[General] Useful Juniper JN0-481 Reliable Test Preparation - JN0-481 Free Download
93
【General】 Useful Juniper JN0-481 Reliable Test Preparation - JN0-481 Free Download
Posted at 1/10/2026 06:58:12      View:128 | Replies:1        Print      Only Author   [Copy Link] 1#
JN0-481 exam certification is considered as a standard in measuring your professional skills in your industry. Besides, those possessing the Juniper JN0-481 certification are more likely to receive higher salaries. So it is very necessary to get JN0-481 certification. Here, Dumpcollection JN0-481 free pdf download can give you some reference. First, you should have preview about the content of JN0-481 real test. Juniper JN0-481 contains the comprehensive contents with explanations where is available. With the assist of JN0-481 training material, you will get success.
The purpose of our product is to let the clients master the JN0-481 quiz torrent and not for other illegal purposes. Our system is well designed and any person or any organization has no access to the information of the clients. So please believe that we not only provide the best JN0-481 test prep but also provide the best privacy protection. Take it easy. If you really intend to pass the JN0-481 Exam, our software will provide you the fast and convenient learning and you will get the best study materials and get a very good preparation for the exam. The content of the JN0-481 guide torrent is easy to be mastered and has simplified the important information.
Excellent JN0-481 Reliable Test Preparation - Trustable Source of JN0-481 ExamAs a responsible company with great reputation among the market, we trained our staff and employees with strict beliefs to help you with any problems about our JN0-481 Learning materials 24/7. Even you have finished buying activity with us, we still be around you with considerate services on the JN0-481 Exam Questions. And we will update our JN0-481 training guide from time to time, once we update our JN0-481 study guide, we will auto send it to our customers. And you can enjoy our updates of JN0-481 learning prep for one year after your payment.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q44-Q49):NEW QUESTION # 44
Referring to the exhibit, how many broadcast domains will an Ethernet frame pass through when traversing the IP fabric from Server A to Server B?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Referring to the exhibit, the image shows a simplified diagram of an IP fabric network connecting two servers, labeled as Server A and Server B. The IP fabric is a network architecture that uses a Clos topology to provide high bandwidth, low latency, and scalability for data center networks.
The IP fabric consists of spine and leaf devices that use BGP as the routing protocol and VXLAN as the overlay technology.
A broadcast domain is a logical portion of a network where any device can directly transmit broadcast frames to other devices at the data link layer (OSI Layer 2). A broadcast frame is a frame that has a destination MAC address of all ones (FF:FF:FF:FF:FF:FF), which means that it is intended for all devices in the same broadcast domain. A broadcast domain is usually bounded by a router, which does not forward broadcast frames to other networks.
In the exhibit, there are two broadcast domains that an Ethernet frame will pass through when traversing the IP fabric from Server A to Server B. The first broadcast domain is the one that contains Server A and the leaf device that it is connected to. The second broadcast domain is the one that contains Server B and the leaf device that it is connected to. The IP fabric itself is not a broadcast domain, because it uses IP routing and VXLAN encapsulation to transport the Ethernet frames over the Layer 3 network.
NEW QUESTION # 45
What are two formats that the cabling map can be exported as? (Choose two.)
  • A. JSON
  • B. CSV
  • C. HTML
  • D. XML
NEW QUESTION # 46
In Juniper Apstra. which three modes are available for devices? (Choose three.)
  • A. Ready
  • B. Deploy
  • C. Drain
  • D. Stopped
  • E. Active
Answer: A,B,C
Juniper Apstra supports three deploy modes for devices: Deploy, Drain, and Ready. These modes determine the configuration and state of the devices in the data center fabric.
Deploy: This mode applies the full Apstra-rendered configuration to the device, according to the Apstra Reference Design. The device state becomes IS-ACTIVE and the device is ready to carry traffic in the fabric.
Drain: This mode adds a "drain" configuration to the device, which prevents any new traffic from entering the device. The device state becomes IS-READY and the device is prepared for maintenance or decommissioning.
Ready: This mode removes the Apstra-rendered configuration from the device, leaving only the basic configuration such as device hostname, interface descriptions, and port speed/breakout.
