[General] Test 1z0-1093-25 Book, Latest 1z0-1093-25 Test Cram
73
General Test 1z0-1093-25 Book, Latest 1z0-1093-25 Test Cram
Posted at 1/10/2026 03:42:06      View351 | Replies3        Print      Only Author   [Copy Link] 1#
What's more, part of that Real4test 1z0-1093-25 dumps now are free: https://drive.google.com/open?id=1m9jlu42-_FxqgdaI3K5FD_Ux0cqY5ZaL
The Oracle Cloud Database Services 2025 Professional (1z0-1093-25) questions have many premium features, so you don't face any hurdles while preparing for 1z0-1093-25 exam and pass it with good grades. It will be an easy-to-use learning material so you can pass the Oracle Cloud Database Services 2025 Professional (1z0-1093-25) test on your first try. We even offer a full refund guarantee (terms and conditions apply) if you couldn't pass the Oracle Cloud Database Services 2025 Professional (1z0-1093-25) exam on the first try with your efforts.
The 1z0-1093-25 learning materials are of high quality, mainly reflected in the adoption rate. As for our 1z0-1093-25 exam question, we guaranteed a higher passing rate than that of other agency. More importantly, we will promptly update our 1z0-1093-25 quiz torrent based on the progress of the letter and send it to you. 99% of people who use our 1z0-1093-25 Quiz guide has passed the exam and successfully obtained their certificates, which undoubtedly show that the passing rate of our 1z0-1093-25 exam question is 99%. So our product is a good choice for you. Choose our 1z0-1093-25 learning materials, you will gain a lot and lay a solid foundation for success.
Hot Test 1z0-1093-25 Book | Valid Latest 1z0-1093-25 Test Cram: Oracle Cloud Database Services 2025 ProfessionalIf you are willing to clear exam successfully, you need to not only read books and study materials but also purchase Oracle 1z0-1093-25 reliable exam cram for well-directed review which will make you half the work with double results. You can find three versions for each exam: PDF version, Software version and APP version. You can choose one or more versions of 1z0-1093-25 Reliable Exam Cram based on your studying methods and habits.
Oracle Cloud Database Services 2025 Professional Sample Questions (Q35-Q40):NEW QUESTION # 35
Which two are valid mechanisms for accessing OS-level metrics on a Base Database Service Virtual Machine?
  • A. All OS metrics are automatically pushed to the Cloud Exadata Service Dashboard, and are not available outside of this service.
  • B. Access OS metrics programmatically via the OCI Monitoring APIs, which allow retrieval of metrics collected by the Oracle Cloud Agent.
  • C. Utilize the vmcli utility, which allows access to OS-level metrics specific to the DB System.
  • D. Access OS metrics using the OCI Metrics Explorer within the OCI Console leveraging the Oracle Cloud Agent.
  • E. The only way to access OS-level metrics is through a custom monitoring agent installed directly on the VM.
B: Access OS metrics using the OCI Metrics Explorer within the OCI Console leveraging the Oracle Cloud Agent.
* OCI Metrics Explorer is part of the OCI Monitoring service.
* The Oracle Cloud Agent collects OS-level metrics and makes them available through the OCI Console.
* Users can view metrics like CPU usage, memory utilization, and disk I/O.
E: Access OS metrics programmatically via the OCI Monitoring APIs:
* The Oracle Cloud Agent collects OS metrics and exposes them via OCI Monitoring APIs.
* This approach allows for automated data retrieval and integration with external monitoring tools.
* A. vmcli utility:This is not a standard tool for accessing OS-level metrics on Base Database Service VMs.
* C. Custom monitoring agent:While possible, it is not the primary or only method. Oracle Cloud Agent is the default tool.
* D. Automatically pushed to the Cloud Exadata Service Dashboard:This statement is incorrect as OS metrics are available through OCI Monitoring.
NEW QUESTION # 36
Which of the following statements accurately describes the recommended procedure for patching Grid Infrastructure in a BaseDB VM system where the database is NOT managed by Oracle Cloud Infrastructure (OCI)?
  • A. Apply the Grid Infrastructure patch directly to the DB system. OCI handles the patching order for all components automatically.
  • B. Apply the Grid Infrastructure patch first, then apply the database patch, after validating the GI is working correctly.
  • C. Apply the database patch first, then apply the Grid Infrastructure patch to ensure compatibility.
  • D. You cannot manually patch Grid Infrastructure in a BaseDB VM system; Oracle Cloud Infrastructure manages all patching operations.
Recommended Patching Order:
In Oracle environments, it is crucial to patchGrid Infrastructure (GI) firstbecause GI components are responsible formanaging cluster resources and storage. Applying GI patches before database patches ensures that the underlying infrastructure is compatible and stable.
* After the GI patching,validatethe environment to ensure all components are functioningcorrectly before proceeding with database software updates.
* This order minimizes the risk ofdowntime or compatibility issues.
* A:OCI does not automatically handle manual patching in non-managed DB systems.
* B:Applying the database patch first may result in compatibility problems.
* D:Users can manually patch Grid Infrastructure in BaseDB VMs.
NEW QUESTION # 37
Which of the following DOES NOT directly contribute to the calculation of provisioned read capacity units (RCUs) required for a NoSQL Database Cloud Service table?
