[General] Pass Guaranteed High-quality Splunk - SPLK-3002 - Instant Splunk IT Service Inte
120
【General】 Pass Guaranteed High-quality Splunk - SPLK-3002 - Instant Splunk IT Service Inte
Posted at 1/10/2026 05:55:51      View:193 | Replies:6        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Splunk SPLK-3002 dumps are available on Google Drive shared by Itexamguide: https://drive.google.com/open?id=1O7ZzH6-mjF68V2Z1RAs70ZnPEsSvKiXw
Practice tests (desktop and web-based) are simulations of actual Splunk SPLK-3002 PDF Questions designed to help individuals prepare and improve their performance for the Splunk SPLK-3002 certification test. Itexamguide facilitates the customers with customizable practice tests which means they can adjust the number of questions and set the time of the test according to themselves which will help them in order to feel the real-based exam pressure and control it.
The best way to study for a Splunk SPLK-3002 Exam is by getting as many practice quizzes as possibleThe SPLK-3002 Exam is not a difficult certification by any means and can be attained with the help of practice exams. However, if you know nothing about Splunk or Splunk IT Service Intelligence, then taking this exam will be quite challenging for you. The material that is covered in the SPLK-3002 Exam is not difficult to understand as such, it's just that there are some concepts that need to be fully understood in order to pass the exam. There are many ways to prepare for a certification like the SPLK-3002 Exam. You can go through books, online courses and study guides. But most effective way of studying is through SPLK-3002 Dumps. The best way to prepare for a certification exam is by taking as many practice exams as possible.
Valid Splunk SPLK-3002 Test Duration | SPLK-3002 Certification QuestionsAvailability in different formats is one of the advantages valued by Splunk IT Service Intelligence Certified Admin test candidates. It allows them to choose the format of Splunk SPLK-3002 Dumps they want. They are not forced to buy one format or the other to prepare for the Splunk SPLK-3002 Exam. Itexamguide designed Splunk IT Service Intelligence Certified Admin exam preparation material in Splunk SPLK-3002 PDF and practice test (online and offline). If you prefer PDF Dumps notes or practicing on the Splunk SPLK-3002 practice test software, use either.
The SPLK-3002 Exam is ideal for individuals who have experience in IT service management and want to enhance their skills in using Splunk ITSI. Splunk IT Service Intelligence Certified Admin certification helps IT professionals demonstrate their expertise in using ITSI to monitor, analyze, and troubleshoot IT services. It covers topics such as configuring ITSI entities, creating service level agreements (SLAs), setting up Glass Tables, and using machine learning to detect anomalies in IT services.
Splunk SPLK-3002 exam is a vendor-neutral certification that is recognized globally. Splunk IT Service Intelligence Certified Admin certification provides IT professionals with a competitive edge in the job market and demonstrates their commitment to keeping up with the latest technologies and trends in IT operations and analytics. Splunk IT Service Intelligence Certified Admin certification is also a valuable credential for IT professionals who work in organizations that rely on Splunk IT Service Intelligence to monitor and manage their IT infrastructure.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q14-Q19):NEW QUESTION # 14
Which of the following are deployment recommendations for ITSI? (Choose all that apply.)
  • A. Deployments should use fastest possible disk arrays for indexers.
  • B. Deployments may increase the number of required indexers based on the number of KPI searches.
  • C. Deployments often require an increase of hardware resources above base Splunk requirements.
  • D. Deployments require a dedicated ITSI search head.
Answer: B,C,D
You might need to increase the hardware specifications of your own Enterprise Security deployment above the minimum hardware requirements depending on your environment.
Install Splunk Enterprise Security on a dedicated search head or search head cluster.
The Splunk platform uses indexers to scale horizontally. The number of indexers required in an Enterprise Security deployment varies based on the data volume, data type, retention requirements, search type, and search concurrency.
A, B, and C are correct answers because ITSI deployments often require more hardware resources than base Splunk requirements due to the high volume of data ingestion and processing. ITSI deployments also require a dedicated search head that runs the ITSI app and handles all ITSI-related searches and dashboards. ITSI deployments may also increase the number of required indexers based on the number and frequency of KPI searches, which can generate a large amount of summary data. Reference: ITSI deployment overview, ITSI deployment planning
NEW QUESTION # 15
What is the range for a normal Service Health score category?
  • A. 80-100
  • B. 60-80
  • C. 40-60
  • D. 20-40
In Splunk IT Service Intelligence (ITSI), the Service Health Score is a metric that provides a quantifiable measure of the overall health and performance of a service. The score ranges from 0 to 100, with higher scores indicating better health. The range for a normal Service Health score category is typically from 80 to 100. Scores within this range suggest that the service is performing well, with no significant issues affecting its health. This categorization helps IT and business stakeholders quickly assess the operational status of their services, enabling them to focus on services that may require attention or intervention due to lower health scores.
