will have no risks of privacy giving away as we will never utter a word about your personal information to anyone else, Salesforce New PDI Test Testking Maybe you have these boring experiences, such as, brain freeze, forgetting everything, sweaty palms, When you have a try of PDI exam sample online, it will allow you to have confidence in passing the exam the first time.
This book has been successfully tested at advanced undergraduate PDI Reliable Exam Topics and introductory graduate levels, and can be a useful addition to security certification courses.
Take a common product that others sell and repackage it in a new way, Here for our Salesforce PDI Exam Study Guide, you will have no risks of privacy giving away Valid PDI Test Pdf as we will never utter a word about your personal information to anyone else.
The Best New PDI Test Testking | 100% Free PDI Reliable Exam TopicsMaybe you have these boring experiences, such as, brain freeze, forgetting everything, sweaty palms, When you have a try of PDI exam sample online, it will allow you to have confidence in passing the exam the first time.
So our professionals provide all customers with the best quality PDI dump torrent materials and most comprehensive service when you buy our PDI passleader vce.
We will promptly provide feedback PDI to you and we sincerely help you to solve the problem.
2026 Latest VCEDumps PDI PDF Dumps and PDI Exam Engine Free Share: https://drive.google.com/open?id=1XNqbceSCisNlfaf5_kao3Aadd_YfMyLW
Posted at 1/10/2026 06:04:05        Only Author  2#
Um Ihre Palo Alto Networks PSE-Strata-Pro-24 Zertifizierungspr¨¹fungen reibungslos erfolgreich zu meistern, brauchen Sie nur unsere Pr¨¹fungsfragen und Antworten zu Palo Alto Networks PSE-Strata-Pro-24 Dumps (Palo Alto Networks Systems Engineer Professional - Hardware Firewall) auswendigzulernen. Viel Erfolg!
Posted at 2/23/2026 05:38:39        Only Author  3#
I¡¯m so thankful for your article, it was really eye-catching. Here are the free Trustworthy H12-811_V1.0-ENU pdf questions. Wishing you all the best for your exams!
