Reliable NCM-MCI-6.10 Test Vce, NCM-MCI-6.10 Certification
Posted at 1/10/2026 06:15:09
View199
Replies4
The Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) certification has become a basic requirement to advance rapidly in the information technology sector. Since Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) actual dumps are vital to prepare quickly for the examination. Therefore, you will need them if you desire to ace the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) exam in a short time.
One of the advantages of taking the Prep4pass Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) practice exam (desktop and web-based) is that it helps applicants to focus on their weak areas. It also helps applicants to track their progress and make improvements. Nutanix NCM-MCI-6.10 Practice Exams are particularly helpful in identifying areas where one needs more practice.
Nutanix NCM-MCI-6.10 Certification & NCM-MCI-6.10 Reliable Learning MaterialsJust the same as the free demo, we have provided three kinds of versions of our NCM-MCI-6.10 preparation exam, among which the PDF version is the most popular one. It is quite clear that the PDF version is convenient for our customers to read and print the contents in our NCM-MCI-6.10 study guide. After printing, you not only can bring the NCM-MCI-6.10 Study Materials with you wherever you go, but also can make notes on the paper at your liberty, which may help you to understand the contents of our NCM-MCI-6.10 learning materials. Do not wait and hesitate any longer, your time is precious!
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q20-Q25):NEW QUESTION # 20
Task 3
An administrator needs to create a report named VMs_Power_State that lists the VMs in the cluster and their basic details including the power state for the last month.
No other entities should be included in the report.
The report should run monthly and should send an email to admin@syberdyne.net when it runs.
Generate an instance of the report named VMs_Power_State as a CSV and save the zip file as DesktopFilesVMs_Power_state.zip Note: Make sure the report and zip file are named correctly. The SMTP server will not be configured.
See the Explanation for step by step solution.
To create a report named VMs_Power_State that lists the VMs in the cluster and their basic details including the power state for the last month, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter VMs_Power_State as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, Cluster Name, vCPUs, Memory, Power State. Click Next.
Under the Time Period option, select Last Month. Click Next.
Under the Report Settings option, select Monthly from the Schedule drop-down menu. Enter admin@syberdyne.net as the Email Recipient. Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
To generate an instance of the report named VMs_Power_State as a CSV and save the zip file as DesktopFilesVMs_Power_state.zip, you can follow these steps:
Log in to Prism Central and click on Operations on the left menu.
Select Reports from the drop-down menu and find the VMs_Power_State report from the list. Click on Run Now.
Wait for the report to be generated and click on Download Report. Save the file as DesktopFilesVMs_Power_state.zip.
1.Open the Report section on Prism Central (Operations > Reports)
2.Click on the New Report button to start the creation of your custom report
3.Under the Custom Views section, select Data Table
4.Provide a title to your custom report, as well as a description if required.
5.Under the Entity Type option, select VM
6.This report can include all as well as a selection of the VMs
7.Click on the Custom Columns option and add the below variables:
a.Name - Name of the listed Virtual Machine
b.vCPUs - A combination of the vCores and vCPU's assigned to the Virtual Machine c.Memory - Amount of memory assigned to the Virtual Machine d.Disk Capacity - The total amount of assigned virtual disk capacity e.Disk Usage - The total used virtual disk capacity f.Snapshot Usage - The total amount of capacity used by snapshots (Excluding Protection Domain snapshots)
8.Under the Aggregation option for Memory and Disk Usage accept the default Average option
9.Click on the Add button to add this custom selection to your report
10.Next click on the Save and Run Now button on the bottom right of the screen
11.Provide the relevant details on this screen for your custom report:
12.You can leave the Time Period For Report variable at the default of Last 24 Hours
13.Specify a report output of preference (PDF or CSV) and if required Additional Recipients for this report to be mailed to. The report can also simply be downloaded after this creation and initial run if required
14.Below is an example of this report in a CSV format:
NEW QUESTION # 21
Following new security guidelines, it must be ensured that the storage of critical virtual machines will be encrypted in future.
The assignment is to be made by a new category called VM-Storage with a value of softwareencrypted in Prism Central. Make sure a second value of SEDencrypted is also created for future use.