NEW QUESTION # 16
In distributed search, which components need to be installed on instances other than the search head?
  • A. SA-IndexCreation on idexers; SA-ITSI-Licensechecker and SA-UserAccess on the license master.
  • B. SA-IndexCreation and SA-ITOA on indexers; SA-ITSI-Licensechecker and SA-UserAccess on the license master.
  • C. SA-ITSI-Licensechecker on indexers.
  • D. SA-IndexCreation and SA-ITSI-Licensechecker on indexers.
SA-IndexCreation is required on all indexers. For non-clustered, distributed environments, copy SA-IndexCreation to $SPLUNK_HOME/etc/apps/ on individual indexers.
In distributed search, the components that need to be installed on instances other than the search head are SA-IndexCreation and SA-ITSI-Licensechecker on indexers. SA-IndexCreation is an add-on that creates the indexes required by ITSI, such as itsi_summary and itsi_tracked_alerts. SA-ITSI-Licensechecker is an add-on that monitors the license usage of ITSI and generates alerts when the license limit is exceeded or about to expire. These components need to be installed on indexers because they handle the data ingestion and storage functions for ITSI. The other components, such as ITSI app and SA-ITOA, need to be installed on the search head(s) because they handle the search management and presentation functions for ITSI. Reference: Install IT Service Intelligence in a distributed environment
NEW QUESTION # 17
Which scenario would benefit most by implementing ITSI?
  • A. Monitoring of system process statuses
  • B. Monitoring of retail sales metrics.
  • C. Monitoring of business services functionality.
  • D. Monitoring of system hardware.
Splunk IT Service Intelligence (ITSI) is a monitoring and analytics solution that uses artificial intelligence and machine learning to provide insights into the health and performance of IT services. ITSI lets you create services that represent the critical components of your IT infrastructure, such as applications, databases, servers, networks, and so on. You can then monitor the status and performance of these services using key performance indicators (KPIs), which are metrics that measure aspects of service health, such as availability, latency, error rate, and so on. ITSI also provides tools for visualizing, investigating, and alerting on service issues, such as service analyzers, glass tables, deep dives, episode review, and so on. The scenario that would benefit most by implementing ITSI is monitoring of business service functionality, because ITSI enables you to measure and improve the quality and reliability of your IT services and align them with your business objectives. Reference: What is Splunk IT Service Intelligence?
NEW QUESTION # 18
There are two Smart Mode configuration settings that control how fields affect grouping. Which of these is correct?
  • A. Text similarity and category deviation.
  • B. Text deviation and category deviation.
  • C. Text deviation and category similarity.
  • D. Text similarity and category similarity.
In the context of Smart Mode configuration within Splunk IT Service Intelligence (ITSI), the two settings that control how fields affect grouping are "Text similarity" and "Category similarity." Smart Mode is a feature used in event grouping that leverages machine learning to automatically group related events. "Text similarity" refers to how closely the textual content of event fields must match for those events to be grouped together, taking into account commonalities in strings or narratives within the event data. "Category similarity," on the other hand, relates to the similarity in the categorical attributes of events, such as event types or source types, which helps in clustering events that are similar in nature or origin. Both of these settings are crucial in determining how events are grouped in ITSI, influencing the granularity and relevance of the event groupings based on textual and categorical similarities.
NEW QUESTION # 19
Valid SPLK-3002 Test Duration: https://www.itexamguide.com/SPLK-3002_braindumps.html
P.S. Free & New SPLK-3002 dumps are available on Google Drive shared by Itexamguide: https://drive.google.com/open?id=1O7ZzH6-mjF68V2Z1RAs70ZnPEsSvKiXw
Posted at 1/10/2026 20:25:15        Only Author  2#
Truly an extraordinary article, I’m thankful for your sharing. Get the CTAL-TM_001 latest test camp file exam materials for free—the key to promotions and higher pay!
Posted at 1/14/2026 14:39:43        Only Author  3#
I’m really thankful for your article, it left a strong impression. The CCCS-203b study reference questions are the key to success—get them for free and unlock your promotion!
Posted at 1/14/2026 16:11:01        Only Author  4#
This content is worth every like. Sharing the Valid C_P2W43_2023 exam notes test questions with you for free—promotions and salary boosts are within reach!
Posted at 1/21/2026 08:45:27        Only Author  5#
I’m truly amazed by the depth of your article, thank you for sharing! Sharing the free Valid C1000-196 exam dumps.zip resources with everyone. Good luck!
Posted at 2/8/2026 20:32:39        Only Author  6#
I’m really moved by this article, thanks for sharing! I was promoted and received a raise with the help of the OGEA-101 valid braindumps book. Now it’s available for free to all. Best wishes for your promotions!
Posted at 3/5/2026 12:11:07        Only Author  7#
By reading this article, I’ve developed a new understanding of both my work and life. Best wishes for your exam! Here’s the free MS-700 test prep material.
