[General] Use PDII-JPN Exam Questions [2026]-Best Preparation Material
108
General Use PDII-JPN Exam Questions [2026]-Best Preparation Material
Posted at 1/10/2026 03:29:50      View155 | Replies2        Print      Only Author   [Copy Link] 1#
The  (PDII-JPN) certification helps you advance your career and even secure a pay raise. Today, the Salesforce certification is an excellent choice for career growth, and to obtain it, you need to pass the PDII-JPN exam which is a time-based exam. To prepare for the PDII-JPN Exam successfully in a short time, it's essential to prepare with real PDII-JPN exam questions. If you don't prepare with PDII-JPN updated dumps, you will fail and lose time and money.
A certification is not only an affirmation to your ability but also can help you enter a better company and improve your salary. PDII-JPN exam cram can help you get your certification successfully. We have a professional team to collect and research the latest information for the exam, and we offer you free update for 365 days after payment, so that you can obtain the latest information. In order to build up your confidence for PDII-JPN Exam Braindumps, we are pass guarantee and money back guarantee if you fail to pass the exam.
Ace Your Salesforce PDII-JPN Exam with Pass4Test: Comprehensive Study Material and Real Exam QuestionsPass4Test offers you the best practice tests for the preparation of PDII-JPN exams. The practice tests are designed to provide you the type of questions you are going to face in real PDII-JPN exams. The simulated real PDII-JPN exam scenario, created in the practice exam software, is meant to make you familiar with the actual PDII-JPN Exam. PDII-JPN announce several changes. Through one year, in their PDII-JPN exams according to the updated technologies. Make sure to purchase the most recent and updated version of PDII-JPN certification practice exam for best preparation of PDII-JPN exam.
Salesforce  Sample Questions (Q82-Q87):NEW QUESTION # 82
_kߤϡΤΤ褦 Queueable 󥿩`ե`gװ륯饹ɤޤ
ФʤΥѥ֥å饹 OrderQueueableJob Queueable gװޤ {
ѥ֥å void g(QueueableContext ƥ) {
// gװå
System.enqueueJob(¤ FollowUpJob());
ǥץȥץһhȤơ_kߤόꤹƥȥ饹ɤҪޤƥȥ饹ˌgФ뤿ˡ_kߤgФ٤2ĤΥϤɤǤ1
  • A. System.enqueueJob(new OrderQueueableJob()) Test.startTest Test.stopTest() LJߤޤ
  • B. ƥȌgФ˥֤BiˤϡTe3st.isRunningTest() gװޤ
  • C. Queueable ֤һ`ɤnjgФǤ褦ˤˤϡseeAllData=true gװޤ2
  • D. ƥ 饹ΌgХ``٤ʤȤ Order ֥Ȥˌ롸٤Ʊʾޤ֤äƤ뤳Ȥ_Jޤ
Testing asynchronous Apex, such as the Queueable interface, requires specific handling to ensure the job actually executes during the test run and adheres to platform limits.
First, Salesforce enforces a strict limit on chaining Queueable jobs during unit tests. Specifically, you cannot chain jobs (enqueue a job from another job) within a test. Since the OrderQueueableJob attempts to enqueue FollowUpJob, the test will throw an error. To resolve this, the developer should use Test.isRunningTest() (Option B) within the execute method to conditionally bypass the System.enqueueJob call during test runs.
Second, asynchronous jobs are queued by the system and do not run immediately. To force the execution of a Queueable job so that results can be asserted, the System.enqueueJob call must be wrapped within Test.
startTest() and Test.stopTest() (Option D). When Test.stopTest() is called, the execution pauses until all queued asynchronous jobs in that block finish running.
Option A is incorrect because seeAllData does not affect asynchronous processing modes. Option C is incorrect because the class is defined as without sharing, meaning it bypasses sharing rules regardless of the running user's permissions. By combining recursion/chaining guards and the startTest/stopTest block, the developer can reliably test the logic within the execute method.
NEW QUESTION # 83
_kߤϡɤΥץեȥ``ɤΥ`åȤ˥Ǥ뤫ָǤCܤ䤨`å ǩ`򱣴椹뷽ҊĤ뤳Ȥޤ
Υǩ`򱣴椹ˤϺΤʹäҪޤ?
  • A. O
  • B. ĥ꥽`
  • C. ᥿ǩ`
  • D. system.Cookie 饹
Custom settings are a type of custom data that can be used to store secret data with an ability to specify which profiles and users can access which secrets. Custom settings can store data in a hierarchical structure, which allows the developer to set different values for different levels of access, such as organization, profile, or user. Custom settings can also be encrypted using the Protected Custom Settings feature, which prevents the data from being exposed in the user interface, the API, or Apex code. By using custom settings, the developer can store the secret data securely and control the access to the data based on the user's profile or identity. Reference: [Custom Settings], [Protected Custom Settings]
NEW QUESTION # 84
Visualforce ک`ȥ`Ǥ transient ``ɤʹäϡɤһĤʥѥե`ޥ󥹆}ޤ?