Create the above-mentioned category and perform further configurations in Prism Central for VM-based storage encryption.
Assign the name Encrypted-Storage to the newly created policy.
See the Explanation below for detailed answer.
Here is the step-by-step solution to create the category and the corresponding storage encryption policy within Prism Central.
1. Create the Category
First, you must create the category and the two values requested.
* In Prism Central, navigate to Administration > Categories.
* Click New Category.
* In the Name field, enter VM-Storage.
* In the Add a Value field, type softwareencrypted and click the Add (plus) button.
* In the Add a Value field again, type SEDencrypted and click the Add (plus) button.
* Click Save.
2. Create the Encryption Policy
Next, you will create the security policy that uses the new category.
* In Prism Central, navigate to Security > Data-at-Rest Encryption.
* Click the + Create Security Policy button.
* In the Policy Name field, enter Encrypted-Storage.
* Ensure the Encryption Type is set to Software-based.
* For Target VMs, select the radio button for VMs matching a category.
* In the Select Category dropdown, choose the VM-Storage category you just created.
* In the Select Value dropdown, choose softwareencrypted.
* Click Save.
This policy will now automatically apply software-based encryption to any new or existing VMs that are assigned the VM-Storage: softwareencrypted category.
NEW QUESTION # 22
Task 15
Depending on the order you perform the exam items, the access information and credentials could change.
Please refer to the other item performed on Cluster B if you have problems accessing the cluster.
The infosec team has requested that audit logs for API Requests and replication capabilities be enabled for all clusters for the top 4 severity levels and pushed to their syslog system using highest reliability possible. They have requested no other logs to be included.
Syslog configuration:
Syslog Name: Corp_syslog
Syslop IP: 34.69.43.123
Port: 514
Ensure the cluster is configured to meet these requirements.
To configure the cluster to meet the requirements of the infosec team, you need to do the following steps:
Log in to Prism Central and go to Network > Syslog Servers > Configure Syslog Server. Enter Corp_syslog as the Server Name, 34.69.43.123 as the IP Address, and 514 as the Port. Select TCP as the Transport Protocol and enable RELP (Reliable Logging Protocol). This will create a syslog server with the highest reliability possible.
Click Edit against Data Sources and select Cluster B as the cluster. Select API Requests and Replication as the data sources and set the log level to CRITICAL for both of them. This will enable audit logs for API requests and replication capabilities for the top 4 severity levels (EMERGENCY, ALERT, CRITICAL, and ERROR) and push them to the syslog server. Click Save.
Repeat step 2 for any other clusters that you want to configure with the same requirements.
To configure the Nutanix clusters to enable audit logs for API Requests and replication capabilities, and push them to the syslog system with the highest reliability possible, you can follow these steps:
Log in to the Nutanix Prism web console using your administrator credentials.
Navigate to the "Settings" section or the configuration settings interface within Prism.
Locate the "Syslog Configuration" or "Logging" option and click on it.
Configure the syslog settings as follows:
Syslog Name: Enter "Corp_syslog" as the name for the syslog configuration.
Syslog IP: Set the IP address to "34.69.43.123", which is the IP address of the syslog system.
Port: Set the port to "514", which is the default port for syslog.
Enable the option for highest reliability or persistent logging, if available. This ensures that logs are sent reliably and not lost in case of network interruptions.
Save the syslog configuration.
Enable Audit Logs for API Requests:
In the Nutanix Prism web console, navigate to the "Cluster" section or the cluster management interface.
Select the desired cluster where you want to enable audit logs.
Locate the "Audit Configuration" or "Security Configuration" option and click on it.
Look for the settings related to audit logs and API requests. Enable the audit logging feature and select the top
4 severity levels to be logged.
Save the audit configuration.
Enable Audit Logs for Replication Capabilities:
Look for the settings related to audit logs and replication capabilities. Enable the audit logging feature and select the top 4 severity levels to be logged.
