[General] New NCP-US-6.5 Test Notes & Reasonable NCP-US-6.5 Exam Price
98
General New NCP-US-6.5 Test Notes & Reasonable NCP-US-6.5 Exam Price
Posted at 1/10/2026 05:22:50      View159 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCP-US-6.5 dumps are available on Google Drive shared by Exam4Tests: https://drive.google.com/open?id=1OnXDlc5-BjByik_hb8eYGB5rfbifSMkT
As you know, many exam and tests depend on the skills as well as knowledge, our NCP-US-6.5 study materials are perfectly and exclusively devised for the exam and can satisfy your demands both. There are free demos of our NCP-US-6.5 exam questions for your reference with brief catalogue and outlines in them. You can free download the demos of our NCP-US-6.5 learning prep on the website to check the content and displays easily by just clicking on them.
Nutanix NCP-US-6.5 Exam Syllabus Topics:
  • Troubleshoot issues related to Nutanix Objects
  • Troubleshoot issues related to Nutanix Volumes
  • Troubleshoot issues related to Nutanix Files
  • Explain Data Management processes for Files and Objects
  • Configure Nutanix Files with advanced features
  • Determine the appropriate method to ensure data availability
  • recoverability
  • Deploy and Upgrade Nutanix Unified Storage
  • Perform upgrades
  • maintenance for Files
  • Objects implementations
Topic 5
  • Utilize File Analytics for data security
  • Troubleshoot Nutanix Unified Storage
  • Configure Nutanix Volumes
Topic 6
  • Identify the steps to deploy Nutanix Files
  • Given a scenario, determine product and sizing parameters
Topic 7
  • Configure Nutanix Objects
  • Describe how to monitor performance and usage
Topic 8
  • Analyze and Monitor Nutanix Unified Storage
  • Describe the use of Data Lens for data security
Topic 9
  • Configure and Utilize Nutanix Unified Storage
  • Identify the steps to deploy Nutanix Objects
2026 Authoritative Nutanix New NCP-US-6.5 Test NotesIt is our responsibility to relieve your pressure from preparation of NCP-US-6.5 exam. To help you pass the NCP-US-6.5 exam is our goal. The close to 100% passing rate of our dumps allow you to be rest assured in our products. Not all vendors dare to promise that if you fail the exam, we will give you a full refund. But our IT elite of Exam4Tests and our customers who are satisfied with our NCP-US-6.5 Exam software give us the confidence to make such promise.
Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Sample Questions (Q66-Q71):NEW QUESTION # 66
After configuring Smart DR, an administrator is unable see the policy in the Policies tab. The administrator has confirmed that all FSVMs are able to connect to Prism Central via port 9440 bidirectional.
What is the possible reason for this issue?
  • A. Port 7575 should be open for all External/Client IPS of FSVMs on the Source and Target cluster.
  • B. The primary and recovery file servers do not have the same version.
  • C. Port 7575 should be open for all Internal/Storage IPs of FSVMs on the Source and Target.
  • D. The primary and recovery file servers do not have the same protocols.
Smart DR is a feature that allows share-level replication between active file server instances for disaster recovery. To configure Smart DR, one of the prerequisites is to open TCP port 7575 for all External/Client IPs of FSVMs on the Source and Target cluster. This port is used for communication between the FSVMs and Prism Central. If this port is not open, Smart DR policies will not be visible in the Policies tab in Prism Central. Reference: Nutanix Files Administration Guide, page 79; Nutanix Files Solution Guide, page 9
NEW QUESTION # 67
An administrator is attempting to create a share that will provide user access via SMB and NFS. However, the Enable multiprosotocol accounts for NFS clients settings is not available.
What would cause this issue?
  • A. NFS configured to use unmanaged authentication.
  • B. The connection to Active Directory has not been configured.
  • C. The incorrect Files license has been applied.
  • D. The file server instance was only configured with SMB.
The cause of this issue is that the connection to Active Directory has not been configured. Active Directory is a service that provides centralized authentication and authorization for Windows-based clients and servers. To create a share that will provide user access via SMB and NFS, the administrator must first configure the connection to Active Directory in the Files Console. This will allow the administrator to enable multiprotocol accounts for NFS clients, which are accounts that map NFS users to SMB users and groups for consistent access control across both protocols. Reference: Nutanix Files Administration Guide, page 32; Nutanix Files Solution Guide, page 6
NEW QUESTION # 68
An administrator needs to improve the performance for Volume Group storage connected to a group of VMs with intensive I/O. Which vg.update vg_name command parameter should be used to distribute the I/O across multiple CVMs?
  • A. flash_mode=true
  • B. load_balance_vm_attachments=true
  • C. flash_mode=enable
  • D. load_balance_vm_attachments=enable
Nutanix Volumes, part of Nutanix Unified Storage (NUS), provides block storage via iSCSI to VMs and external hosts. A Volume Group (VG) in Nutanix Volumes is a collection of volumes that can be attached to VMs. For VMs with intensive I/O, performance can be improved by distributing the I/O load across multiple Controller VMs (CVMs) in the Nutanix cluster. The vg.update command in the Nutanix CLI (e.g., ncli) is used to modify Volume Group settings, including parameters that affect I/O distribution.
