[General] Get Updated NSE4_FGT_AD-7.6 PDF Questions - All in itPass4sure
87
General Get Updated NSE4_FGT_AD-7.6 PDF Questions - All in itPass4sure
Posted at 1/10/2026 05:53:12      View150 | Replies2        Print      Only Author   [Copy Link] 1#
Your personal information on our NSE4_FGT_AD-7.6 exam braindumps such as your names, email address will be strictly protected by our system. Our workers will never randomly spread your information to other merchants for making money. In short, your purchasing of our NSE4_FGT_AD-7.6 Preparation quiz is totally safe and sound. Also, our website has strong back protection program to resist attacking from hackers. We will live up to your trust and keep advancing on our NSE4_FGT_AD-7.6 study materials.
Fortinet NSE4_FGT_AD-7.6 Exam Syllabus Topics:
  • VPN: This domain focuses on implementing meshed or partially redundant IPsec VPN topologies for secure connections.
  • Routing: This domain covers configuring static routes for packet forwarding and implementing SD-WAN to load balance traffic across multiple WAN links.
  • Firewall Policies and Authentication: This domain focuses on creating firewall policies, configuring SNAT and DNAT for address translation, implementing various authentication methods, and deploying FSSO for user identification.
  • Content Inspection: This domain addresses inspecting encrypted traffic using certificates, understanding inspection modes and web filtering, configuring application control, deploying antivirus scanning modes, and implementing IPS for threat protection.
Topic 5
  • Deployment and System Configuration: This domain covers initial FortiGate setup, logging configuration and troubleshooting, FGCP HA cluster configuration, resource and connectivity diagnostics, FortiGate cloud deployments (CNF and VM), and FortiSASE administration with user onboarding.
NSE4_FGT_AD-7.6 Pdf Demo Download | NSE4_FGT_AD-7.6 Test PreparationFree demos offered by itPass4sure gives users a chance to try the product before buying. Users can get an idea of the Fortinet NSE4_FGT_AD-7.6 exam dumps, helping them determine if it's a good fit for their needs. The demo provides access to a limited portion of the NSE4_FGT_AD-7.6 dumps material to give users a better understanding of the content. Overall, NSE4_FGT_AD-7.6 free demo is a valuable opportunity for users to assess the value of the itPass4sure study material before making a purchase. The Fortinet provides 1 year of free updates of real questions. This offer allows students to stay up-to-date with changes in the exams content.
Fortinet NSE 4 - FortiOS 7.6 Administrator Sample Questions (Q27-Q32):NEW QUESTION # 27
Which statement correctly describes NetAPI polling mode for the FSSO collector agent?
  • A. The collector agent must search Windows application event logs.
  • B. NetAPI polling can increase bandwidth usage in large networks.
  • C. The NetSessionEnum function is used to track user logouts.
  • D. The collector agent uses a Windows API to query DCs for user logins.
NetAPI: Polls temporary sessions created on the DC when a user logs on or logs off and calls the NetSessionEnum function on Windows. It's faster than the WinSec and WMI methods; however, it can miss some logon events if a DC is under heavy system load. This is because sessions can be quickly created and purged form RAM, before the agent has a chance to poll and notify FG.
NEW QUESTION # 28
An administrator wants to form an HA cluster using the FGCP protocol.
Which two requirements must the administrator ensure both members fulfill? (Choose two.)
  • A. They must have the same number of configured VDOMs.
  • B. They must have the heartbeat interfaces in the same subnet.
  • C. They must have the same hard drive configuration.
  • D. They must have the same HA group ID.
They must have the same HA Group ID and same Hard Drive Configuration.
NEW QUESTION # 29
Refer to the exhibit. Which two statements about the FortiGuard connection are true? (Choose two.)
  • A. The weight increases as the number of failed packets rises.
  • B. FortiGate identified the FortiGuard Server using DNS lookup.
  • C. FortiGate is using the default port for FortiGuard communication.
  • D. You can configure unreliable protocols to communicate with FortiGuard Server.
FortiGate identified the FortiGuard Server using DNS lookup The server is shown with a private IP (10.0.1.241), which indicates FortiGate resolved it via DNS or explicit override rather than using default FortiGuard anycast servers.
The weight value reflects server reliability. It decreases with good performance and increases as packet loss or failures rise, meaning higher weight indicates more failures.
NEW QUESTION # 30
Refer to the exhibits.
The exhibits show a diagram of a FortiGate device connected to the network, as well as the firewall policy and IP pool configuration on the FortiGate device.
Two PCs, PC1 and PC2, are connected behind FortiGate and can access the internet successfully. However, when the administrator adds a third PC to the network (PC3), the PC cannot connect to the internet.
Based on the information shown in the exhibit, which two configuration options can the administrator use to fix the connectivity issue for PC3? (Choose two.)
  • A. In the IP pool configuration, set endipto 192.2.0.12.
  • B. Configure another firewall policy that matches only the address of PC3 as source, and then place the policy on top of the list.
  • C. In the IP pool configuration, set typeto overload.
  • D. In the firewall policy configuration, add 10.0.1.3as an address object in the source field.
With IP pool type set to One-to-One, only as many internal hosts as there are public IPs in the pool (192.2.0.10-192.2.0.11) can use NAT. Changing the type to overload allows all internal hosts (including PC3) to share the available public IPs, so PC3 can reach the internet.
Alternatively, keeping One-to-One but extending the pool to 192.2.0.10-192.2.0.12 adds another public IP, allowing a third internal host (PC3) to be mapped and gain internet access.
NEW QUESTION # 31
Refer to the exhibit, which shows a firewall policy to enable active authentication.
When attempting to access an external website using an active authentication method, the user is not presented with a login prompt.
What is the most likely reason for this situation?
  • A. No matching user account exists for this user.
  • B. The Service DNS is required in the firewall policy.
  • C. The Remote-users group must be set up correctly in the FSSO configuration.
  • D. The Remote-users group is not added to the Destination.
DNS is usually used by HTTP so that people can use domain names for websites, instead of their IP address. DNS is allowed because it is a base protocol and will most likely be required to initially see proper authentication protocol traffic... However, the DNS service must still be defined in the policy as allowed, in order for it to pass.
NEW QUESTION # 32
When prepare a exam, we may face the situation like this: there are so many books in front of me, which one should I choose for preparing for the exam? If you are ready to attentd the NSE4_FGT_AD-7.6 exam, then just choose us, our product is the one you can trust, with the experienced professionals to expect and update, the quality of the product is quite high. Furthermore, our company respect the privacy of the customers, with our product, there is no need for you to worry about the probleml. Except for this, if you buy product for the NSE4_FGT_AD-7.6 Exam , you will get the free update for one year, and money back gurantee within 60 days after you buy it, so don't hesitate, just do it.
NSE4_FGT_AD-7.6 Pdf Demo Download: https://www.itpass4sure.com/NSE4_FGT_AD-7.6-practice-exam.html
Posted at 1/15/2026 11:48:52        Only Author  2#
This article is a gem, thank you for sharing it with us! Free access to Valid study guide MS-900 books content is provided, hoping it will benefit your studies.
Posted at 1/29/2026 12:34:44        Only Author  3#
This is an inspiring article, and Im grateful for your share! Reliable DP-700 exam collection file exam materials are the secret to promotion and salary increasesavailable for free!