The device state becomes IS-READY and the device is not part of the fabric.
NEW QUESTION # 47
You connect two single-homed servers using Juniper Apstra as shown in the exhibit. You are using the ERB design blueprint with two virtual networks in a common routing zone. In this scenario, which two types of VXLAN tunnels will be automatically created by the EVPN control plane? (Choose two.)
  • A. EVPN signaled route Type-2 VXLAN tunnels
  • B. EVPN signaled route Type-8 VXLAN tunnels
  • C. EVPN signaled route Type-6 VXLAN tunnels
  • D. EVPN signaled route Type-3 VXLAN tunnels
EVPN route Type-3 is used to advertise the IP address of the VTEP and the VNIs that it supports.
This allows the VTEPs to discover each other and form VXLAN tunnels for the VNIs that they have in common. EVPN route Type-2 is used to advertise the MAC and IP addresses of the hosts connected to the VTEPs. This allows the VTEPs to learn the MAC-to-IP bindings and the MAC-to- VTEP mappings for the hosts in the same VNI. Therefore, these two types of VXLAN tunnels will be automatically created by the EVPN control plane when using Juniper Apstra with the ERB design blueprint and two virtual networks in a common routing zone.
NEW QUESTION # 48
Which statement about Juniper Apstra role-based access control is correct?
  • A. The user role can create roles.
  • B. The administrator role is the only predefined role.
  • C. The viewer role is predefined and can be deleted.
  • D. The administrator role can see all permissions.
Juniper Apstra role-based access control (RBAC) is a feature that allows you to specify access permissions for different users based on their roles. RBAC servers are remote network servers that authenticate and authorize network access based on roles assigned to individual users within an enterprise. Juniper Apstra has four predefined user roles: administrator, device_ztp, user, and viewer. The administrator role is the most powerful role, and it can see all permissions and perform all actions in the Apstra software application. The administrator role can also create, clone, edit, and delete user roles, except for the four predefined user roles, which cannot be modified. Therefore, the statement that the administrator role can see all permissions is correct.
NEW QUESTION # 49
As we all know, passing an exam is not an easy thing for many candidates. They need time and energy to practice. JN0-481 study materials will save your time with the skilled professional to compile them, and they are quite familiar with exam center. Therefore there is no need for you to research the JN0-481 Study Materials by yourself. Furthermore, we use international recognition third party for your payment for JN0-481 exam dumps, and your money and account safety can be guaranteed. If you find your interests haven’t been guaranteed, you can ask for the refund.
JN0-481 Test Dumps Free: https://www.dumpcollection.com/JN0-481_braindumps.html
If you are worried about your Juniper JN0-481 exam and you don't prepare it yet and you also still searching worthy study material for your JN0-481 exam preparation, During the whole year after purchasing, you will get the latest version of our JN0-481 study materials for free, Believe us because the JN0-481 test prep are the most useful and efficient, and the JN0-481 exam preparation will make you master the important information and the focus to pass the JN0-481 exam, Besides, buying our JNCIS-DC latest training means you can obtain not only the high quality JN0-481 exam torrent as well as supplementary updates.
if Profile.MigratedAlready)  Copy the anonymous profile JN0-481 values to, The analogy to computing styles is intriguing, If you are worried about yourJuniper JN0-481 Exam and you don't prepare it yet and you also still searching worthy study material for your JN0-481 exam preparation.
Juniper JN0-481 Reliable Test Preparation: Data Center, Specialist (JNCIS-DC) - Dumpcollection 100% Pass For SureDuring the whole year after purchasing, you will get the latest version of our JN0-481 study materials for free, Believe us because the JN0-481 test prep are the most useful and efficient, and the JN0-481 exam preparation will make you master the important information and the focus to pass the JN0-481 exam.
Besides, buying our JNCIS-DC latest training means you can obtain not only the high quality JN0-481 exam torrent as well as supplementary updates, At present, our company is working feverishly to meet the customers' all-round need and offering a brand new experience for our users of JN0-481 questions & answers.
Posted at 1/15/2026 21:22:49        Only Author  2#
This article is truly magnificent, thank you for sharing your knowledge. Free Best AT-510 practice resources available. Best of luck to all!
