[General] 2026 Fantastic 300-745: Reliable Designing Cisco Security Infrastructure Exam Qu
68
【General】 2026 Fantastic 300-745: Reliable Designing Cisco Security Infrastructure Exam Qu
Posted at 1/10/2026 07:23:43      View:147 | Replies:1        Print      Only Author   [Copy Link] 1#
It is acknowledged that there are numerous 300-745 learning questions for candidates for the 300-745 exam, however, it is impossible for you to summarize all of the key points in so many materials by yourself. But since you have clicked into this website for 300-745 practice materials you need not to worry about that at all because our company is especially here for you to solve this problem. We have a lot of regular customers for a long-term cooperation now since they have understood how useful and effective our 300-745 Actual Exam is.
It is well known that the best way to improve your competitive advantages in this modern world is to increase your soft power, such as graduation from a first-tier university, fruitful experience in a well-known international company, or even possession of some globally recognized 300-745 certifications, which can totally help you highlight your resume and get a promotion in your workplace to a large extend. If you are interested our 300-745 Guide Torrent, please contact us immediately, we would show our greatest enthusiasm to help you obtain the certification.
Valid 300-745 Exam Cost & Latest 300-745 Exam PracticeTherefore, make the most of this opportunity of getting these superb exam questions for the Cisco 300-745 certification exam. We guarantee you that our top-rated Designing Cisco Security Infrastructure practice exam (PDF, desktop practice test software, and web-based practice exam) will enable you to pass the Cisco 300-745 Certification Exam on the very first go.
Cisco Designing Cisco Security Infrastructure Sample Questions (Q40-Q45):NEW QUESTION # 40
Which two metrics are important for evaluating the performance of automated security response workflows? (Choose two.)
  • A. Mean Time to Detect (MTTD)
  • B. Mean Time to Respond (MTTR)
  • C. CPU temperature
  • D. VLAN propagation speed
MTTD measures how quickly incidents are detected, and MTTR measures how quickly they are resolved. Together, they indicate the effectiveness of automated security response workflows.
NEW QUESTION # 41
A legal services company wants to prevent remote employees from accessing personal email and social media accounts while using corporate laptops. Which security solution enforces the policy?
  • A. network monitoring tool
  • B. Cisco TrustSec
  • C. Cisco Umbrella
  • D. RADIUS server
Cisco Umbrella provides DNS-layer security and content filtering, allowing organizations to block categories such as personal email and social media. This enforces acceptable-use policies for remote employees regardless of where they connect, ensuring corporate devices comply with security requirements.
NEW QUESTION # 42
A company published software that had a security vulnerability, and an attacker used the vulnerability to steal critical information from the environment. The issue was reported by the security team, and the administrator was instructed to run shift-left security tests before publishing the software. Which component of the software development pipeline must be recommended to run the tests?
  • A. cloud security posture management
  • B. software bill of material analysis
  • C. continuous deployment
  • D. source code management
Shift-left security means running security tests earlier in the development lifecycle. By integrating tests in the source code management stage (e.g., Git repositories), vulnerabilities can be detected and fixed before software is built and deployed, reducing the risk of publishing insecure code.
NEW QUESTION # 43
A financial company uses a remote access solution that directs all traffic over a secure tunnel.
The company recently received some large ISP bills from the headcounter location. According to traffic analysis during the investigation, most of the network traffic was due to employees spending a lot of time on video conferences provided by a SaaS collaboration company. What must the company modify to reduce the cost without negatively impacting security or employee experience?
  • A. Block the video conferencing app when connected on VPN.
  • B. Split-exclude the video SaaS application from the VPN.
  • C. Reduce the video resolution size permitted within the SaaS application.
  • D. Suggest users to disconnect from the VPN when on video calls.
Split-exclusion allows trusted SaaS traffic (such as video conferencing) to bypass the VPN tunnel while keeping all other traffic secured. This reduces bandwidth costs at the headend location without degrading security or employee experience, since traffic to the SaaS provider is still encrypted natively.
NEW QUESTION # 44
A global hotel chain is using Cisco ISE and Cisco switches to manage the network. The hotel company wants to enhance network security by segmenting users and endpoints. The company must ensure that devices within the same VLAN cannot communicate with each other. The goal is to prevent cross-communication without the use of dynamic access control lists. Which action must be taken using Cisco ISE to meet the requirement?
  • A. Implement device posturing.
  • B. Set up endpoint profiling.
  • C. Configure TrustSec.
  • D. Enable identity groups.
Cisco TrustSec provides software-defined segmentation by assigning Security Group Tags (SGTs) to users and devices. This allows policy enforcement that prevents communication between devices in the same VLAN without needing dynamic ACLs. It is the correct approach to achieve secure segmentation in this scenario.
NEW QUESTION # 45
As we all know, respect and power is gained through knowledge or skill. The society will never welcome lazy people. Do not satisfy what you have owned. Challenge some fresh and meaningful things, and when you complete 300-745 Exam, you will find you have reached a broader place where you have never reach. Your life will become more meaningful because of your new change, and our 300-745 question torrents will be your first step.
Valid 300-745 Exam Cost: https://www.actualcollection.com/300-745-exam-questions.html
If you buy our 300-745 exam questions, then we will provide you with 24-hour online service for our 300-745 study tool, We adopt international recognition third party for your payment for the 300-745 exam braindumps, and the third party will protect interests of yours, therefore you don’t have to worry about the safety of your money and account, You will pass your real test at your first attempt with our Valid 300-745 Exam Cost - Designing Cisco Security Infrastructure latest prep dumps.
Just as some costs of a function may go unnoticed, so also Latest 300-745 Exam Practice may several benefits of implementing a systems management function, It cannot be neglected that service management has now become a quite integral part of organizations and Reliable 300-745 Exam Question hence many candidates are required to have the basic knowledge regarding these IT service management processes.
ActualCollection 300-745 Exam Questions are Verified by Subject Matter ExpertsIf you buy our 300-745 Exam Questions, then we will provide you with 24-hour online service for our 300-745 study tool, We adopt international recognition third party for your payment for the 300-745 exam braindumps, and the third party will protect interests of yours, therefore you don’t have to worry about the safety of your money and account.
You will pass your real test at your first attempt with our Designing Cisco Security Infrastructure 300-745 latest prep dumps, Our company has a very powerful payment system, At present you get the new version of Designing Cisco Security Infrastructure VCE available in the printable format because we know the worth of print-outs and how easy it is to learn when you log in our website on computer and download hard-copy of 300-745 real questions available.
Posted at 1/29/2026 14:08:00        Only Author  2#
Pass4TestのPython InstituteのPCEP-30-02試験トレーニング資料は現在で一番人気があるダウンロードのフォーマットを提供します。PDFとソフトのフォーマットで、ダウンロードするのは易いです。Pass4Testが提供した製品がIT専門家は実際の経験を活かして作った最も良い製品で、あなたが自分の目標を達成するようにずっと一生懸命頑張っています。