  • A. Average record size being read.
  • B. Number of reads expected per second.
  • C. Complexity of the security roles defined on the table.
  • D. Data consistency requirements.
RCU Calculation:
Read Capacity Units (RCUs) are determined based ondata size (average record size), read frequency (number of reads per second), and consistency level (eventual vs. strong consistency). Complex security roles do not impact the calculation because they do not directly influence the amount of data read or the frequency of access.
Why the other options are correct:
* Aarger record sizes increase RCU requirements.
* B:Higher read frequency demands more RCUs.
* D:Strong consistency requires more read operations compared to eventual consistency.
NEW QUESTION # 38
Which two of the following options are valid statements regarding the management of the operating system on a Base Database Service Virtual Machine DB System?
  • A. Customers are responsible for the initial OS installation, but then patching is controlled entirely by Oracle.
  • B. Oracle manages the underlying operating system patching and updates, ensuring the system remains secure and compliant.
  • C. Customers are responsible for the security and maintenance of the operating system, including applying necessary patches and updates.
  • D. Direct SSH access to the underlying VM is restricted, and all OS-level operations must be performed through the Web Console.
  • E. Customers have full root access to the underlying operating system of the Virtual Machine DB System, allowing for customization and installation of custom software.
Answer: C,E
B: Full root access:
* Customers have root-level access to manage the OS, install custom software, and configure settings.
* This provides flexibility to meet specific application requirements.
D: Responsibility for OS security:
* With root access, customers must manage OS security, including updates and patches.
* Oracle provides tools to facilitate patching, but the responsibility lies with the customer.
* A. Restricted SSH access:SSH access is allowed for VM DB systems.
* C. Oracle-managed OS patching:Oracle does not automatically patch the OS; this is a customer responsibility.
* E. Initial OS installation by customers:The OS is pre-installed, but ongoing maintenance is customer- driven.
NEW QUESTION # 39
Within the context of Oracle Cloud Infrastructure (OCI) Base Database Service (BaseDB) virtual machine (VM) provisioning, which action is typically the RESPONSIBILITY of the customer?
  • A. Ensuring the underlying hardware infrastructure remains fault-tolerant.
  • B. Maintaining the OCI hypervisor software.
  • C. Managing the Oracle Grid Infrastructure software stack.
  • D. Automatically applying critical security patches to the operating system.
B: Managing the Oracle Grid Infrastructure software stack:
* Customers are responsible for the installation, configuration, and maintenance of the Oracle Grid Infrastructure when using BaseDB VMs.
* This includes managing Oracle Clusterware and Automatic Storage Management (ASM) if applicable.
* Ensuring the Grid Infrastructure's availability and performance is part of customer-managed tasks.
* A. Hardware fault tolerance:Managed by Oracle Cloud Infrastructure.
* C. Hypervisor maintenance:Handled by Oracle as part of the OCI infrastructure.
* D. Security patching:While OCI provides tools, the responsibility for OS patching lies with the customer.
NEW QUESTION # 40
We have full confidence of your success in exam. It is ensured with 100% money back guarantee. Get the money you paid to buy our exam dumps back if they do not help you pass the exam. To know the style and quality of exam 1z0-1093-25 Test Dumps, download the content from our website, free of cost. These free brain dumps will serve you the best to compare them with all available sources and select the most advantageous preparatory content for you. We are always efficient and give you the best support. You can contact us online any time for information and support for your exam related issues. Our devoted staff will respond you 24/7.
Latest 1z0-1093-25 Test Cram: https://www.real4test.com/1z0-1093-25_real-exam.html
Before the purchase, the clients can download and try out our 1z0-1093-25 study materials freely, Oracle Test 1z0-1093-25 Book Especially worthy of mentioning is our after sale service for our customers, We regard the quality of our Exam Collection 1z0-1093-25 PDF as a life of an enterprise, If you want to buy 1z0-1093-25 Oracle Cloud Database Services 2025 Professional training dumps, it is set with easy procedure, PDF version of Dumps PDF for 1z0-1093-25--Oracle Cloud Database Services 2025 Professional is available for some candidates who like studying and writing on paper.
What should teams be looking at today, and what should they be looking for tomorrow, How to Grow a Business, Before the purchase, the clients can download and try out our 1z0-1093-25 Study Materials freely.
With Real4test Oracle 1z0-1093-25 Real Questions Nothing Can Stop You from Getting SuccessEspecially worthy of mentioning is our after sale service for our customers, We regard the quality of our Exam Collection 1z0-1093-25 PDF as a life of an enterprise.
DOWNLOAD the newest Real4test 1z0-1093-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1m9jlu42-_FxqgdaI3K5FD_Ux0cqY5ZaL
Posted at 1/24/2026 06:02:28        Only Author  2#
This article has helped me answer many questions, and it's really great. Get free Training Mule-Con-201 Solutions to improve your IT knowledge. Wishing you success!
Posted at 1/28/2026 18:17:51        Only Author  3#
Thank you for sharing this remarkable article; it was fantastic! Free C-BCBTP-2502 new braindumps files study materials available nowgood luck!
Posted at 2/1/2026 05:37:36        Only Author  4#
Thank you for your article; it really opened my eyes! About to face the CS0-003 valid study guide free exam C hoping for good results!
