[General] 2026 Cisco Realistic Latest 800-150 Exam Forum
90
General 2026 Cisco Realistic Latest 800-150 Exam Forum
Posted at 1/10/2026 07:19:17      View127 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that PracticeTorrent 800-150 dumps now are free: https://drive.google.com/open?id=1p5DVJpFCvQQdcKyf01wxMrm4mjWUzsHA
As long as you have a will, you still have the chance to change. Once you are determined to learn our 800-150 study materials, you will become positive and take your life seriously. Through the preparation of the 800-150 exam, you will study much practical knowledge. Of course, passing the exam and get the 800-150 certificate is just a piece of cake. With the high pass rate of our 800-150 practice braindumps as 98% to 100%, i can say that your success is guaranteed.
Cisco 800-150 Exam Syllabus Topics:
  • Networking Foundations: This section of the exam measures the skills of a Network Engineer and covers the basic building blocks of computer networking. It explains different types of networks like local area networks and wireless networks, and introduces lightweight wireless LANs. It describes the layers of communication models like the OSI model and TCP
  • IP stack, and explains how data moves across networks. It also discusses the physical cabling used in networks, such as Ethernet and fiber optics. Students will learn about network switching, IP addressing, subnetting, and routing at Layer 3. The section also introduces Ciscos campus network devices, data center switches, UCS servers, and collaboration devices, describing their roles and functions in the network.
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Ciscos software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Ciscos UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Ciscos cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
Topic 5
  • Common Service Tasks and Tools: This section of the exam measures the skills of a Technical Support Engineer and focuses on tasks commonly needed to manage Cisco devices. It explains how devices boot up, introduces common Cisco IOS commands, and identifies tools for file management. It shows how to confirm physical connections, remotely access devices, and connect to the console port. It also covers how to capture the status of a device, recover passwords, and replace devices by using proper tools. Students are also taught how to find serial numbers on Cisco equipment to assist with support and maintenance activities.
800-150 Test Torrent is Very Easy for You to Save a Lot of Time to pass Supporting Cisco Devices for Field Technicians exam - PracticeTorrentAdditionally, all operating systems also support this format. The third format is the desktop 800-150 Practice Exam software. It is ideal for users who prefer offline Supporting Cisco Devices for Field Technicians (800-150) exam practice. This format is supported by Windows computers and laptops. You can easily install this software in your system to use it anytime to prepare for the examination.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q78-Q83):NEW QUESTION # 78
Which component of the Cisco Room system requires removal of the upper textile grille and the use of release levers during its replacement process?
  • A. Antenna module
  • B. Loudspeaker
  • C. Codec
  • D. Quad camera
In Cisco Room systems such as the Room Kit Pro and similar setups, replacing thequad camerainvolves a physical disassembly process. Specifically, theupper textile grille must be removedto gain access to the internal mounting mechanism. After that,release levers are used to disengage the quad camera unitfrom its housing.
This procedure ensures secure installation while allowing relatively straightforward removal when maintenance or replacement is necessary. The codec, loudspeaker, and antenna module do not typically require this specific removal method.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Maintenance and RMA Procedures
NEW QUESTION # 79
Which component serves as the central management and communication core and provides a single point of management via Cisco UCS Manager in a Cisco UCS environment?
  • A. UCS E-Series server in ISR platforms
  • B. MDS 9000 Series SAN Switch
  • C. Nexus 9000 Series Switch
  • D. UCS Fabric Interconnect
TheUCS Fabric Interconnectis the central management and communication hub of theCisco UCS (Unified Computing System)environment. It integrates compute, network, and storage access into a unified system.
Fabric Interconnects:
* Manage all servers and I/O modules connected to the UCS domain
* Provide connectivity and are the point of integration with the Cisco UCSManager
* Offer high-availability and centralized policy management
Other options like the Nexus or MDS switches do not serve this unified management function in a UCS deployment.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) -Cisco Equipment and Related Hardware Explanation:
The UCS Fabric interconnect serves as the central management and communication core in a Cisco UCS environment, providing a single point of management via Cisco UCS Manager for the entire UCS system, including servers, networking, and storage components.
NEW QUESTION # 80
Which two results are achieved by briefly pressing the restore/reset button on a Cisco Meraki switch? (Choose two.)
  • A. The device reboots.
  • B. A full factory restore is performed.
  • C. Cloud management is disabled.
  • D. The management interface is cleared.
  • E. The downloaded configuration is deleted.
On aCisco Meraki switch, briefly pressing therestore/reset button(typically less than 5 seconds) triggers:
* A reboot of the device(Option A)
* Clearing of the local management interface settings(Option D), which may include temporary network information such as DHCP leases or local overrides.
To perform a full factory reset (Option B), the button must be held down for a longer duration, usuallymore than 10seconds. Options C and E do not reflect standard reset behavior.
NEW QUESTION # 81
Which deployment model minimizes dependence on internet connectivity for core collaboration functions?
  • A. Hosted Collaboration Solution
  • B. Cloud-based deployment
  • C. Software-as-a-Service model
  • D. On-premises deployment
Anon-premises deploymentmodel minimizes dependence on internet connectivity for core collaboration functions. In this model, all critical services, including call control, messaging, and conferencing, are hosted within the organization's local infrastructure. This ensures that internal communication services remain operational even if internet connectivity is lost.
In contrast, cloud-based deployments (Options A and C) and Hosted Collaboration Solutions (Option D) rely on internet connectivity to access services hosted externally, making them more susceptible to internet outages.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Licensing and Smart Licensing
NEW QUESTION # 82
Which mode must the console terminal of the device be in before a prewritten configuration is pasted to transfer the configuration from an old device to a new one?
  • A. Interface configuration mode
  • B. Privileged EXEC mode
  • C. Global configuration mode
  • D. User EXEC mode
To apply a prewritten configuration to a new Cisco device, the console terminal must be inGlobal Configuration Mode. This mode allows administrators to enter configuration commands that affect the device's overall operation. To access Global Configuration Mode, one must first enter Privileged EXEC Mode by typingenable, and then enterconfigure terminal. Once in Global Configuration Mode, theprewritten configuration can be pasted, and the device will accept the commands accordingly.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Device Configuration and Verification
NEW QUESTION # 83
Do you want to have a new change about your life? If your answer is yes, it is high time for you to use the 800-150 question torrent from our company. As the saying goes, opportunities for those who are prepared. If you have made up your mind to get respect and power, the first step you need to do is to get the 800-150 Certification, because the certification is a reflection of your ability. If you have the 800-150 certification, it will be easier for you to get respect and power. Our company happened to be designing the 800-150 exam question.
Reliable 800-150 Exam Review: https://www.practicetorrent.com/800-150-practice-exam-torrent.html
P.S. Free & New 800-150 dumps are available on Google Drive shared by PracticeTorrent: https://drive.google.com/open?id=1p5DVJpFCvQQdcKyf01wxMrm4mjWUzsHA
Posted at 1/23/2026 04:37:38        Only Author  2#
Thank you for sharing this inspiring article with us! Valid DA0-002 exam tips exam papers are free for everyone! Best of luck on your exams!