Analysis of Options:
* Option A (flash_mode=enable): Incorrect. The flash_mode parameter enables flash mode for a Volume Group, which prioritizes SSDs for I/O operations to improve performance. While this can help with intensive I/O, it does not distribute I/O across multiple CVMs-it focuses on storage tiering, not load balancing.
* Option B (load_balance_vm_attachments=true): Correct. The load_balance_vm_attachments=true parameter enables load balancing of VM attachments for a Volume Group. When enabled, this setting distributes the iSCSI connections from VMs to multiple CVMs in the cluster, balancing the I/O load across CVMs. This improves performance for VMs with intensive I/O by ensuring that no single CVM becomes a bottleneck.
* Option C (load_balance_vm_attachments=enable): Incorrect. While this option is close to the correct parameter, the syntax is incorrect. The load_balance_vm_attachments parameter uses true or false as its value, not enable. The correct syntax is load_balance_vm_attachments=true (option B).
* Option D (flash_mode=true): Incorrect. Similar to option A, flash_mode=true enables flash mode for the Volume Group, prioritizing SSDs for I/O. This does not distribute I/O across multiple CVMs, as it addresses storage tiering rather than load balancing.
Why Option B?
The load_balance_vm_attachments=true parameter in the vg.update command enables load balancing for VM attachments to a Volume Group, distributing iSCSI connections across multiple CVMs. This ensures that the I
/O load from VMs with intensive I/O is balanced across the cluster's CVMs, improving performance by preventing any single CVM from becoming a bottleneck. This directly addresses the requirement to distribute I/O for better performance.
Exact Extract from Nutanix Documentation:
From the Nutanix Volumes Administration Guide (available on the Nutanix Portal):
"To improve performance for Volume Groups with intensive I/O, use the vg.update command to enable load balancing with the parameter load_balance_vm_attachments=true. This setting distributes iSCSI connections from VMs across multiple CVMs in the cluster, balancing the I/O load and preventing bottlenecks."
Nutanix Volumes Administration Guide, Version 6.0, Section: "Optimizing Performance for Volume Groups" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix Volumes Performance Tuning".
NEW QUESTION # 69
An administrator has created a volume and needs to attach it to a windows host a via iSCSI. The data Services IP has been configured in the MS iSCSI Initiator, but no target are visible.
What is most likely the cause this issue?
  • A. The host's IQN is not authorized to access to the volume.
  • B. The host' s IP address is not authorized to access the volume.
  • C. The CHAP Authentication has not been configured on the client.
  • D. The CHAP password configured on the client is incorrect.
Nutanix Volumes uses IQN-based authorization to control access to volumes. The administrator must specify the IQN of the host that needs to access the volume when creating or editing the volume. If the host's IQN is not authorized, it will not be able to see the target in the MS iSCSI Initiator3. References: Nutanix Volumes Administration Guide3
NEW QUESTION # 70
What is the most efficient way of enabling users to restore their files without administrator intervention in multiple Files shares?
  • A. Add all FSVMs to a Consistency Group within a single asynchronous Protection Domain in PE.
  • B. Click Enable Self Service Restore in the Edit wizard for each share in Shares tab from Files Console.
  • C. Assign the same Category to all FSVMs and adding that Category to a single Protection Policy in PC.
  • D. Click Enable next to the name of the share in Manage Recovery Settings from Data Lens.
Nutanix Files allows users to restore their files from the snapshots taken by the protection policy. A protection policy is a set of rules that defines how often snapshots are taken, how long they are retained, and where they are replicated. A protection policy can be applied to one or more file shares. To enable users to restore their files without administrator intervention, the administrator must enable the Self Service Restore option for each share in the Files Console. This option adds a hidden folder named .snapshot in each share, which contains all the snapshots taken by the protection policy. Users can access this folder and browse the snapshots to find and restore their files. The administrator can also configure the permissions and quota for the .snapshot folder. Reference: Nutanix Files Administration Guide, page 75; Nutanix Files Self-Service Restore Guide
NEW QUESTION # 71
The NCP-US-6.5 practice test pdf contains the most updated and verified questions & answers, which cover all the exam topics and course outline completely. The NCP-US-6.5 vce dumps can simulate the actual test environment, which can help you to be more familiar about the NCP-US-6.5 Real Exam. Now, you can free download Nutanix NCP-US-6.5 updated demo and have a try. If you have any questions about NCP-US-6.5 pass-guaranteed dumps, contact us at any time.
Reasonable NCP-US-6.5 Exam Price: https://www.exam4tests.com/NCP-US-6.5-valid-braindumps.html
P.S. Free & New NCP-US-6.5 dumps are available on Google Drive shared by Exam4Tests: https://drive.google.com/open?id=1OnXDlc5-BjByik_hb8eYGB5rfbifSMkT
Posted at 2/7/2026 02:29:00        Only Author  2#
This article is truly exceptional, thank you for sharing it with us. Free access to Instant D-PSC-DY-23 discount materials for allgood luck!
Posted at 2/16/2026 03:46:56        Only Author  3#
It was a deep and thoughtful article. Thanks to the JS-Dev-101 latest exam vce free, I was able to earn a promotion and raise. Its now free to all. Wishing you all the best for your promotion!