After completing these steps, the Nutanix clusters will be configured to enable audit logs for API Requests and replication capabilities. The logs will be sent to the specified syslog system with the highest reliability possible.
ncli
<ncli> rsyslog-config set-status enable=false
<ncli> rsyslog-config add-server name=Corp_Syslog ip-address=34.69.43.123 port=514 network- protocol=tdp relp-enabled=false
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=APLOS level=INFO
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=CEREBRO level=INFO
<ncli> rsyslog-config set-status enable=true
https://portal.nutanix.com/page/ ... =kA00e0000009CEECA2
NEW QUESTION # 23
Use Prism Element for this question.
The Application team has a 3 tier application (App Server, Web Server, and Database Server) that is mission critical and requires as close to 0 RPO and RTO as possible with their current license level.
The organization has 2 clusters, with one cluster (Cluster 1) being production and the other cluster (Cluster 2) being remote/DR. Cluster 2 should be able to fail back to Cluster 1.
The connectivity between the two sites is >5ms and replication traffic should not use more than 10Mbps of bandwidth. The Application team requests a plan that includes the ability to go back 2 days locally, and 2 days remotely.
The team also requests that all 3 VMs be treated as a single group and backed up collectively in a snapshot.
The three VMs are:
* Web-Prod
* App-Prod
* DB-Prod
Use Task3 as part of the name for any objects created for this task.
Note: VMs do NOT need to be powered on. You will need to use the 172.30.0.x IP addresses when configuring DR.
Here is the step-by-step solution to configure Disaster Recovery from the Cluster 1 Prism Element interface.
1. Add Cluster 2 as a Remote Site
First, you must register Cluster 2 as a DR target for Cluster 1.
* From the Cluster 1 Prism Element dashboard, navigate to Data Protection from the main dropdown menu.
* Click the Remote Site tab.
* Click the + Remote Site button and select Physical Cluster.
* In the "Name" field, enter Cluster2_DR_Task3.
* In the "Address" field, enter the 172.30.0.x Virtual IP address of Cluster 2.
* Click Save. The clusters will exchange credentials and connect.
2. Throttle Replication Bandwidth
Next, apply the 10 Mbps bandwidth limit for traffic going to Cluster 2.
* On the same Remote Site tab, select the newly created Cluster2_DR_Task3.
* Click the Update button.
* In the dialog, set the Bandwidth Limit to 10 Mbps.
* Click Save.
3. Create the Protection Domain
A Protection Domain (PD) is the top-level object that will manage the VMs and replication schedules.
* In the Data Protection dashboard, click the Table tab.
* Click the + Protection Domain button and select Async DR.
* For the Name, enter App_PD_Task3.
* Click Create.
4. Protect VMs in a Consistency Group
Now you will add the three application VMs to the new Protection Domain as a single Consistency Group (CG).
* You will be taken to the dashboard for the new App_PD_Task3. In the Entities panel, click the Protect Entities button.
* In the " rotect Entities" dialog, search for and select the three VMs:
* Web-Prod
* App-Prod
* DB-Prod
* Click Next.
* Select Create new consistency group and name it App_CG_Task3.
* Click Protect.
5. Create the Replication Schedule
Finally, configure the schedule to meet the RPO and retention requirements.
* In the App_PD_Task3 dashboard, click the Schedules tab.
* Click the + New Schedule button.
* Remote Site: Select Cluster2_DR_Task3.
* RPO (Repeat every): Select NearSync. Set the RPO to 1 minute.
* Note: This is the lowest possible RPO for an Async (>5ms latency) connection, fulfilling the "as close to 0" requirement.
* Local Retention: Set to 2 Days.
* Remote Retention: Set to 2 Days.
* Ensure the "Store snapshots for 2-way replication" checkbox is enabled to allow failback from Cluster 2.
* Click Create Schedule.
NEW QUESTION # 24
Create a VM template on Cluster 1 named Small Template that matches the small VM Configuration in NVD-2031 (see the FilesDocumentation 6.10 folder) however, you will use default storage container.
Configure SMTP Alerting and NCC reports per NVD-2031 for Cluster 1.
Settings:
* SMTP: Use Cluster 2 IP address
* Cluster email: cluster1@ACME.org
* Alert emails: primaryalerts@ACME.org, secondaryalerts@ACME.org
Here is the step-by-step solution to complete both tasks on Cluster 1.
