Realistic Valid EAEP2201 Exam Vce - Exam Enterprise Administration Professional
Posted at 1/10/2026 07:34:02
View204
Replies5
P.S. Free 2026 Esri EAEP2201 dumps are available on Google Drive shared by Exam4Tests: https://drive.google.com/open?id=1A4ZKpre4WHFkMt_6rwRWVYu2WufBzlHM
The desktop-based practice exam is customizable, tracks your progress, and creates a real Enterprise Administration Professional 2201 (EAEP2201) exam environment. This software works offline on Windows computers. The web-based practice exam is similar to the desktop-based practice exam and can be taken on any browser without needing to install separate software. Moreover, the web-based Enterprise Administration Professional 2201 (EAEP2201) practice exam is also compatible with all operating systems.
Becoming Esri EAEP2201 Certified demonstrates a high level of expertise in enterprise GIS administration and can help professionals advance in their careers. It also provides a valuable credential for organizations that use Esri's enterprise GIS products, as it ensures that their GIS administrators have the necessary skills and knowledge to maintain a high-performing and secure GIS system.
Exam EAEP2201 Quiz - Online EAEP2201 TestIf you are not certain whether the EAEP2201 prep guide from our company is suitable for you or not, so you are hesitate to buy and use our study materials. Do not worry, in order to help you solve your problem and let you have a good understanding of our EAEP2201 study practice dump, the experts and professors from our company have designed the trial version for all people. You can have a try of using the EAEP2201 Prep Guide from our company before you purchase it. We believe that the trial version provided by our company will help you know about our study materials well and make the good choice for yourself. More importantly, the trial version of the EAEP2201 exam questions from our company is free for all people. We believe that the trial version will help you a lot.
The EAEP2201 exam consists of multiple-choice questions that cover a broad range of topics related to enterprise GIS administration. These topics include system architecture, security, data management, performance optimization, and user management. EAEP2201 exam is designed for experienced GIS professionals who have a deep understanding of GIS concepts and practical experience with enterprise-level GIS systems. Passing the EAEP2201 exam demonstrates a high level of competence in GIS administration, which is highly valued by employers in industries such as government, utilities, and natural resources management.
Esri EAEP2201 Exam evaluates the proficiency of candidates in multiple areas, including geodatabase management, server administration, web services and interfaces, and security management. These skills are essential for working with ArcGIS Enterprise systems, which allow organizations to efficiently store, manage, process, and share spatial data. These systems are particularly useful for enterprise-level applications, where large volumes of data from multiple sources must be integrated and analyzed.
Esri Enterprise Administration Professional 2201 Sample Questions (Q42-Q47):NEW QUESTION # 42
An organization is configuring ArcGIS Enterprise. They want to enable asingle sign-on experiencefor users using theirexisting SAML identity provider.
What action should the organization perform?
- A. Set up Lightweight Directory Access Protocol with portal-tier authentication
- B. Register the portal's service provider metadata with the identity provider
- C. Configure ArcGIS Web Adaptor to use Integrated Windows Authentication
- D. Register the identity provider as a web-tier authenticator
To enableSAML-based SSO, the ArcGIS Enterpriseportal acts as the Service Provider (SP). To link it to an Identity Provider (IdP), you mustregister the portal's SP metadatawith the IdP and configure the portal to trust it.
From Esri's documentation:
"To complete SAML configuration, register the portal's SAML service provider metadata with your organization's identity provider, then configure the portal with the IdP metadata."
* OptionAis for IWA (Kerberos), not SAML.
* OptionCrefers to LDAP but doesn't configure SAML or SSO.
* OptionDis not a valid standalone action for SAML integration.
Reference:ArcGIS Enterprise -Configuring SAML Identity Providers for Single Sign-On
NEW QUESTION # 43
A client has an internet-accessible ArcGIS Enterprise deployment with the Web Adaptors in theDMZ, and the remaining components are on aninternal networkbehind afirewall. A user on the internet must access a web map in that environment.
Which ports must be open in the firewall between the DMZ and the internal network?
- A. 80 and 443
- B. 6443 and 7443
- C. 2443 and 6443
- D. 443 and 6443
Web Adaptors in the DMZ must forward requests to internal components (Portal and Server). These internal services operate over HTTPS via ports:
* 7443 for Portal for ArcGIS
* 6443 for ArcGIS Server
Therefore, the firewall mustallow traffic over ports 6443 and 7443from the Web Adaptors (DMZ) to the respective internal services.
From ArcGIS Enterprise security documentation:
"When using Web Adaptors in the DMZ, make sure ports 6443 and 7443 are open between the Web Adaptors and the internal ArcGIS Server and Portal components respectively."
* OptionBis partially correct but leaves out Portal (7443).
* OptionCis for HTTP/HTTPS access from the public,not internal communications.
* OptionDincludes the Data Store admin port (2443), which isn't required here.
Reference:ArcGIS Enterprise -Firewalls, Ports, and DMZ Configuration
NEW QUESTION # 44
A portal administrator is trying to enable web-tier authentication (IWA) for the ArcGIS Enterprise portal using Active Directory and IIS.
Steps taken:
* Configured portal with Microsoft version of ArcGIS Web Adaptor
* Set identity store to Active Directory
* Added AD users to the portal
* Disabled anonymous access in Portal
Users are not prompted to sign in and are not automatically logged in.
What should the administrator do next?
- A. Work with the IT department to disable anonymous access to the IIS web server
- B. Refresh user membership in the Portal Administrator Directory
- C. Assign a default user type to all portal members
- D. Enable Windows Authentication in IIS
When usingIWA through the Web Adaptor (IIS), theIIS server itself must be configuredto deny anonymous access and allow Windows Authentication. Simply disabling anonymous accesswithin the Portal settingsisnot enough.