  • A. Υѥե`ޥ󥹤Ϥޤ
  • B. ک`ܞͤƤޤ
  • C. `ɕrg̿sޤ
  • D. ӥ`Ʃ`Ȥpޤ
NEW QUESTION # 85
Iˤϡ}δҎģʥǩ`٩` Web `ӥκӳgФ Apex ץޤ
ǩ`٩`ץWeb`ӥόgФLrgϤꡢ혷ˌgФҪޤ_kߤϡХޤ䥷ƥޤ˵ִ뤳ȤʤApex`ɤɤΤ褦ӛФ褤Ǥ礦123
  • A. Apex SchedulerʹäƸץ򥹥`뤷ޤ56
  • B. ץȥ`륢Ȥ} @future ᥽åɤʹäޤ
  • C. Хʩ`ޤ_顢Limits 饹ʹäƥץȫֹͣޤ8
  • D. Queueable Apex ʹäƥ֤Bi혷ˌgФޤ
This requirement specifies two critical constraints: the operations take a long time (likely exceeding synchronous CPU and timeout limits) and they must be performed sequentially.
Queueable Apex (Option D) is the optimal solution because it supports job chaining. Chaining allows one Queueable job to enqueue another Queueable job from its execute() method. This effectively creates a sequence where Job B only starts after Job A has successfully finished. Each job in the chain starts with a fresh set of governor limits, which is essential for "extensive database operations" and long-running callouts.
Option C (@future) is unsuitable because future methods cannot be chained; you cannot call one future method from another. Furthermore, the order in which multiple future methods execute is not guaranteed by the platform, violating the "sequential" requirement. Option A (Apex Scheduler) is intended for delayed or recurring tasks and is not designed for managing immediate sequential dependencies. Option B is a defensive coding practice but does not solve the underlying need to complete the work. Queueable Apex provides the programmatic control needed to manage complex, multi-step asynchronous workflows safely.
NEW QUESTION # 86
Universal Containers ϡδI⤬kϤˡApex ʹäƥ।٥Ȥ_뤳Ȥⲿƥ֪ͨȿƤޤ
Ҫ򜺤mФʥѥ֥å/֥饤 åϺΤǤ?
  • A. addError() ᥽åɤʹäƥ` ٥ȤkФCometD ʹäⲿƥ˥٥Ȥ򥵥֥饤֤ޤ
  • B. ⲿƥ˥٥ ͥ򥵥֥饤֤ޤ椹ҪϤޤ
  • C. addError() ᥽åɤʹäƥ` ٥ȤkФ٥Ȥ򥵥֥饤֤ⲿƥ֪ͨȥꥬ`ɤޤ
  • D. Eventtrus.publish() ᥽åɤʹäƥ` ٥ȤkФCometD ʹäⲿƥ˥٥Ȥ򥵥֥饤֤ޤ
NEW QUESTION # 87
Undoubtedly, passing the Salesforce PDII-JPN certification exam is one big achievement. Regardless of how tough the PDII-JPN exam is, it serves an important purpose of improving your skills and knowledge of a specific field. Once you become certified by Salesforce PDII-JPN, a whole new career scope will open up to you.
PDII-JPN Actual Exam Dumps: https://www.pass4test.com/PDII-JPN.html
The PDII-JPN exam dumps can be downloaded in no time after purchase, thus you won't waste your time and can study PDII-JPN PDF training material immediately, When you choose our  online test engine, the modern and user friendly interface will give you surprise and motivate your enthusiasm for the PDII-JPN study preparation, Tens of thousands of our worthy customers have been benefited by our PDII-JPN exam questions.
He is also the author of the previous editions of this PDII-JPN guide as well as a contributing editor for Computer Graphics World magazine, In fact, when you walkinto the computer section of a Best Buy or similar PDII-JPN Actual Exam Dumps consumer electronics store, you'll find more traditional notebooks than you will any other type of PC.
2026 Realistic Salesforce Sample PDII-JPN Questions Free PDFThe PDII-JPN Exam Dumps can be downloaded in no time after purchase, thus you won't waste your time and can study PDII-JPN PDF training material immediately.
When you choose our  online test engine, the modern and user friendly interface will give you surprise and motivate your enthusiasm for the PDII-JPN study preparation.
Tens of thousands of our worthy customers have been benefited by our PDII-JPN exam questions, We transcend other similar peers for so many years in quality and accuracy.
Experts groups offering help.
Posted at 1/11/2026 03:01:59        Only Author  2#
This article really made an impact, thank you for sharing! Upgrade your IT skills with free New C1000-173 dumps files. Best wishes for your success!
Posted at 1/13/2026 22:40:33        Only Author  3#
Thank you for your thought-provoking article, it deeply impressed me. The DP-300 online version resources are excellent, and theres no cost to access them.