This solution requires you to first find the IP of Cluster 2 (for the SMTP server) and then perform all configurations within the Prism Element interface for Cluster 1.
Prerequisite: Find Cluster 2 IP
* In Prism Central, navigate to Hardware > Clusters.
* Find Cluster 2 in the list and note its IP Address. You will use this in the steps below.
Task 1: Create the VM Template
* Log in to the Prism Element (PE) interface for Cluster 1. (From PC, go to Hardware > Clusters > click the name "Cluster 1").
* Navigate to the VM view from the main dashboard.
* Click the + Create VM button.
* Fill in the VM details based on the NVD-2031 "Small VM" configuration (e.g., 2 vCPUs, 1 Core per vCPU, 4 GB RAM).
* Name: Small Template
* Compute Details:
* vCPUs: 2
* Number of Cores per vCPU: 1
* Memory: 4 GB
* Scroll down to Storage and click + Add New Disk.
* Operation: Select Clone from Image Service.
* Image: Select any available guest OS image (e.g., a Windows or CentOS image).
* Storage Container: Ensure the default container is selected (as required by the task).
* Click Add.
* Scroll down to Network Adapters (NIC) and click + Add NIC.
* Select any available VLAN/Subnet (e.g., Primary).
* Click Add.
* Click Save. The VM will be created (and remain powered off).
* Find the new Small Template VM in the list. Select its checkbox.
* Click the Actions dropdown and select Convert to Template.
* Confirm the action by clicking OK.
Task 2: Configure SMTP and NCC Reports
* While still in the Cluster 1 Prism Element interface, click the gear icon (Settings) in the top-right corner.
* Select SMTP Server from the left-hand menu.
* Click the Configure button.
* In the "Server Settings" tab, fill in the following:
* Server Address: Enter the Cluster 2 IP Address (which you found in the prerequisite step).
* Port: 25 (leave as default).
* From Email Address: cluster1@ACME.org
* Click Next.
* In the "Email Recipients" tab, click + Add Email Recipient.
* Address: primaryalerts@ACME.org
* Ensure all severities (Critical, Warning, Info) are checked.
* Click Save.
* Click + Add Email Recipient again.
* Address: secondaryalerts@ACME.org
* Ensure all severities are checked.
* Click Save.
* Click Done. A test email will be sent.
* In the main Settings menu, select Alerts and Notifications.
* Scroll to the NCC Health Checks section.
* Check the box labeled Email Nutanix Cluster Check reports to recipients. (This will use the SMTP settings and recipients you just configured).
* Click Save.
NEW QUESTION # 25
There are multiple choices on the versions of our NCM-MCI-6.10 learning guide to select according to our interests and habits since we have three different versions of our NCM-MCI-6.10 exam questions: the PDF, the Software and the APP online. The Software and APP online versions of our NCM-MCI-6.10 preparation materials can be practiced on computers or phones. They are new developed for the reason that electronics products have been widely applied to our life and work style. The PDF version of our NCM-MCI-6.10 Actual Exam supports printing, and you can practice with papers and take notes on it.
NCM-MCI-6.10 Certification: https://www.prep4pass.com/NCM-MCI-6.10_exam-braindumps.html
Nutanix Reliable NCM-MCI-6.10 Test Vce If you can get the certification you will get outstanding advantages, good promotion, nice salary and better life, Prep4pass offers up-to-date Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) practice material consisting of three formats that will prove to be vital for you, What you need to do first is to choose a right NCM-MCI-6.10 exam material, which will save your time and money in the preparation of the NCM-MCI-6.10 exam, Wrong topic tend to be complex and no regularity, and the NCM-MCI-6.10 torrent prep can help the users to form a good logical structure of the wrong question, this database to each user in the simulation in the practice of all kinds of wrong topic all induction and collation, and the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) study question then to the next step in-depth analysis of the wrong topic, allowing users in which exist in the knowledge module, tell users of our NCM-MCI-6.10 exam question how to make up for their own knowledge loophole, summarizes the method to deal with such questions for, to prevent such mistakes from happening again.
With our NCM-MCI-6.10 exam preparation, you can practice time and again till you think you have got the knowledge, Are there previous versions of a rule, If you can get the certification NCM-MCI-6.10 you will get outstanding advantages, good promotion, nice salary and better life.