From Esri's web-tier authentication guide:
"For IWA to function as expected, anonymous access must be disabled in IIS for the ArcGIS Web Adaptor, and Windows Authentication must be enabled. If IIS still allows anonymous access, users will bypass authentication prompts."
* OptionBis irrelevant here-user types don't affect login behavior.
* OptionCis a content sync feature, not related to authentication.
* OptionD(Enable Windows Authentication) is correctonly if it hasn't already been done, but the missing step isdisabling anonymous accessin IIS.
Reference:ArcGIS Enterprise -Configuring Web-Tier Authentication with IIS
NEW QUESTION # 45
An ArcGIS Enterprise deployment is completely internal and does not have access to the internet. How should the organization find patches and updates for the deployment components?
- A. Open the Check For Updates option on the machine where ArcGIS Server is installed
- B. Refer to the Patches and Service Pack page on the Esri Support website
- C. Run the patch notification bat utility from the command line
For environments without internet access, the organization can use thepatchnotification.batutility to check for available patches and updates. This utility can be run from the command line and provides information about the current patch status of the ArcGIS Enterprise components. Administrators can then manually download the necessary patches from another machine with internet access and transfer them to the internal environment for installation.
Reference Source:ArcGIS Enterprise documentation on checking for and installing software patches and updates
NEW QUESTION # 46
An administrator needs to share content with a specific group of users. The administrator is concerned that several important applications will stop working for the users if they leave the group.
Which action should the administrator perform to prevent users from leaving the group?
- A. Create a group visible only to group members
- B. Change the role of the users
- C. Create an administrative group
NEW QUESTION # 47
Exam EAEP2201 Quiz: https://www.exam4tests.com/EAEP2201-valid-braindumps.html
- Free EAEP2201 Dumps 🍴 Valid Braindumps EAEP2201 Pdf 🐖 EAEP2201 Reliable Exam Book 📑 Open ▷ [url]www.practicevce.com ◁ and search for ➥ EAEP2201 🡄 to download exam materials for free 🚁Vce EAEP2201 Download[/url]
- EAEP2201 Reliable Exam Book 🍅 EAEP2201 New Study Materials 🥦 Vce EAEP2201 Download ⏹ Open website ➥ [url]www.pdfvce.com 🡄 and search for ✔ EAEP2201 ️✔️ for free download 🌉EAEP2201 Certification Cost[/url]
- Free PDF High-quality Esri - EAEP2201 - Valid Enterprise Administration Professional 2201 Exam Vce 🎤 Copy URL ➠ [url]www.dumpsquestion.com 🠰 open and search for [ EAEP2201 ] to download for free ❤EAEP2201 Certification Cost[/url]
- Enterprise Administration Professional 2201 Updated Training Material - EAEP2201 Study Pdf Vce - Enterprise Administration Professional 2201 Actual Exam Questions 🦙 Download ▷ EAEP2201 ◁ for free by simply entering ▶ [url]www.pdfvce.com ◀ website 🟨Valid Braindumps EAEP2201 Pdf[/url]
- Valid Braindumps EAEP2201 Pdf 😳 Reliable EAEP2201 Braindumps Free 🏮 EAEP2201 Exam Cram 🧁 Download ⇛ EAEP2201 ⇚ for free by simply entering ⇛ [url]www.examcollectionpass.com ⇚ website 🍿EAEP2201 New Study Materials[/url]
- EAEP2201 Certification Cost 🤥 Reliable EAEP2201 Braindumps Free 👬 EAEP2201 Free Updates K Search for ➽ EAEP2201 🢪 and download exam materials for free through ⮆ [url]www.pdfvce.com ⮄ ⏰EAEP2201 Paper[/url]
- Efficient Valid EAEP2201 Exam Vce - Leading Offer in Qualification Exams - Free PDF Esri Enterprise Administration Professional 2201 🍆 Search on ➥ [url]www.prepawayexam.com 🡄 for ▶ EAEP2201 ◀ to obtain exam materials for free download 🤕EAEP2201 Exam Cram[/url]
- Enterprise Administration Professional 2201 Updated Training Material - EAEP2201 Study Pdf Vce - Enterprise Administration Professional 2201 Actual Exam Questions 🏎 Enter [url]www.pdfvce.com and search for ⏩ EAEP2201 ⏪ to download for free 🦰Reliable EAEP2201 Braindumps Free[/url]
- www.verifieddumps.com EAEP2201 Test Questions Prioritize Your Study Time 📎 Immediately open ➠ [url]www.verifieddumps.com 🠰 and search for ▶ EAEP2201 ◀ to obtain a free download 🦃Exam EAEP2201 Torrent[/url]
- Valid EAEP2201 Exam Vce - Esri Realistic Valid Enterprise Administration Professional 2201 Exam Vce Pass Guaranteed Quiz 🐗 Open [url]www.pdfvce.com and search for ☀ EAEP2201 ️☀️ to download exam materials for free 👮EAEP2201 Valid Exam Labs[/url]
- EAEP2201 Valid Exam Labs 🌷 Latest EAEP2201 Learning Materials 📼 EAEP2201 Paper 😘 Download ✔ EAEP2201 ️✔️ for free by simply entering [url]www.examcollectionpass.com website 🥝Exam EAEP2201 Details[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, lekoltoupatou.com, writeablog.net, www.stes.tyc.edu.tw, github.com, www.cropmastery.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
P.S. Free & New EAEP2201 dumps are available on Google Drive shared by Exam4Tests: https://drive.google.com/open?id=1A4ZKpre4WHFkMt_6rwRWVYu2WufBzlHM