NCM-MCI-6.10 - Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) CReliable Reliable Test VcePrep4pass offers up-to-date Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) practice material consisting of three formats that will prove to be vital for you, What you need to do first is to choose a right NCM-MCI-6.10 exam material, which will save your time and money in the preparation of the NCM-MCI-6.10 exam.
All contents of NCM-MCI-6.10 practice materials contain what need to be mastered.
- 100% Pass Quiz 2026 NCM-MCI-6.10 - Reliable Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Test Vce 🥟 Search for ▷ NCM-MCI-6.10 ◁ and download it for free immediately on ✔ [url]www.troytecdumps.com ️✔️ 🕜NCM-MCI-6.10 Interactive EBook[/url]
- Exam NCM-MCI-6.10 Vce 🚨 NCM-MCI-6.10 Latest Dumps Sheet 👾 NCM-MCI-6.10 Pdf Format 🦸 Open { [url]www.pdfvce.com } enter ⮆ NCM-MCI-6.10 ⮄ and obtain a free download 🦲NCM-MCI-6.10 Latest Dumps Sheet[/url]
- NCM-MCI-6.10 Actual Test - NCM-MCI-6.10 Test Questions - NCM-MCI-6.10 Exam Torrent 🔒 Immediately open ➠ [url]www.practicevce.com 🠰 and search for NCM-MCI-6.10 to obtain a free download 👍Exam NCM-MCI-6.10 Course[/url]
- Nutanix's Exam Questions for NCM-MCI-6.10 Help You Achieve Success in Your First Attempt ✒ Easily obtain ▷ NCM-MCI-6.10 ◁ for free download through ➥ [url]www.pdfvce.com 🡄 💛NCM-MCI-6.10 Pdf Format[/url]
- Rely on Real Nutanix NCM-MCI-6.10 Questions For Success 😬 Download NCM-MCI-6.10 for free by simply entering ➽ [url]www.troytecdumps.com 🢪 website ⬅Reliable NCM-MCI-6.10 Exam Cram[/url]
- High Pass-Rate Reliable NCM-MCI-6.10 Test Vce Supply you Effective Certification for NCM-MCI-6.10: Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) to Study easily 🦇 Search for ➠ NCM-MCI-6.10 🠰 and download it for free on [url]www.pdfvce.com website 🔀NCM-MCI-6.10 Interactive EBook[/url]
- Get Help From Real Nutanix NCM-MCI-6.10 Exam Questions in Preparation 🧰 ⮆ [url]www.pdfdumps.com ⮄ is best website to obtain ➽ NCM-MCI-6.10 🢪 for free download 📮Reliable NCM-MCI-6.10 Exam Cram[/url]
- NCM-MCI-6.10 Exam Preparation - NCM-MCI-6.10 Study Guide - NCM-MCI-6.10 Best Questions ❇ Enter ➤ [url]www.pdfvce.com ⮘ and search for NCM-MCI-6.10 to download for free 🎫
ass NCM-MCI-6.10 Guaranteed[/url] - Nutanix NCM-MCI-6.10 PDF Dumps - The Fastest Way To Prepare For Exam 🎲 Enter ➤ [url]www.practicevce.com ⮘ and search for [ NCM-MCI-6.10 ] to download for free 🔒NCM-MCI-6.10 Latest Test Testking[/url]
- Valid Dumps NCM-MCI-6.10 Book 🔵 Braindumps NCM-MCI-6.10 Pdf 🚆 Pass NCM-MCI-6.10 Guaranteed 🧇 Search for NCM-MCI-6.10 and download it for free immediately on [url]www.pdfvce.com 🖌NCM-MCI-6.10 Download[/url]
- Exam NCM-MCI-6.10 Vce 🦹 NCM-MCI-6.10 Dumps Questions 🚰 Reliable NCM-MCI-6.10 Test Camp 🍯 Search on ➠ [url]www.exam4labs.com 🠰 for ▛ NCM-MCI-6.10 ▟ to obtain exam materials for free download 😒Reliable NCM-MCI-6.10 Test Voucher[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mpgimer.edu.in, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
